Essai Pantalon Furygan TALIUS Emptypar SuperTiti Hier à 21:40
Essai Pantalon Furygan TALIUS Emptypar Joe644 Hier à 18:56
Essai Pantalon Furygan TALIUS Emptypar yop1025 Hier à 13:10
Essai Pantalon Furygan TALIUS Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Essai Pantalon Furygan TALIUS Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Essai Pantalon Furygan TALIUS Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Essai Pantalon Furygan TALIUS Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Essai Pantalon Furygan TALIUS Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Essai Pantalon Furygan TALIUS Emptypar Arni Dim 17 Nov 2024 - 14:06
Essai Pantalon Furygan TALIUS Emptypar Arni Dim 17 Nov 2024 - 13:13
Essai Pantalon Furygan TALIUS Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Essai Pantalon Furygan TALIUS Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Essai Pantalon Furygan TALIUS Emptypar Fredard Sam 16 Nov 2024 - 9:43
Essai Pantalon Furygan TALIUS Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Essai Pantalon Furygan TALIUS Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Essai Pantalon Furygan TALIUS Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Essai Pantalon Furygan TALIUS Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Essai Pantalon Furygan TALIUS Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Essai Pantalon Furygan TALIUS Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Essai Pantalon Furygan TALIUS Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Essai Pantalon Furygan TALIUS Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Essai Pantalon Furygan TALIUS Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Essai Pantalon Furygan TALIUS Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Essai Pantalon Furygan TALIUS Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Essai Pantalon Furygan TALIUS Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
garde selle réservoir feux boue amortisseur synchro huile phare filtre embrayage longues fourche arrière manuel vidange chaine suis reglage tenere galére crash pneus essence tuto rabaissement
Le Deal du moment : -30%
139.99 €
Yann
Yann
Moto : Triumph Tiger 1050
MessageSujet: Essai Pantalon Furygan TALIUS   Essai Pantalon Furygan TALIUS EmptyJeu 30 Déc 2010 - 9:18
Hello,
Nos essais continuants durant l'hiver, il faut savoir s'équiper en conséquence.
Voici notre dernier test, le pantalon toutes saisons Furygan Talius.
Furygan Talius
Bonne lecture
MessageSujet: Re: Essai Pantalon Furygan TALIUS   Essai Pantalon Furygan TALIUS EmptyDim 22 Mai 2011 - 0:04
je suis en train de tester ce pantalon que j'ai acheté sur le net , voici mes conclusions :
pour la taille j'ai pris du XXL qui correspond à un 46 , ça taille assez grand ce qui permet un peu d'aisance , la longueur conviendrait mieux à une personne de 1,80 à 1,85 m mais ça le fait quand même pour 1,75 m .
c'est quand même un sac , pas très près du corps ................
je l'utilise sans la doublure et il est nécessaire de mettre un pantalon de survet pour éviter que la membrane plastique soit en contact avec la peau sinon on se retrouve avec les jambes mouillées de transpiration car ce pantalon ne respire pas du tout ! ( inutilisable en dessus de 15°c )
pire , il n'est pas étanche du tout au niveau de l'entrejambe , dès que l'eau coule un peu sur la selle ça traverse de suite , j'ai testé ce jour sous une pluie continue mais pas très forte , donc dès que ça dépasse le stade de crachin vaut mieux mettre son pantalon de pluie .
la doublure amovible parait chaude mais je n'ai pas testé , peut être qu'il est efficace dans le froid .
bref , moi qui cherchait un pantalon à tout faire , je suis vraiment déçu de ce pantalon qui m'oblige à mettre un survet dessous ( qui est soit trempé de transpiration ou de pluie le soir à l'étape ) et un pantalon de pluie par dessus .
conclusion : j'ai perdu 90 euros
cry
MessageSujet: Re: Essai Pantalon Furygan TALIUS   Essai Pantalon Furygan TALIUS EmptyDim 22 Mai 2011 - 9:15
en plus un survet trempé ....
perso je n'ai que des sur pantalons. Après en avoir essayé des tripotés, je me suis arrêté au Bering easy. C'est le seul qui reste étanche plusieurs années malgré l'utilisation intensive en RP, les pliage dans le topcase, et environ 16000 km par ans (pas tout le temps sous la pluie, heureusement)
Il se met sur le bord de la route , rapidement , et sans enlever les bottes...
mais c'est .... un sur pantalon....
MessageSujet: Re: Essai Pantalon Furygan TALIUS   Essai Pantalon Furygan TALIUS EmptyVen 17 Juin 2011 - 19:51
à propos de surpantalon , j'ai un pantalon de pluie bering houston , épais , doublé avec une poche bien pratique sur la cuisse , je le mettais presque tous les jours en irlande pour rester au sec vu que mon pantalon soit disant étanche ne l'était pas !
avec les 2 pantalons j'étais bien au sec .
par contre quand je l'ai mis par dessus le jean , j'ai eu la désagréable surprise d'avoir les burnes au frais et bien trempées après quelques mn de bonne pluie !
reste en sa faveur le côté pratique avec ses fermetures éclair qui remontent jusqu'à la ceinture et qui permettent de l'enfiler très facilement bottes aux pieds .
pour conclure , je n'ai jamais trouvé un seul pantalon de pluie étanche , étrange non ? j'ai commencé avec des vêtements de jardin , puis des combardes , des pantalons légers de rando décath et maintenant des futals moto de marque ......... je prend toujours la flotte au niveau de la partie en contact avec la selle .
je vais donc tenter de le recouvrir d'imperméabilisant en spray ..........!
MessageSujet: Re: Essai Pantalon Furygan TALIUS   Essai Pantalon Furygan TALIUS EmptyVen 17 Juin 2011 - 20:41
oui, bizarre ....... j'ai un vieux pantalon de pluie, que j'ai acheté il y a plus de 20 ans ........ et il est étanche, il est moche, mais j'ai les burnes au sec !
Essai Pantalon Furygan TALIUS Barre_10
Essai Pantalon Furygan TALIUS Luba10
MessageSujet: Re: Essai Pantalon Furygan TALIUS   Essai Pantalon Furygan TALIUS EmptySam 18 Juin 2011 - 12:29
pourtant je les prends assez amples de manière à ne pas étirer les coutures au niveau de l'entrejambe .
MessageSujet: Re: Essai Pantalon Furygan TALIUS   Essai Pantalon Furygan TALIUS EmptyMer 23 Jan 2013 - 11:32
perso, mon pantalon pluie ne m'a tenu qu'une fois les burne au sec(dans le magasin lors de l'essai) dès la première pluie, l'eau stagnante au niveau des burnes lorsqu'on est assis en selle...me les hydrate rapidement!
» Essai Furygan VERTIGO
» Essai de la veste Furygan Commando
» Essai "Gants" Furygan Land Gel
» Essai pantalon iXS Nairobi
» Essai du pantalon SCOTT Cargo TP
