Fuite essence - Page 2 Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
Fuite essence - Page 2 Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Fuite essence - Page 2 Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Fuite essence - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Fuite essence - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Fuite essence - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Fuite essence - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Fuite essence - Page 2 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Fuite essence - Page 2 Emptypar Arni Dim 17 Nov 2024 - 14:06
Fuite essence - Page 2 Emptypar Arni Dim 17 Nov 2024 - 13:13
Fuite essence - Page 2 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Fuite essence - Page 2 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Fuite essence - Page 2 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Fuite essence - Page 2 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Fuite essence - Page 2 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Fuite essence - Page 2 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Fuite essence - Page 2 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Fuite essence - Page 2 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Fuite essence - Page 2 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Fuite essence - Page 2 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Fuite essence - Page 2 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Fuite essence - Page 2 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Fuite essence - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Fuite essence - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Fuite essence - Page 2 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
réservoir reglage feux selle chaine longues phare filtre arrière garde tenere amortisseur embrayage essence huile galére fourche boue tuto crash rabaissement pneus vidange manuel suis synchro
-36%
254.99 € 399.01 €
 Fuite essence
Mélou13
Mélou13
Moto : 750 xtz 1989
Ville ou région : paca
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 25 Avr 2011 - 18:37
Flo44 a écrit:
starter coincé à mon avis!
Salut, là il faut que t m'aide!!
j'en ai marre de démonter le réservoir à chaque essai!!!! carbu pas accessibles!!!
Bon, ça démarre, au starter, que j'enlève assez rapidement, le ralenti est ok, ça monte en régime nickel
SAUF que au bout d'1 minute, montée en régime, ratatouille,et elle cale.
J'insiste, elle redemarre et rebelote, j'essaie a nouveau, plus rien, avec ou sans starter.
Je pense a une mauvaise arrivée d'essence, pourtant, ça coule quand j'ouvre les purgeurs de cuve, et çà coule aussi quand je retire les durites de la pompe essence, comprends pas!!!
C'est certainement pas grand chose, mais quoi?
a+
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 25 Avr 2011 - 18:46
tu as regardé en démontant tes carbus, les pointeaux de starter??
regarde ici
https://www.super-tenere.org/t1692-refection-carbus-en-photos
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 25 Avr 2011 - 19:03
Salut, bon je vais vérifier ça, si c'est pas ça je passe à l'étape mise en piece carbu en suivant ton tuto
je te tiens au courant
a+
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 25 Avr 2011 - 19:09
les pointeaux plastiques "fondent"
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 25 Avr 2011 - 19:50
melou 13
tu trouve un bidon avec une durite... ta durite tu la branche la ou tu sais est tu fait tes essais cooll est si tu veux rouler pas de prob
Fuite essence - Page 2 Reserv10
milou13 j'suis sur que sa vas aller Fuite essence - Page 2 916683 quelqu'un vas finir par trouver !!!
moi jsais pas mais la pompe a essence???? suprime la ....est branche mon (tilleau) en directe tu as déjà essayer???
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 25 Avr 2011 - 21:48
Tu as raison tabar, je vais récupérer un bidon de lave glace à la casse, et vais faire comme ça, la pompe, j vais la shunter pou essayer.
a+
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 25 Avr 2011 - 21:59
a tu controler hauteur du niveau d'essence des carbus,et voir si la pompe fonctionne correctement,au bidon si ça marche ça vient de la pompe!!!!
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 25 Avr 2011 - 23:45
Hello à tous ...
La pompe n'est utile que quand le réservoir est presque vide et que la gravité ne suffit plus ... donc avec un niveau d'essence ou réservoir additionnel (voir une idée dans ma signature ;-) plus haut que les carbus pas de problème ... ça marche sans problèmes sans pompe ;-) ...
Flo a raison ... si les pointeaux ne ferment pas l'essence arrive en trop grande quantité dans les cuves et se déverse dans les pipes d'admission par les trop plein des cuves sans passer par les gicleurs ... d'où un mélange trop riche en un calage du moteur ;-) ...
C'est pour ça que je te conseillais un kit joints complet au lieu du joint de cuve seul ;-) ...
Tchüss à tous ;-) ...
Fuite essence - Page 2 Rassos10
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 26 Avr 2011 - 5:16
vaut peu etre mieux controler avant d'acheter!!!!!!!si ça vient pas des joint ou du pointeau c'est bete
si l'essence coule dans le carbu ça ne demarer pas
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 26 Avr 2011 - 16:13
Comment fait tu pour controler ce niveau?
les pointeaux sont neufs, ils étaient dans le sachet. J'ai mis les joints de cuve, le torique sur le plastique support des flotteurs et les petits toriques sous les chapeaux à coté des membranes
a+
et encore merci pour votre aide
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 26 Avr 2011 - 18:15
derfu
j'suis rester une journée en panne.... suite a une panne seche..
avec 1 litre d'essence la mob n'as jamais voulu démarrer (la garce)
batterie hs après recharge j'ai pris mon réservoir de compete,ou de tapette, est pof car de tour
vas comprendre charle!!!!! cheers Fuite essence - Page 2 559756 mes potes sont partis sans moi Fuite essence - Page 2 660723 tabar..
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 26 Avr 2011 - 18:52
Hello à tous ...
1L c'est vraiment peu ... La pompe n'est vraiment utile que lorsque l'on passe sur réserve ... il doit rester en tout 5L dans le réservoir ...
Tu ne devrais pas rouler avec aussi peu d'essence ... tu risques des désamorçages à répétition et aspirer de la me_de aussi ;-) ...
Mélou ...
Pour faire les niveaux des cuves il faut un tube, le fixer à la place de la durit de vidange ... Sur la cuve il y a un repère, ton niveau doit être là ... et surtout doit être le même sur les deux cuves ... à 5.1 à 6.1mm au dessus du trait (cf RTM76).
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptySam 14 Mai 2011 - 17:44
Mélou ...
Tchüss à tous ;-) ...[/quote]
Salut, de retour!!
Ce matin, reprise du brico moto cause boulot!!
Démarrage, idem,rien n'a changé, normal!!
Je met les durites transparentes pour verif niveaux, resultat, un peu au dessous du niveau, demmarage elle cale au bout dune minute.
J'essaie au bout de 10 minutes en tournant le ralenti avec les vis de cuves ouvertes et duites raccordées, le niveau passe au dessus du niveau cuve. 5 minutes de ralenti, montée en régime de temps en temps.
Bilan, ça broute plus ça monte en régime bien linéaire et redescend normal!!!! Juste une petite fumée noire à l'accel qui a disparu depuis.
Donc, pour resumer, J'AI RIEN COMPRIS MAIS CA MARCHE!!!!!
Sauf doute sur refroidissement(voir autre post)
Merci à tous
Mélou13
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 27 Juin 2011 - 22:11
Salut à tous
deterrage de post!!! sur les conseils de flo44, voici les pointeaux de starter!!
Il font un peu la gueule, surtout les joints!!
Par contre la partie pointeau a l'air d'avoir chauffé , elle est bien rugueuse et pas lisse, comme de la saleté collé mais qui part pas en grattant, en bref ça m'a l'ai usé.
Cela pourrait correspondre à une arrivée supp d'essence qui fait brouter à bas régime. Mais là où je seche c'est qu'au ralenti, sans starter, pas de prob, le régime monte et redescend sans ratés. Ca le fait seulement en roulant, quand le moteur est en charge. Après il y a les watts, mais en bas, dès que je relance, rebelote!!! Et ça cogne dans le moulin!!! J'aurais du me faire suivre pour voir si ça fume à la relance.
Pensez vous que ça vient des starters?
a+
Fuite essence - Page 2 Sam_2010
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyLun 27 Juin 2011 - 23:19
Houlàaaa ... pas beaux tes plongeurs :-\ ...
Perso je dirais ... Aiguille et puits d'aiguille + Gicleur d'essence principal ... pour ton problème de reprise ...
En gros ... vus que t'as tombé les plongeurs de starters, t'as donc les carbus à disposition ...
Démonte le tout ... Nettoie bien tous les Gicleurs de carburant ... vérifie si tes puits ... là tu vas avoir du mal ... mais surtout si les aiguilles sont marquées, lustrées sur la partie basse de l'aiguille, là où elle frotte dans le puits ...
Mate aussi les soufflets des boisseaux ... s'ils sont poreux ... à changer :-\ ... les joints aussi ...
Voilà Man ... Bon courage à toi ... remarque, les carbus, c'est pas le pire à refaire ;-) ...
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 12:29
Salut derfu tu as encore raison!!!!
Les joints de gicleurs principaux sont nazes!! Archi secs et abimés. J'ai mis ceux de la pochette, semblent plus fin, ils s'écrasent au montage et rempliront la totalité de la gorge, enfin je pense. Une fois montés, il bougent un peu Normal?
Par contre, les aiguilles et puits nettoyés, Il manque une rondelle métal au bout du ressort sur 1carbu!!!!
sûr qu'elle y étais pas, j'ai démonté selon la RT en identifiant les elements. C'est peut être une cause de mon souci!!, par quoi puis je la remplacer, deux rondelles classiques même épaisseur c'est bon? le ressort est si sensible?
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 13:53
effectivement,vérifie se probléme,est en commander une !!!!sa prend pas un bras et six sous!!! tu roule en altitude???
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 14:40
Non, plutot bord de mer. je vais remonter pour voir, maintenant qu'il y a des joints neufs, mais avec le pointeaux bizzare, je me fais pas des idées, en même temps 37.5 euros x 2 pour les starters chez yam, il y a que les prix qui sont pas au diapason.........
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 15:09
Hello Mélou ...
Mélou13 a écrit:
... Les joints de gicleurs principaux sont nazes!! Archi secs et abimés. J'ai mis ceux de la pochette, semblent plus fin, ils s'écrasent au montage et rempliront la totalité de la gorge, enfin je pense. Une fois montés, il bougent un peu Normal ?
Oui pas de soucis, le gicleur de carburant n'est soumis à aucun efforts, la fourche qui le maintien est largement suffisant ...
Par contre, les aiguilles et puits nettoyés, Il manque une rondelle métal au bout du ressort sur 1er carbu !!!
Sûr qu'elle y étais pas, j'ai démonté selon la RT en identifiant les éléments.
T parles de quelle rondelle ... tu peux détailler stp ?
Fuite essence - Page 2 Carbur10
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 15:13
salut derfu, c'est le 28
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 16:06
Oki ... la rondelle du repère 28 ...
Fuite essence - Page 2 Carbur11 Fuite essence - Page 2 98514110
Fuite essence - Page 2 Mikuni10
A gauche ... Montage normal ...
A droite ... Montage avec rondelle modifiée pour éviter à l'aiguille de frotter dans le puits ...
Si tu as les circlips positionnés au même endroit sur tes deux aiguilles, l'une est donc plus basse que l'autre ... Ca c'est pas bon ça ...
Pour pallier à l'absence de rondelle sur l'aiguille, il faudrait peut-être remonter le circlips d'un cran ... Ca c'est pas mieux
Supprimer la rondelle de l'autre côté ... c'est la rondelle en téflon qui va prendre tous les chocs sur l'arrête saillante intérieure du boisseau ... Ca c'est nul ... Aïe !
Si tu as la même rondelle dans ta boite à rondelles ... bin change là ... mais le mieux c'est de commander les rondelles chez Yam ou chez un détaillant Mikuni ... je sais plus si j'ai pas le link d'un site là dessus .. j'vais regarder ;-) ...
N'oublie pas que c'est de la mécanique de précision l'élaboration du mélange gazeux dans un carbu ... les pièces d'origine ont un poids et une taille bien définie par Mr Mikuni ;-) ...
Au pire si tu as vraiment besoin de ta mob, enlève l'autre temporairement, place tes circlips dans la même encoche d'aiguille, reprends les réglages de carbus ... et commande ta pièce ;-) ...
Tchüss Man ;-) ...
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 17:49
Ca y est , j'ai tout remonté, ça a l'air de fonctionner Fuite essence - Page 2 897922 (pas les rondelles 28, en commande). ça petarade de temps en temps au ralenti, rien de méchant, j'attends que ma femme rentre du boulot et j'enfourche la bête(la moto, pas ma femme!!!!) Fuite essence - Page 2 80767
P....tain, si elle lit le post!!! Fuite essence - Page 2 641958
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 18:40
Hello Mélou ...
Mélou13 a écrit:
... Ca pétarade de temps en temps au ralenti, rien de méchant ...
Mélange trop riche ... fais ton réglage de richesse ... c'est pas compliqué ... c'est dans la RTM ;-) ...
... J'attends que ma femme rentre du boulot et j'enfourche la bête (la moto, pas ma femme !!!) P....tain, si elle lit le post !!!
Pourquoi ? ... Y a revue de chambre avant ? ... Si le ménage est pas bien fait tu restes puni ? ...
Moi qui croyais que dans le SUD, c'est l'homme qui portait la culotte ... Oh putaing, en fait vous êtes pas mieux lotis que nous, les Nordistes ;-) ...
Tchüss à tous ...
MessageSujet: Re: Fuite essence   Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 19:39
dans le sud nos louises!!!! elle on jamais mal la téte ..... c'est lhomme...Fuite essence - Page 2 198135!!dans le ch"nord au dessud de gallargue voui!!!! Fuite essence - Page 2 49290
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: a    Fuite essence - Page 2 EmptyMar 28 Juin 2011 - 19:56
Bon ça y est, ça roule, reste plus qu'a s'en servir, 300 kms en 5 mois!! Le anakee a encore les picots!!!
Fuite essence
» [résolu]pb boite vitesse
» Fuite huile
» Fuite de courant...
» Fuite d’essence
» fuite d huile
