Kit Warning Buzzer XTZ1200 Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
Kit Warning Buzzer XTZ1200 Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Kit Warning Buzzer XTZ1200 Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Kit Warning Buzzer XTZ1200 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Kit Warning Buzzer XTZ1200 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Kit Warning Buzzer XTZ1200 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Kit Warning Buzzer XTZ1200 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Kit Warning Buzzer XTZ1200 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Kit Warning Buzzer XTZ1200 Emptypar Arni Dim 17 Nov 2024 - 14:06
Kit Warning Buzzer XTZ1200 Emptypar Arni Dim 17 Nov 2024 - 13:13
Kit Warning Buzzer XTZ1200 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Kit Warning Buzzer XTZ1200 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Kit Warning Buzzer XTZ1200 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Kit Warning Buzzer XTZ1200 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Kit Warning Buzzer XTZ1200 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Kit Warning Buzzer XTZ1200 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Kit Warning Buzzer XTZ1200 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Kit Warning Buzzer XTZ1200 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Kit Warning Buzzer XTZ1200 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Kit Warning Buzzer XTZ1200 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Kit Warning Buzzer XTZ1200 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Kit Warning Buzzer XTZ1200 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Kit Warning Buzzer XTZ1200 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Kit Warning Buzzer XTZ1200 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Kit Warning Buzzer XTZ1200 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
crash phare reglage synchro suis rabaissement manuel longues tenere amortisseur fourche pneus arrière galére huile chaine boue réservoir vidange feux selle garde essence filtre embrayage tuto
-25%
749.99 € 999.99 €
JMM
JMM
Moto : XTZ 1200 Limited Préparée...
MessageSujet: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyDim 6 Jan 2013 - 16:27
Bonjour
Sur ma 1ere XTZ 1200 j'avais fait monter un kit buzzer pour l'avoir sur les warnings
Le problème c'est que j'avais le buzzer aussi sur les clignotants !
J'avais donc tout fait retirer.
J'ai fait la même demande sur la nouvelle XTZ que je vais avoir, mais j'ai l'angoisse de me retrouver avec le même soucis.
Y a t il quelqu'un qui connaisse un montage fiable pour :
- Avoir le buzzer seulement sur les warnings
- Pas sur les clignotants.
Merci d'avance de vos infos. Voudrais bien trouver une solution à très court terme.
En cycle urbain, je préfère avoir les warnings avec buzzer pour passer entre les files, même si j'y vais cool...
http://www.BATI-SERVICES.org
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyDim 6 Jan 2013 - 17:25
Bin logiquement en électronique, rien n'est impossible, ... mais pour ça il faudrait que tu nous postes le schéma de montage ... passkeu comme ça à l'aveuglette on peut pas faire grand'chose :-\ ...
Kit Warning Buzzer XTZ1200 Rassos10
JMM
JMM
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyDim 6 Jan 2013 - 19:43
schéma de montage du kit, je suppose ?...
Penses tu que ce soit possible que justement ce soit impossible ?...
Ca me parait bizarre...
On doit bien pouvoir schinter à un moment ou un autre
On semble me répondre qu'on ne peut pas dissocier les 2 ?....
JMM
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyDim 6 Jan 2013 - 22:03
Avec des diodes si ... on peut isoler un circuit par rapport à l'autre ... suivant le schéma je pourrai te dire si on peut ou pas ;-) ...
fireball77
fireball77
Moto : 750 Ténéré 1993
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyLun 7 Jan 2013 - 7:47
Si tout ce passe par contacts dans le commodo effectivement pour pourrez rien différencier et isoler. Je le verrai bien comme ca... Il faut réfléchir à un montage avec relai qui se déclenche "que" s'il reçoit du jus par le cligno gauche et droit en même temps. C'est la solution à mon avis.
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyLun 7 Jan 2013 - 10:03
Question c*n.... c'est quoi un buzzer sur une moto???
Kit Warning Buzzer XTZ1200 230111
fireball77
fireball77
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyLun 7 Jan 2013 - 11:42
Le shéma est simple. 2 relais normalement ouverts. Le premier se ferme lorsqu'il recoit le jus par le cligno gauche, le deuxième se ferme lorsqu'il recoit du jus du cligno droit. Un montage buzzer dont l'alim passe par les deux relais. le buzzer ne sonne que lorsque les warning sont engagés et pas quand tu mets les clignos seuls... J'aimerai bien savoir combien ca coute en concess, parce que à fabriquer ca va vraiment pas chercher loin... :-)
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyLun 7 Jan 2013 - 23:24
Bin alors JMM, toujours pas de schéma ? ...
On attend camarade ;-) ...
JMM
JMM
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyJeu 10 Jan 2013 - 21:37
Je vais le demander au mécano dès réception des clignos
JMM
pascal81
pascal81
Moto : XTZ 1200 WORLDCROSSER
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyJeu 10 Jan 2013 - 22:58
Kit Warning Buzzer XTZ1200 170742
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyJeu 10 Jan 2013 - 23:27
Oki ;-) ...
Juste une piste que j'ai déjà mis en à l'épreuve sur un de mes circuits ... La plupart d'entre vous savez qu'une diode ne laisse passer le courant que dans un seul sens ;-) ...
Le but du jeu ici est de laisser passer le courant qui commande les clignots venant de la centrale clignotante des Warnings avec le buzzer, mais de ne pas laisser le courant remonter vers cette même centrale Warnings quand on actionne les clignots à partir de la commande des clignotants ;-) ...
Voici une diode :
Kit Warning Buzzer XTZ1200 Diode-de-redressement
un moyen mnémotechnique pour se souvenir comment elle fonctionne, suivez la flèche ;-) :
Kit Warning Buzzer XTZ1200 DIODE
De l'anode vers la cathode le courant passe, de la cathode vers l'anode, il ne passe pas pas ;-) ...
On peut symboliser l'anode par un "A" couché, il forme la flèche, la cathode est quant a elle symbolisée par un "K" la barre plus la pointe de la flèche ...
J'espère que je vous ai pas trop embrouillé avec mon explication ;-) ...
Donc JMM, ...
Si ton module Warnings a 2 sorties, une pour chaque côté de clignots, il faudra que tu intercales une diode forte puissance sur chaque fils de commande ...
Si cette commande est une masse il faudra que tu places la Kathode du côté de la centrale Warning, si au contraire c'est un +12 qui est envoyé par la centrale Warning, il te faudra mettre l'Anode du côté de la centrale Warnings ;-)
Si ta centrale warning n'a qu'une seule commande qui va piloter les 2 circuits gauche et droit en même temps, il te faudra procéder de la même manière avec une seule diode, voire 2 en parallèle pour absorber la puissance nécessaire au fonctionnement ;-) ...
Pour ce qui est de la puissance justement, La plupart des centrales clignotantes sont prévues pour fonctionner avec des ampoules de 21 à 23W et un voyant de 3.4W ...
Ca nous fait 2x23+3.4 = 49.4W soit 4.1 Ampère ... chaque diode devra supporter 4.1 A ... il faudra donc des diodes 5Ampères ;-) ...
N'oublies pas de poster le schéma ... je poserai les diodes dessus ;-) ...
Tchüss à tous ;-) ...
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 0:08
C'est ça ;-) ...
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 8:52
Kit Warning Buzzer XTZ1200 429990 oui merci derfu, j'avais déja tapé avant de demandé dans google: buzzer, buzzer moto, buzzer clignotant... mais j'ai pas trouver et surtout j'ai pas compris a quoi ça servait.
et ducoup tu le met ou(et a quoi ça sert)??? pasque c'est pas tout petit Kit Warning Buzzer XTZ1200 210464
Kit Warning Buzzer XTZ1200 Britai10
JMM
JMM
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 10:37
Merci pour ces infos Derfu
Je vais me rapprocher de mon mécano pour te faire passer les infos.
JM
JMM
JB
Moto : XTZ 1200 n° 1106
Ville ou région : Saverne
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 13:24
Pourquoi vous vous compliquez la vie ? Y a un interrupteur Warning. Faut se repiquer sur la sortie de cet interrupteur et commander un relais pour le buzzer. C'est tout.
nanard
Moto : TENERE 700. WR250R
Kms de ma moto : 3000. 10000
Ville ou région : rhone alpes
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 17:24
ON VEUT SAVOIR A QUOI CA SERT ???????
JMM
JMM
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 17:26
Bonjour
Le kit buzzer sur warning, c'est pour quand tu roule en cycle urbain :
Quand on met les warnings, ca buzze au rythme des clignotants.
JM
JMM
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 17:27
Du calme nanard Kit Warning Buzzer XTZ1200 210464 bon vu qu'ils veulent pas répondre, j'ai beaucoup googler pour trouver. En fait ça fait juste du bip bip quand t'a tes clignos alumés (surement pour pas les oublier comme en caisse)
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 17:28
ha ba jmm a répondu avant moi saispas
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 23:24
applaudit agenouille clapping trosuper content Kit Warning Buzzer XTZ1200 246821 premier ... Trop fort ce Clem' ;-D ...
MessageSujet: Re: Kit Warning Buzzer XTZ1200   Kit Warning Buzzer XTZ1200 EmptyVen 11 Jan 2013 - 23:28
On se complique la vie !?! ... avec 2 pôv' diodes en série sur le circuit !?! ...
C'est sûr que ta méthode est bien moins compliquée ... Du fil, un relais, le fixer quelque part, encore du fil, ... juste pour le buzzer ...
T'as raison JB, c'est beaucoup moins compliqué ;-) ...
» Warning sur 750XTZ
» Installation d'un Warning sur XTZ750
» Warning, barbelé au Jaffar!
» conseil pour ajout warning XTZ 750
» WAM : Warning Automatique Moto ... ERGO/ASAP Electronique
