Refection carbus en PHOTOS - Page 3 Emptypar SuperTiti Hier à 21:40
Refection carbus en PHOTOS - Page 3 Emptypar Joe644 Hier à 18:56
Refection carbus en PHOTOS - Page 3 Emptypar yop1025 Hier à 13:10
Refection carbus en PHOTOS - Page 3 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Refection carbus en PHOTOS - Page 3 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Refection carbus en PHOTOS - Page 3 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Refection carbus en PHOTOS - Page 3 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Refection carbus en PHOTOS - Page 3 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Refection carbus en PHOTOS - Page 3 Emptypar Arni Dim 17 Nov 2024 - 14:06
Refection carbus en PHOTOS - Page 3 Emptypar Arni Dim 17 Nov 2024 - 13:13
Refection carbus en PHOTOS - Page 3 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Refection carbus en PHOTOS - Page 3 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Refection carbus en PHOTOS - Page 3 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Refection carbus en PHOTOS - Page 3 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Refection carbus en PHOTOS - Page 3 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Refection carbus en PHOTOS - Page 3 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Refection carbus en PHOTOS - Page 3 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Refection carbus en PHOTOS - Page 3 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Refection carbus en PHOTOS - Page 3 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Refection carbus en PHOTOS - Page 3 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Refection carbus en PHOTOS - Page 3 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Refection carbus en PHOTOS - Page 3 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Refection carbus en PHOTOS - Page 3 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Refection carbus en PHOTOS - Page 3 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Refection carbus en PHOTOS - Page 3 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
galére selle tuto longues boue suis reglage huile amortisseur vidange feux essence embrayage phare rabaissement synchro pneus crash réservoir arrière garde manuel filtre tenere chaine fourche
-23%
(Black Friday) Apple watch Apple SE GPS 44mm (plusieurs coloris) à ...
199 € 259 €
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 18:43
attend attend!!!
avant de mettre tes merdouilles filtrantes en bas de maman.
tu me dis pétarade ralenti? c'est à dire tu es a ton ralenti, 1000trs environ et ça pétarade?
si c'est ça, c'est une mauvaise syncro soit des papillons, soit des vis de richesse.
si au grand jamais tu vires la boite à air pour mettre tes poubelles à 10euros... bon courage pour le réglage carbu
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 20:42
vince34 a écrit:
joel1974 a écrit:
faut en profite pour monter le kit gigleur suisse,c'est ce que je ferais cet hiver(grosse economie d'essence)
les detonation peuvent venir d'une soupape qui ferme mal,maets un produit nettoyant qu'on melange a l'essence,quelque fois ça marche
connais pas!
donne moi plus d'info!
ok demain on en parle a la maison!!!!fait moi y penser,car je vais les commander
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 20:46
psyckorel a écrit:
Sinon l'idée de Joël n'est pas mauvaise ( produit dans le réservoir)d'ailleur si tu sais quel marque prendre et ou le trouver...A essayer
Au fait en parcourant le fofo j'ai vu qu'il y a des partisans des filtres cornet et d'autres qui sont contre mais je viens de sauter le pas et j'en ai trouver à 10 Euros pièces histoire de ne pas me ruiner.
Bon je n'ai pas pus démarrer depuis (carbus sur la table de cuisine...)
mais j pense que ma richesse va déjà bien descendre grace a ca et au changement aiguilles/puits cette aprem.
avec les filtre reste d'origine,pour le produit tu prends un nettoyant pour moteur a carbu (centre commercial comme carrefour)
controle aussi le niveau de cuve,regarde au cas ou aussi tes bougie(couleur et proprete)
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 20:48
on en parle avec moi..
car moi aussi il me faut le kit carbu et robinet d'essence...
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 20:53
pour les soupapes tu achete ça
Refection carbus en PHOTOS - Page 3 Aut31910
une pochettede joints(webmoto),et la revue,c'est pas difficile a faire
tu demonte ta culasse,tu repere tes soupape,tu les deponte ,tu change les joints,tu les rode ,tu controle leur etancheite a l'essence,tu remonte le tout bien gras,c'est pas difficile,et tu repart sur du neuf et etanche,le reste c'est du solide,une bonne journee de boulot,mais de grosse economie!!!!!
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 20:55
pas de probleme,je veux juste verifier ,certain truc et on en reparle avant la commande!!!
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 20:58
tabar,j'ai un client qui vient avec une xtz a faire rougir tout le monde!!!moto suspendu monte cross,amortisseur sur mesure(400euro mais il conserve son ressort),fourche modifie avec des ressort d'africa,cale pied,selecteur,frein,guidon,pompe a carburant,faisceaux,.........modifie,et beaucoup de fait maison!!!!!une bombe!!!!
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 21:14
Refection carbus en PHOTOS - Page 3 49290
mouaii une bonne journée...
sauf, un rodage de soupape sur des soupapes fuyarde ça sert à rien, d'ailleurs je comprend pas les partisants du rodage de soupapes bornées.
tu démontes la soupape, une rectif, un rodage. D'ailleurs apres ça, jeu aux soupapes obligatoire.
mais là j'ai l'impression que jojo embringue notre amis dans une mise à poil d'un moteur alors qu'il faut juste régler les carbu s Refection carbus en PHOTOS - Page 3 49290 Refection carbus en PHOTOS - Page 3 49290
et puis avant de mettre de la poudre de perlimpinpin, regle les carbus... lol!
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 21:16
photos hello
je mettrai pas 400 dans une modif d'hydrau, je prefère garder mes sous pour un ohlins ou ... fournales Double V
psyckorel
psyckorel
Moto : Super Ténéré 750 XTZ,3LD de 90
Ville ou région : Cote D'Or
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 21:31
J adore ta franchise Flo au sujet de mes "merdes" à 10 euros.
Je viens d'en racheter 2 cet aprem pour 12 Euros dans un magasin moto..
Ça fait pas chère les merdes ;) c'est sur...
Mais je tenais pas a investir dans des K&N a X Euros si c'est pour les virer dans 1 semaine.
Je veu juste essayer et qui sait, je rejoindrai peu etre ton camp (heum,heum pas sur kan meme Refection carbus en PHOTOS - Page 3 726643)
https://www.youtube.com/user/aurelgratte
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 21:33
c'est des cornets ou des cartouches que tu met dans la boite à air?
si c'est des cornets, il faudra que tu mettes +25pts au gicleur, trouver les bon profils d'aiguilles etc... je changerais pas d'avis Double V
psyckorel
psyckorel
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 21:48
Euh...c'est des jolies cornets qui vont remplacer la boite à air.
J'entend déjà ton refrain sur l'équilibre des pressions ( retours du reniflard d'huile ) et dépression, que le constructeur a longuement étudié.
Mais que veu tu j suis têtu.Mais je te le répète c'est simplement un test.
En tout cas je comprend ta position.
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 22:01
ça peux marcher, juste pas à la porté d'un régleur carbu amateur, et surtout "bête" sur un trail
essaye, tu nous diras bien
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 22:11
je n'ais pas dit qu'il falait refaire le moteur,j'explique comment faire si une soupape fuit,apres chacun fait comme il veut,et un rodage soupape suffit pas besoin de les rectifier,c'est pas la premiere fois que je bosse sur des moteur,j'ai bosse dans la mecanique agricole avant de changer de metier
psyckorel
psyckorel
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 22:12
Ok je partagerai l'expérience du montage de cornet sur le forum.
Sinon quand tu dis que c'est "bête" pour un trail tu entend quoi ?
Autrement je suis mécanicien auto alors j'espère que mes connaissances seront suffisante pour le réglage.Mais j'avoue que les carbus à dépression c'est relativement nouveau pour moi,alors je verrai bien
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 22:15
tans que c'est démonté autant faire du vrai boulot, autrement les portés de soupapes sont trop grandes.
un trail c'est fait pour sortir de la route propre Double V
le problème c'est d'avoir le panel gicleur profil d'aiguilles (20 gicleurs 4-5 profils d'aiguilles) pour faire tes essais, plus une oreille mécanique, car tu n'as pas de controleur AFR
psyckorel
psyckorel
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 22:21
Je viendrai peu etre au chemins mais pour l'instant je me cantonne au bitume alors ca devrai aller.
What is this "controleur AFR" ? Une station de réglages de valeur du Co ,lambda,etc...
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 22:44
beaucoup de matos pour des motos de l'epoque,une bonne caisse a outil et c'est parti,si tu bosse sur des bagnol,la xtz c'est de la rigolade!!!!pas besoin de sortir de faculte!!!!!
psyckorel
psyckorel
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 22:53
Refection carbus en PHOTOS - Page 3 64068 Refection carbus en PHOTOS - Page 3 897922
Bien parlé Joël !Au fait le fameux produit nettoyant tu la déjà utilisé ?
Parce qu'en général je suis pas trop partant pour les additifs en tout genre mais
si tu as déjà testé avec de bons résultats à la clef...
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 23:05
ça nettoie la calamine,tu mets dans le reservoire et tu fais le plein avant de rouler,je l'ais fait sur plusieur becane et quad,mais ça ne reglera pas ton probleme!!!!commence par un reglage au poil,avec de bonne bougie,controle l'usure des aiguille de carbu et vois ce que ça donne
ça doit bien fonctionner sans intervenir sur le moteur sauf si ça pète a la deceleration
ou si ça fume
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 23:07
attention mec flo44 c'est un bon et a l'habitude de ces machine!!!!!il t'expliquera mieux que moi!!!!
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 23:11
un exemple de produit
Refection carbus en PHOTOS - Page 3 91200010
psyckorel
psyckorel
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 23:18
Merci Joël c'est cool.Et t'inquiète pas j'avais bien senti que Flo44 était un bon..
psyckorel
psyckorel
MessageSujet: Re: Refection carbus en PHOTOS   Refection carbus en PHOTOS - Page 3 EmptyMar 11 Oct 2011 - 23:20
Au fait mes bougies ont 200 kms et s'es des Iridium.Pour les aiguilles et leurs puits j les ai changé cet aprem.
Demain j vai tenter de régler tout ca..
» Mon SuperT 750 de 91 en réfection
» Refection Moteur
» carburateur kit réfection vis inconnues
» REFECTION ET MODIFICATION CARBURATION SUR 750 XTZ
» Revision des carbus XTZ 750
Page 3 sur 6Aller à la page : Précédent  1, 2, 3, 4, 5, 6  Suivant
