Probleme elec. Emptypar SuperTiti Hier à 21:40
Probleme elec. Emptypar Joe644 Hier à 18:56
Probleme elec. Emptypar yop1025 Hier à 13:10
Probleme elec. Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Probleme elec. Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Probleme elec. Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Probleme elec. Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Probleme elec. Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Probleme elec. Emptypar Arni Dim 17 Nov 2024 - 14:06
Probleme elec. Emptypar Arni Dim 17 Nov 2024 - 13:13
Probleme elec. Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Probleme elec. Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Probleme elec. Emptypar Fredard Sam 16 Nov 2024 - 9:43
Probleme elec. Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Probleme elec. Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Probleme elec. Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Probleme elec. Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Probleme elec. Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Probleme elec. Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Probleme elec. Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Probleme elec. Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Probleme elec. Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Probleme elec. Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Probleme elec. Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Probleme elec. Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
huile garde embrayage rabaissement chaine vidange tenere réservoir feux amortisseur synchro longues suis pneus crash reglage galére tuto selle manuel essence boue fourche filtre phare arrière
-23%
(Black Friday) Apple watch Apple SE GPS 44mm (plusieurs coloris)
199 € 259 €
 Probleme elec.
Kimmor
Kimmor
Moto : Super tenere xtz
Kms de ma moto : 43 000
Ville ou région : Nantes
MessageSujet: Probleme elec.   Probleme elec. EmptyMer 17 Aoû 2016 - 22:53
[size=45]Bonjour a tous. Je suis mecanicien sur les engins mais mes competences ont des limites en ce qui concerne la moto. Voila je suis proprietaire d'un super tenere de 1990 depuis 2 semaines , il totalise 43000 kms et est plutot en tres bon etat esthetique et fonctionne tres bien a premiere vue . Connaissant les faiblesses de ces modeles j'ai voulu controler le circuit de charge et la je me suis appercu que moteur tournant peu importe le nombre de tour la charge n'excedait pas 12,4v. Je zappe le regulateur et me dirige direct vers l'alternateur pour controler la resistance du stator et en enlevant le carter d'alternateur j'ai vidangé de l'huile moteur..a peu pres 1l..est ce normal que l'alternateur baigne dans l'huile ???? Merci a vous de m'eclairer[/size]
Kms de ma moto : laquelle ?
Ville ou région : Besançon
MessageSujet: Re: Probleme elec.   Probleme elec. EmptyJeu 18 Aoû 2016 - 1:31
que ça baigne dans l'huile, oui t'as pas à t'inquiéter. Pourquoi t'as zappé le regulateur ?
Kimmor
Kimmor
MessageSujet: Re: Probleme elec.   Probleme elec. EmptyJeu 18 Aoû 2016 - 8:51
En theorie un regulo cramé ne regule plus, donc tension au dessus de 14 v,(corrige moi si je me trompe) moi j'ai des oscillations de tension entre 11,9 et 12,4 jai donc pensé a l'alternateur qui ne produit pas assez de tension.
Kimmor
Kimmor
MessageSujet: Re: Probleme elec.   Probleme elec. EmptyJeu 18 Aoû 2016 - 8:52
De plus tous les organes electriques ( feux, cligno, klaxon) sont plutot faiblards a bas regime.
MessageSujet: Re: Probleme elec.   Probleme elec. EmptyJeu 18 Aoû 2016 - 10:58
En théorie comme tu dis ... Jette un oeil à ton régulateur ;)
yd64
yd64
Moto : XT660Z (2011)
MessageSujet: Re: Probleme elec.   Probleme elec. EmptyJeu 18 Aoû 2016 - 13:52
Jeter un œil sur les connections du régulateur d’accord.
Mais comment le tester si ce n'est en prenant la tension à la batterie,moteur en marche à + ou - 14v???
MessageSujet: Re: Probleme elec.   Probleme elec. EmptyJeu 18 Aoû 2016 - 17:20
Mesure les tensions en voltmètre alternatif en sortie d'alternateur, ça va déjà te donner une idée ...
Ensuite, au niveau de la batterie, les valeurs que tu trouves sont insuffisantes en tension "continu"; as tu refait la même mesure en voltmètre alternatif ? il se peut très bien que le régulateur qui est aussi régulateur- redresseur fasse mal son travail de redresseur et laisse passer des alternances que tu vas retrouver à la batterie; si tu as largement plus d'un volt (genre 2 ou 3 volts)en "alternatif", moteur tournant, aux bornes de la batterie...Méfiance!!  (l'idéal, bien entendu étant de n'avoir que quelques 10 èmes de volt . )
Méfie toi aussi des connecteurs qui s'oxydent ...
Kimmor
Kimmor
MessageSujet: Re: Probleme elec.   Probleme elec. EmptyJeu 18 Aoû 2016 - 21:11
Merci a vous. Bons conseils dédé je vais les suivre. Jai un joint de carter d'alternateur ,un pressostat et quelqies bricoles a changer quelqu'un aurait un site de pieces détachées neuves a me conseiller? Pas simples de trouver tout ca. Merci
Probleme elec.
» question elec
» Drole de faisceau elec
» panne de elec cet apres midi !!!!!!!!!!
» ACCES AU CONNECTEUR FAISCEAU ELEC AVANT AMPOULE DU FEU ARRIERE ST 1200
