support sw motech Emptypar oeuf Aujourd'hui à 10:11
support sw motech Emptypar oeuf Aujourd'hui à 10:03
support sw motech Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
support sw motech Emptypar Joe644 Mer 20 Nov 2024 - 18:56
support sw motech Emptypar yop1025 Mer 20 Nov 2024 - 13:10
support sw motech Emptypar REYNALD Mar 19 Nov 2024 - 10:58
support sw motech Emptypar REYNALD Mar 19 Nov 2024 - 10:49
support sw motech Emptypar REYNALD Mar 19 Nov 2024 - 10:46
support sw motech Emptypar REYNALD Mar 19 Nov 2024 - 10:44
support sw motech Emptypar jackal74 Lun 18 Nov 2024 - 11:58
support sw motech Emptypar Arni Dim 17 Nov 2024 - 14:06
support sw motech Emptypar Arni Dim 17 Nov 2024 - 13:13
support sw motech Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
support sw motech Emptypar yop1025 Sam 16 Nov 2024 - 23:12
support sw motech Emptypar Fredard Sam 16 Nov 2024 - 9:43
support sw motech Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
support sw motech Emptypar J-Marc Mar 12 Nov 2024 - 12:44
support sw motech Emptypar J-Marc Lun 11 Nov 2024 - 21:58
support sw motech Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
support sw motech Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
support sw motech Emptypar thierry83 Dim 10 Nov 2024 - 9:29
support sw motech Emptypar REYNALD Ven 8 Nov 2024 - 16:55
support sw motech Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
support sw motech Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
support sw motech Emptypar REYNALD Mar 29 Oct 2024 - 20:18
huile crash amortisseur arrière manuel rabaissement essence synchro galére filtre boue vidange feux phare pneus chaine tenere fourche embrayage selle reglage suis longues réservoir garde tuto
 support sw motech
sub_zero30
sub_zero30
Kms de ma moto : 63000
Ville ou région : ALES
MessageSujet: support sw motech   support sw motech EmptyLun 17 Sep 2018 - 13:26
salut la compagnie, est ce que l'un d'entre vous à ça qui traîne dans son garage?
Je cherche le support haut de chez sw-motech qui se monte sur une 1200 super tenere afin de pouvoir placer mes feux tecnoglobe en hauteur!
faites moi vos propositions en mp!
merci d'avance! V
petite photo d’illustration!support sw motech Suppor10
MessageSujet: Re: support sw motech   support sw motech EmptyLun 17 Sep 2018 - 17:52
Pinaiz j'en voulais un aussi. Et quand j'ai vu le prix je me suis résigné.
Cette position fait qu'en TT sur piste étroite ou chemin ça accroche tout! Et si tu t'en poses une, selon comment, tu peux les arracher.
Tu peux facilement te bricoler un support ou en trouver un et te fixer sur les vis du cache sous le bloc optique. Ce que j'ai fait, ça donne un peu comme le montage des AB de chez Yam.
sub_zero30
sub_zero30
MessageSujet: Re: support sw motech   support sw motech EmptyLun 17 Sep 2018 - 19:11
Bin c'est ce que j'ai fait, j'ai fait un support mais je ne suis pas complétement satisfait... J'ai du mal à régler de manière optimale mes projecteurs. Bien que c'est déjà pas mal ! Je chipote pour avoir quelque chose de tip top.support sw motech Img_2010
MessageSujet: Re: support sw motech   support sw motech EmptyMar 18 Sep 2018 - 13:36
C'est quoi le réglage spécifique que tu voudrais faire?
sub_zero30
sub_zero30
MessageSujet: Re: support sw motech   support sw motech EmptyMar 18 Sep 2018 - 14:33
avoir un peu plus de"marge" pour les reglages, la les fils touchent les flancs et ne me laissent pas trop de choix. Mon support que j'ai fabriqué est en acier donc pas super leger non plus...
MessageSujet: Re: support sw motech   support sw motech EmptyMer 19 Sep 2018 - 13:13
C'est vrai qu'ils sont plus gros que les miens tes feux.
Bon pour le poids, on s'en fou un peu, on n'est plus à ça près avec cette grosse mémère.
Et pour les fils, là je peux pas te dire... j'ai du mal à voir sur ta première photos.
Sinon pour les réglages de faisceau, je ne comprends pas, tu voudrais que ça éclaire plus sur les côtés ou autres?
sub_zero30
sub_zero30
MessageSujet: Re: support sw motech   support sw motech EmptyMer 19 Sep 2018 - 13:48
ouais ils sont assez gros (10cm de diamètre!)
pour le poids, c'est surtout pour limiter les tensions sur le support des feux qui sont en plastiques. Vu que mes Lp ne sont pas super légers...
pour le réglage, idéalement je voudrais pouvoir croiser les faisceaux. mais vu le passage (position centrale)du câble à l'arrière du feux et le fait que ça touche l’intérieur du carénage je suis un peu obligé d’éclairer "droit" a coté du faisceau d'origine. Du coup je n'y gagne pas énormément en virage bien que ça éclaire quand même sévère! tu pourra le voir bientôt!
Ca eclaire tellement fort que je songe à installer un dimer!
MessageSujet: Re: support sw motech   support sw motech EmptyVen 21 Sep 2018 - 15:30
Ah ok... tu t'es repris sur les trous qui servent à fixer le cache sous le feu des ZE?
C'est quoi tes feux? Technoglobe?
Effectivement ils ont l'air d'envoyer aussi. J'ai mis un dimmer sur les miens car ça éblouit même en plein jour.
Il est bien foutu ce dimmer car il a un relais interne avec un fil en sortie. Quand tu mets 12V sur ce fil, l'éclairage passe à pleine puissance. Et quand il a 0V, il passe au réglage de puissance donnée par le dimmer. Très pratique la nuit quand tu croises des véhicules.
Je mets le dimmer au mini, ça suffit pour être mieux vu le jour (remontée de file) et ne pas éblouir la nuit et quand je mets les pleins phare, la puissance passe au max.
sub_zero30
sub_zero30
MessageSujet: Re: support sw motech   support sw motech EmptyVen 21 Sep 2018 - 19:06
ouais je me suis servi de ces fixations! vachement pratique!
mes feux c'est bien des tecnoglobe. lien du modèle: http://www.tecnoglobemoto.com/eclairage-tg/243-feu-led.html
tu peux me rappeler quel dimmer tu as?
MessageSujet: Re: support sw motech   support sw motech EmptyLun 24 Sep 2018 - 13:10
Celui d'ADV Monster chez qui j'avais acheté les feux également.
http://stores.advmonster.com/rotary-led-dimmer-with-high-beam-bypass/
J'avais bien apprécié la présence du by-pass pour l'alternance feu croisement / route. Et j'avais l'assurance de la compatibilité avec mes feux. Car les leds, ça ne se pilote pas avec n'importe quoi.
support sw motech
» support SW motech
» SW MOTECH support
» Support GPS SW MOTECH XTZ 1200
» [HELP] ... Support valises SW-Motech TraX ... ;-) ...
» pose support motech pour ST 1200 2014 sur modele 2013
SUPER TENERE XTZ :: PETITES ANNONCES :: ACHATS / VENTES PIECES DÉTACHÉES pour Ténéré et Super Ténéré XTZ, Accessoires, équipement etc.. :: RECHERCHES PIECES DÉTACHÉES-
