Montage Switch ABS Off the road. Emptypar oustad Hier à 20:14
Montage Switch ABS Off the road. Emptypar SuperTiti Hier à 13:04
Montage Switch ABS Off the road. Emptypar oeuf Hier à 10:11
Montage Switch ABS Off the road. Emptypar oeuf Hier à 10:03
Montage Switch ABS Off the road. Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Montage Switch ABS Off the road. Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Montage Switch ABS Off the road. Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Montage Switch ABS Off the road. Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Montage Switch ABS Off the road. Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Montage Switch ABS Off the road. Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Montage Switch ABS Off the road. Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Montage Switch ABS Off the road. Emptypar Arni Dim 17 Nov 2024 - 14:06
Montage Switch ABS Off the road. Emptypar Arni Dim 17 Nov 2024 - 13:13
Montage Switch ABS Off the road. Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Montage Switch ABS Off the road. Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Montage Switch ABS Off the road. Emptypar Fredard Sam 16 Nov 2024 - 9:43
Montage Switch ABS Off the road. Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Montage Switch ABS Off the road. Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Montage Switch ABS Off the road. Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Montage Switch ABS Off the road. Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Montage Switch ABS Off the road. Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Montage Switch ABS Off the road. Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Montage Switch ABS Off the road. Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Montage Switch ABS Off the road. Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Montage Switch ABS Off the road. Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
manuel phare fourche selle reglage rabaissement réservoir arrière amortisseur boue essence tuto garde suis filtre pneus synchro tenere galére vidange feux chaine crash longues embrayage huile
29.99 €
J-Marc
J-Marc
Ville ou région : Isère
MessageSujet: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyJeu 26 Avr 2012 - 19:31
Montage Switch ABS Off the road. 697753
Hier j'ai reçu le switch pour déconnecter/reconnecter l'ABS de chez Off the road : ben c'est cher pour ce que c'est affraid :
Montage Switch ABS Off the road. Dscn5510
Pour la maudique (voir maudite) somme de 77,40 roros. Bon c'est moins cher que de refaire les flancs pour cause de gamelles dans la gadou je pense.
En fait le principe est trés simple :
On se branche en lieu et place du fusible de l'ABS, et l'inter (un pov coupe circuit de moteur : c'est même marqué Engine OFF/ON) simule une coupure du fusible et on n'a plus d'ABS, sur ce nouveau câble il y a un porte fusible pour replacer ce dernier dessus..
Pour le montage :
Démontage du flanc droit :
Montage Switch ABS Off the road. Dscn5512
Mise en place de l'inter au guidon poignée gauche : j'ai dû démonter le protége main et le rétro (en partie)
Montage Switch ABS Off the road. Dscn5513
Ensuite j'ai fait suivre le chemin du merdier de câbles qui va de la poignée gauche à la batterie.
Le fusible de l'ABS est le fusible 30 ampères du bas, il faut le retirer et mettre à la place les 2 fiches de l'extrémité du câble et mettre le fusible dans le porte fusible.
Montage Switch ABS Off the road. Dscn5514
A l'intention des puristes qui ne manqueront pas de me faire la remarque (à raison d'ailleurs) : J'ai mis des jolies colliers pour tenir tout ça et surtout bien vérifier qu'en tournant le guidon gauche/droite à fond on n'arrache pas tout.
Voila!! Alors si il y en a que ça tente et qu'ils ont un coupe circuit, 2 câbles, un porte fusible et 2 fiches c'est pas compliqué à faire pour un tarif trés abordable.
En ce qui concerne l'utilisation on peut couper l'ABS en roulant, par contre pour le remettre en fonction il faut :
1-S'arrêter,
2-Couper le contact,
3-Actionner l'inter,
4-Redémarrer.
Pour gagner quelques centièmes on doit pouvoir sauter l'étape 1 mais j'ai pas encore osé.
En plus c'est marrant mais pour couper l'ABS il faut mettre l'inter sur ON, la rigueur Allemande c'est plus ce que c'était!!
http://www.2bernard.fr
flogarty
flogarty
Moto : 1200 xtz
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyJeu 26 Avr 2012 - 21:10
super post
tres bien montée
edit ""En plus c'est marrant mais pour couper l'ABS il faut mettre l'inter sur ON, la rigueur Allemande c'est plus ce que c'était!!""
dorigine c un fusible le courant passe!! donc abs activé !! ton inter sur ON le courant passe alors abs activé et toi c l inverse
c chelou
tu dois pouvoir bidouiller l inter pour qu il coupe sur off
il te faut un multi pour la continuité et du calme lol
faut acheter francais
Montage Switch ABS Off the road. Canon_10Montage Switch ABS Off the road. Img00710Montage Switch ABS Off the road. Canon_12Montage Switch ABS Off the road. Canon_11Montage Switch ABS Off the road. 2012-120Montage Switch ABS Off the road. 2011-110Montage Switch ABS Off the road. 2012-010
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyJeu 26 Avr 2012 - 21:34
Montage Switch ABS Off the road. 170742
J-Marc
J-Marc
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyVen 27 Avr 2012 - 9:08
Oula je touche plus arien si je puis dire Montage Switch ABS Off the road. 49290 je vais juste mettre une étiquette ON sur OFF et une OFF sur ON, de toute façon quand l'ABS est déconnecté le voyant est allumé dans le cockpit donc y a pas d'soucis en fait!!Montage Switch ABS Off the road. 356876
A++
le marin
le marin
Kms de ma moto : 13000
Ville ou région : Gironde
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyMar 25 Nov 2014 - 12:42
je pense que je vais investir dans cette interrupteur
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyMar 25 Nov 2014 - 12:55
Le système OTR est une arnaque !!!
- On  trouve ce genre d'inter pour 2,50 € sur Ebay.....
http://www.ebay.fr/itm/7-8-Interrupteur-Guidon-Switch-de-Phare-Universel-DC12V-Moto-Scooter-Motoneige/371094487157?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140620091323%26meid%3D44ebc7a085d04e69a4be6a69b46162fd%26pid%3D100005%26prg%3D20140620091323%26rk%3D3%26rkt%3D6%26sd%3D191341887558&rt=nc
- On peut mettre n'importe quel interrupteur sur le fil d'alim' de la centrale (déjà protégée par un fusible à part)
C'est précisément ce que j'avais fait et exposé dans un post sur ce forum en juillet 2013 :
https://www.super-tenere.org/t6944-abs-or-not-abs
(voir en bas de page...) Coût total : 4 €......
J-Marc
J-Marc
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyMar 25 Nov 2014 - 14:15
C'est sur, comme je le disais dés le début du post ils se foutent un peu de notre gueule vu le prix des éléments du kit, à refaire je le fais moi-même.
Vu le prix je m'atttendais à autre chose mais bon... Le post à la limite était plus là pour permettre à de joyeux bricoleurs de ne pas tomber dans le même panneau que moi et de "copier" le systeme OTR!
Pour la prochaine je le ferais moi!
a++
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyMar 25 Nov 2014 - 14:39
Pas de souci J-Marc , je me suis juste permis d'enfoncer le clou que tu avais planté..... doigtsenV
Je trouve vraiment scandaleux de faire payer une telle somme pour ça , et il fallait bien insister pour que PERSONNE ne tombe à nouveau dans ce panneau (dans lequel j'ai failli tomber moi aussi , je te rassure....) bien
J-Marc
J-Marc
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyMar 25 Nov 2014 - 15:41
Je te rassure (si besoin était) pas de soucis de mon coté non plus amis
Montage Switch ABS Off the road. Wallpa11
https://www.2bernard.fr/
jackal74
jackal74
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyMar 25 Nov 2014 - 16:14
c'est sûr qu'il y a des escrocs partout  pas content
pour être complet, quelle section de fil faut-il  pour se bricoler çà soit-même ?
Montage Switch ABS Off the road. Sans_t10Montage Switch ABS Off the road. P1010010 Montage Switch ABS Off the road. Logo_c10Montage Switch ABS Off the road. P1010012
http://www.lescimes.org
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyMar 25 Nov 2014 - 17:56
Le calcul de base , c'est 1 mm² pour 2,5 Ampères....
Je prends systématiquement du 1,5 mm² pour tous type de branchement moto et 2 mm² s'il s'agit de phares additionnels...
le marin
le marin
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyJeu 27 Nov 2014 - 19:03
Je dit peu être une connerie mais t'a essayé d'inverser ton branchement la ou tu t'es connecté à la place du fusible initiale ?
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyJeu 27 Nov 2014 - 19:44
Non ça ne change rien, vu qu'un inter c'est juste ouvrir et fermer un circuit  saispas donc si t'inverse, le résultat est le même.
En fait cet inter est un coupe circuit , ça m'a fait le même coup pour mes phares (j'ai exactement le même inter, et je n'envenimerais pas les choses en disant le prix que je l'ai payer Montage Switch ABS Off the road. 114152  )
Montage Switch ABS Off the road. 230111
le marin
le marin
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyJeu 27 Nov 2014 - 19:59
Oui exact pas faux
Je vais qd même le commander et me le fabriquer (sans enfoncer le clou) chuutt
lucolt
lucolt
Moto : xt1200z
Kms de ma moto : 6000
Pneu AV/AR : metzeler
Ville ou région : ALES (30)
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyVen 29 Mai 2015 - 15:51
salut a tous,
je viens de faire ce petit montage, avec un bouton d’arrêt moteur (acheter sur ebay), un peu de fil, 2 cosses, 1 porte fusible.
j'ai lu que lors de la mise en œuvre de ce montage, le compteur de la moto ne fonctionne plus, hors je viens de faire un essais aprés le montage,
le voyant abs est allumé (donc en défaut), j'ai bien testé que les 2 roues se bloques lors d'un freinage appuyé a basse vitesse dans le gravier,
mais le compteur a l'air de fonctionner normalement.
si ceux qui ont aussi fait ce petit montage pouvait me faire un petit retour.
XTZ1200ZE année 2016 - 10 000km
XTZ700 année 2020 - 6 000km
XTR660 année 2015 - (ex)
XT1200Z année 2012 -  (ex)
XTE600 année 2003 -  (ex)
ELEFANT 350 année 1992 - (ex)
CEVENNES REMORQUES vente et location de remorques sur ALES
http://www.atouloc.fr
J-Marc
J-Marc
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyVen 29 Mai 2015 - 19:47
salut Lucolt,
Pas de soucis non plus de mon coté le compteur de la moto fonctionne sans problème avec ou sans le switch en fonction.
J-Marc.
lucolt
lucolt
Moto : xt1200z
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyVen 29 Mai 2015 - 22:28
J-Marc a écrit:
salut Lucolt,
J-Marc.
salut j-marc,
merci pour ton retour.
je tenais aussi a te remercier pour la qualité de ton "reportage" grace auquel j'ai pu faire se petit montage sans soucis et sans depenser 70€ Montage Switch ABS Off the road. 49290
Montage Switch ABS Off the road. 231456 @+
J-Marc
J-Marc
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptySam 30 Mai 2015 - 10:48
De rien, avec plaisir !
J-marc.
thierry10
thierry10
Ville ou région : AUBE
MessageSujet: Re: Montage Switch ABS Off the road.   Montage Switch ABS Off the road. EmptyMer 8 Nov 2017 - 16:24
Attention au diamètre des fils, c'est du 30 A quand même !!!
Lord Oaristus
Lord Oaristus
Moto : XTZ 1200 Worldcrosser
Kms de ma moto : 38000
Pneu AV/AR : Anakee 3 malheureusement
Ville ou région : Paris
MessageSujet: Merci pour le tuyau, économie confortable...   Montage Switch ABS Off the road. EmptyLun 4 Juin 2018 - 12:51
https://i.servimg.com/u/f62/19/90/78/05/tablea10.jpg
Un petit bouton tout rond !!
Et pas de coupure du compteur de vitesse pour moi non plus.
» switch abs
» Le off-road à 50 ans ? Ben yes !
» OFF THE ROAD
» ON ZE ROAD AGAIN
» Road trip suisse italie
