ECROU DU PIGNON DE SORTIE DE BOITE Emptypar SuperTiti Hier à 21:40
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar Joe644 Hier à 18:56
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar yop1025 Hier à 13:10
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar REYNALD Mar 19 Nov 2024 - 10:58
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar REYNALD Mar 19 Nov 2024 - 10:49
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar REYNALD Mar 19 Nov 2024 - 10:46
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar REYNALD Mar 19 Nov 2024 - 10:44
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar jackal74 Lun 18 Nov 2024 - 11:58
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar Arni Dim 17 Nov 2024 - 14:06
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar Arni Dim 17 Nov 2024 - 13:13
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar yop1025 Sam 16 Nov 2024 - 23:12
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar Fredard Sam 16 Nov 2024 - 9:43
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar J-Marc Mar 12 Nov 2024 - 12:44
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar J-Marc Lun 11 Nov 2024 - 21:58
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar thierry83 Dim 10 Nov 2024 - 9:29
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar REYNALD Ven 8 Nov 2024 - 16:55
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar REYNALD Mar 29 Oct 2024 - 20:18
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar REYNALD Mar 29 Oct 2024 - 20:00
ECROU DU PIGNON DE SORTIE DE BOITE Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
tenere boue reglage selle pneus feux rabaissement chaine phare synchro vidange manuel fourche huile embrayage amortisseur réservoir tuto essence crash galére suis arrière garde filtre longues
29.99 €
rodmac02
rodmac02
Kms de ma moto : 51000
MessageSujet: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyMer 12 Mar 2014 - 17:49
bonjour à tous,
 en graissant ma chaine, j'ai retrouvé l'écrou qui maintient le pignon de sortie de boite enlevé!
impossible de le remettre. il commence à s'accrocher puis il saute. en ai, acheté un neuf, impossible de le faire prendre.
Quelqu'un a déjà eu ce soucis?
marci d'avance
erick07
erick07
Moto : 660 xtz 91
Kms de ma moto : 77000
Pneu AV/AR : Conti escape
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyMer 12 Mar 2014 - 19:03
NON,,,,Mais je vais vérifier quand même!!! bounce
ECROU DU PIGNON DE SORTIE DE BOITE 413816 ECROU DU PIGNON DE SORTIE DE BOITE 550966 ECROU DU PIGNON DE SORTIE DE BOITE 210451 ECROU DU PIGNON DE SORTIE DE BOITE 210451 ECROU DU PIGNON DE SORTIE DE BOITE 210451
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyMer 12 Mar 2014 - 20:37
ECROU DU PIGNON DE SORTIE DE BOITE Ct2rou14ECROU DU PIGNON DE SORTIE DE BOITE Logo_y12ECROU DU PIGNON DE SORTIE DE BOITE Vosges11 ECROU DU PIGNON DE SORTIE DE BOITE J_y_yt11  ECROU DU PIGNON DE SORTIE DE BOITE J_y_yt10
rodmac02
rodmac02
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyMer 12 Mar 2014 - 21:01
mince, je l'avais oublié ce post là! pourtant je l'ai lu dans tous les sens! pas beau de vieillir rouge colere
je te remercie ch'ti-cool.
ayant besoin de rouler rapidement, je vais opter pour les points de soudure.
quelqu'un l a t il déjà fait? éventuellement une photo pour voir ou souder sans rien casser?
merci à vous
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyMer 12 Mar 2014 - 21:47
la mode barbare ça paye pas (dans le temps) si tu es très pressé netoie l'axe nikel pousse le pignon a fond puis un filet de S glue pour stabiliser 2 colsons puis re dose de S glue en attendant de faire du bon taf  bien
rodmac02
rodmac02
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyMer 12 Mar 2014 - 22:01
ok, on va regarder cela de plus près.
Moto : 750 Super T
Ville ou région : Ajaccio
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyJeu 13 Mar 2014 - 16:23
Moi j'ai le psb soudé, a l'arc, et ca tient meme que le joint spi ne fuit pas  Double V .
Un petit coup de disqueuse et ca s'enleve, mais comme j'ai un attache rapide sur la chaine je vois pas l'interet de demonter le pignon vue qu'il doit avoir seulement 15000km  ( donc la soudure ca tient quand meme  ECROU DU PIGNON DE SORTIE DE BOITE 198135  , et je roule pas cool ).
Apres chacun fait ce qu'il veut, chacun prend ses risques  hello  .
rodmac02
rodmac02
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyJeu 13 Mar 2014 - 18:31
merci pour ton avis ED clin d\'oeil
chaudard
chaudard
Moto : 750 super tenere
Kms de ma moto : 82000
Pneu AV/AR : rond noir en caoutchoux
Ville ou région : autun
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyJeu 13 Mar 2014 - 20:32
deux points de soudure legé  , fais 3000km r a s ; mimi meuleuse pour enlever les points
rodmac02
rodmac02
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyJeu 13 Mar 2014 - 20:36
ok, merci pour le renseignement chaudard.
vais le faire faire demain par un ami. je n ai jamais soudé sick !
j'imagine qu'il faut débranché la batterie.
un point de soudure de chaque coté de l'axe?
chaudard
chaudard
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyVen 14 Mar 2014 - 15:04
enleve le cdi il
 bien  tien par deux vis
rodmac02
rodmac02
MessageSujet: Re: ECROU DU PIGNON DE SORTIE DE BOITE   ECROU DU PIGNON DE SORTIE DE BOITE EmptyVen 14 Mar 2014 - 15:06
je l'avais oublié celui là, je te remercie
» roulement axe sortie de boite
» Problème ecrou sortie de boite
» Fuite d'huile axe de sortie de boite
» Echange pignon sortie de boite + vérifs et ...Essais !!
» Mise en garde joint spi sortie de boite
