Entretien fourche (huile, joints et ressort) Emptypar oustad Hier à 20:14
Entretien fourche (huile, joints et ressort) Emptypar SuperTiti Hier à 13:04
Entretien fourche (huile, joints et ressort) Emptypar oeuf Hier à 10:11
Entretien fourche (huile, joints et ressort) Emptypar oeuf Hier à 10:03
Entretien fourche (huile, joints et ressort) Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Entretien fourche (huile, joints et ressort) Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Entretien fourche (huile, joints et ressort) Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Entretien fourche (huile, joints et ressort) Emptypar Arni Dim 17 Nov 2024 - 14:06
Entretien fourche (huile, joints et ressort) Emptypar Arni Dim 17 Nov 2024 - 13:13
Entretien fourche (huile, joints et ressort) Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Entretien fourche (huile, joints et ressort) Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Entretien fourche (huile, joints et ressort) Emptypar Fredard Sam 16 Nov 2024 - 9:43
Entretien fourche (huile, joints et ressort) Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Entretien fourche (huile, joints et ressort) Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Entretien fourche (huile, joints et ressort) Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Entretien fourche (huile, joints et ressort) Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Entretien fourche (huile, joints et ressort) Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Entretien fourche (huile, joints et ressort) Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Entretien fourche (huile, joints et ressort) Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Entretien fourche (huile, joints et ressort) Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
galére manuel fourche tenere pneus vidange crash reglage feux synchro chaine garde boue suis embrayage selle réservoir essence tuto filtre huile rabaissement phare longues arrière amortisseur
-25%
749.99 € 999.99 €
le marin
le marin
Kms de ma moto : 13000
Ville ou région : Gironde
MessageSujet: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptySam 9 Oct 2010 - 9:44
Salut a tous xtz-man (voir girl)
Je souhaite entretenir mes tubes fourche donc
-Changer l'huile ainsi que les joints éventuel
-changer les ressorts
Le problème c'est que je n'ai jamais fait cela et je sais pas comment m'y prendre
est-ce possible d'avoir un tutoriel la dessus ?
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptySam 9 Oct 2010 - 14:01
regarde dans ma signature tu as la base.
deja il faudra que tu te fasse un outils, pour pouvoir démonter la vis creuse en fond de fourche.
Les ressorts, a moins qu'ils aient beaucoup de bornes, il ne semblerait pas obliger de les changer sauf si tu fais un upgrade
le marin
le marin
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 10 Oct 2010 - 9:25
L'outils il te permet de sortir quoi ?
Pas besoin de l'outil pour sortir les ressorts ?
Les ressorts je les changes pour quel plonge moins
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 10 Oct 2010 - 12:32
le tarage est trop mou d'origine, met des cales de précontraintes (30mm c'est bien)
tu veux changer tes spy, tu es obliger de démonter le fameux écrou :lol:
le marin
le marin
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyVen 15 Oct 2010 - 9:27
erf ok merci
Je vais pas pouvoir du coup faire ca moi même
il y a un petit garage a coté de chez moi
Il me change les ressorts main d'œuvre compris pour 240 euros
Le marin
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyVen 15 Oct 2010 - 20:07
euhh et il te met quoi comme ressorts???
didiercoca
didiercoca
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 8 Jan 2012 - 21:45
c est quoi comme outil???
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 8 Jan 2012 - 21:53
un écrou de 30 (cléf) souder sur une tige en fer .....en ...T...
bien sur l'écrou en bas du T longueur 1000?..
didiercoca
didiercoca
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 8 Jan 2012 - 21:56
longueur 1metre? oulalala c est du serieux comme outil!
bon quand j y serai je verrai bien!
merci du renseignement
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 8 Jan 2012 - 21:58
te fait une photo demain.du T..... simple ..zérororos...tu dois trouvez...
sergeb
sergeb
Moto : yamaha 750xtz super tenere 3LD-000267
Ville ou région : Proximité de TOULOUSE haute-garonne
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 18 Jan 2012 - 11:39
Salut Tabar,
Où est la tof???
sergeb
sergeb
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 18 Jan 2012 - 11:43
Salut Flo44?
'Scuse, comment ont fait pour voir la base? pas su trouver
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 18 Jan 2012 - 18:09
heuuuu!!!s'cuse je me suis tromper....
Entretien fourche (huile, joints et ressort) T_00210mon SDS...Smile
Entretien fourche (huile, joints et ressort) T_00310un écrous de 30..
Entretien fourche (huile, joints et ressort) Humou210
Entretien fourche (huile, joints et ressort) T_00410
c'est pas un truc pour nain,,,heuu!!!scratch ..j'ai dis une connerie??????.pale .........Entretien fourche (huile, joints et ressort) 64068
sergeb
sergeb
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyJeu 19 Jan 2012 - 10:34
Salut Tabar et les autres
Joli le bestiau, tu l'engraisses pour un futur paté ou une daube provencale ? Entretien fourche (huile, joints et ressort) 165632
Concernant l'outil, je suppose que c'est la périphérie (et non pas le pas de vis ) de l'ecrou de 30 qui sert au démontage.
http://www2.yamaha-motor.fr/2010/ypec/?prodCategory=10
Sur le site Yam , c'est la piece 9 qu'on dévisse?
csandjo
csandjo
Moto : 660 tenere 2008
Ville ou région : porto-vecchio
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMar 26 Juin 2012 - 22:15
apres diagnostique je m'aperçoit que ma fourche n'a plus d'huile, les spy tres certainement a changer, seul probleme les bagues sont arrivées a leur terme et j'ai des rayures sur mes tubes ! j'hesite a changer spy, bagues...sans changer les tubes pour ne pas a recommencer le tout et detruire les spy neuf ect... quel'qun 'un a deja eu ce genre de rayures ? secondo le prix des tubes 290 euros pieces 580 les deux, j'en ai trouvé n adaptable a 160 euros pieces, quelqu'un en a deja essayer ? merci
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMar 26 Juin 2012 - 22:37
nous on vends deux tube complet bonne etat!!!!!Entretien fourche (huile, joints et ressort) 49290
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 27 Juin 2012 - 5:41
a 80 euros tu peux avoir une fourche complette d'occaseEntretien fourche (huile, joints et ressort) 704842 .......
a remonter......Very Happy le coin coin!!!!
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 27 Juin 2012 - 8:14
ou chez nous!!!!Entretien fourche (huile, joints et ressort) 49290
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 27 Juin 2012 - 12:27
ben vouiEntretien fourche (huile, joints et ressort) 49290
csandjo
csandjo
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyVen 29 Juin 2012 - 18:12
combien peu couter une fourche d'occas nikel pour mon 660 de 2008 ?
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptySam 30 Juin 2012 - 14:02
jojo a de la pièces de 750Entretien fourche (huile, joints et ressort) 49290
Entretien fourche (huile, joints et ressort) Barre_10
csandjo
csandjo
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMar 17 Juil 2012 - 22:56
pour demonter fourche du 660 tenere de 2008 la longue cle c'est bien un boulon de 30 ?
» Changer les joints SPY de fourche.
» Ressort de fourche
» Niveau huile de fourche
» ressort de fourche
