POIGNEES CHAUFFANTES - Page 5 Emptypar SuperTiti Hier à 21:40
POIGNEES CHAUFFANTES - Page 5 Emptypar Joe644 Hier à 18:56
POIGNEES CHAUFFANTES - Page 5 Emptypar yop1025 Hier à 13:10
POIGNEES CHAUFFANTES - Page 5 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
POIGNEES CHAUFFANTES - Page 5 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
POIGNEES CHAUFFANTES - Page 5 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
POIGNEES CHAUFFANTES - Page 5 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
POIGNEES CHAUFFANTES - Page 5 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
POIGNEES CHAUFFANTES - Page 5 Emptypar Arni Dim 17 Nov 2024 - 14:06
POIGNEES CHAUFFANTES - Page 5 Emptypar Arni Dim 17 Nov 2024 - 13:13
POIGNEES CHAUFFANTES - Page 5 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
POIGNEES CHAUFFANTES - Page 5 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
POIGNEES CHAUFFANTES - Page 5 Emptypar Fredard Sam 16 Nov 2024 - 9:43
POIGNEES CHAUFFANTES - Page 5 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
POIGNEES CHAUFFANTES - Page 5 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
POIGNEES CHAUFFANTES - Page 5 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
POIGNEES CHAUFFANTES - Page 5 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
POIGNEES CHAUFFANTES - Page 5 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
POIGNEES CHAUFFANTES - Page 5 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
POIGNEES CHAUFFANTES - Page 5 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
POIGNEES CHAUFFANTES - Page 5 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
POIGNEES CHAUFFANTES - Page 5 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
POIGNEES CHAUFFANTES - Page 5 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
POIGNEES CHAUFFANTES - Page 5 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
POIGNEES CHAUFFANTES - Page 5 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
garde crash amortisseur vidange synchro tenere phare embrayage selle arrière essence galére suis boue tuto pneus manuel réservoir fourche longues chaine reglage filtre huile rabaissement feux
-17%
249 € 299 €
Laurents
Laurents
Moto : XTZ1200 Mat grey 2014
Kms de ma moto : 26000
Pneu AV/AR : Metz Tourance NEXT
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 13:09
Bon, merci à tous pour vos retours.
J'ai commandé les Technoglobe Gold ce matin.
Je ne suis pas encore prêt pour les manchons... Ni à mettre 300€ de plus dans les Yam.
Je pense qu'avec les gants chauffants + les PC cela devrait aller.
Juste une questions aux élec du forum :
J'ai trouvé le connecteur réservé aux PC yamaha (+ après contact, à priori sur les fusibles éclairage ?) et je vais bien sûr l'utiliser proprement avec sa fiche mâle qui sert de bouchon actuellement.
Par contre, dois-je alimenter les PC sur la batterie (avec un relai) ou puis-je brancher le tout directement sur la prise disponible ??? Je n'arrive pas à voir l'ampérage maxi de ce connecteur...
Les PC font à priori 50 watts, donc un peu plus de 4 ampères...
Merci par avance !
tonio29
tonio29
Moto : BMW R 1200 GS LC
Kms de ma moto : 28000 kms
Pneu AV/AR : Anakee 3
Ville ou région : bretagne
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 13:19
tu as un tuto sur le forum qui explique super bien comment installer les pc technoglobe, je m'en suis servi pour installer les miennes! j'ai réussi et pourtant j'ai 2 mains gauches!!!
Kms de ma moto : 140000
Pneu AV/AR : SCORPION
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 15:06
Tu peux brancher directement les PC sur cette prise, elle est faite pour.
Laurents
Laurents
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 15:28
@ tonio29 :
Oui, merci ! Je l'avais bien consulté mais à priori, sur son tuto, Jluc n'utilisait pas les connecteurs dédiés. Dans ce cas il est effectuivement impératif d'utiliser un relai pour dissocier la commande de l'alimentation à brancher directement sur la batterie.
@ Cfrançois
Cool, merci Cfrançois ! Voilà la réponse que j’espérais !
Bon, dans le pire des cas, je grille un fusible... 50 watts, vu la section des fils, je vais pas fondre le faisceau !
Merci à tous les 2.
Je reçois les PC cette semaine. Montées ce we si tout se passe bien !
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 15:39
Un petit conseil pour le montage des PC, on en a probablement déjà parlé, mais le redire ne coûte rien !! le diamètre du guidon doit être augmenter pour que les nouvelles poignées tiennent bien (qu'elles ne tournent pas surtout), pour cela il faut mettre du ruban adhésif autour du support, il faut prendre du ruban large et épais, mais pas tramé car il ne glisse pas bien, et le disposer en long sur le tube, de manière à ce qu'il n'y ai pas de changement d'épaisseur sur la longueur à enfiler pour ne pas se retrouver à mi-course avec l'impossibilité d'aller au bout et d'être coincé à ne plus pouvoir faire marche arrière !! Ensuite il vaut mieux mettre une couche de moins et ressortir la PC pour remettre une couche que le contraire.
Laurents
Laurents
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 15:49
J'ai du scotch américain, cela fera l'affaire je pense.
En plus, côté gauche, cela isole un peu la poignée du métal du cintre.
C'est aussi ce qui me fait pencher pour le scotch plutôt que pour la colle néoprène.
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 16:16
C'est ce genre de scotch que j'ai utilisé. Comme les PC se dilatent avec la chaleur, tu peux les laisser au soleil un bon moment avant de les monter, ça sera plus facile (il ne faut pas non plus attendre l'hiver pour ça)
Pneu AV/AR : toujours sale
Ville ou région :
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 20:23
Grosse promo chez LOUIS.de sur les SAÏTO II à 34,95€ ( longueur 130mm )
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 20:45
Les SAITO à 34€95, ce n'est pas cher, par contre pour avoir eu des Saito sur ma moto précédente, je trouve que la température n'est pas aussi équilibrée entre droite et gauche que les tecnoglobe.
Ville ou région :
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyLun 22 Sep 2014 - 21:11
Il suffit d'isoler la poignée gauche du guidon pour retrouver l'équilibre
Laurents
Laurents
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyVen 3 Oct 2014 - 10:28
Laurents a écrit:
@ tonio29 :
@ Cfrançois
Merci à tous les 2.
Les poignées Technoglobe Gold sont posées.
Pose :
Facile, cela a été plié en 1h. Pas de démontage à par le flanc droit.
J'ai suivi le cheminement des faisceaux électriques. C'est propre. Aucun souci de ce côté.
Finalement, je n'ai mis qu'une bande de sotch américain sur la poignée droite et ajouté un peu de colle.
Il faut prendre garde à l'orientation des poignées. L'interrupteur de la poignée gauche peut gêner. Il faut le centrer entre la commande de clignos et le phare.
Raccordement :
Je me suis branché directement sur la prise PC disponible. J'ai donc utilisé la prise mâle qui sert de bouchon et y ai inséré 2 connecteurs avec leur joint d'étanchéité. C'est nickel, comme d'origine !
Test :
Pour l'instant, pas encore de grand froid. Je les utilise en position 2 (sur 5) pour les roulages au petit matin et tard le soir, avec les gants d'été. Elles diffusent une douce chaleur. J'ai rapidement testé la position 5, ça semble chauffer très fort.
Chaleur équilibrée entre les 2 côtés.
Préhension impeccable, elles "accrochent" un peu plus que les origine. Elles sont également d'un diamètre légèrement plus important mais c'est plutôt agréable.
La commandes est pratique et accessible du pouce. Le voyant bien visible permet de connaitre la position d'un coup d'oeil. Elles s'arrêtent à la coupure de contact. Au redémarrage, une pression sur le bouton et on retrouve la position de chauffe précédente.
Voilà, pour l'instant, je suis satisfait !
leblaireau
leblaireau
Moto : XTZ1200
Ville ou région : COULOMMIERS
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyVen 3 Oct 2014 - 11:52
Laurents, tu dis plus haut que tu vas combiner gants chauffants et PC.
Pour utiliser des gants chauffants, je les trouve suffisants, je ne vois pas en quoi les PC seront utiles en même temps ?
Laurents
Laurents
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyVen 3 Oct 2014 - 12:19
Je suis un grand frileux. J'ai une circulation très moyenne dans les doigts et j'ai facilement l'onglée. C'est très douloureux et très dangereux à moto...
D'autre part, sur les longs trajets, les gants n'ont pas suffisamment d'autonomie (testé sur un A/R Narbonne - Aix cet hiver, ma main droite s'en souvient... La gauche a été épargnée car elle restait sur la sortie d'air chaud du radiateur !).
Et de plus, les poignées sont toujours disponibles : c'est pratique en automne ou au printemps lorsque l'amplitude thermique entre la nuit et le jour peut atteindre 15° !
Je trouve donc que les 2 sont complémentaires.
Voilà, tu sais tout de ma vie !
Sinon, je suis très content des gants chauffants aussi (des V quattro, impeccables, étanches et chauds même sans le chauffage et pas trop gros avec une bonne sensibilité des commandes).
leblaireau
leblaireau
Moto : XTZ1200
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyVen 3 Oct 2014 - 13:22
Ah oui, maintenant je crois me souvenir que tu expliquais ça quelque part, à moins que ce soit quelqu'un d'autre, je n'ai pas relu tout le post.
Mes gants (gerbing) sont directement branchés sur la batterie, c'est pour ça que j'ai pas pensé à l'autonomie.
En tout cas, vu tes problèmes avec le froid, je comprends mieux.
rubinho
rubinho
Moto : XTZ660 2013 sans ABS
Ville ou région : 80
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyMer 28 Jan 2015 - 10:01
Pour ma part, satisfait aussi du pouvoir chauffant des Technoglobe Gold. Toutefois un peu gêné par l'odeur de cramé, type grille-pain qui s'en dégage à l'usage? c'est assez désagréable, mêm après 3 mois d'installation. Je croyais même que quelque chose fondait ou brulait, type plastique, mais rien. J'ai même regardé sous la selle, tout est normal. Bref, çà marche bien, mais çà sent le grillé dans mon cas. A moins que ce ne soit le chatterton plastique bas de gamme mis sous la poignée pour qu'elle ne tourne plus qui fonde? Je regarderai à l'occasion. saispas
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyJeu 29 Jan 2015 - 19:01
En fait si vous voyez un gars à Amiens qui rentre dans les magasins avec sa moto à la main, C'est qu'en fait...Il est collé ! POIGNEES CHAUFFANTES - Page 5 80767
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyJeu 29 Jan 2015 - 21:45
Salut,vu que tu parle de gants chauffant avec une certaine autonomie tu dois parler de gants a accus
J'utilise des gerbing filaire et il chauffe tres bien et tout le temps vu la source d'energie
Maintenant il existe des gants chauffant bi-energie filaire et accus
Je ne sais pas si c'est bien bon de faire chauffer des gants chauffants si il ni aurait pas un risque pour le systeme electrique interrogation interrogation
Depuis que j'utilise des gants chauffant je ne monte plus de poignée chauffante
Sinon il y a une solution efficace c'est de mettre des manchons,c'est ce que je fais l'hiver quand je fais des grand trajet avec risque de flotte
Salut Michel
POIGNEES CHAUFFANTES - Page 5 8490181200XTZ1
POIGNEES CHAUFFANTES - Page 5 229534038POIGNEES CHAUFFANTES - Page 5 7568070011POIGNEES CHAUFFANTES - Page 5 150151029POIGNEES CHAUFFANTES - Page 5 457366023POIGNEES CHAUFFANTES - Page 5 555053040
MES ALBUMS PHOTOS et MON BLOG
Otra76
Otra76
Moto : Super tenere 1200
Kms de ma moto : 2500
Ville ou région : Rouen
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyMer 30 Nov 2016 - 22:36
luccky13 a écrit:
sonylegitan a écrit:
Les prix des poignées chauffantes c'est juste du vol... ça existe depuis 60 ans, c'est toujours la même technologie qui ne coûte 10 Euros à produire et ils vendent ça entre 150 et 300 Euros. Ca ne fait pas avancer le débat mais ça soulage.
pour reprendre ce que tu disait c'est vrai que c'est un peut cher.
alors hier j'ai commander des resistances en forme de plaques que l'on place sur ( ou sous les poignées )
et qui ne sont ni plus ni moins que les même plaque qu'il y a dans les poignées chauffantes yamaha a 190 euros   sauf que je l'ai ai payer moins de 9 euros livraison comprise.directement en chine via le site (virtual village) daccord il n'y a pas plusieur reglage de temperature mais quand ce sera trop chaud ,il me suffira ce couper l'interupteur.je mettrait des photos dés que je les recevrais ça devrait mettre une dizaine de jours.
POIGNEES CHAUFFANTES - Page 5 00210
Salut luccky13,
Bon je ressort un dossier du grimoire  clin d\'oeil mais je voulais savoir si tu avais monté tes plaques de résistances et quel en été le résultat?
Je m'explique, je vais acheter des manchons (moche mais efficace) et je me disais que ce petites résistances pourraient faire l'appoint de température Very Happy
Merci de ton retour
jackal74
jackal74
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyJeu 1 Déc 2016 - 9:55
franchement ??!!
des Technoglobe super efficace, çà coûte 70 ou 80 balles...avec un réglage de chauffe sur 5 positions
seul petit "défaut" (qui n'en est pas un pour moi) les poignées ont un Ø un peu plus gros
en plus, si tu es serré-serré, c'est bientôt les soldes...
POIGNEES CHAUFFANTES - Page 5 Sans_t10POIGNEES CHAUFFANTES - Page 5 P1010010 POIGNEES CHAUFFANTES - Page 5 Logo_c10POIGNEES CHAUFFANTES - Page 5 P1010012
http://www.lescimes.org
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyJeu 1 Déc 2016 - 15:35
Salut,sinon maintenant il existe des manchons chauffant chez bagster il me semble
Michel
daredevil43
daredevil43
Moto : XTZE 1200
Pneu AV/AR : Road 5
Ville ou région : Auvergne -Haute Loire
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyJeu 1 Déc 2016 - 18:35
je suis de l'avis de Jackal74 car j'avais des Tecnoglob Gold sur mon Tiger
et franchement j'en étais super content.
Elles testaient la batterie au démarrage, avaient 5 niveaux de chauffe et la commande
 intégrée dans la poignée de gauche avec des diodes de couleurs différentes selon les niveaux: Le Top.
Et je les avais acheté en solde sur Motoblouz pour 105€.
C'est bientôt Noël donc il faut surveiller les sites motos...
Otra76
Otra76
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyJeu 1 Déc 2016 - 22:02
J'avais des poignées chauffantes (oxford) sur ma sportive par le passé mais je trouvais que quand il faisait froid bah glagla le boud des doigts
jackal74
jackal74
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyVen 2 Déc 2016 - 9:07
je plussois
sur les 5 positions des Technoblobe, je n'ai jamais utilisé les 4 et 5
même sur 3, çà devient gênant au bout d'un moment
les miennes n'avaient pas la commande sur la poignée mais sur le guidon (76€)
POIGNEES CHAUFFANTES - Page 5 2013-011
+ manchon Carrefour à 23€ qui passent sur les protège-main et facilement ajustable
POIGNEES CHAUFFANTES - Page 5 2012-110
pas super étanche à l'air sans les déflecteurs, mieux avec
les poignées chauffantes, c'est très bien. mais sans manchons, le dessus de la mains n'est pas au chaud, même avec des pare-mains. à moins d'avoir des gants "spécial poignées chauffantes" : type gant été sur la paume et gant hiver sur la main (pas beaucoup de références)
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyVen 2 Déc 2016 - 23:29
pour rappel, les sociétères de la MACIF on droit a 10% chez Motoblouz.
A propos de PC, les miennes ne fonctionnent plus. la semaine prochaine, révision des 30000 et réparation des PC
MessageSujet: Re: POIGNEES CHAUFFANTES   POIGNEES CHAUFFANTES - Page 5 EmptyDim 4 Déc 2016 - 19:48
Salut,ce wwek-end en descendant au millevaches j'ai testé les gants chauffant,bah y a rien a dire c'est bien bien bien
Michel
» Poignées chauffantes HS
» Plus de poignées chauffantes au menu
» poignées chauffantes
Page 5 sur 6Aller à la page : Précédent  1, 2, 3, 4, 5, 6  Suivant
