PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar Joe644 Mer 20 Nov 2024 - 18:56
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar yop1025 Mer 20 Nov 2024 - 13:10
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar REYNALD Mar 19 Nov 2024 - 10:58
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar REYNALD Mar 19 Nov 2024 - 10:49
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar REYNALD Mar 19 Nov 2024 - 10:46
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar REYNALD Mar 19 Nov 2024 - 10:44
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar jackal74 Lun 18 Nov 2024 - 11:58
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar Arni Dim 17 Nov 2024 - 14:06
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar Arni Dim 17 Nov 2024 - 13:13
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar yop1025 Sam 16 Nov 2024 - 23:12
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar Fredard Sam 16 Nov 2024 - 9:43
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar J-Marc Mar 12 Nov 2024 - 12:44
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar J-Marc Lun 11 Nov 2024 - 21:58
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar thierry83 Dim 10 Nov 2024 - 9:29
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar REYNALD Ven 8 Nov 2024 - 16:55
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar REYNALD Mar 29 Oct 2024 - 20:18
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar REYNALD Mar 29 Oct 2024 - 20:00
PROBLEME INDICATION TEMPERATURE EXTERIEURE Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
galére longues garde manuel arrière tenere fourche huile tuto feux amortisseur selle suis chaine pneus rabaissement boue filtre vidange reglage phare synchro réservoir embrayage crash essence
Le Deal du moment : -30%
139.99 €
PATRAMA
PATRAMA
Moto : XTZ 1200 SUPER TENERE
Ville ou région : VITRY SUR SEINE
MessageSujet: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptyMar 14 Sep 2010 - 15:17
J'ai installé le pare carter sur ma xt1200 et depuis l'installation la température extérieure indiquée sur mon tableau de bord est supérieure à la réalité (+5 à 10°).
Je pense que la sonde a du être déplacée pendant l'installation PROBLEME INDICATION TEMPERATURE EXTERIEURE 738603 .
Y a t-il quelqu'un d'entre vous qui sache où se trouve cette sonde ?
La température indiquée a toujours tendance a etre supérieure à la normale et je suppose que la sonde ne doit pas être tres éloignée du moteur.
Merci pour votre aide.
mxjazz
mxjazz
Moto : YAMAHA 1200 XTZ
Kms de ma moto : 19000
Pneu AV/AR : Anakee 2
Ville ou région : Lausanne - Suisse
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptyMar 14 Sep 2010 - 20:38
Salut PATRAMA,
Je n'ai pas d'idée où se trouve la sonde de température. A ta place, j'essaierais de démonter le pare carter pour voir si la température redevient normale où alors j'utiliserais un spray réfrigérant qui m'aiderait à localiser cette sonde.
Bon, ce ne sont que des idées qui me passent par la tête. PROBLEME INDICATION TEMPERATURE EXTERIEURE 242583
Kms de ma moto : 140000
Pneu AV/AR : SCORPION
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptyMar 14 Sep 2010 - 21:53
Il me semble que la sonde mesure non pas la thempérature extérieur, mais la thempérature de l'air à l'entrée de la boite à air, ce qui fait qu'elle doit être au fin fond d'un truc et je ne pense pas qu'on puisse déplacer le truc en montant le pare carter.
Au fait, c'est compliquer à monter un pare carter ? le mien vient d'arriver chez mon concess, avec la bulle secdem pour remplacer la bulle haute, aprés essais, j'vous dirais koi !
François
PATRAMA
PATRAMA
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptyMer 15 Sep 2010 - 8:25
mxjazz a écrit:
Salut PATRAMA,
A priori le pare carter n'a aucun contact avec les connections électriques, je crois que cela serait plutôt lié aux éléments qui doivent être démontés pour la mise en place.
merci pour ton aide.
PATRAMA
PATRAMA
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptyMer 15 Sep 2010 - 8:33
François
J'ai regardé hier et je n'ai rien vu, tout semble avoir été remonté correctement.
Pour un premier montage il faut compter environ 2 heures mais si ton concess à déjà un peu d'expérience sur la bécane en une heure c'est ok.
Les instructions de montage ne sont pas très bien faites, ils demandent de relever le réservoir mais franchement celà ne sert à rien.
Il suffit de démonter les caches latéraux et les deux pare carter d'origines et tout va bien.
Le cache latéral droit (lorqu'on est assis sur la bécane) se démonte avec quatres fixations 1/4 de tour ce ne sont pas des vis donc ATTENTION !!!!.
Honnêtement si tu as 2 heures à perdre tu peux le faire toi même et si tu ne démonte que les caches latéraux tu ne devrais pas avoir le même problème que moi.
Merci pour ton aide.
Super-Ice-T
Super-Ice-T
Kms de ma moto : 62500
Pneu AV/AR : Trailmax
Ville ou région : Rouen
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptyVen 17 Sep 2010 - 23:04
Bonsoir, j'ai ma super T depuis mardi, je n'ai pas encore le pare carter, et la température extérieure est tout à fait farfelue.
Mais selon le mnuel, page 3-12, ce n'est pas la température extérieure qui s'affiche, mais la température de l'air d'admission.
Bizarre PROBLEME INDICATION TEMPERATURE EXTERIEURE 242583
WHYZEED
Moto : 490 IT YZ XT 600 TENERE SUPERT RD 350 TY 175 DTMX YZ 250 FAZER S2
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptySam 18 Sep 2010 - 7:51
PROBLEME INDICATION TEMPERATURE EXTERIEURE 690590
Non , il n y a rien de BIZARRE, Yamaha prend ses clients pour des pilotes, et l'info pour un pilote c'est de connaitre la temperature de l'air admis dans le moteur, pas la temperature exterieur. la sonde est dans le boitier de filtre à air (comme toutes les yam equipées).
on peut quand meme connaitre la temperature de l'air , au premier demarrage (moteur Froid), pour ceux qui veulent
PATRAMA
PATRAMA
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptySam 18 Sep 2010 - 12:24
Je suis quand même surpris (A moins de m'être trompé) d'aavoir eu un affichage de temp globalement normal avant le montage du pare carter.
Bon bref tout le reste fonctionne correctement alors c'est le principal et puis pour la temp je vais installer un baromètre au dessus du tableau de bord PROBLEME INDICATION TEMPERATURE EXTERIEURE 106876
Sans l'invention de la roue, les motards du Dakar seraient condamnés à porter leur bécane sur le dos.
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptySam 18 Sep 2010 - 13:37
Le thermomètre sur la SuperT est un pousse au crime : plus tu roules vite, plus l'air arrive vite dans la boite à air, et plus la valeur de la th° est proche de la réalité !
Déjà qu'on nous fait rouler avec un truc sur lequel il est clairement écrit interdit sur route !!
François
PATRAMA
PATRAMA
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptyDim 19 Sep 2010 - 20:26
François
C'est clair !!!
Pour moi c'est problématique car quand je roule vite c'est ma temp qui monte !!! t\\'es fou PROBLEME INDICATION TEMPERATURE EXTERIEURE 690590
sonylegitan
sonylegitan
Ville ou région : LILLE NORD
MessageSujet: Re: PROBLEME INDICATION TEMPERATURE EXTERIEURE   PROBLEME INDICATION TEMPERATURE EXTERIEURE EmptyDim 19 Sep 2010 - 20:46
+1, comme il est dit dans le manuel, il s'agit de la Temp de l'admission, tout comme mes Ducati avant, cette température est forcément supérieure à la réalité car proche de plastiques plus chaud ou isolants. Ca peut, à la rigueur, te donne une idée de l'ambiant, mais d'une manière générale laisse tomber ça n'a pas d'intérêt.
» Température extérieure / dysfonctionnement
» Problème de temperature
» Température moteur
» indication de conso
» Température du cardan
