Montage joint spi XT660R ou XT660Z  Emptypar SuperTiti Hier à 21:40
Montage joint spi XT660R ou XT660Z  Emptypar Joe644 Hier à 18:56
Montage joint spi XT660R ou XT660Z  Emptypar yop1025 Hier à 13:10
Montage joint spi XT660R ou XT660Z  Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Montage joint spi XT660R ou XT660Z  Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Montage joint spi XT660R ou XT660Z  Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Montage joint spi XT660R ou XT660Z  Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Montage joint spi XT660R ou XT660Z  Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Montage joint spi XT660R ou XT660Z  Emptypar Arni Dim 17 Nov 2024 - 14:06
Montage joint spi XT660R ou XT660Z  Emptypar Arni Dim 17 Nov 2024 - 13:13
Montage joint spi XT660R ou XT660Z  Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Montage joint spi XT660R ou XT660Z  Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Montage joint spi XT660R ou XT660Z  Emptypar Fredard Sam 16 Nov 2024 - 9:43
Montage joint spi XT660R ou XT660Z  Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Montage joint spi XT660R ou XT660Z  Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Montage joint spi XT660R ou XT660Z  Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Montage joint spi XT660R ou XT660Z  Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Montage joint spi XT660R ou XT660Z  Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Montage joint spi XT660R ou XT660Z  Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Montage joint spi XT660R ou XT660Z  Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Montage joint spi XT660R ou XT660Z  Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Montage joint spi XT660R ou XT660Z  Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Montage joint spi XT660R ou XT660Z  Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Montage joint spi XT660R ou XT660Z  Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Montage joint spi XT660R ou XT660Z  Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
galére longues vidange essence boue amortisseur suis phare embrayage tuto selle chaine manuel fourche feux garde reglage tenere synchro filtre pneus huile rabaissement réservoir crash arrière
Le Deal du moment : -25%
749.99 €
luminfo
luminfo
Moto : XTZ 660
Kms de ma moto : 18000
Pneu AV/AR : TKC80 /MITAS C02 E09
Ville ou région : Nord
MessageSujet: Montage joint spi XT660R ou XT660Z    Montage joint spi XT660R ou XT660Z  EmptyDim 18 Jan 2015 - 23:05
Le principal problème pour changer le joint spi sur la fourche du 660 c'est d'arriver à séparer les 2 tubes.
D'après la revue technique il faut utiliser un outil de maintien de la pipe d'amortisseur.
Après avoir essayer de faire cet outil je ne pense pas que cela soit la bonne solution car la pipe est ronde et ne dispose d'aucune accroche pour la bloquer.
J'ai réussi à la débloquer avec une clef à choc.
Une autre solution possible est décrite ici : elle consiste à remplir la fourche d'huile après a prévoir enlever le ressort puis la mettre sous pression avec un cric de voiture :
http://www.xt660.com/showthread.php?t=21627
Quelques photos de la séparation de la fourche en 2 ...
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  20150111" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  20150112" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  20150113" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  I8kioq10" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  20150114" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  20150115" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  Dimens10" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  Cmsqid10" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  20150116" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  20150117" />
Montage joint spi XT660R ou XT660Z  <a href=Montage joint spi XT660R ou XT660Z  20150118" />
http://azimut.enduro.over-blog.fr/2014/05/les-pyrenees-mai-2014.
J-Marc
J-Marc
Ville ou région : Isère
MessageSujet: Re: Montage joint spi XT660R ou XT660Z    Montage joint spi XT660R ou XT660Z  EmptyMer 21 Jan 2015 - 17:01
Salut!
Pour désolidariser les 2 tubes et dévisser la vis exacave j'ai utilisé une sangle à cliquet pour comprimer le ressort et ça permet de dévisser cette fameuse vis, ça marche bien aussi, faut juste se gaffer à ce que la sangle tienne bien parce que si ça se barre et que tu te prends l'amortisseur dans la tronche y a moyen de perdre tous tes chicots!!
Jean-Marc.
Montage joint spi XT660R ou XT660Z  Wallpa11
https://www.2bernard.fr/
http://www.2bernard.fr
etinag
etinag
Pneu AV/AR : Cramponnés
MessageSujet: Re: Montage joint spi XT660R ou XT660Z    Montage joint spi XT660R ou XT660Z  EmptyMer 21 Jan 2015 - 18:39
Le coup du cric de bagnole ça m'a bien fait rire  bien
» Montage amortisseur réglable YSS XTX/XTR sur XT660Z
» Joint spy fourche
» VENDS KIT MONTAGE VALISES ORIGINE XT660Z TENERE
» 2015 XTZ660Z/XT660R/XT660X Campagne de Rappel
» Bouchon vidange
