PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar SuperTiti Hier à 21:40
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar Joe644 Hier à 18:56
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar yop1025 Hier à 13:10
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar REYNALD Mar 19 Nov 2024 - 10:58
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar REYNALD Mar 19 Nov 2024 - 10:49
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar REYNALD Mar 19 Nov 2024 - 10:46
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar REYNALD Mar 19 Nov 2024 - 10:44
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar jackal74 Lun 18 Nov 2024 - 11:58
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar Arni Dim 17 Nov 2024 - 14:06
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar Arni Dim 17 Nov 2024 - 13:13
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar yop1025 Sam 16 Nov 2024 - 23:12
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar Fredard Sam 16 Nov 2024 - 9:43
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar J-Marc Mar 12 Nov 2024 - 12:44
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar J-Marc Lun 11 Nov 2024 - 21:58
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar thierry83 Dim 10 Nov 2024 - 9:29
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar REYNALD Ven 8 Nov 2024 - 16:55
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar REYNALD Mar 29 Oct 2024 - 20:18
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar REYNALD Mar 29 Oct 2024 - 20:00
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
tuto chaine garde fourche filtre amortisseur reglage phare manuel galére rabaissement essence pneus feux longues synchro huile crash suis embrayage vidange arrière selle tenere boue réservoir
Le Deal du moment : -25%
lolo- dab
lolo- dab
Moto : XTZ750 super Ténéré
Kms de ma moto : 76000
Ville ou région : 64000 Pau
MessageSujet: PROBLEME MOTEUR SUR UN SEUIL CYLINDRE   PROBLEME MOTEUR SUR UN SEUIL CYLINDRE EmptyDim 26 Mai 2019 - 12:25
bonjour
J’ai un petite problème quand je démarre la moto à froid elle tourne que sur un cylindre une fois avoir tourné 10-15 min elle tourne sur les 2 cylindres
Le cylindres sur le quel j’ai le problème est sur le côté gauche de la moto (côte vitesse) d’où peut venir se problème à froid car à chaud elle fonctionne parfaitement.
Les 2 bougies sont neuve (je pence a un problème de carburateur ou un problème de soupape) mais avant d'attaque quoi que se soit un peut d’information ou de retour d’expérience.
inconnu
inconnu
Moto : je sais pas
Ville ou région : 44
MessageSujet: Re: PROBLEME MOTEUR SUR UN SEUIL CYLINDRE   PROBLEME MOTEUR SUR UN SEUIL CYLINDRE EmptyLun 27 Mai 2019 - 14:38
ce que tu peux essayer c'est de virer ton réservoir , tu l'as fait démarré avec nourisse et tu inject un poil d'essence dans le carbus si elle pete direct c'est que tu as un probleme , nettoyage du carbus pour commencer , si elle pete pas bas heu soupape qui serait plus etanche ... mais j'y crois pas
lolo- dab
lolo- dab
MessageSujet: Re: PROBLEME MOTEUR SUR UN SEUIL CYLINDRE   PROBLEME MOTEUR SUR UN SEUIL CYLINDRE EmptyLun 27 Mai 2019 - 16:28
Les trucs c’est quel démarre nickel vue que la batterie et les bougies sont neuves mais elle démarre sur 1 cylindre et une fois chaude plus de problème je vais teste sa se week-end ou dans la semaine car j’ai pas la moto chez moi je fait le teste je de ferais le retour
nicolas01037313
nicolas01037313
Moto : Tenere 700
Kms de ma moto : 100
Pneu AV/AR : pirelli rally STR
Ville ou région : 13
MessageSujet: Re: PROBLEME MOTEUR SUR UN SEUIL CYLINDRE   PROBLEME MOTEUR SUR UN SEUIL CYLINDRE EmptyMar 28 Mai 2019 - 19:32
Pour être certain que tu fonctionne que sur 1 cylindre, tu peux mesurer la température au niveau des collecteurs en sortie du moteur. Si tu as un écart très important, c'est effectivement probablement le cas.
Tu peux vérifier si les bougies fonctionnent bien : tu démontes et tu contrôle l'étincelle.
Si OK : Tu peux nettoyer tes carburateurs : tu as peut être un gicleur de ralenti bouché et donc pas d'arrivée d'essence sur 1 cylindre au démarrage ce qui se sent moins en roulant car le carbu passe le puits d’aiguille.
joxt1200
joxt1200
Moto : crf 1000
Kms de ma moto : 10000
MessageSujet: Re: PROBLEME MOTEUR SUR UN SEUIL CYLINDRE   PROBLEME MOTEUR SUR UN SEUIL CYLINDRE EmptyMer 29 Mai 2019 - 1:10
76000 = bobine crayon
tente
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Luba10PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Sans_t11PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Cevenn11
PROBLEME MOTEUR SUR UN SEUIL CYLINDRE Tour_i13
MessageSujet: Re: PROBLEME MOTEUR SUR UN SEUIL CYLINDRE   PROBLEME MOTEUR SUR UN SEUIL CYLINDRE EmptyMer 29 Mai 2019 - 8:09
Pas de bobine crayon sur le 750 clin d\'oeil
joxt1200
joxt1200
Moto : crf 1000
MessageSujet: Re: PROBLEME MOTEUR SUR UN SEUIL CYLINDRE   PROBLEME MOTEUR SUR UN SEUIL CYLINDRE EmptyMer 29 Mai 2019 - 8:28
oups pas fais gaffe
tente
» [RESOLU] Moteur qui tourne sur un cylindre
» problème moteur
» probleme moteur
» problème moteur
» problème moteur
