MotoZ Tractionator Adventure Emptypar SuperTiti Hier à 21:40
MotoZ Tractionator Adventure Emptypar Joe644 Hier à 18:56
MotoZ Tractionator Adventure Emptypar yop1025 Hier à 13:10
MotoZ Tractionator Adventure Emptypar REYNALD Mar 19 Nov 2024 - 10:58
MotoZ Tractionator Adventure Emptypar REYNALD Mar 19 Nov 2024 - 10:49
MotoZ Tractionator Adventure Emptypar REYNALD Mar 19 Nov 2024 - 10:46
MotoZ Tractionator Adventure Emptypar REYNALD Mar 19 Nov 2024 - 10:44
MotoZ Tractionator Adventure Emptypar jackal74 Lun 18 Nov 2024 - 11:58
MotoZ Tractionator Adventure Emptypar Arni Dim 17 Nov 2024 - 14:06
MotoZ Tractionator Adventure Emptypar Arni Dim 17 Nov 2024 - 13:13
MotoZ Tractionator Adventure Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
MotoZ Tractionator Adventure Emptypar yop1025 Sam 16 Nov 2024 - 23:12
MotoZ Tractionator Adventure Emptypar Fredard Sam 16 Nov 2024 - 9:43
MotoZ Tractionator Adventure Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
MotoZ Tractionator Adventure Emptypar J-Marc Mar 12 Nov 2024 - 12:44
MotoZ Tractionator Adventure Emptypar J-Marc Lun 11 Nov 2024 - 21:58
MotoZ Tractionator Adventure Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
MotoZ Tractionator Adventure Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
MotoZ Tractionator Adventure Emptypar thierry83 Dim 10 Nov 2024 - 9:29
MotoZ Tractionator Adventure Emptypar REYNALD Ven 8 Nov 2024 - 16:55
MotoZ Tractionator Adventure Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
MotoZ Tractionator Adventure Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
MotoZ Tractionator Adventure Emptypar REYNALD Mar 29 Oct 2024 - 20:18
MotoZ Tractionator Adventure Emptypar REYNALD Mar 29 Oct 2024 - 20:00
MotoZ Tractionator Adventure Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
rabaissement reglage galére huile longues tuto amortisseur embrayage tenere boue selle arrière crash filtre feux pneus essence chaine suis phare fourche manuel synchro réservoir garde vidange
etinag
etinag
Pneu AV/AR : Cramponnés
MessageSujet: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyMar 1 Oct 2019 - 17:22
Essai d'une paire de pneus MotoZ Tractionator Adventure
Ici sur la photo au premier plan et à comparer au Full Bore Adventure monté sur les jantes qui sont, on va dire... bref ... bof
Agrandir cette image Cliquez ici pour la voir à sa taille originale.
MotoZ Tractionator Adventure Img-2010
Taille 150/70/17 ar et 110/80/19 av sur XTZ1200 de 2013
MotoZ Tractionator Adventure Img_2168
MotoZ Tractionator Adventure Img_2167
Testé sur le CMT 2019 (Catharemototrail) du 26 au 29 /09. Trois jours de mix pistes/routes. Environ 50/50 voir 60 % de pistes.
Météo : très humide par moments vu départ très matinal (ouvreur) et altitude mais ensuite chaleur et soleil.
Je recherchais une paire de pneus pour la XTZ1200 pouvant rendre celle-çi plus fun à emmener sur pistes et chemins.  J'avais déjà essayé divers montes mais aucune ne me satisfaisait. Trop de galettes/pas assez de crampon/pneus trop routier/usure trop rapide etc ...
Ici rien de tout ça. D'emblée quand vous voyez les crampons (on parle bien de crampons et non de galettes) vous vous dites " là ça cause !" Je n'avais plus d’appréhension à emmener la grosse sans devoir être constamment sur la retenue.
Le résultat de l'essai à été plus loin que mes attentes.
Cette monte a complètement transfiguré le comportement de la 12. J'ai bien sur réglé la compression 0+3 et détente 0+3 de la fourche  (au plus souple). précontrainte sur 7 (sur 10 ). A l'arrière molette de précontrainte au plus soft et réglage de la détente au plus soft càd 0+3 sur 20 . J'avais donc là une moto réglée au plus souple avec une dureté de précontrainte à l'avant contenue.
Pression 2.0 av et 2.0 ar.
Déjà étant enduriste assez confirmé et ayant aussi l'habitude de tabasser avec ma 660 XTZ je peux dire que cette monte/réglage n'a rien a envier au plus légère cramponnée. Ce chässis de 1200XTZ est tout simplement bluffant. Et la monte MotoZ en retire toute la quintessence. Je me suis jamais autant amusé avec la 12 et ce sans retenue. Le fait de pouvoir régler est un must et la fourche inversée régale. Contrairement à une 660 XTZ 2008+ qui se tortille (vous avez beau upgrader les suspattes le châssis est du mou de veau) ici l'ensemble est très cohérent. L'ensemble vous téléphonera la piste et les réactions immédiatement.
Que ce soit dans le sec à caillasse ou l'herbe enrobée d'humidité matinale elle a assuré. Elle m'a tellement rassuré que j'y prenais même plus de plaisir qu'avec la 660 XTZ montée en MT21 av et Mitas 09 ar.
Bien sur j'ai un guidon enduro avec 2 cm de rehausse (l'origine ne permet pas de rouler debout constamment et trop large), et sélecteur relevé d'un cran pour utilisation botte enduro.
Forcément vous n'ouvrez pas de la même façon avec 270 kg comme avec 110 voir 190 kg car les distances de freinage sont considérablement allongées si vous devenez trop généreux avec la mains droite. ABS au top aussi et TCS sur 1 avec mode moteur sur T. Au plus soft j'ai dis ;-) . Ce TCS est une merveille aussi vu le poids à tirer dans les grimpettes et surtout ne pas devoir tirer dans les pneus. Toujours en mouvement bien sur car les départs à zéro en côte sont mortelles .
Me suis permis quelques sessions "pour voir" et on oublie vite qu'on envoi près de 350 kg sur la piste (moto + gars dessus). Changement d'ornières ou dérive en virage, tout est permis.
Ce moteur qui permet de descendre et reprendre quasi au ralenti sans cogner/caler est une merveille aussi.
Bref ce binôme moto/pneus est une merveille et cerise sur le gâteau il n'a quasi pas bougé sur les 1200 km pratiqué.
Ah si un défaut : le bruit des crampons ... mais on oublie vite une fois sur la piste ;-)
Et puis sa disponibilité. Les miens viennent d'Espagne (merci en passant à Issac de TwinTrail ;-))
MotoZ Tractionator Adventure Img_2169
MotoZ Tractionator Adventure Img_2170
gerardgrandgg
gerardgrandgg
Moto : 1200 xtz
Kms de ma moto : 50000
Pneu AV/AR : michelein anakee3
Ville ou région : le rouret
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyMer 2 Oct 2019 - 5:58
bon ça ma l'air top tout ça ,quand pense tu pour de les monter sur la petite soeur (660 XTZ),je dois partir 10 au Maroc sur les pistes et je cherche quoi monter ,sachant que j'aurai environ 500km de route
volpone
volpone
Moto : bmw1100GS / yamaha 700 tenere
Kms de ma moto : 95000
Ville ou région : vercors sud
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyMer 2 Oct 2019 - 8:30
le probleme c'est pour trouvé ces pneus c'est le parcours du combattent !! MotoZ Tractionator Adventure 49290
"Heureux soient les fêlés, car ils laisseront passer la lumière."
CasseDale
CasseDale
Moto : XTZ 1200 sept. 2017
Kms de ma moto : 83.000
Ville ou région : Lille
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyJeu 3 Oct 2019 - 0:05
Excellent, ton retour d'expérience, Etinag !
Pour le TCS, je croyais qu'en off-road il était préférable d'autoriser un peu de glissouille et donc de régler le TCS sur 2 ? Est-ce que je me trompe ?
etinag
etinag
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyJeu 3 Oct 2019 - 10:20
@CasseDale
Pour le TCS il est vrai que certains préfèrent limiter son fonctionnement. Mais bon même si je ne suis pas un manchot en enduro/trail light ici on parle de 270 kg de bestiau à tirer dans les chemins. Frétos ne se posera pas de questions (quoique j'avais lu qu'il roulait avec aussi) alors que moi j'aime sentir le TCS réguler les pertes de motricités. Et il le fait très bien. Des grimpettes infâmes avec cailloux roulant et/ou saignées et gérées par ce TCS1 s'avalent sans problèmes. Impressionnant comment ce moteur peu repartir de rien alors que ces coupures d'injection te font croire qu'il est en train de s'arrêter/caler.
De plus les pistes sèches et plates se régulent plus facilement aussi car le bestiau ayant quand même une certaine puissance tu laisse vite des longueurs de circonférences de roue ar largement supérieure à la distance parcourue  clin d\'oeil .
Pour une fois que j'ai le bon pneu pour déconner dans les chemins avec cette 12 je voudrai les préserver un peu quand même.
CasseDale
CasseDale
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyJeu 3 Oct 2019 - 16:25
@Etinag
Ca paraît très rassurant, en effet, un TCS1 comme ça.
Sur route, le TCS1 m'a déjà sorti de situations scabreuses et j'en suis ravi.
N'étant en rien un motard off-road, je m'excuse à l'avance pour mes questions béotiennes, que je pose quand même parce que les pistes (sèches) me font de l'oeil et qu'un voyage au long cours me tente bien (et des pistes pourraient être incontournables, alors je me prépare mentalement).
C'est que, voilà, je visionne pas mal de vidéos de motards sur pistes et j'ai l'impression qu'ils prennent leurs virages en drift pour s'aider à tourner, comme une glissade légère et contrôlée que le TCS1 ne devrait pas permettre, si j'ai bien saisi. Mais peut-être le TCS2 est-il conçu pour ça ?
J'ai souvenir d'avoir ainsi "drifté" une 404 pick-up en Afrique sur des virages en tôle ondulée de latérite à 90 km/h mini, assez flippant au début, plutôt drôle ensuite. Après tout, une moto, c'est une propulsion aussi.
Je suis avide de tes commentaires d'enduriste !
etinag
etinag
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyJeu 3 Oct 2019 - 18:48
Arfff ...
Drifter avec un 1200 de 270 kg (hors pilote) ... ma foi ...
Ok c'est fun sur piste blanche avec vue et largeur dégagée mais gare à l’atterrissage. Tu ouvre ça envoi/répond direct mais pour freiner... Tu me demanderai aussi de débrancher l'ABS que je dirai non!
Le TCS1 me sert surtout à enquiller des grimpettes un poil technique ou normalement je devrais empoigner/jouer avec l'embrayage (un peu comme avec le Rekluse sur ma 501 HVA mais lui c'est mécanique alors que le TCS c'est électronique) . En partant de ça, et comme il n'est pas modulable à la demande en roulant, c'est caler sur TCS1, point.
Bref toute cette technologie embarquée permet de s'amuser avec des maxi-trails  clin d\'oeil
Plus d'une fois j'ai terminé une grimpette ou c'était TCS1 à la mitraillette dans le dernier mètre et témoin allumé quasi en permanence. Moteur qui descend aussi quasi au plus bas et ce sans caler.
Remph
Remph
Moto : XT600 - XTZ 1200
Kms de ma moto : 70 000
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyJeu 3 Oct 2019 - 19:32
Salut Casse Dalle, ton observation est juste mais pour tes pistes sèches en mode voyage, je pense pas que tu aies besoin de faire tourner la moto aux gaz.^^ Ou alors tu voyages vite. ;)
En revanche tu as tout de même besoin d'avoir une accélération constante pour tourner, si tu coupes en virages tu sens que la moto veut élargir. (un peu de frein arrière aide à ce moment là). Avis d'un non enduriste ceci dit.
Le TCS1 t'autorisera juste ce qu'il faut de glissouille en fin de virage ou pour faire virer la moto dans du serré. Et puis comme dit Etinag, il te fait passer partout. Les copains étaient sur le cul quand j'étais juste derrière eux en montée sur terre humide avec des vieux Tourance Next usés. Le TCS te donne l'impression que la moto va caler mais tu gardes les gaz et la moto fait le boulot moyennant un peu d'équilibre en déplaçant le bassin. Cette assistance est un super garde-fou, j'apprécie beaucoup.
Le seul moment où le TCS1 "gêne" c'est pour le demi tour sur place ou quand il te coupe les gaz alors que t'as contrebraqué en prévision de la glisse, ce qui m'a fait découvrir d'un peu plus près un buisson proche.
Sur route en TCS2 ou off, tu sens aussi que la puissance arrive plus violemment.
Le mieux: tu te trouves une piste sèche large, tu ouvres en grand dans chaque mode puis tu compares. ;) Sans oublier qu'il y a un gros bestiau à stopper ensuite. Tu as l'air de t'intéresser de plus en plus à mettre ta 12 sur les pistes, surtout il faut oublier les vidéos promo, rouler lentement les pieds sur les reposes pieds un maximum, sinon c'est la désillusion.
Au plaisir de te revoir de passage dans l'Oise !
CasseDale
CasseDale
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyJeu 3 Oct 2019 - 19:52
Merci, les gars, grâce à vous, je comprends mieux ce à quoi le Traction Control sert effectivement et je vais sagement en rester au TCS1.
Quant aux pistes, glop glop, mais en apprentissage avec une moto plus légère (et à usage moins professionnel, aussi, parce que je ne peux pas me passer de ma 12 pour aller au boulot, du coup je ne veux pas risquer de l'abîmer).
izno
izno
Moto : XTZ 1200 super tenere 2012
Kms de ma moto : 51000
Ville ou région : bergerac
MessageSujet: Re: MotoZ Tractionator Adventure   MotoZ Tractionator Adventure EmptyJeu 5 Nov 2020 - 19:08
désoler du déterrage de poste ;) mais ; etinag pourrait tu m'en dire plus avec le recule sur cette monte t'en au niveau off road sur sec et gras , que sur bitume sèche et pluie  , je roule actuellement tout les jours et par tout temps en mitas E09 et j'en suit ravis , la longévité est elle au rendez vous combien de kilomètre avec la monte merci par avance de tes réponse ;)
doigtsenV
» KTM adventure
» Tony en GS 800 ADVENTURE
» Trail adventure
» vol d'une KTM 950 Adventure de 2003
» Essai Ktm 990 Adventure
