pb d allumage xtz 1990 - Page 2 Emptypar SuperTiti Hier à 21:40
pb d allumage xtz 1990 - Page 2 Emptypar Joe644 Hier à 18:56
pb d allumage xtz 1990 - Page 2 Emptypar yop1025 Hier à 13:10
pb d allumage xtz 1990 - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
pb d allumage xtz 1990 - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
pb d allumage xtz 1990 - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
pb d allumage xtz 1990 - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
pb d allumage xtz 1990 - Page 2 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
pb d allumage xtz 1990 - Page 2 Emptypar Arni Dim 17 Nov 2024 - 14:06
pb d allumage xtz 1990 - Page 2 Emptypar Arni Dim 17 Nov 2024 - 13:13
pb d allumage xtz 1990 - Page 2 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
pb d allumage xtz 1990 - Page 2 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
pb d allumage xtz 1990 - Page 2 Emptypar Fredard Sam 16 Nov 2024 - 9:43
pb d allumage xtz 1990 - Page 2 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
pb d allumage xtz 1990 - Page 2 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
pb d allumage xtz 1990 - Page 2 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
pb d allumage xtz 1990 - Page 2 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
pb d allumage xtz 1990 - Page 2 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
pb d allumage xtz 1990 - Page 2 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
pb d allumage xtz 1990 - Page 2 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
pb d allumage xtz 1990 - Page 2 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
pb d allumage xtz 1990 - Page 2 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
pb d allumage xtz 1990 - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
pb d allumage xtz 1990 - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
pb d allumage xtz 1990 - Page 2 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
amortisseur boue filtre selle chaine pneus phare tuto synchro crash fourche feux réservoir longues embrayage rabaissement manuel essence arrière suis reglage galére garde huile vidange tenere
Le Deal du moment : -36%
254.99 €
MessageSujet: Re: pb d allumage xtz 1990   pb d allumage xtz 1990 - Page 2 EmptyMar 15 Jan 2013 - 23:44
cristi-mic a écrit:
Ça commence a ressembler a un problème de carburation/jeu aux soupapes. Ça marche bien a froid puis ça chauffe et ça commence...
Tin tu m'énerves toi !!! ... toujours à dire avant moi ce que j'allais dire !!! ... clin d\'oeil ...
Ouais, la piste de Cristian semble la plus plausible maintenant ...
Quand j'ai lu ton post, Franck, j'ai pensé aux plongeurs de starter ... y sont bien clipsés, pas trop bouffés à la pointe non plus ? ...
pb d allumage xtz 1990 - Page 2 Rassos10
franck40
Moto : xtz 750 de 1990
Ville ou région : landes
MessageSujet: Re: pb d allumage xtz 1990   pb d allumage xtz 1990 - Page 2 EmptyMer 16 Jan 2013 - 19:48
Bonsoir après nettoyage des cosses est inspection des câbles le problème reste inchangé... :( à combien s élève le réglage des jeu de soupape cher un professionnel ? Car c est bien quelque chose que je ne me sent pas capable de faire ! J ai quand même envi qu'elle reprenne la route cette moto .. Si j'ai bien compris une carburation défaillante peut faire dysfonctionner un allumage ?
MessageSujet: Re: pb d allumage xtz 1990   pb d allumage xtz 1990 - Page 2 EmptyMer 16 Jan 2013 - 22:57
franck40 a écrit:
Bonsoir, après nettoyage des cosses est inspection des câbles le problème reste inchangé... :(
A combien s'élève le réglage du jeu aux soupapes chez un professionnel ?
Entre 160 et 300€ ^^ ... tout dépend s'il y a des pastilles à changer ou non ^^ ...
Car c'est bien quelque-chose que je ne me sent pas capable de faire !
J'ai quand même envie qu'elle reprenne la route cette moto ...
Aps exactement, ...
si le mélange à enflammer est trop pauvre ou trop riche, c'est ce mélange qui aura du mal à s'enflammer ou qui continuera à brûler dans le pot ^^ ...
Si l'étincelle y est, c'est la carburation qui est en cause ... et ton problème de ralenti qui tantôt monte en sur régime à chaud me rappelle étrangement le souci que j'avais avec la mienne ^^ ...
Bilan de mon côté, jeux aux soupapes dans les tolérances, ... après un bon nettoyage des carbus tout est rentré dans l'ordre ...
Je te conseille de partir par là avant le jeu aux soupapes ... ça coute rien et c'est facile à faire ...
franck40
MessageSujet: Re: pb d allumage xtz 1990   pb d allumage xtz 1990 - Page 2 EmptyDim 24 Fév 2013 - 23:46
bonsoir a vous et merci derfu , tu a vu dans le mille , mon amis est venu il a retreci tres legerement l ecartement des electrodes aux bougies, nettoyer les cuves de carbu, les gicleurs a la souflette et miracle sa marche ! Smile que du bonheur !!j ai une derniere question : comment nettoyer un reservoir ? car proche de l ocean la rouille s incruste partt .. j en profite pour posé une petite photo Smile
pb d allumage xtz 1990 - Page 2 Img_0310
MessageSujet: Re: pb d allumage xtz 1990   pb d allumage xtz 1990 - Page 2 EmptyLun 25 Fév 2013 - 1:40
Hello, ...
Pour le réservoir y a plusieurs méthodes, mais si c'est juste pour le nettoyer, la rouille reviendra, de toute manière tous les réservoirs des 3LD rouillent ... le mieux que tu aies à faire est de laisser comme ça, de remplir le réservoir, le vider en position réserve au travers d'un filtre à café dans un entonnoir, l'avantage c'est que tu peux régler le débit avec les robinets ;-) ...
Ensuite, intercale un filtre à carburant pour automobile entre le réservoir et la pompe ... et basta ;-) ...
Tchüss @+ ;-) ...
» allumage???
» pas d'allumage
» Plus D’allumage....!
» Mon XTZ de 1990
» XTZ 750 de 1990
