pb platine support top case Emptypar Cyrille35 Aujourd'hui à 15:44
pb platine support top case Emptypar oustad Hier à 20:14
pb platine support top case Emptypar SuperTiti Hier à 13:04
pb platine support top case Emptypar oeuf Hier à 10:11
pb platine support top case Emptypar oeuf Hier à 10:03
pb platine support top case Emptypar Joe644 Mer 20 Nov 2024 - 18:56
pb platine support top case Emptypar yop1025 Mer 20 Nov 2024 - 13:10
pb platine support top case Emptypar REYNALD Mar 19 Nov 2024 - 10:58
pb platine support top case Emptypar REYNALD Mar 19 Nov 2024 - 10:49
pb platine support top case Emptypar REYNALD Mar 19 Nov 2024 - 10:46
pb platine support top case Emptypar REYNALD Mar 19 Nov 2024 - 10:44
pb platine support top case Emptypar jackal74 Lun 18 Nov 2024 - 11:58
pb platine support top case Emptypar Arni Dim 17 Nov 2024 - 14:06
pb platine support top case Emptypar Arni Dim 17 Nov 2024 - 13:13
pb platine support top case Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
pb platine support top case Emptypar yop1025 Sam 16 Nov 2024 - 23:12
pb platine support top case Emptypar Fredard Sam 16 Nov 2024 - 9:43
pb platine support top case Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
pb platine support top case Emptypar J-Marc Mar 12 Nov 2024 - 12:44
pb platine support top case Emptypar J-Marc Lun 11 Nov 2024 - 21:58
pb platine support top case Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
pb platine support top case Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
pb platine support top case Emptypar thierry83 Dim 10 Nov 2024 - 9:29
pb platine support top case Emptypar REYNALD Ven 8 Nov 2024 - 16:55
pb platine support top case Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
longues huile essence garde galére pneus reglage réservoir vidange synchro embrayage selle boue fourche amortisseur tuto arrière crash suis chaine tenere filtre phare rabaissement feux manuel
29.99 €
franckflo
franckflo
Moto : XTZ1200
Kms de ma moto : 65000
Ville ou région : Talence près de Bordeaux
MessageSujet: pb platine support top case   pb platine support top case EmptyMer 2 Mai 2012 - 19:53
Bonsoir à tous,
voici mon problème, lors de l'achat de mon 1200 XT j'ai commandé les valises GIVI et le topcase Shad. Donc moto livrée avec la bagagerie et montée par Yam.
Six mois après, je constate que la platine Yam, sur laquelle est fixée le support Shad + le top case est fêlée.
Je retourne chez mon cons qui me dit pas de problème la garantie fonctionne. il me change après avoir vérifié que mon 1200 XT ne faisait pas partie des premières séries où le problème avait été décelé.
Cela fait 2 mois que j'ai la nouvelle platine et on recommence, fêlée au même endroit.
Petite précision, jusqu'à maintenant la charge n'a pas dépassée le poids d'un ordi portable (3 kg max).
Je téléphone à mon cons qui me dit que ce n'est pas garanti car topcase Shad et pas Yam. Il prend donc à sa charge le prix de la première platine.
Est-ce que ce genre de désagrément est arrivé à l'un d'entre vous? Les fissures se trouvent sur la partie qui se trouve juste derrière la selle. (Pas facile à voir).
savez vous s'il existe des platines non Yam et solides
merci pour votre aide
FranckFlo
teneriste un jour
yudansha
yudansha
Moto : xtz 1200 blanche de 2011
Kms de ma moto : 20 000
Pneu AV/AR : michelin annakee 3 et annakee 2
Ville ou région : pas de calais/boulogne sur mer
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyMer 2 Mai 2012 - 20:01
j'ai eu le même problème, j'ai réglé le problème avec une tôle galva (platine de boite à lettre trouver à leroi merlin, je vais faire des photos et je les mettrai sur le fofo demain, la platine yam est en plastique avec les vibrations elle se fend, j'avais essyer de réparer mais ça n'avais pas tenu, il faut bricoler un peu perçage, découpage, meulage, environ 1 heure de travail
à plus
la nuit je mens
je prends des trains à travers la plaine
la nuit je mens je m'en lave les mains
Jean Fauque/Alain Bashung
rick&joe
rick&joe
Kms de ma moto : 53000
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyMer 2 Mai 2012 - 20:05
j'ai demonte la platine grise yam et j'ai fixe la platine givi directement sur le support noir sous la platine d'origine pas de probleme
vieux motard que jamais
franckflo
franckflo
Moto : XTZ1200
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyMer 2 Mai 2012 - 20:52
Yudansha,
j'attends tes photos avec impatience.
Rick&joe,
tu parles de platine Givi, ce n'est pas Shad. Sur le site de Givi, il semble qu'il n'y ait pas besoin de la platine Yam.
merci à tous les deux
FranckFlo
teneriste un jour
yudansha
yudansha
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyJeu 3 Mai 2012 - 18:32
desolé je ne suis pas rentré ce midi, promis demain je les mets sur le fofo,
pb platine support top case 504810 j'ai un shad,
la nuit je mens
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyJeu 3 Mai 2012 - 19:06
utilisez la fonction "Rechercher" ce sujet à déjà été largement traité .... allez voir par ici
pb platine support top case Barre_10
pb platine support top case Luba10
franckflo
franckflo
Moto : XTZ1200
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyJeu 3 Mai 2012 - 20:47
bonsoir,
J'ai bien cherché mais dans le répertoire bagagerie uniquement!!!
dans le topic pour l'avoir parcouru rapidement il s'agit des premières moto avec la platine qui présentait un défaut. Ce qui n'est pas mon cas, Yam a vérifié le n° de série.
en tous cas merci à ceux qui ont pris le temps de me répondre
FranckFlo
teneriste un jour
yudansha
yudansha
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyVen 4 Mai 2012 - 18:02
pb platine support top case Dscn0911
pb platine support top case Dscn0912
pb platine support top case Dscn0913
pb platine support top case Dscn0914
comme promis je te mets les photos de la platine que j'ai confectionnée,
je vais être absent du forum pendant une semaine, départ demain pour l'irlande penserais à vous, ferez un cr en rentrant salut à tous
la nuit je mens
yudansha
yudansha
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyVen 4 Mai 2012 - 18:04
j'ai oublié j'ai encore la platine à peindre, faut que je trouve de la peinture qui tienne sur le galva
à bientôt
la nuit je mens
franckflo
franckflo
Moto : XTZ1200
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyVen 4 Mai 2012 - 22:42
Merci pour les photos Yudansha, je te souhaite un bon séjour en Irlande en espérant que la météo soit avec toi.
FranckFlo
teneriste un jour
yudansha
yudansha
MessageSujet: Re: pb platine support top case   pb platine support top case EmptySam 5 Mai 2012 - 10:08
de rien on part dans 3 heure avec 450 kms sous la pluie pb platine support top case 97700 (boulogne sur mer/cherbourg), en irlande ça devrait aller pour la semaine pb platine support top case 27894
a plus
la nuit je mens
yudansha
yudansha
MessageSujet: Re: pb platine support top case   pb platine support top case EmptySam 12 Mai 2012 - 15:49
bonjour
retour d'irlande , le temps a été correct dans l'ensemble, en ce qui concerne la platine maison elle a tenue sans problème les 2000 kms chargée et avec madame qui s'est adossée sur le top case, rien n'a bougé, je ferai un crdu voyage avec photos la semaine prochaine
à plus pb platine support top case 230111
la nuit je mens
patkite
patkite
Moto : 1200xtz, 280climber,125 cb
Ville ou région : clermont ferrand
MessageSujet: Re: pb platine support top case   pb platine support top case EmptyVen 18 Mai 2012 - 8:13
bjr,
eu le même soucis avec cette satanée platine en plastique , à 145€ donc je l'ai remplacée par une "faite maison" en alu de 4mm et découpée a la même forme .par contre il y avait un autre souci d'origne sur la platine infériéure (noire ) et yam clermont m'a fait profiter d'un retour de piéce défectueuse, avant même que celle ci me joue des tours ! !
depuis plus de soucis, même avec top case bien chargé ! ! !
à+
» donne top case+platine
» Danger XTZ 1200 Support Topcase casse ! Ne pas utiliser
» support top case
» Support de top case... encore !
» support pour top case
