Claquement transmission Emptypar SuperTiti Hier à 21:40
Claquement transmission Emptypar Joe644 Hier à 18:56
Claquement transmission Emptypar yop1025 Hier à 13:10
Claquement transmission Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Claquement transmission Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Claquement transmission Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Claquement transmission Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Claquement transmission Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Claquement transmission Emptypar Arni Dim 17 Nov 2024 - 14:06
Claquement transmission Emptypar Arni Dim 17 Nov 2024 - 13:13
Claquement transmission Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Claquement transmission Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Claquement transmission Emptypar Fredard Sam 16 Nov 2024 - 9:43
Claquement transmission Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Claquement transmission Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Claquement transmission Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Claquement transmission Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Claquement transmission Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Claquement transmission Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Claquement transmission Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Claquement transmission Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Claquement transmission Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Claquement transmission Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Claquement transmission Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Claquement transmission Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
suis galére feux fourche synchro huile amortisseur arrière filtre selle reglage chaine vidange rabaissement longues boue essence phare embrayage réservoir manuel tuto garde crash pneus tenere
35 €
fcalcav
fcalcav
Kms de ma moto : 36000
Ville ou région : thonon les bains
MessageSujet: Claquement transmission   Claquement transmission EmptyLun 19 Aoû 2024 - 21:44
Bonjour
Je restaure un xtz 750 de 1996 : carbu,freins,disque embryage,carroserie....mais rien dans le moteur
Le compteur annonce 35000 km mais aucune garantie....et il pousse fort apres refexion carbu
Et je rencontre un bruit de boite a la relance du genre tac - tac - tac...mais irregulier en frequence et intensité..surtout sur les 3 premiers rapports en dessous de 3500 tr.... Ca ne le fait pas haut regime a plus de 3800...Rien quand je relache les gaz. Rien au point mort.on dirait des coup de marteau
Avec la mains sur le carter pignon je peut sentir des chocs synchroniser avec le bruit
Les disques d embrayage sont neufs. Le pignon de boite est bien serré. RAS sur le kit chaine
Au debut cela ne le faisait pas et maintenant ca le fait de plus en plus..
j'ose plus rouler car j'ai peur de tout casser.
Comment savoir d ou cela peut provenir ?
Merci pour votre aideClaquement transmission 20240713
Borgil
Borgil
Kms de ma moto : 89000
Ville ou région : Grenoble
MessageSujet: Re: Claquement transmission   Claquement transmission EmptyMar 20 Aoû 2024 - 9:23
As-tu regardé la cloche d'embrayage quand tu as changé les disques ? Car très souvent (pour ne pas dire tout le temps), les cloches d'origine de XTZ-750 finissent par lacher.
Perso ça m'a coûté un moteur (un ressort s'est barré, s'est mis dans une bielle, a éclaté coussinet + bielle + piston + cylindre...).
Et comme ça ne coûte pas grand chose à vérifier (un joint de carter et 10min de démontage), je te conseil de regarder rapidement. Il y a plein de topics sur le sujet dans le forum, je te laisse regarder
fcalcav
fcalcav
MessageSujet: Re: Claquement transmission   Claquement transmission EmptyMar 20 Aoû 2024 - 13:10
Bonjour.
Non je n ai pas encore regardé car les symptomes ne sont identiques a ce que je peux lire sur le forum..mais je vais le faire pas acquis de conscienc.
fcalcav
fcalcav
MessageSujet: Re: Claquement transmission   Claquement transmission EmptyMar 20 Aoû 2024 - 21:23
Bonjour
je viens de constater que je n'avais de roulette guide chiane comme les autre. Je n'ai memepas d'axe pour cette roulette. Cela peut expliquer le Probleme ?
Borgil
Borgil
MessageSujet: Re: Claquement transmission   Claquement transmission EmptyMer 21 Aoû 2024 - 9:43
Avec des photos ça serait surement plus clair
fcalcav
fcalcav
MessageSujet: Re: Claquement transmission   Claquement transmission EmptyMer 21 Aoû 2024 - 21:08
Mauvaise nouvelle : Apres test avec les roulettes supérieure et inférieure, ca cogne toujours pareil au bout de 1 ou 2 km des que l'huile commence a chauffer. Rien, a froid ou au dessus de 4000tr/ mn, ni en décélération. rien au point mort
Aucun jeu dans l'axe du pignon. Ca cogne en régulier dans les ronds points et plutot irregulier en ligne droite....
un avis ?
La depose moteur semble incontournable...mais peut on ouvrir la boite sans demonter tout le
moteur ?
Ramier08
Moto : XTZ 750 de 1992
Ville ou région : Ardennes
MessageSujet: Re: Claquement transmission   Claquement transmission EmptyJeu 22 Aoû 2024 - 6:51
J'ai le même symptôme, mais c'est uniquement la maille rapide de la chaine (plus épaisse)qui "tape" aléatoirement. Claquement s plus prononcés à bas/ moyen régime. Plus perceptible lorsque la chaîne est légèrement détendue. ... Je prévois de mettre une maille à sertir...
Ça peut être une piste
fcalcav
fcalcav
MessageSujet: Re: Claquement transmission   Claquement transmission EmptyJeu 22 Aoû 2024 - 7:26
Merci je n ai pas d attache rapide.
» Transmission par courroie ???
» Claquement moteur xtz
» Bruit transmission xt1200ze
» claquement moteur
» Claquement
