OUTIL BLOQUE PLONGEUR FOURCHE Emptypar SuperTiti Hier à 21:40
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar Joe644 Hier à 18:56
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar yop1025 Hier à 13:10
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar REYNALD Mar 19 Nov 2024 - 10:58
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar REYNALD Mar 19 Nov 2024 - 10:49
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar REYNALD Mar 19 Nov 2024 - 10:46
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar REYNALD Mar 19 Nov 2024 - 10:44
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar jackal74 Lun 18 Nov 2024 - 11:58
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar Arni Dim 17 Nov 2024 - 14:06
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar Arni Dim 17 Nov 2024 - 13:13
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar yop1025 Sam 16 Nov 2024 - 23:12
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar Fredard Sam 16 Nov 2024 - 9:43
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar J-Marc Mar 12 Nov 2024 - 12:44
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar J-Marc Lun 11 Nov 2024 - 21:58
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar thierry83 Dim 10 Nov 2024 - 9:29
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar REYNALD Ven 8 Nov 2024 - 16:55
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar REYNALD Mar 29 Oct 2024 - 20:18
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar REYNALD Mar 29 Oct 2024 - 20:00
OUTIL BLOQUE PLONGEUR FOURCHE Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
boue vidange arrière essence reglage fourche manuel tuto embrayage réservoir amortisseur huile pneus crash synchro selle suis longues chaine galére garde phare feux filtre rabaissement tenere
-19%
PC portable MSI Gaming Pulse 16” -Ultra7 155H -16Go/512 Go
1299 € 1599 €
JMM34
JMM34
Moto : XTZ 750 REPLICA DAKAR
Kms de ma moto : 61000
Ville ou région : MIREVAL
MessageSujet: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyMar 12 Juil 2022 - 9:44
Je suis en train de refaire complétement ma fourche et je me suis trouvé confronté au problème du blocage du plongeur qui permet de pouvoir dévisser les vis BTR en bas des fourreaux.
Je n'avais pas d'écrou de 30 comme le préconise la RTM pour me faire cet outil.
Je me suis souvenu qu'en plomberie il y avait des écrous de cette taille.
J'ai cherché dans mes drouilles et j'ai trouvé un raccord femelle 20/27 (3/4") Male 15/21 (1/2")
j'ai limé un peu l'intérieur du coté 1/2" pour y adapter le carré de ma clé à cliqué.
Puis je lui ai emboité la rallonge de 25cm.
Et nickel, j'ai pu défaire les fameuse vis.  OUTIL BLOQUE PLONGEUR FOURCHE 49290
Pour l'instant je n'arrive pas à mettre de photos, dés que je peux j'illustrerai ma prose.
Borgil
Borgil
Kms de ma moto : 89000
Ville ou région : Grenoble
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyMar 12 Juil 2022 - 9:52
En effet, je pense que des photos aideraient, car là j'ai du mal à visualiser :p
De plus, ça servira surement à quelqu'un à un moment ou un autre Smile
JMM34
JMM34
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyMar 12 Juil 2022 - 12:23
C'est bien pour cela que je l'édite.
Le système d'ajout d'image a changé.
J'importe du JPG inférieur à 0.9M, mais ça ne marche pas  embarrassé
Borgil
Borgil
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyMar 12 Juil 2022 - 14:39
Pourtant c'est très simple.
Tu clic sur ce bouton, puis tu choisis tes images, puis "tout envoyer"  ==> "tout insérer"
OUTIL BLOQUE PLONGEUR FOURCHE 312
JMM34
JMM34
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyMar 12 Juil 2022 - 15:48
Oui, c'est ce que je faisais auparavant.
Là, je n'ai pas la ligne des icones en visuel.
JMM34
JMM34
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyMar 12 Juil 2022 - 16:37
Ce coup ci c'est bon  bien
OUTIL BLOQUE PLONGEUR FOURCHE P1070117
OUTIL BLOQUE PLONGEUR FOURCHE P1070121
OUTIL BLOQUE PLONGEUR FOURCHE P1070124
OUTIL BLOQUE PLONGEUR FOURCHE P1070125
Borgil
Borgil
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyMer 13 Juil 2022 - 9:31
Aaaah ça c'est bien plus parlant
Merci pour l'info et le partage. En effet, c'est un peu du joe la débrouille, mais c'est carrément suffisant pour faire ce genre de chose !
JMM34
JMM34
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyVen 15 Juil 2022 - 16:35
Pas cher, et rapidement fait   OUTIL BLOQUE PLONGEUR FOURCHE 49290
Blunt74
Blunt74
Kms de ma moto : 70000
Pneu AV/AR : TRAILMAX
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptySam 25 Fév 2023 - 7:39
 Et oui !!! Et ça me sert justement, c'est exactement ce que je cherchais !
Je suis tombé plusieurs fois sur l'outil a souder mais ça ne me convenais pas.
Question : Quelle longueur de rallonge il faut prévoir ?
A plus
JMM34
JMM34
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptySam 25 Fév 2023 - 8:26
Au moins la longueur du fourreau  clin d\'oeil
Blunt74
Blunt74
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptySam 25 Fév 2023 - 14:05
Au moins 2 voir 3 rallonges de 25 alors j'imagine.
J'ai pas encore démonté mais si je me trompe pas, l'outil sert a désolidariser le tube du bas de fourche. l'empreinte de 30 doit se trouver au fond du tube.
Blunt74
Blunt74
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptySam 25 Fév 2023 - 14:08
En tous cas bravos pour l'outil, je le trouve nickel, j’étais en train de chercher une tige filetée et un écrou de 30
JMM34
JMM34
MessageSujet: Re: OUTIL BLOQUE PLONGEUR FOURCHE   OUTIL BLOQUE PLONGEUR FOURCHE EmptyLun 27 Fév 2023 - 18:21
C'est bien 2 rallonge de 25cm.
Depuis j'ai trouvé un écrou de 30mm pour souder sur une tige filletée.
Ce sera au prochain démontage.
J'aime bien rouler aussi.clin d\'oeil
» un bon outil?
» L'outil ultime !
» Démontage roue avant ET roue arrière ST 1200 en photos
» Sacoche à outil
» Trousse à outil T 700
