En panne ... encore ... help, encore :( Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
En panne ... encore ... help, encore :( Emptypar Joe644 Mer 20 Nov 2024 - 18:56
En panne ... encore ... help, encore :( Emptypar yop1025 Mer 20 Nov 2024 - 13:10
En panne ... encore ... help, encore :( Emptypar REYNALD Mar 19 Nov 2024 - 10:58
En panne ... encore ... help, encore :( Emptypar REYNALD Mar 19 Nov 2024 - 10:49
En panne ... encore ... help, encore :( Emptypar REYNALD Mar 19 Nov 2024 - 10:46
En panne ... encore ... help, encore :( Emptypar REYNALD Mar 19 Nov 2024 - 10:44
En panne ... encore ... help, encore :( Emptypar jackal74 Lun 18 Nov 2024 - 11:58
En panne ... encore ... help, encore :( Emptypar Arni Dim 17 Nov 2024 - 14:06
En panne ... encore ... help, encore :( Emptypar Arni Dim 17 Nov 2024 - 13:13
En panne ... encore ... help, encore :( Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
En panne ... encore ... help, encore :( Emptypar yop1025 Sam 16 Nov 2024 - 23:12
En panne ... encore ... help, encore :( Emptypar Fredard Sam 16 Nov 2024 - 9:43
En panne ... encore ... help, encore :( Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
En panne ... encore ... help, encore :( Emptypar J-Marc Mar 12 Nov 2024 - 12:44
En panne ... encore ... help, encore :( Emptypar J-Marc Lun 11 Nov 2024 - 21:58
En panne ... encore ... help, encore :( Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
En panne ... encore ... help, encore :( Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
En panne ... encore ... help, encore :( Emptypar thierry83 Dim 10 Nov 2024 - 9:29
En panne ... encore ... help, encore :( Emptypar REYNALD Ven 8 Nov 2024 - 16:55
En panne ... encore ... help, encore :( Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
En panne ... encore ... help, encore :( Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
En panne ... encore ... help, encore :( Emptypar REYNALD Mar 29 Oct 2024 - 20:18
En panne ... encore ... help, encore :( Emptypar REYNALD Mar 29 Oct 2024 - 20:00
En panne ... encore ... help, encore :( Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
vidange tuto fourche phare réservoir boue galére embrayage longues filtre rabaissement suis selle pneus feux chaine synchro arrière crash huile essence tenere reglage garde amortisseur manuel
-20%
Drone Dji DJI Mini 4K (EU)
239 € 299 €
Vincent974
Vincent974
Moto : SuperTénéré XTZ 750 1995
Ville ou région : Réunion
MessageSujet: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyLun 25 Jan 2021 - 10:33
Salut tous,
encore une fois en panne avec cette maudite Ténéré ...
je vous la fait courte mais mi décembre, problème de réglage carburation du jour au lendemain, sans explication. Je sais que j'avais les joints de pointeau starter fatigué. je les ai changé semaine dernière ... la moto n'avait pas tourné depuis mi décembre. Je redémarre, nickel, petit réglage richesse/ralenti, très bien. Même si le ralenti est pas hyper stable je trouve mais je chipote.
Hier soir je refais ma pression des pneus avec le compresseur et par acquis de concience vu que je dois aller bosser avec aujourd'hui, je la fait péter 5min, et elle péte!
Ce matin, je monte dessus, j'allume ça pète ... je bricole avec mon blouson en même temps, j'ai zappé le starter ça calle une 1ere fois. Je redémarre elle recalle. Et derrière, plus rien! impossible de repartir!! elle veut pas démarrer. 4h que je suis dessus ... Nettoyage bougies, vérification étincelle, controle des arrivées d'essence ... recharge batterie ... rien, ça pète pas! Ca veut pas exploser et je dois trouver la solution pour demain matin ... j'en peux plus de cette brèle
Debulmont
Debulmont
Moto : XTZ750 SUPER TENERE XTR 660 CRF250L
Kms de ma moto : 55000 16000 6000
Pneu AV/AR : michelin anakee wild
Ville ou région : Jemeppe sur Sambre. Belgique
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyLun 25 Jan 2021 - 12:45
Slt.
Perso quand la miene se noie je doit changer les bougies l'étincelle est trop jaune et sa démarre plus.
Debulmont
Debulmont
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyLun 25 Jan 2021 - 13:08
La résistance, "R" sur la bougie, supporte mal d’être humide.
Apres 15 jours de séchage sur la chaudière elle redémarre mais elle pète dans tout les sens.
Vincent974
Vincent974
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyLun 25 Jan 2021 - 14:13
Merci pour l'info, en effet on vient de rentrer en pleine saison des pluies ici ...
J'ai fini par trouver un copain pour mettre la moto dans mon camion, je vais aler faire un tour chez mon mécano demain matin en espérant qu'il puisse me sauver la "vie"
Vincent974
Vincent974
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyMar 26 Jan 2021 - 16:33
Après une journée à batailler chez le mécano :
batteries ok
régulateur ok
carburation ok
problème sur le capteur de béquille (fil sectionné mais anecdotique) et capteur de point mort défaillant
On enlève les bougies, laissé un peu tout sécher, un coup de booster pour l'aider et ça pète! Cool Smile sauf qu'en chauffant, y a plus rien qui tourne rond ... ralenti qui se casse la gueule, moto qui monte dans les tours qd on accélère mais qui redescend pas et reste coincé à 2000trs/min .... bref le bordel!
après contrôle, la bougie du cylindre gauche est pleine d'huile, et avec controle de la température, il est à 70° contre 200° pour le droit. Je tourne sur un cylindre ... parfois 2 ...
D'après mon mécano, soit une segmentation soit un piston, au mieux ... au pire, tout est possible.
J'ai remis la moto dans mon camion. Fin de l'aventure pour moi avec ce véhicule.
sebti
sebti
Moto : ténéré 700
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyMar 26 Jan 2021 - 17:05
Salut, déjà il aurait fallu essayer avec des bougies neuves, pour être sûr.
D'après ce que tu dis, ton problème vient très probablement de ton stator a faire rebobiner, sur une moto de cet âge, ça n'est pas une surprise. ;)
insta: mobylette rollers
Smile
Debulmont
Debulmont
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyMar 26 Jan 2021 - 18:46
Mwai, je suis d'accord avec sebti 2 bougies sa coûte pas un bras, et le ralenti qui reste élevé,sa me fait penser a une prise d'air au niveau des pipes d'admissions en caoutchouc sous les carbus.
segment, piston!! j'i croie pas trop.
coolstef
coolstef
Kms de ma moto : 14800
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyMer 27 Jan 2021 - 5:43
Même impression, ces problèmes de carbu sont classiques sur ces bécanes, peu de chance que ça vienne des segments ou d’un piston et ça ressemble fort à une prise d’air quelque part. Ce que je ferai :
Bougies neuves avant tout.
Recherche d’une prise d’air au niveau des pipes, des manchons (la boîte à air est souvent mal fixée après un démontage), du starter (il ne revient pas complètement ou les plongeurs sont usés), de la pompe à essence (fuite sur la durite de dépression qui va du carbu à la pompe ou sur la pompe elle même. On verifie en bouchant la durite de dépression et en alimentant direct le carbu).
Et puis un peu de patience 😉 Je dis ça car j’ai passé du temps sur ce genre de problème (voir mon sujet « rénovation de deux XTZ ») et aujourd’hui, ça tourne nickel !
Vincent974
Vincent974
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyMer 27 Jan 2021 - 10:23
Oui j'ai repensé le truc toute la nuit ... ça colle pas son histoire de piston en effet. les carbus ont été refait il y a moins de 8000kms, la boite à air a les problèmes qu'on lui connait mais elle est emboitée, les starters ont également été refait. Je peux pas jurer qu'il n y a pas une prise d'air sur les manchons, mais en visu tout est absolument nickel. Y a un côté ON/OFF dans la panne qui fait vraiment penser à de l'électrique. Mon capteur de point mort a laché sans raison et mon cable de masse du capteur de position béquille s'est sectionné ... le circuit électrique est vraiment bancale ... j'ai un gars compétent et de confiance qui vient vendredi, on va passer tout ça à la loupe.
coolstef
coolstef
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyMer 27 Jan 2021 - 10:43
Alors en effet, si t’es plutôt confiant côté carbu, faut regarder côté allumage mais je vérifierais quand même, si tu l’as pas déjà fait, ton arrivée d’essence en branchant un bidon direct sur le carbu. C’est pas compliqué et ça élimine vite fait une autre cause...
Vincent974
Vincent974
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyJeu 28 Jan 2021 - 4:46
Non c'est fait, tout fonctionne à ce niveau là. Seul bémol, elle est équipée d'un kit suisse.
J'ai également mis des bougies neuves. Hier soir avec bougies neuves elle a bien démarré, et j'ai roulé un peu dans le quartier, ça semblait ok malgré un ralenti plutot irrégulier.
Ce matin, elle a repété correctement une 1ere fois, laissé bien chauffé le bazard, puis j'a icoupé et rallumé qqs instant après et là, re la m***e. La bougie de mon cylindre gauche et noire de chez noire alors que celle de mon cylindre droit est nickel. Même après nettoyage, rien n'y fait, ça ne tourne plus correctement, je suis sur un cylindre. Avant nettoyage je devais être sur cylindre et demi, et après, sur un seul. Le problème c'est que la liste peut-être vraiment très longue au niveau des problèmes et je n'ai que peu de pièces de dispos localement voir pas du tout. Je verrais vendredi mais je suis pas super confiant... et histoire d'être rock'n roll jusqu'au bout, j'ai mes joints spi de fourche qui viennent de lacher, donc plus d'huile et une suspention avant ultra casse gueule.
coolstef
coolstef
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyJeu 28 Jan 2021 - 19:12
Bonne nouvelle, t'as quand même pu rouler un peu donc ça élimine à priori un problème de piston ou de compression.
Une bougie noire et grasse, c'est normalement signe de mélange trop riche. Moi je resterais pour l'instant sur un problème de carbu. As-tu fais une synchro ? As-tu vérifié tes niveaux de cuve ? Tes pointeaux ?
Bref, à ta place, je démonterais les carburateurs pour une vérification complète, y compris le "fameux joint qui tue "
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyVen 29 Jan 2021 - 10:18
Salut Vincent.
Je suis ce post depuis quelques temps sans connaître la 750 plus que ça mais...
... Il me semble qu'il y a une pompe à essence là dessus qui fonctionne avec une membrane qui prend sa dépression certainement dans une pipe d'admission, ne serait ce pas la gauche par hasard ?
Si tu as vérifié les carbus, que , de ce côté là, tout semble ok, il ne faudrait pas que la carburation d'un cylindre soit enrichie anormalement par l'ajout d'une injection d'essence venant de la prise à dépression de la pompe;
J'dis ça, j'dis rien, mais... Débranche donc ta prise à dépression , bouche la prise d'air sur la pipe, assure toi d'avoir suffisamment d'essence pour que la pompe ne serve à rien(niveau au dessus des carbus), assure toi que l'essence arrive aux carbus et essaie comme ça ! La membrane de la pompe pourrait bien fuir et laisser passer de l'essence par là !
Tu peux aussi aspirer au bout du tuyau pour essayer de boire un canon d'essence mais pas sur que tu suces assez fort si la membrane est juste poreuse ... manque d'expérience ricane ricane  peut être ...
En tout cas , bon courage dans tes recherches, je ne suivrai pas ton post dans les jours qui suivent, je me tire en vacances... Sans internet !... si nos gouvernants me laissent m'échapper bien entendu ...
Vincent974
Vincent974
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyVen 29 Jan 2021 - 14:17
Allez les gars on va rire un coup :
ce matin passage du mécano, test démarrage, ça veut presque mais ça veut pas. Démontage bougie neuve, rien d'exceptionnel. On remonte, ça pète mais 1 cylindre sur 2. On fait le tour avec le voltmètre, tout semble ok.
La RMT dit : 1 cylindre ne tourne pas => antiparasite / bougie / carburation
 - bougies => check ok
 - antiparasites => check ok
 - étincelle magré tout faible ... on raccourcit de 1cm les cables car en effet ils sont fatigués =>ça pète mieux! mais tjs un seul cylindre
 - vérification prise d'air => ça semble ok, les pipes sont pas vieilles, les boisseaux bougent bien ...
 - vérification membrane, une a une microfragilité sur le bord ... peu probable que ça vienne de là. On remonte tout.
 - On reteste, ça pète, mais tjs 1 seul cylindre ... par contre c'est plus le même cylindre scratch scratch scratch
pas logique ... à moins qu'en remontant les membranes elles aient été inversées et du coup ... donc recontrole en croisant les doigts pour que ce soit ça et je voule donne en mille ??? BINGO!!!!!
MEMBRANE HS, ça explique tout ...
La commande a été passé à l'instant chez nos amis de Wemoto ... va falloir être patient car j'ai pris un kit pour la fourche également du coup.
Je vous tiens au jus dès que c'est monté mais je reprend confiance ... même si je suis parti pour me faire ch**r dans des bouchons de débile avec mon camion sans clim en pleine saison des pluies pour aller bosser, mais bon ...
Merci à tous
coolstef
coolstef
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyVen 29 Jan 2021 - 14:55
Ah Ah, je savais bien que c’était un problème de carbu mais une prise d’air sur une des membranes, c’est vicieux !
L’analyse de Dédé est judicieuse aussi, j’ai eu ce problème sur ma pompe avec un comportement aléatoire.
benproof
benproof
Moto : XTZ 750 Super Ténéré
Kms de ma moto : 68000
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptySam 30 Jan 2021 - 11:27
Hello,
Petite question, tu n'avais pas changé les membranes lors de ta réfection des carbus il y a 8000km ?
Non parce que je rencontre un problème similaire...7 000 km depuis une réfection complète des carbus, je dirais qu'il manque juste à changer la membrane d'enrichissement à la décélération.
Mais bref depuis le week dernier; démarrage sans problème mais ralentis qui se maintiens à 1 500-1 600trs au lieu de 1 200trs sans rien avoir toucher...et j'entends que ça fait de petites explosion dans le pots, le froid peut etre ?
je roule 100m et à la décélération, le moteur redescend très lentement et le ralentis se maintiens à 3 000trs !
Pire, le moteur est bien chaud, je mets le starter et le régime augmente encore plus?
Bon je vais regarder demain mais je te rejoins, c'est vrai qu'elle est aussi attachante qu’épuisante cette meule!
Mais je me demande quand même si ça ne viendrais pas de tous ces kits réfection carbu et dans la qualité des joints plasthiques. Qui sont de moindre qualité que les Yamaha. Pour info j'ai fait 7000 km depuis la réfection des carbu sans aucun prob.
coolstef
coolstef
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptySam 30 Jan 2021 - 16:16
Au final, on a tous plus ou moins les mêmes symptômes avec un ralenti instable, trop haut, des pétarades dans le pot et et des descellerations pas franches.
J’ai pas mal cherché aussi. Il peut y avoir d’autres causes bien sûr mais c’est quand même très souvent lié à une prise d’air quelque part entre la boîte à air et les pipes d’admission, ce qui fait beaucoup de pistes à explorer, donc de haut en bas :
-manchons mal fixés (put... de filtre à air...)
-membranes même légèrement poreuses ou mal jointes
-joints dans le carbu (joint du pointeau, porte gicleur, joint de la mort...)
-starter (tirette qui revient pas bien, plongeurs en plastique bouffés...)
-mauvaise synchro
-durite de dépression vers la pompe mal fixée ou poreuse
-membrane de la pompe usée
-j’en oublie...
benproof
benproof
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptySam 30 Jan 2021 - 17:32
C'est ca! je me demande aussi si ca vient pas de ma pompe à essence aliexpress à 10€...bref ya du travail!
Merci pour ta réponse
Vincent974
Vincent974
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyLun 1 Fév 2021 - 16:32
benproof a écrit:
Hello,
Suis exactement sur le même schémas! Je n'avais juste pas changé les membranes et pourtant entre temps j'avais installé un kit suisse ... mais ces derniers temps, j'ai eut en effet les symptomes que tu décris, notamment ce ralenti qui ne redescend pas bien à la décélération. Kedo propose des membranes seules vendues à l'unité. Ces petits problèmes deviennent de plus en plus récurents jusqu'au moment où ça fait du ON/OFF qui ne semble pas trop lié aux incidents précédents.
Bon, j'ai pas encore reçu les miennes pour pouvoir affirmer que je suis tiré d'affaire
Sinon, quelqu'un sait où je peux acheter un capteur de point mort??? le mien a rendu l'âme.
Egalement si vous avez des références de guidon sympa à adapter su nos brèles, le mien est fatigué et très légèrement tord suite à une chute du précédent proprio
coolstef
coolstef
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyLun 1 Fév 2021 - 19:19
On est tous un peu dans le même cas avec ces carbus mais je pense que j'ai énuméré plus haut la plupart des problèmes potentiels. J'ai aussi mis un kit suisse et la seul chose que je n'ai pas changé, c'est justement les membranes et pourtant je n'ai plus de problème donc à suivre...
Pour ton guidon, j'ai mis un Renthal 701, un peu plus plat mais je le trouve plus confortable.
benproof
benproof
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptySam 6 Fév 2021 - 21:33
Bon ben voila je viens de trouver ma panne, c'est le piston du starter du cylindre gauche qui etait resté coincé en position ouverte!
Reste que même à chaud quand j'activais le starter la moto monter encore plus des les tours.
Qu'est ce qu'active le starter de l'XTZ quand on le mets? est ce que c'est un mélange air essence ou juste de l'essence pour enrichir le mélange au demarrage ?
Bonfaut que je vois pourquoi par contre le starter restait coincé...
alain30à10
alain30à10
Moto : 750 XTZ 1989 (n° 2279)
Pneu AV/AR : ANAKEE
Ville ou région : 10
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyDim 7 Fév 2021 - 8:47
slt à tous.
coolstef a écrit : "la boîte à air est souvent mal fixée après un démontage".
Pour ne plus être em....é j'avais suivi les conseils d'un gar du forum et j'ai mis des raccords de plomberie (caoutchouc souple) entre la boîte à air et les carbus.
coolstef
coolstef
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyDim 7 Fév 2021 - 11:07
Une autre solution est de chauffer les manchons. J’utilise un petit radiateur soufflant, je mets la boite à air avec les manchons devant . Dès que les caoutchoucs sont ramollis, je positionne la boîte sans difficultés.
MiniSapin
MiniSapin
Moto : XTZ 750 Super Tenere
Kms de ma moto : 62300
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyDim 7 Fév 2021 - 21:50
Le starter c'est un mélange air/essence qui est fait par un gicleur spécifique au starter Smile
benproof
benproof
MessageSujet: Re: En panne ... encore ... help, encore :(   En panne ... encore ... help, encore :( EmptyDim 7 Fév 2021 - 22:35
Merci!
Pour le retour d'expérience.
Comme la moto à tournée avec le cylindre gauche avec le stater en position "ON" je me suis dit qu'on aller jeter un œil aux pistons du starter.
Ces deux pistons de starter on 9 000 km.
Celui qui est resté en position ouverte cylindre gauche est mort (je ne sais combien de kilométres), pas dans un état pitoyable mais mort quand même.
Celui du cylindre droit est ok
» En panne...
» Help en panne !
» HELP C'EST LA PANNE !
» panne carbu 750
