Modification richesse injection ? Emptypar SuperTiti Hier à 21:40
Modification richesse injection ? Emptypar Joe644 Hier à 18:56
Modification richesse injection ? Emptypar yop1025 Hier à 13:10
Modification richesse injection ? Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Modification richesse injection ? Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Modification richesse injection ? Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Modification richesse injection ? Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Modification richesse injection ? Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Modification richesse injection ? Emptypar Arni Dim 17 Nov 2024 - 14:06
Modification richesse injection ? Emptypar Arni Dim 17 Nov 2024 - 13:13
Modification richesse injection ? Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Modification richesse injection ? Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Modification richesse injection ? Emptypar Fredard Sam 16 Nov 2024 - 9:43
Modification richesse injection ? Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Modification richesse injection ? Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Modification richesse injection ? Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Modification richesse injection ? Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Modification richesse injection ? Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Modification richesse injection ? Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Modification richesse injection ? Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Modification richesse injection ? Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Modification richesse injection ? Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Modification richesse injection ? Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Modification richesse injection ? Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Modification richesse injection ? Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
embrayage essence manuel réservoir suis arrière synchro feux huile pneus chaine crash selle reglage rabaissement galére filtre amortisseur boue garde fourche longues vidange phare tuto tenere
Steph06
Steph06
Moto : SUPER TENERE XTZ 1200
Ville ou région : 06130 Grasse
MessageSujet: Modification richesse injection ?   Modification richesse injection ? EmptyLun 17 Oct 2011 - 16:56
Salut à tous,
je viens de commander un leovince carbone et un de mes amis m'a demandé si du coup, je ne devais pas modifier la richesse de l'injection !
sa question est pas idiote, on peut penser que le leovince (ou autres) est plus "libre" que le silencieux d'origine et que si il laisse passer plus d'air, il faudrait compenser par une augmentation de la richesse d'injection.
je me doute que ça fonctionne sans toucher les réglages mais si on veut garder une moto bien réglé ?
des retours sur cette question ?
merci, @+
ALDR (G...X)
ALDR (G...X)
Moto : G 650 X Country
Ville ou région : Orléans
MessageSujet: Re: Modification richesse injection ?   Modification richesse injection ? EmptyLun 17 Oct 2011 - 17:50
La solution est peut-être dans le module Accelerator, comme celui que j'ai monté sur ma BM. Il enrichit essentiellement le mélange dans les phases d'acceleration, ce qui donne plus de moelleux et, un peu, de coffre dans les bas et moyens régimes, ensuite, la sonde lambda prend théoriquement la main et rétabli le ratio stochiomètrique établi pour la norme Euro 3, se qui garanti une conso contenue à vitesse stabilisée.
Ca tombe bien, le fabricant vient d'en lancer un pour la 1200 ST!
ACCELERATOR
Modification richesse injection ? Inscri11
Steph06
Steph06
MessageSujet: Re: Modification richesse injection ?   Modification richesse injection ? EmptyLun 17 Oct 2011 - 18:22
ACCELERATOR
ça a l'air de le faire...
mais il me semble avoir vu qu'on avait accès aux modifs du CO directement sur l'ordi de bord ?
c'est pas la même chose ?
la il va nous falloir un expert en mécanique Modification richesse injection ? 704842
ALDR (G...X)
ALDR (G...X)
MessageSujet: Re: Modification richesse injection ?   Modification richesse injection ? EmptyLun 17 Oct 2011 - 18:37
Par ailleurs, le LéoVince libéré n'est pas tout; Il s'agit de savoir si l'admission sera libérée elle aussi (filtre K&N, etc..)
Steph06
Steph06
MessageSujet: Modification richesse injection ?   Modification richesse injection ? EmptyMar 18 Oct 2011 - 10:50
pour l'instant, je n'ai commandé que le silencieux, comme beaucoup d'autres..
j'ai fait qq recherches sur le web :
http://xjrteam.forumsdediscussions.com/t856-reglage-richesse
http://www.binano.fr/viewtopic.php?t=19847
je ne sais pas si c'est transposable sur le XTZ1200 mais d'autres se posent la question aussi...sans vraiment apporter de réponse "unique" d'ailleurs.
le mieux c'est encore peut être de la faire régler par un spécialiste ; ce qui est sur c'est que le réglage d'origine correspond au silencieux d'origine et que ce réglage correspond aussi aux normes de pollution !!
à suivre...
sonylegitan
sonylegitan
Ville ou région : LILLE NORD
MessageSujet: Re: Modification richesse injection ?   Modification richesse injection ? EmptyMar 18 Oct 2011 - 18:49
Le Leovince n'engendre pas la suppression de la sonde lambda donc rien à changer.
Steph06
Steph06
MessageSujet: Re: Modification richesse injection ?   Modification richesse injection ? EmptyMer 19 Oct 2011 - 10:21
mon cons m'a confirmé cet avis, merci pr ta réponse !!
» vis de richesse 600 xtz
» Vis richesse
» Injection et +
» Reglage richesse
» réglage richesse
