Vidange fourche XTZ 750 Emptypar SuperTiti Hier à 21:40
Vidange fourche XTZ 750 Emptypar Joe644 Hier à 18:56
Vidange fourche XTZ 750 Emptypar yop1025 Hier à 13:10
Vidange fourche XTZ 750 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Vidange fourche XTZ 750 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Vidange fourche XTZ 750 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Vidange fourche XTZ 750 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Vidange fourche XTZ 750 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Vidange fourche XTZ 750 Emptypar Arni Dim 17 Nov 2024 - 14:06
Vidange fourche XTZ 750 Emptypar Arni Dim 17 Nov 2024 - 13:13
Vidange fourche XTZ 750 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Vidange fourche XTZ 750 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Vidange fourche XTZ 750 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Vidange fourche XTZ 750 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Vidange fourche XTZ 750 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Vidange fourche XTZ 750 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Vidange fourche XTZ 750 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Vidange fourche XTZ 750 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Vidange fourche XTZ 750 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Vidange fourche XTZ 750 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Vidange fourche XTZ 750 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Vidange fourche XTZ 750 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Vidange fourche XTZ 750 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Vidange fourche XTZ 750 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Vidange fourche XTZ 750 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
amortisseur tenere réservoir manuel crash arrière feux rabaissement vidange longues galére tuto phare garde essence selle chaine pneus reglage suis synchro filtre huile boue fourche embrayage
Le Deal du moment : -29%
269.99 €
Galor SuperTenere
Galor SuperTenere
Moto : Yamaha XTZ 750
Kms de ma moto : 70 000
MessageSujet: Vidange fourche XTZ 750   Vidange fourche XTZ 750 EmptyJeu 2 Avr 2015 - 16:09
Bonjour à tous  hello
voilà, je vais prochainement faire ma première vidange de fourche moto, sur ma XTZ 750 en l'occurrence puisqu'elle commence à plonger trop facilement à mon goût avec le temps.
L'opération est des plus simple d'après ce que j'en est lu et je n'ai pas de souci avec ça.
Une fois les fourreaux de fourche dégagés de la moto, ma crainte est la suivante : il faut exercer une pression sur l'écrou supérieur des fourreaux de fourche lorsqu'ils seront en fin de filet pour comprimer le ressort, mais je me demande si cette force doit être vraiment importante ou pas ?
Sur une vidéo Youtube, une personne l'a fait et ça lui a sauté "au visage", il s'est coupé un peu la main avec le cylindre qui saute, mais il a pleins de rondelles avec le ressort. Je me demande si d'origine il y en a autant et si ça pourrait expliquer le fait qu'il n'ait pas réussi à retenir l'ensemble d'après-vous ?
Vidéo ici vers 3:45 : https://youtu.be/bWzdnyOa6o8?t=3m44s
Je n'ai juste pas envie de me blesser pour ça.
Et deuxième question, la RTM me dit d'utiliser une huile moteur SAE 10 W. Genre si j'ai de l'huile 10W40 (celle pour le moteur de la moto) je peux l'utiliser ?
Ou bien je prends quand même de la 10W spéciale pour fourche à environ 15€/L ? http://www.norauto.fr/produit/huile-de-fourche-bardahl-10w-1l_468990.html
La RTM m'indique 669cm3 dans chaque tube.
Merci d'avance pour vos réponses  Smile
michel24
michel24
Kms de ma moto : 98000
MessageSujet: Re: Vidange fourche XTZ 750   Vidange fourche XTZ 750 EmptyJeu 2 Avr 2015 - 17:14
salut regarde un peu ici tu devrais trouver ce qui t'interesse
https://www.super-tenere.org/t9244-niveau-huile-de-fourche?highlight=vidange+de+fourche
et encore un
http://www.dl650.org/photos/pbsoluces/Ludo51/tuto-fourche/index.html
dambzh
dambzh
Moto : 1200 ZRX 2004
Kms de ma moto : 45000
MessageSujet: Re: Vidange fourche XTZ 750   Vidange fourche XTZ 750 EmptyJeu 2 Avr 2015 - 22:06
C'est un goret ce mec, il cale sa moto avec un simple bout de bois qui se dérobe et il se prend le bouchon dans la gueule car il a toutes c'est rondelles entre le ressort et la cale  Vidange fourche XTZ 750 261789
il faut absolument de huile  de fourche , tu peux mettre de la 15, pense a desserrer légèrement le bouchon de fourche avant de démonter les tubes.
au lieu de rincer avec du White ou autre, je préfère utiliser un peu d'huile de fourche.
il faut mieux mesurer la distance entre l'huile et le haut du tube plutôt que de mettre 669cm3.
Vidange fourche XTZ 750 Carte_postale_3
Galor SuperTenere
Galor SuperTenere
MessageSujet: Re: Vidange fourche XTZ 750   Vidange fourche XTZ 750 EmptyVen 3 Avr 2015 - 13:50
Merci pour l'huile  clin d\'oeil
Et donc pour les cales sur la vidéo, ce n'est pas d'origine on est d'accord ?
Si la mienne n'a pas été trafiquée (ce dont je doute fortement) ça ne devrait pas être aussi raide quand j'ouvrirais, pas de risque que ça me saute au visage ?
MessageSujet: Re: Vidange fourche XTZ 750   Vidange fourche XTZ 750 EmptyVen 3 Avr 2015 - 16:07
fais comme dans la RTM, et n'oublies pas de vérifier en mesurant!
si tu as les ressorts d'origine, impossible que çà te saute à la gueule!
si il y a des progressifs, tu vas sentir une résistance lorsque tu vas commencais à dévisser les bouchons...vas alors progressivement en appuyant sur la clé avec ton autre main ( ouverte pour retenir doucement)
si il y as une cale qui précontraint tes ressorts, pareil que pour les ressorts progressifs!
si tu as une fourche qui plonge pas mal au freinage, et qui est très souple mets du 15W, çà freine la plongée de la fourche sans la durcir de trop!
utilise de l'huile de fourche, même si tu la paye plus cher, çà dure longtemps!
si tu fais souvent des vidanges de fourche, tu peux mettre de l'huile moteur, certains font comme cela et semblent ne pas s'en plaindre!
Vidange fourche XTZ 750 Barre_10
Galor SuperTenere
Galor SuperTenere
MessageSujet: Re: Vidange fourche XTZ 750   Vidange fourche XTZ 750 EmptyVen 3 Avr 2015 - 19:12
Super, merci pour ces précisions !! bien
Pour l'huile j'hésite avec la 15W effectivement, à près de 50 000 bornes les ressorts n'ont peut être plus leur forme d'antan, donc c'est peut être pas plus mal de monter en viscosité pour compenser un peu, et puis je fais 90% de route avec.
Galor SuperTenere
Galor SuperTenere
MessageSujet: Re: Vidange fourche XTZ 750   Vidange fourche XTZ 750 EmptyLun 20 Avr 2015 - 19:28
Hello Smile
Besoin d'une confirmation s'il vous plaît : j'ai démonté et vidé la fourche (elle va rester toute la nuit à l'envers) et j'avais positionné mes ressorts tels qu'ils sont sortis des tubes, mais quelqu'un a tapé dedans et je ne sais plus dans quel sens il doit être.
Le truc c'est que visuellement, toutes les spires ont strictement le même espacement et c'est aussi le même diamètre partout...
Donc pour moi, les ressorts (je suppose d'origine) de la XTZ 750 n'ont pas de sens de montage, vous confirmez ?
La RTM n'en fait pas mention.
Galor SuperTenere
Galor SuperTenere
MessageSujet: Re: Vidange fourche XTZ 750   Vidange fourche XTZ 750 EmptyLun 20 Avr 2015 - 21:59
J'ai ma réponse ici, il n'y a pas de sens pour les ressorts d'origine sur cette XTZ750 ;)
https://www.super-tenere.org/t6657p20-changer-les-joints-spy-de-fourche?highlight=fourche
» FOURCHE ET VIDANGE
» Vidange fourche XTZ 1200
» Vidange fourche Xtz 600 3aj
» Tuto vidange de fourche
