Help remise en route 80MTX Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
Help remise en route 80MTX Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Help remise en route 80MTX Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Help remise en route 80MTX Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Help remise en route 80MTX Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Help remise en route 80MTX Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Help remise en route 80MTX Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Help remise en route 80MTX Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Help remise en route 80MTX Emptypar Arni Dim 17 Nov 2024 - 14:06
Help remise en route 80MTX Emptypar Arni Dim 17 Nov 2024 - 13:13
Help remise en route 80MTX Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Help remise en route 80MTX Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Help remise en route 80MTX Emptypar Fredard Sam 16 Nov 2024 - 9:43
Help remise en route 80MTX Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Help remise en route 80MTX Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Help remise en route 80MTX Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Help remise en route 80MTX Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Help remise en route 80MTX Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Help remise en route 80MTX Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Help remise en route 80MTX Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Help remise en route 80MTX Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Help remise en route 80MTX Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Help remise en route 80MTX Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Help remise en route 80MTX Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Help remise en route 80MTX Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
tuto pneus arrière filtre huile longues suis manuel réservoir feux crash essence chaine embrayage phare amortisseur garde selle reglage vidange synchro tenere galére boue rabaissement fourche
-25%
749.99 € 999.99 €
Valoche
Valoche
Moto : XTZ 660 Ténéré
Kms de ma moto : 11000
Pneu AV/AR : Michelin Sirac
Ville ou région : Nord
MessageSujet: Help remise en route 80MTX   Help remise en route 80MTX EmptyMar 9 Aoû 2016 - 21:26
Salut à tous!
Je refait actuellement une Honda 80mtx, histoire de me faire un peu la main  clin d\'oeil Ca faisait plus de dix ans qu'elle était remisée.
Malheureusement, je n'arrive pas à la faire démarrer (ni au kick ni à la poussette). Elle a pas pété un seul coup.
J'ai nettoyé le carbu, il est niquel.
Arrivé d'essence ok, pas de problème avec le réservoir.
Les huiles et l'essence ont été changées.
La bougie est neuve et en la testant contre la culasse, j'ai bien une étincelle. La batterie est neuve aussi.
J'ai de la compression.
Je ne sais plus trop quoi faire.. Vous avez des idées? D'autres choses que je devrait vérifier?
Merci d'avance!
V
PS: pour le réglage du carbu j'ai remis le même que celui avant le démontage, donc il est pas forcément top mais elle devrait péter un coup malgré tout non?
Kms de ma moto : 72500
MessageSujet: Re: Help remise en route 80MTX   Help remise en route 80MTX EmptyMar 9 Aoû 2016 - 21:37
La bougie se noie?  scratch
Help remise en route 80MTX Logo_t10
Valoche
Valoche
MessageSujet: Re: Help remise en route 80MTX   Help remise en route 80MTX EmptyMar 9 Aoû 2016 - 22:58
Salut Jackol, je ne crois pas mais je n'en suis pas sûr :-( . Le puit de bougie est compliqué à atteindre (sous la poutre du cadre) donc j'arrive pas à voir par le trou. Quand je démonte la bougie, elle est sèche et comme neuve.
Par quel autre moyen puis-je m'assurer que la bougie se noie? Ca vaut le coup de tenter de la demarrer en modifiant le reglage carbu pour qu'il soit moins riche en essence?
Merci ;)
a9stewaf
Moto : xtze 1200 2016
Kms de ma moto : 57000 KM
MessageSujet: Re: Help remise en route 80MTX   Help remise en route 80MTX EmptyMer 10 Aoû 2016 - 9:41
Bonjour. Si ta bougie est seche malgre tes tentatives de demarrage l essence n arrive pas au moteur... Il faut demonter la bougie pour le voir. Si l essence arrive au carbu alors un mauvais remontage du carbu empecherait l essence d entrer dans le moteur. Je ne vois que ca. Ou les clapets bloques (mais pas sur que le mtx en ait). Voila je passe lamain.laurent
Moto : 750 Super T
Ville ou région : Ajaccio
MessageSujet: Re: Help remise en route 80MTX   Help remise en route 80MTX EmptyMer 10 Aoû 2016 - 11:40
Simple, tu met des gouttes de melange directement dans le puits de bougie, tu referme, met l'antiparasite et ca doit péter, la tu sera sur que c'est ton carbu qui m***e ( et que la compression est suffisante ).
Sinon la methode barbare a peter le joint de culasse, tu kick gaz en grand et en meme temps une tiers personne met un coup de nettoyant frein dans l'admission, bon faut prevoir un extincteur lol! .
Bizarre quand meme que meme avec le starter ca petouille pas, ton pointeau doit etre naze, as tu de l'essence dans la cuve du carbu ?
Etat des gicleurs, tu vois le jour a travers ?
J'y pense, verifie si le pot n'est pas bouché, ca peut empecher l'admission, deja vu sur une voiture.
MessageSujet: Re: Help remise en route 80MTX   Help remise en route 80MTX EmptyMer 10 Aoû 2016 - 13:28
Si la bougie reste sèche suite aux essais, a mon avis y'a un problème de carbu... Help remise en route 80MTX 242583
Valoche
Valoche
MessageSujet: Re: Help remise en route 80MTX   Help remise en route 80MTX EmptyMer 10 Aoû 2016 - 23:36
CA PEEEEEETE!!!
Le gagnant est a9stewaf ! Il y a bien une boite à clapets sur la mtx. En démontant la pipe j'ai trouvé du mélange qui stagnait au niveau de la boite à clapets. Etrange sachant que ce mélange était de couleur verte, la couleur de l'ancienne huile que j'ai vidangée. J'ai donc démonté et les clapets étaient bloqués, pris dans le caoutchouc sur lequel ils viennent se reposer!
Le mélange ne pouvait donc pas accéder au cylindre.
Ce qui m'étonne, c'est que même en introduisant du mélange directement par le puit de la bougie, il n'y a pas eu d'explosion. Un problème de volume d'air qui n'a pas pu être aspiré j'imagine..
Dans tous les cas, merci à tous pour vos réponses!
Me reste maintenant à la régler, parce que là ca tourne pas rond hehe :p
V
a9stewaf
MessageSujet: Re: Help remise en route 80MTX   Help remise en route 80MTX EmptyJeu 11 Aoû 2016 - 9:20
Salut. Content que tu is trouve le probleme.... Je m y connait un peu en deux temps mon fils ayant roule longtemps en motocross j ai donc assure le role de mecano infirmier cuisto chauffeur coach et enfin non des moindes sponsor.... Bref la bougie etait seche donc le melange n arrivait pas . Il suffisait de remonter depuis le cylindre voir ou ca "bloquait".
Je suis toujours en phase de reflexion pour mon xtz de plus le mgasin est ferme pendant le mois d aout. Si l un de vous conniassait un proprietaire de xtze en ile de france car ma femme voudrait monter derriere pour voir le conmfort..... Merci. Laurent
Valoche
Valoche
MessageSujet: Re: Help remise en route 80MTX   Help remise en route 80MTX EmptyJeu 11 Aoû 2016 - 11:44
Salut, c'est vrai que ca parait logique de vérifier la boite à clapets quand on connait sa configuration (ca a l'air de pouvoir facilement se bloquer avec le temps) mais je n'en avais jamais vu auparavant..
Concernant ton xtz, si tu veux rencontrer un membre près de chez toi, je te conseille d'aller dans l'onglet carte (juste à côté du bouton déconnexion) et d'envoyer un mp aux membres les plus proches   bien
» Remise en route
» Remise en route d'un XTZ 660
» Remise en route XTZ 660
» remise en route
» Remise en route 750 xtz
