XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar Joe644 Mer 20 Nov 2024 - 18:56
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar yop1025 Mer 20 Nov 2024 - 13:10
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar REYNALD Mar 19 Nov 2024 - 10:58
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar REYNALD Mar 19 Nov 2024 - 10:49
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar REYNALD Mar 19 Nov 2024 - 10:46
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar REYNALD Mar 19 Nov 2024 - 10:44
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar jackal74 Lun 18 Nov 2024 - 11:58
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar Arni Dim 17 Nov 2024 - 14:06
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar Arni Dim 17 Nov 2024 - 13:13
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar yop1025 Sam 16 Nov 2024 - 23:12
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar Fredard Sam 16 Nov 2024 - 9:43
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar J-Marc Mar 12 Nov 2024 - 12:44
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar J-Marc Lun 11 Nov 2024 - 21:58
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar thierry83 Dim 10 Nov 2024 - 9:29
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar REYNALD Ven 8 Nov 2024 - 16:55
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar REYNALD Mar 29 Oct 2024 - 20:18
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar REYNALD Mar 29 Oct 2024 - 20:00
XTZ660Z Ténéré  Vidange:Comment faire..... Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
tuto longues rabaissement garde fourche amortisseur pneus arrière selle embrayage essence synchro phare suis vidange crash chaine filtre tenere manuel réservoir boue huile feux galére reglage
-28%
229.99 € 318.99 €
Ohlins
Ohlins
Moto : 2008 XTZ660Z Ténéré.
Kms de ma moto : 83,000 kms
Pneu AV/AR : Mitas E07
Ville ou région : Irlande et 64800
MessageSujet: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyDim 16 Fév 2014 - 19:09
Pour faire le vidange avec un filtre de huile et 2.6 litres de huile. ***Important lire le dernier paragraphe de l'article***
J'utiliser 10W40 ou 10W50 semi synthèse ou synthèse quand je trouver un bon prix. (Super U a présent 2L 100% syn = €8.50)Je faire le vidange chaque 5000kms avec un filtre de huile.
Démarrer le moteur pour 5 ou 7 minutes et cherche les outils.
Besoin:
Clés/douilles  1x 13mm,1x 19mm, et 1x clé allen 5mm. Aussi 1x entonnoir et 2x bidons pour le huile vieux.
Un option aussi;un clé dynamométrique.
J'ai un béquille centrale et ça marche bien pour faire le vidange.
Trouver le jauge de niveau de huile a la direction et desserrer.
XTZ660Z Ténéré  Vidange:Comment faire..... Xgekg9
XTZ660Z Ténéré  Vidange:Comment faire..... 29c4efa
Demonter le sabot en plastique (4x boulons)...pour moi non.
Avec un douille/clé 13mm desserrer le boulon dans le cadre à côté  de le klaxon. Faire attention pour un rondelle un cuivre sur la boulon.Imaginer ma mot c'est propre!! Smile
XTZ660Z Ténéré  Vidange:Comment faire..... 2vlocar
XTZ660Z Ténéré  Vidange:Comment faire..... Ayrdxh
Poser un bidon pour le huile a la boulon.....faire attention parce que le huile sortie avec force contra le pneu avant
XTZ660Z Ténéré  Vidange:Comment faire..... 2072fba
Apres desserrer le boulon derrière  de le sélecteur avec 19mm clé/douille et poser un bidon en dessous
XTZ660Z Ténéré  Vidange:Comment faire..... 2rqlo2r
XTZ660Z Ténéré  Vidange:Comment faire..... Fxume
XTZ660Z Ténéré  Vidange:Comment faire..... Wsso5d
Reste comme ça et desserrer le carter de le filtre d'huile avec le clé allen 5mm (a droite de le moteur)Il y a trois boulons.
XTZ660Z Ténéré  Vidange:Comment faire..... 25umtmw
Présumer un peu de huile sort.
XTZ660Z Ténéré  Vidange:Comment faire..... 34ff7nc
Quand pas de huile demonter  le carter. Faire attention pour le petit joint spi ('o' ring) orange..dans l'image
XTZ660Z Ténéré  Vidange:Comment faire..... 2ym9m5c
Bien nettoyer le carter avec in chiffon
XTZ660Z Ténéré  Vidange:Comment faire..... Xp3a6g
Reagarder le corrosion dans mes boulons. (Aprés je bien nettoyer et  réinstaller avec graisse un cuivre)
XTZ660Z Ténéré  Vidange:Comment faire..... 2ptw2mg
Bien nettoyer le carter avec un chiffon.
XTZ660Z Ténéré  Vidange:Comment faire..... Jjr5g8
Poser le filtre de huile sur le carter.
XTZ660Z Ténéré  Vidange:Comment faire..... Wb2oh3
Monter le filtre de le moteur et serrer les trois boulons. Un astuce...quand les boulons reste fermement serrer continuer un tour de huitième et arrêter.
Dans le Manual il dit pour purge a la filtre de huile..mais je jamais faire ça...c'est le choix personnel
Pour serrer officiellement  Yamaha dit 10Nm mais c'est facile pour couper le  filetage.
Reinstaller le boulon de moteur et serrer jusqu'à 30Nm
XTZ660Z Ténéré  Vidange:Comment faire..... Nzognc
Reinstaller l'autre boulon a la cadre avec le rondelle en cuivre.
XTZ660Z Ténéré  Vidange:Comment faire..... 33pfvw4
Serrer jusqu'â 18Nm.
XTZ660Z Ténéré  Vidange:Comment faire..... Dcvuf
****Après ( a la jauge) verser 1.9 litres de huile. Serrer le juge et démarrer le moteur et faire vombrir 5 ou 6 fois et arrêter le moteur.
Desserrer la jauge et verser encore 0.7 litre de huile. Monter la jauge et démarrer le moteur pour 5 minutes. Après contrôle le niveau de huile. ****
Desole pour la grammaire....c'est un problème de Ulster!
Boire le bièrre.
Smile
tabar
tabar
Moto : revére ntv 650
Kms de ma moto : 100 000km
Pneu AV/AR : Mitas
Ville ou région : 30220
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyDim 16 Fév 2014 - 19:44
salut mec....
pour ton prochain topic......"xtz660z comment faire pour avoir une moto propre" clin d\'oeil ........... humour
ça reste sympa a regarder....papyconseille.............................
XTZ660Z Ténéré  Vidange:Comment faire..... Bonett10 XTZ660Z Ténéré  Vidange:Comment faire..... OAatjW
________________
XTZ660Z Ténéré  Vidange:Comment faire..... Mr84-110
XT 600 3TD
Ohlins
Ohlins
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyDim 16 Fév 2014 - 19:47
Smile
www.edcontour.com
mamaz
mamaz
Moto : XT660Z 2009 bleue
Kms de ma moto : 35000
Ville ou région : Nouméa
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyDim 16 Fév 2014 - 20:06
Coooool, et bien présenté!!  bien
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyDim 16 Fév 2014 - 21:07
Pourquoi est-ce que YAM ne préconise pas les vidanges tous les 5 000 km alors que ce serait plus à son avantage (je parle pour les concessionnaires), pas des clients qui font leur vidange eux-même.
Petite précision que j'ai apprise sur le forum consacré aux 650 FMX il y a quelques temps :
Toujours remplir d'huile le nouveau filtre à huile, afin que le moteur soit plus vite lubrifié après le redémarrage après une vidange.
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyDim 16 Fév 2014 - 21:23
aussi, se preparer un entonoir "a tuyeau" afin d'acceder a l'orifice de remplissage
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyDim 16 Fév 2014 - 21:27
C'est vrai qu'ils ont fait fort de le caser à cet endroit...
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyLun 17 Fév 2014 - 13:52
ou là :
http://660xtx.forumactif.com/t6225-vidange-moteur-avec-changement-de-filtre-a-huile?highlight=vidange
XTZ660Z Ténéré  Vidange:Comment faire..... Dsc00811XTZ660Z Ténéré  Vidange:Comment faire..... Dsc01224XTZ660Z Ténéré  Vidange:Comment faire..... Dsc_0617XTZ660Z Ténéré  Vidange:Comment faire..... Nkp11XTZ660Z Ténéré  Vidange:Comment faire..... Dsc_1619
Ohlins
Ohlins
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyLun 17 Fév 2014 - 14:02
Bon information aussi pour la commune de XTZ
Smile
www.edcontour.com
Launelie
Launelie
Moto : Yamaha XTZ 660 /2012
Kms de ma moto : 63886 km
Ville ou région : BASSENS 33530
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyLun 7 Juin 2021 - 10:27
Besoin:
Boire le bièrre.
Smile
Bonjour Ohlins . Pourquoi pas de Purge ? C'est important d'éviter poche d'air ou autres ?
Je dit ça car je chercher à savoir: Si l'Huile doit sortir en "pression" ou juste un "écoulement" ??
Merci et bonne Bierotte !
robindesbois
robindesbois
Moto : 1200 xtz e
Kms de ma moto : en rodage...
Ville ou région : rhone alpes
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyLun 7 Juin 2021 - 16:00
Tu peux aller jeter un coup d’œil sur YouTube , le gars Vaclav a fait pas mal de tuto sur l'entretien du 660 xtz
https://www.youtube.com/watch?v=5zc_9crVF7I&list=PL2WIUXDt_NLjSzxQ_ViB0nVIYE6xuoMfD&index=2
Le voyage est le meilleur moyen de se perdre et de se retrouver en même temps.
Brenna Smith
Launelie
Launelie
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyLun 7 Juin 2021 - 16:47
Salut . Ok, oui merci. J'connais se site sur Youtube mais no abla English et il y en d'autres ... Je cherche juste à savoir si l'Huile (Vis de Purge) sort en pression ou en écoulement (bien sur , c'est en écoulement) Mais quand tu vois la pression en Bar que produit la Pompe Huile sur ces moteurs , je suis surpris de ne voir qu'un filet d'huile suinter le long du carter . Voila , c'est tout. Mais merci quand même "robindesbois"
robindesbois
robindesbois
Moto : 1200 xtz e
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyLun 7 Juin 2021 - 17:04
Perso je dévissais au 3/4 la vis supérieur, et dès que ça suintait bien je revissais
Brenna Smith
Launelie
Launelie
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyMar 8 Juin 2021 - 10:42
Yes bien , on est d'accord.
Launelie
Launelie
MessageSujet: Re: XTZ660Z Ténéré Vidange:Comment faire.....   XTZ660Z Ténéré  Vidange:Comment faire..... EmptyMar 8 Juin 2021 - 15:20
Encore moi . Bon bé sur Revue technique de 2008 pour XTZ 660 ils préconisent de purger Huile, mais, sur R.T. de 2016 ils n'en parlent pas . Pourtant Moteur équivalent . Perso , je reste sur la Purge !  XTZ660Z Ténéré  Vidange:Comment faire..... 1f61b
» XTZ660Z Vidange..comment faire.
» XTZ660Z Comment faire le graissage de suspension/pivots.
» Comment faire pour bien faire? ou à la Anto34 ;-)
» faire la vidange
» faire la vidange
