Coupure a 4000 tours et/ou 110km/h Emptypar SuperTiti Hier à 21:40
Coupure a 4000 tours et/ou 110km/h Emptypar Joe644 Hier à 18:56
Coupure a 4000 tours et/ou 110km/h Emptypar yop1025 Hier à 13:10
Coupure a 4000 tours et/ou 110km/h Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Coupure a 4000 tours et/ou 110km/h Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Coupure a 4000 tours et/ou 110km/h Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Coupure a 4000 tours et/ou 110km/h Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Coupure a 4000 tours et/ou 110km/h Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Coupure a 4000 tours et/ou 110km/h Emptypar Arni Dim 17 Nov 2024 - 14:06
Coupure a 4000 tours et/ou 110km/h Emptypar Arni Dim 17 Nov 2024 - 13:13
Coupure a 4000 tours et/ou 110km/h Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Coupure a 4000 tours et/ou 110km/h Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Coupure a 4000 tours et/ou 110km/h Emptypar Fredard Sam 16 Nov 2024 - 9:43
Coupure a 4000 tours et/ou 110km/h Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Coupure a 4000 tours et/ou 110km/h Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Coupure a 4000 tours et/ou 110km/h Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Coupure a 4000 tours et/ou 110km/h Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Coupure a 4000 tours et/ou 110km/h Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Coupure a 4000 tours et/ou 110km/h Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Coupure a 4000 tours et/ou 110km/h Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Coupure a 4000 tours et/ou 110km/h Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Coupure a 4000 tours et/ou 110km/h Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Coupure a 4000 tours et/ou 110km/h Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Coupure a 4000 tours et/ou 110km/h Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Coupure a 4000 tours et/ou 110km/h Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
galére embrayage boue tenere tuto crash rabaissement feux synchro pneus essence selle amortisseur reglage vidange réservoir suis huile manuel filtre chaine fourche longues garde arrière phare
-25%
749.99 € 999.99 €
nohcar
nohcar
Moto : tenere 750 de 1989
Kms de ma moto : 36000
MessageSujet: Coupure a 4000 tours et/ou 110km/h   Coupure a 4000 tours et/ou 110km/h EmptyVen 19 Sep 2014 - 19:50
salut  Tous  ......
Vous l'aurez compris , petit souci mecanique que je n'arrive a ressoudre ....
Ma becanne fonctionne correctement,pas de bruit anormal,pas de fumée,bref rien de speciale.
Cependant lorsque je roule il met impossible de depassé les 110 km/h  (certain me diront : tant mieux , c'est notre vitesse maxi autorisé ..... enfin dans les alpes maritimes)
Serieusement , voila le probleme :
tout va bien quelque soit le rapport tant que je ne depasse pas les 4000 t/m et les 110 km/h
quand j'arrive a cette limite , la moto a un trou et beuhhhhhhh , plus rien , suis obligé de laché les gaz , tant que je reste en dessous ..... aucun probleme .
En en parlant autour de moi , j'ai eu droit à :
- pipe d'admission qui se dilatte  : trop regulier est precis pour etre vraie , je n'y crois pas !
- boitier CDI et/ou regulateur : j'ai eu des probleme de CDI sur des quad , les machines ne tournaient pas ou tres mal ...
Donc si quelqu'un a eu le probleme ou a une idée , je suis preneur  ...... Merci d'avance
skritch
skritch
Moto : xtz 750 super ténéré
Kms de ma moto : 58000
Ville ou région : Grenoble
MessageSujet: Re: Coupure a 4000 tours et/ou 110km/h   Coupure a 4000 tours et/ou 110km/h EmptyVen 19 Sep 2014 - 21:20
kit carbu?
Super Ténéré?! la Legende!
Takapas
Takapas
Moto : 1200XTZ
Kms de ma moto : 12000
Ville ou région : Essonne
MessageSujet: Re: Coupure a 4000 tours et/ou 110km/h   Coupure a 4000 tours et/ou 110km/h EmptyVen 19 Sep 2014 - 22:17
bin un truc si précis, je verrais bien le calculateur, ou alors une info mal interprété ( donc un capteur quelconque )  qui donne une mauvaise info et le calculateur décide de couper scratch
si le régulateur est hs, soit pas jus , soit plus de 12v mais je vois pas pourquoi 4000T...
L'année dernière j’étais encore un peu présomptueux, mais cette année je suis parfait ... Coupure a 4000 tours et/ou 110km/h 49290
nohcar
nohcar
MessageSujet: Re: Coupure a 4000 tours et/ou 110km/h   Coupure a 4000 tours et/ou 110km/h EmptyVen 19 Sep 2014 - 23:11
pas de kit carbu (entierement d'origine)
je pense plus a un probleme electrique
encore un petit detail (avec starter plus de probleme) ..... oup's , maintenant que je l'ecrit !! carbu me parait probable , mais la precision du defaut me fait douté
Bazingounette
Bazingounette
Kms de ma moto : 42000
Pneu AV/AR : Mich - Anakee 2
MessageSujet: Re: Coupure a 4000 tours et/ou 110km/h   Coupure a 4000 tours et/ou 110km/h EmptyVen 19 Sep 2014 - 23:28
Un trou à l’accélération peu effectivement être le signe d'une carburation mal réglée.
Cependant, à 4000T, ce n'est plus le réglage des vis de richesse d'air qui peu être en cause, mais, d'après moi, plus le boisseau, le puit d'aiguille ou l'aiguille...
Comment sont tes membranes ?
A 4000T un régulateur défaillant va également avoir du mal à redresser et contenir la tension, un petit contrôle de ce dernier pourrait être intéressant.
Yamaha XTZ 750 - 1991
chaudard
chaudard
Moto : 750 super tenere
Kms de ma moto : 82000
Pneu AV/AR : rond noir en caoutchoux
Ville ou région : autun
MessageSujet: Re: Coupure a 4000 tours et/ou 110km/h   Coupure a 4000 tours et/ou 110km/h EmptyMar 23 Sep 2014 - 8:25
salut ,tu est a 110 kmh 4000 tours ??? moi a 4000 je suis a  un petit 100kmh
JB
Moto : XTZ 1200 n° 1106
Ville ou région : Saverne
MessageSujet: Re: Coupure a 4000 tours et/ou 110km/h   Coupure a 4000 tours et/ou 110km/h EmptyMar 23 Sep 2014 - 10:46
C'est arrivé d'un coup ce pb ? Tu dois avoir une prise d'air qq part : vérifie toutes les pipes du filtre à air au bloc moteur, état, serrage des colliers ...
MessageSujet: Re: Coupure a 4000 tours et/ou 110km/h   Coupure a 4000 tours et/ou 110km/h EmptyMar 23 Sep 2014 - 12:15
As tu des pétarades dans l'échappement au moment de la panne si tu ouvres les gaz à fond ?
Lorsque le fonctionnement normal se rétablit, se rétablit il d'un seul coup ou plus graduellement comme si tu allais passer sur la réserve ?
As tu également des problèmes de ralenti ?
» Roadtrip Supermoto de 4000 km !
» Pas de reprise après 3 - 4000
» Coupure moteur
» Coupure du régulateur de vitesse
» Coupure moteur ST750
