jauge temperature 750 xtz Emptypar SuperTiti Hier à 21:40
jauge temperature 750 xtz Emptypar Joe644 Hier à 18:56
jauge temperature 750 xtz Emptypar yop1025 Hier à 13:10
jauge temperature 750 xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:58
jauge temperature 750 xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:49
jauge temperature 750 xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:46
jauge temperature 750 xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:44
jauge temperature 750 xtz Emptypar jackal74 Lun 18 Nov 2024 - 11:58
jauge temperature 750 xtz Emptypar Arni Dim 17 Nov 2024 - 14:06
jauge temperature 750 xtz Emptypar Arni Dim 17 Nov 2024 - 13:13
jauge temperature 750 xtz Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
jauge temperature 750 xtz Emptypar yop1025 Sam 16 Nov 2024 - 23:12
jauge temperature 750 xtz Emptypar Fredard Sam 16 Nov 2024 - 9:43
jauge temperature 750 xtz Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
jauge temperature 750 xtz Emptypar J-Marc Mar 12 Nov 2024 - 12:44
jauge temperature 750 xtz Emptypar J-Marc Lun 11 Nov 2024 - 21:58
jauge temperature 750 xtz Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
jauge temperature 750 xtz Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
jauge temperature 750 xtz Emptypar thierry83 Dim 10 Nov 2024 - 9:29
jauge temperature 750 xtz Emptypar REYNALD Ven 8 Nov 2024 - 16:55
jauge temperature 750 xtz Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
jauge temperature 750 xtz Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
jauge temperature 750 xtz Emptypar REYNALD Mar 29 Oct 2024 - 20:18
jauge temperature 750 xtz Emptypar REYNALD Mar 29 Oct 2024 - 20:00
jauge temperature 750 xtz Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
amortisseur pneus embrayage huile essence chaine filtre phare crash selle tuto feux réservoir longues boue galére rabaissement fourche vidange reglage garde synchro manuel suis arrière tenere
-17%
249 € 299 €
zoreille73
zoreille73
Moto : 600 cbr-f de 98
Ville ou région : Grenoble / chambery
MessageSujet: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyMar 24 Aoû 2010 - 17:37
Je voulais savoir : la jauge de mon super T marche bien. Par contre, je voulais savoir comment se comporte la jauge sur un xtz ? En gros, est ce que la jauge monte a moitie de temperature et ne bouge plus, reste quasiment en bas, oscille en permanence ?
En gros comment elle fonctionne, car je soupsonne ma mob de ne pas avoir de thermostat, et ne voulant pas démonter pour rien, je m'en remets à vous
Au revoir 750 xtz, bonjour 600 cbr
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyMar 24 Aoû 2010 - 21:25
salut zoreille, la mienne de jauge de température, reste sur le premier tiers sur route (même avec des températures élevées) mais grimpe presque en zone rouge (avec déclenchement du moto ventilateur) après quelques minutes en ville, dans les bouchons
zoreille73
zoreille73
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyMar 24 Aoû 2010 - 21:41
oky. par contre, même dans les bouchons, et même dans les manifs ffmc, l'aiguille n'est jamais monté plus des deux tiers ...
diabolo
diabolo
Moto : 750xtz - choda ; guzzi 850 le mans 78 - BMW Rock' ED80
Ville ou région : Francin (Savoie)
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyMer 25 Aoû 2010 - 21:31
salut voisin.
Sur mon tricyvle, ça deconne tout :
a froid , bah c'est froid, a chaud, ça ne monte pas plus d'un tiers, meme dans les bouchons par 35°.
Du moment que le ventilo se met en marche....
dans la rtm, il est expliqué comment tester le truc. Si tu ne l'a pas, je peux te scanner la page concernée.
zoreille73
zoreille73
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyMer 25 Aoû 2010 - 22:23
la revue c'est bon je l'ai, mais c'était pour avoir différents avis. Merci bien pour les réponses
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyMer 25 Aoû 2010 - 23:57
Hello a tous ...
Pareil pour moi ... je crois même me souvenir que le ventilo se déclenceh à un peu plus de la moitié ...
Tchusss a tous ...
jauge temperature 750 xtz Rassos10
legrandyan
legrandyan
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyJeu 30 Sep 2010 - 18:49
bé mouaaa le ventilo ne se déclenche pas et la moto s'arrête.... aiguille température 2/3 du maxi...
bon là elle était pas encore super chaudasse...
jauge temperature 750 xtz Temp_m11
avis d'air zen
Mélou13
Mélou13
Moto : 750 xtz 1989
Ville ou région : paca
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptySam 14 Mai 2011 - 17:30
Salut, pour moi, la jauge monte pas apres 15 minutes de ralenti.
Le ventilo déclenche pas, pourtant ok,testé shunt elec comme prevu sur la RTM
Les durites du circuit sont bouillantes.
Question: le calorstat ok ou naze?
LA jauge est elle branchée sur le petit capteur derriere le capteur ventilo( fil vert/rouge), celui est il testable?
legrandyan
legrandyan
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptySam 14 Mai 2011 - 17:59
nettoie ces pièces là et ça devrait le faire, surtout celle en bas à droite
jauge temperature 750 xtz Ensemb12
avis d'air zen
piolan04
piolan04
Moto : XTZ 750 SUPERTENERE ET JE NE SAIS PAS QUOI PRENDRE EN PLUS
Kms de ma moto : 97000
Pneu AV/AR : dunlop trailmax
Ville ou région : VAR
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptySam 14 Mai 2011 - 18:17
Perso, la mienne ne chauffe presque pas. Le ventilo, pourtant dans le sud, ne se déclenche jamais. Pourtant je l'ai testé..Mais bon, je reste rarement dans les bouchons...
Mélou13
Mélou13
Moto : 750 xtz 1989
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptySam 14 Mai 2011 - 22:07
J'ai suivi tes conseils
Alors démontage rapide et accessible
jauge temperature 750 xtz Sam_1910
Constat des pieces, calorstat neuf, mais tout le reste est vraiment sale.
jauge temperature 750 xtz Sam_1911
Un petit bain d'anticalcaire
jauge temperature 750 xtz Sam_1912
Nettoyage et remontage
jauge temperature 750 xtz Sam_1913
ET TOUT FONCTIONNE!!! Jauge + declenchement ventilo!!!
Merci Legrandyan
jauge temperature 750 xtz 379565
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyDim 15 Mai 2011 - 0:13
Y devient balèze ce Yan ;-) ...
legrandyan
legrandyan
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyDim 15 Mai 2011 - 10:24
content que ça t'ai rendu service, j'espère que t'en a profiter pour changer ton LDR (liquide de refroidissement), pour le calorstat, y'a un topic sur le faux rhum, une réf daewoo à moins de 8 euros sur oscaro, contre un bras chez yam... jauge temperature 750 xtz 2120
avis d'air zen
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyDim 15 Mai 2011 - 15:33
Et en plus y se souviens des bonnes astuces ... Trop trop fort ;-) ...
legrandyan
legrandyan
MessageSujet: Re: jauge temperature 750 xtz   jauge temperature 750 xtz EmptyDim 15 Mai 2011 - 20:14
ouaip, je sais plus qui avait filé l'info, mais champion du monde !!! jauge temperature 750 xtz 2120
avis d'air zen
» Capteur jauge temperature
» Jauge essence 660 xtz
» Joint Jauge huile
» Jauge cassée
» jauge d'essence
