CLIGNOTANTS A LED 1200 XTZ Emptypar SuperTiti Hier à 21:40
CLIGNOTANTS A LED 1200 XTZ Emptypar Joe644 Hier à 18:56
CLIGNOTANTS A LED 1200 XTZ Emptypar yop1025 Hier à 13:10
CLIGNOTANTS A LED 1200 XTZ Emptypar REYNALD Mar 19 Nov 2024 - 10:58
CLIGNOTANTS A LED 1200 XTZ Emptypar REYNALD Mar 19 Nov 2024 - 10:49
CLIGNOTANTS A LED 1200 XTZ Emptypar REYNALD Mar 19 Nov 2024 - 10:46
CLIGNOTANTS A LED 1200 XTZ Emptypar REYNALD Mar 19 Nov 2024 - 10:44
CLIGNOTANTS A LED 1200 XTZ Emptypar jackal74 Lun 18 Nov 2024 - 11:58
CLIGNOTANTS A LED 1200 XTZ Emptypar Arni Dim 17 Nov 2024 - 14:06
CLIGNOTANTS A LED 1200 XTZ Emptypar Arni Dim 17 Nov 2024 - 13:13
CLIGNOTANTS A LED 1200 XTZ Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
CLIGNOTANTS A LED 1200 XTZ Emptypar yop1025 Sam 16 Nov 2024 - 23:12
CLIGNOTANTS A LED 1200 XTZ Emptypar Fredard Sam 16 Nov 2024 - 9:43
CLIGNOTANTS A LED 1200 XTZ Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
CLIGNOTANTS A LED 1200 XTZ Emptypar J-Marc Mar 12 Nov 2024 - 12:44
CLIGNOTANTS A LED 1200 XTZ Emptypar J-Marc Lun 11 Nov 2024 - 21:58
CLIGNOTANTS A LED 1200 XTZ Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
CLIGNOTANTS A LED 1200 XTZ Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
CLIGNOTANTS A LED 1200 XTZ Emptypar thierry83 Dim 10 Nov 2024 - 9:29
CLIGNOTANTS A LED 1200 XTZ Emptypar REYNALD Ven 8 Nov 2024 - 16:55
CLIGNOTANTS A LED 1200 XTZ Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
CLIGNOTANTS A LED 1200 XTZ Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
CLIGNOTANTS A LED 1200 XTZ Emptypar REYNALD Mar 29 Oct 2024 - 20:18
CLIGNOTANTS A LED 1200 XTZ Emptypar REYNALD Mar 29 Oct 2024 - 20:00
CLIGNOTANTS A LED 1200 XTZ Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
manuel filtre rabaissement feux essence amortisseur reglage garde selle embrayage synchro huile réservoir crash longues phare tuto boue galére vidange chaine suis pneus tenere arrière fourche
Le Deal du moment : -36%
254.99 €
MessageSujet: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyJeu 26 Jan 2012 - 15:47
Quelqu'un peut il me dire si le changement des clignos par des clignos à LED nécessite aussi une adaptation du relais de commande électrique ou autre, comme semble vouloir le dire Touratech (ajout d'une résistance) .
Ou alors rien de spécial à prévoir type "plug and play" ?
clin d\'oeil
svenleterrible
svenleterrible
Ville ou région : metz
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyJeu 26 Jan 2012 - 17:53
je suis ton sujet mais je crois qu'il y a deja un sujet sur le forum, tu as cherché ?
CLIGNOTANTS A LED 1200 XTZ 687864 sven "la grenouille"
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyLun 12 Mar 2012 - 18:15
cherché ?
ben, pas trouver Very Happy
j'ai des clignotants a leds et il reste en feux fixe alors que moi je voudrais:
CLIGNOTANTS A LED 1200 XTZ 807114sa marche,sa marche plus, sa marche etc.etcCLIGNOTANTS A LED 1200 XTZ 64297
faut il une centrale ,je pensais avoir lu un fofo là dessus,maisCLIGNOTANTS A LED 1200 XTZ 377927
http://shop.ebay.fr/i.html?_nkw=centrale%20clignotants%20leds&_dmd=1&clk_rvr_id=323018611039&keyword=centrale+clignotants+leds&geo_id=81&crlp=7783402493_221&MT_ID=57&tt_encode=raw
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyLun 12 Mar 2012 - 19:17
En fait l'astuce c'est ça :
GOLDDRIVER a écrit:
Mon cons. a reçu ce jour une note de service Yamaha
concernant le montage des clignos LED. De fait, il ne faut connecter
qu'une résistance par côté.
Je viens de les monter et c'est nickel. CLIGNOTANTS A LED 1200 XTZ 367158
Le fil de discussion est ici :
https://www.super-tenere.org/t343-bon-a-savoir-pour-les-clignotants-de-la-xtz1200
CLIGNOTANTS A LED 1200 XTZ 379565
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyLun 12 Mar 2012 - 19:27
voui ,mais c'est pour 1200, je sais pas si pour les 750 c'est idem:scratch:
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyLun 12 Mar 2012 - 19:38
CLIGNOTANTS A LED 1200 XTZ 413816
Ben là je ne sais Tabar....
Faudrait essayer la même méthode... qui sait ça pourrait marcher...
legrandyan
legrandyan
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyLun 12 Mar 2012 - 20:07
oui il faut une centrale cligno adaptée, par contre je sais pas si sur les 1200 y'a warning ou pas..... pis savoir déjà combien de bornes, sur la 750 c'est une 2 bornes sur la 1200 "I don't no" CLIGNOTANTS A LED 1200 XTZ 413816
avis d'air zen
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyLun 12 Mar 2012 - 20:17
descriptions
*100% 25 marque nouvelle
*La couleur comme montré dans l'image
*Fixer pas de clignoter, Stop ampoules souffler, moins de chaleur, avec un cliquetis
*Branchez n Play / Facile à installer (remplacer le relais d'usine)
*12V (Tension de fonctionnement: 11V - 15V)
*Commutateur Courant 0.02A - 20A (20A max actuelle)
*3 broches
*Position de broches: broche positive (+)à gauche et broche négatif (-) à droit
(S'il vous plaît regarder mes autres listes pour le relais de côté contraire)
*Détail de taille comme représenté sur la l'image
*Fit pour la plupart des véhicules
*paquet contient: 1 PCS
si, je comprend l'explication, il en faut deux?scratch
legrandyan
legrandyan
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyLun 12 Mar 2012 - 20:34
bé non mon z'ami, une seule suffit CLIGNOTANTS A LED 1200 XTZ 413816
avis d'air zen
svenleterrible
svenleterrible
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 18:51
pour la 1200 c une centrale par coté (gauche et droite) et non 4 centrale car ds ce cas ca ne marche pas
legrandyan
legrandyan
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 19:02
c'est bien la première fois que j'entends ça... CLIGNOTANTS A LED 1200 XTZ 198135
t'es sur de ta source ?
avis d'air zen
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 19:25
oui, sur.... une centrale par coté trois broches..+&-..et sortie clignotant.CLIGNOTANTS A LED 1200 XTZ 704842
si tu trouve une quatre broches yam tu m'en parle.. Very Happy
legrandyan
legrandyan
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 19:31
c'est zarrebi, y'a les feux de détresse sur le bouzin ? CLIGNOTANTS A LED 1200 XTZ 242583
avis d'air zen
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 19:46
nan,un clicli a gauche,et un clicli a droite..CLIGNOTANTS A LED 1200 XTZ 49290
c'est pour l'instant, la seule information que j'ai ...CLIGNOTANTS A LED 1200 XTZ 377927
mais, pour mon problème a moi, je pense avoir mis le doigt dessus..
après démontage de mes nouveaux clignotants, c'est des ampoules de 6w et pas des leds..
les ampoules d'origines 22 w ;Une résistance de 22w et obligatoire pour le
déclenchement de ma centrale...
je pense, car, pas encore reçue mes résistances..pale
demain ,je voulais essayer de mettre en série, une ampoule de 22w avant les clignotants . CLIGNOTANTS A LED 1200 XTZ 242583
legrandyan
legrandyan
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 20:00
c'est ce que j'avais fait mon ami, mes mini cligno en 12 V 6 W mais il a fallu que je change la centrale, ç'a m'a couté 5 euros CLIGNOTANTS A LED 1200 XTZ 46975
CLIGNOTANTS A LED 1200 XTZ 100_2914
avis d'air zen
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 20:06
5 euros????? et ou!CLIGNOTANTS A LED 1200 XTZ 49290 par terre Very Happy
legrandyan
legrandyan
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 21:14
bin sur VPC ou equip'moto j'sais plus...et pas tombé du camion, avé une vraie facture ;-)
tiens regarde là , la 3 eme 5 euros mon z'ami
http://www.vpcbike.com/catalog/centrale-clignotants-c-25_33_1549.html
avis d'air zen
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 21:21
ah,voui merciCLIGNOTANTS A LED 1200 XTZ 2120 .....avais pas vueCLIGNOTANTS A LED 1200 XTZ 64297
donc mes résistances.....dans le ful CLIGNOTANTS A LED 1200 XTZ 198135
legrandyan
legrandyan
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 13 Mar 2012 - 22:01
bien vaut mieux qu'il y ai de la "résistance" à cet endroit là CLIGNOTANTS A LED 1200 XTZ 548622
avis d'air zen
MessageSujet: Re: CLIGNOTANTS A LED 1200 XTZ   CLIGNOTANTS A LED 1200 XTZ EmptyMar 27 Mar 2012 - 10:37
ANNONCE :
Nouveau Sondage pour commande à "prix forum" :
- Spots LED LP 20W 1800Lm (Longue portée)
- Spots LED Anti-fog 20W 1800Lm (Anti-brouillard)
- Dimmer (Atténuateur Plein phares/ Feux de croisement)
Inscription ici.
CLIGNOTANTS A LED 1200 XTZ Rassos10
» clignotants
» Relocalisation de la plaque d'immat'
» clignotants à LED
» clignotants LED
» SOS clignotants
