Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar SuperTiti Hier à 21:40
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar Joe644 Hier à 18:56
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar yop1025 Hier à 13:10
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar Arni Dim 17 Nov 2024 - 14:06
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar Arni Dim 17 Nov 2024 - 13:13
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar Fredard Sam 16 Nov 2024 - 9:43
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
chaine pneus feux suis manuel rabaissement huile fourche synchro embrayage longues phare tuto selle crash galére amortisseur filtre garde essence vidange boue arrière réservoir tenere reglage
Flash22
Flash22
Moto : Yam 660 XTZ 2011
Ville ou région : Côtes d'Armor BRETAGNE
MessageSujet: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 25 Nov 2012 - 16:53
Bonjour a Tous,
j'ai vu sur les différants sujets qu'il etait possible de boucher le Systeme anti-pollution... (plus de pétarades)
qu'en est-il de l'effet sur la sonde Lambda et le Catalyseur ? (risque d'encrassement)
je souhaite boucher L'anti pollution et monter des Leovince sans catalyseur...
j'ai vu sur OTR un système d'elimination de sonde Lambda... utilité ?
Merci d'avance pour vos réponses !Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 2120
Flash22
Flash22
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 25 Nov 2012 - 20:42
Personne ?Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 312252
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyLun 26 Nov 2012 - 0:18
Alors en gros et pour faire simple, tu peux boucher l'antipol tranquillou-billou, ton catalyseur s'encrassera de toutes manières, et ta sonde est juste là pour réguler ton mélange air-essence en fonction de ce qu'elle renifle.
Si tu lui fais renifler trop pauvre ou trop riche, elle régulera l'injection en conséquence, c'est fait pour.
Mais pour faire encore plus simple, tu débrides le bouzin avec un shunt sous selle, tu montes un PC5 et roule ma poule. C'est ce que j'ai fait, pétarades zéro et sondes déconnectées, ça consomme un poil plus et c'est tout.
Flash22
Flash22
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyLun 26 Nov 2012 - 11:04
Merci pour ta réponse !Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 3199447018
le truc c'est que je ne veu pas de Power Commendeur...
juste boucher l'anti pollution , pots Leovince , Filtre KN et Bougie Iridium...
Mais vu qu'en bouchant le système anti-pollution ca doit changer les infos que reçoit la sonde Lambda... est-ce génant ? Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 49290
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyLun 26 Nov 2012 - 17:33
Oublie mon précédent post, j'avions pas vu que c'était pour une 660, j'ai une 1200, pas la même chose.
Dsl... Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 494680
meche
meche
Moto : xtz 660
Kms de ma moto : 31 000
Ville ou région : mouries
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptySam 11 Jan 2014 - 13:44
bon voila j arrie de chez yam avignon ils ne veulent pas me virer se putain de truc de la moto!!!d apres eux aucune influence sur la duree de vie du moteur , moi j ai des doutes car les soupapes et l echappement sont pas prévus pour ca. je suis deg qu ils ne veulent le faire et la bonne excuse s est les pots leo vince , qu ils aillent a lourdes tous!!!
MG
MG
Moto : XTZ1200 / XTZ1200E
Pneu AV/AR : Tourance
Ville ou région : Essonne
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptySam 11 Jan 2014 - 19:32
quel l'intérêt de virer cela? pour les pétarades et alors? cela fait quoi? sur la 660xtz j'ai fait 88000 le pb que j'ai eu ne vient pas du pot etc...
le de puissance à mon avis négligeable, sur la 660 c'est surtout le gain de poids qu'il faut travailler le rapport poids puissance sera bien plus favorable...
MG
Pneu AV/AR : toujours sale
Ville ou région :
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptySam 11 Jan 2014 - 20:32
MG
Petit joueur
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 51a18fed33269_zps7442a52a
meche
meche
Moto : xtz 660
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptySam 11 Jan 2014 - 22:05
si tu vire ca apparament elle petarade bcp moins entre deux et trois miles tours ! enfin si yama veut te le faire lol je vais le faire moi du coup!
meche
meche
Moto : xtz 660
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptySam 11 Jan 2014 - 22:06
http://www.off-the-road.de/en/XT-660Z/Engine-tuning/AGR-blanket-kit-XT-660.html
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptySam 11 Jan 2014 - 22:34
j'ai bouché le mien avec un bout de scotch dans la boite a air, en 5mm
meche
meche
Moto : xtz 660
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptySam 11 Jan 2014 - 22:53
a ouais bonne conbine finalement et tout c*n !!! et s est efficace franck?
MG
MG
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 12 Jan 2014 - 0:08
entre 2 & 3OOO trs ce n'est pas le bon régime pour un mono au même titre que 8-9000 trs non plus? donc je ne vois tus pas l'intérêt ??
MG
meche
meche
Moto : xtz 660
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 12 Jan 2014 - 8:11
qaund tu descens les vitessestu es un peut oblie de passer se se regine moteur et la tu as comme des coup de fusil qui se produisent
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 12 Jan 2014 - 9:42
MG
Petit joueur
Oh put... le lkilométrage... Tu peux nous faire un retour d'expérience sur les ennuis que tu as eus sur la durée ? clin d\'oeil
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 12 Jan 2014 - 9:46
J'avais trouvé le truc en voulant imiter ce que j'avais fait sur mon 650 FMX, sauf que l'accessibilité n'était pas évidente pour boucher le tuyau avec une bille. J'ai d'abord obturé le trou avec une sorte de bouchon, et finalement, j'ai mis un bout de scotch d'électricien (les rouleaux de toutes les couleurs que tu trouves partout). Ca n'a pas bougé depuis, et il n'y a plus de coups de fusil... parfois quelques rares pétarades, mais pas gênantes.
meche
meche
Moto : xtz 660
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 12 Jan 2014 - 19:40
j ai pas la moto a la maison en se moment elle est chez yam sinon j aurais jette titioeil!!! il n y que se trou a boucher qui se trouve donc dans la boite a air qu il faut que j ouvre et un tuyeau qui part de se trou jusqu entre les deux tube d echappement?
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 12 Jan 2014 - 20:02
Oui, ouvre la boîte à air côté droit, le trou est à droite :
https://www.super-tenere.org/t6293-petarades-leovince-sur-660
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 12 Jan 2014 - 20:35
ben oui ... j'ai pas de moyen de comparaison, mais mais je pense que ça doit boucher comme d'une autre façon...
(desolé de repondre si tard... j'avais pas vu ta question)
XT=tracteur
XT=tracteur
Moto : XTR 125; XTZ 660 Blue 2013; quad Bruin 350 ultramatic
Kms de ma moto : 3300
Pneu AV/AR : en caoutchouc et latex
Ville ou région : Aquitaine Oloron Ste Marie
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyLun 13 Jan 2014 - 23:59
Salut à toi!
Moi j'ai mis une bille dans la durite courte ou vient se brancher un tuyau genre inox qui lui arrive entre les 2 tuyau d'échappement. Une fois ça bouché c'est IMPECCABLE !!!! sa n'a plu rien avoir !!!! Par contre y a un truc auquel je ne comprendrai jamais, c'est la sonde lambda, elle n'auras plus cet air amené à l'échappement donc je sais pas ce quelle fait  Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 49290 . En tout cas ça toune pareil qu'avant mais sans ces coups de fusils .
XT = tracteur : c'est molo mais costaud ...
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? Images13
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyMar 14 Jan 2014 - 7:26
T'a sonde lambda corrige sur ton injection, je suis pas un pro de la mécanique  mais il me semble que c'est elle qui t'appauvrie le mélange en altitude par exemple, car elle voit que ton mélange est trop riches et que les gaz sont non bullés (je sait pas si t'es déjà monté avec un djebel a carbu sans sonde lambda au sommet du galibier, mais c'est un désastre) Le tuyau que tu as boucher est simplement une mise à l'aire  qui facilite l'inflammation de l’essence non brûlé (ce qui fait les détonations)
Donc si tu veux essaye de viré ta sonde (je suis même pas sur que t'on alimentation fonctionnera), mais la pauvre ne fait que du bien a ta machine.
Par contre, ce que tu peux faire as ce niveau, c'est refaire une programmation d'injection (la faire flashé, ou power commander), sur nos trapanels je suis pas sur que sa serve a quelque chose.
Si je raconte des grosses conneries reprenez moi, car je sait que par exemple sur les flats, on peut facilement shunté cette sonde car le mélange est réglé trop pauvre d'origine.
Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 230111
Ville ou région :
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyMar 14 Jan 2014 - 20:41
Obturateur du système de la première heure, j'ai fais le Brenner en septembre avec armes et bagages sans ressentir de faiblesse moteur.
Ville ou région :
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 21 Sep 2014 - 17:11
J'ai monté un "O2 sensor eliminator" Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 49290  qui se monte en place du contacteur de la sonde lambda, je fais les essais cette semaine, je vous tiens au jus.
http://www.ebay.com/itm/o2-Oxygen-Sensor-Eliminator-For-Yamaha-YZF-R6-2006-2013-more-/221413143718?pt=UK_Motorcycle_Parts&hash=item338d4074a6
Ville ou région :
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 28 Sep 2014 - 14:36
Bonjour à tous
Voilà donc une semaine que j'ai supprimé ma sonde Lambda remplacé donc par le O2 S.E.....
Au démarrage à froid comme à chaud,  il n'y a aucune modification, ni à l'oreille ni sur le tableau de bord.
A l'usage, il y a comme un ressenti de plus grande souplesse, une sensation que la chaine est parfaitement graissée et tendue. le coté rugueux du mono à disparu affraid affraid et les pétarades sont quasi inexistante.
Le ralenti est passé de 1300 t/m à 1000 t/m les reprises se font en rondeur avec une accélération  plus cossue qu'à l'accoutumé  passé 5000 t/m
Le coté marteau piqueur de la zone 2500/3000 en 4eme puis 5eme se passe tout seul.
Pour tout ceux qui comme moi on changé leur silencieux par un modèle bruyant performant  Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? 49290 n'hésitez pas à virer la sonde lambda qui ne sert qu'à mal faire fonctionner nos monos pour soit disant moins polluer.
Pour récapituler, j'ai monté sur la 660: bougie iridium,  DNA stage 2, filtre KN, pot Exan, O2 sensor éliminator. cette combinaison fonctionne bien mieux que l'origine et reste pérenne pour la fiabilité moteur
fred
LaurentXTZ
LaurentXTZ
Moto : 1200 XTZ
Ville ou région : Languedoc
MessageSujet: Re: Systeme Anti Pollution - Sonde Lambda - Catalyseur ???   Systeme Anti Pollution - Sonde Lambda - Catalyseur ??? EmptyDim 28 Sep 2014 - 15:38
Merci Fred, pour ce compte rendu.
Les retours étant les mêmes concernant la 1200, je vais en commandrer.
Est il nescessaire de virer les sondes et remplacer par les bouchons ?
Laurent.
» suppression sonde Lambda
» shunt sonde lambda xtz 1200
» boucher le dispositif anti-pollution
» Anti-pollution et filtre à air ouvert : difficulté à démarrer
» Une histoire de catalyseur
