CABLE +  SOUS LA SELLE ? Emptypar SuperTiti Hier à 21:40
CABLE +  SOUS LA SELLE ? Emptypar Joe644 Hier à 18:56
CABLE +  SOUS LA SELLE ? Emptypar yop1025 Hier à 13:10
CABLE +  SOUS LA SELLE ? Emptypar REYNALD Mar 19 Nov 2024 - 10:58
CABLE +  SOUS LA SELLE ? Emptypar REYNALD Mar 19 Nov 2024 - 10:49
CABLE +  SOUS LA SELLE ? Emptypar REYNALD Mar 19 Nov 2024 - 10:46
CABLE +  SOUS LA SELLE ? Emptypar REYNALD Mar 19 Nov 2024 - 10:44
CABLE +  SOUS LA SELLE ? Emptypar jackal74 Lun 18 Nov 2024 - 11:58
CABLE +  SOUS LA SELLE ? Emptypar Arni Dim 17 Nov 2024 - 14:06
CABLE +  SOUS LA SELLE ? Emptypar Arni Dim 17 Nov 2024 - 13:13
CABLE +  SOUS LA SELLE ? Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
CABLE +  SOUS LA SELLE ? Emptypar yop1025 Sam 16 Nov 2024 - 23:12
CABLE +  SOUS LA SELLE ? Emptypar Fredard Sam 16 Nov 2024 - 9:43
CABLE +  SOUS LA SELLE ? Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
CABLE +  SOUS LA SELLE ? Emptypar J-Marc Mar 12 Nov 2024 - 12:44
CABLE +  SOUS LA SELLE ? Emptypar J-Marc Lun 11 Nov 2024 - 21:58
CABLE +  SOUS LA SELLE ? Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
CABLE +  SOUS LA SELLE ? Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
CABLE +  SOUS LA SELLE ? Emptypar thierry83 Dim 10 Nov 2024 - 9:29
CABLE +  SOUS LA SELLE ? Emptypar REYNALD Ven 8 Nov 2024 - 16:55
CABLE +  SOUS LA SELLE ? Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
CABLE +  SOUS LA SELLE ? Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
CABLE +  SOUS LA SELLE ? Emptypar REYNALD Mar 29 Oct 2024 - 20:18
CABLE +  SOUS LA SELLE ? Emptypar REYNALD Mar 29 Oct 2024 - 20:00
CABLE +  SOUS LA SELLE ? Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
huile boue reglage galére tuto filtre embrayage réservoir feux manuel pneus longues crash chaine phare selle essence fourche vidange rabaissement arrière suis amortisseur tenere synchro garde
Le Deal du moment : -55%
49.99 €
a9stewaf
Moto : xtze 1200 2016
Kms de ma moto : 57000 KM
MessageSujet: CABLE + SOUS LA SELLE ?   CABLE +  SOUS LA SELLE ? EmptySam 18 Avr 2020 - 15:33
Bonjour existe t il une possibilité de brancher un chargeur sous la selle par une connexion +12v et un - ? Ca existe sur certaines machines mais sur la ST 12 je ne sais pas. Merci. Laurent
a9stewaf
MessageSujet: Re: CABLE + SOUS LA SELLE ?   CABLE +  SOUS LA SELLE ? EmptyDim 19 Avr 2020 - 16:34
Bonjour je réponds a mon interrogation après avoir passé en revue les manuels de la Z et de la ZE ; malheureusement il n'y a rien de prévu pour brancher une pince croco , il faut donc démonter la cache latéral droit pour avoir accès. Laurent
Domi1663
Domi1663
Moto : Tracer 9 GT
Kms de ma moto : 6500
MessageSujet: Re: CABLE + SOUS LA SELLE ?   CABLE +  SOUS LA SELLE ? EmptyDim 19 Avr 2020 - 19:18
Sinon, j'ai acheté un chargeur genre OPTIMATE chez MOTO AXXE (sans vouloir faire de pub) il est livré avec des câbles et une fiche à fixer et laisser sur la moto. Il suffit de le place à un endroit accessible facilement, genre sous la selle pour ensuite brancher le chargeur dessus.
J'ai du payer ça 40 ou 50 € max.
Après si tu a déjà un chargeur, il te suffit de tirer depuis la batterie 2 fils + et - sous la selle et leur mettre une fiche, si possible avec détrompeur, on ne sait jamais et équiper ton chargeur avec la même fiche modèle opposé (mâle ou femelle fonction de celle mise sous la selle).
MessageSujet: Re: CABLE + SOUS LA SELLE ?   CABLE +  SOUS LA SELLE ? EmptyDim 19 Avr 2020 - 23:34
CABLE +  SOUS LA SELLE ? Dsc00811CABLE +  SOUS LA SELLE ? Dsc01224CABLE +  SOUS LA SELLE ? Dsc_0617CABLE +  SOUS LA SELLE ? Nkp11CABLE +  SOUS LA SELLE ? Dsc_1619
a9stewaf
MessageSujet: Re: CABLE + SOUS LA SELLE ?   CABLE +  SOUS LA SELLE ? EmptyMar 21 Avr 2020 - 19:22
salut a vous; oui je sais pour le chargeur....laurent
joe64
joe64
Moto : xt1200z
Kms de ma moto : 23000
Ville ou région : cote basque
MessageSujet: Re: CABLE + SOUS LA SELLE ?   CABLE +  SOUS LA SELLE ? EmptyMer 22 Avr 2020 - 10:29
CABLE +  SOUS LA SELLE ? Img_2010
Pour ma part, j'ai coincé la prise dans le haut du carénage, elle très facile d’accés , de plus le câble est suffisamment long pour la déboîter  afin d'emmancher l'autre plus facilement .
sly32
sly32
Moto : Super ténéré Raid edition 2019
Kms de ma moto : 4000
Ville ou région : montauban
MessageSujet: Re: CABLE + SOUS LA SELLE ?   CABLE +  SOUS LA SELLE ? EmptyMer 22 Avr 2020 - 13:23
ok pour le chargeur mais au bord de la route si on doit sortir les cables, existe il un systeme ?
» cable libre dans le coffre sous la selle ?
» connecteur sous dosseret de selle
» Prise sous la selle
» Prises sous la selle
» branchements sous la selle
