Freinage 750 Super Tenere - Page 2 Emptypar SuperTiti Hier à 21:40
Freinage 750 Super Tenere - Page 2 Emptypar Joe644 Hier à 18:56
Freinage 750 Super Tenere - Page 2 Emptypar yop1025 Hier à 13:10
Freinage 750 Super Tenere - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Freinage 750 Super Tenere - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Freinage 750 Super Tenere - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Freinage 750 Super Tenere - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Freinage 750 Super Tenere - Page 2 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Freinage 750 Super Tenere - Page 2 Emptypar Arni Dim 17 Nov 2024 - 14:06
Freinage 750 Super Tenere - Page 2 Emptypar Arni Dim 17 Nov 2024 - 13:13
Freinage 750 Super Tenere - Page 2 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Freinage 750 Super Tenere - Page 2 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Freinage 750 Super Tenere - Page 2 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Freinage 750 Super Tenere - Page 2 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Freinage 750 Super Tenere - Page 2 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Freinage 750 Super Tenere - Page 2 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Freinage 750 Super Tenere - Page 2 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Freinage 750 Super Tenere - Page 2 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Freinage 750 Super Tenere - Page 2 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Freinage 750 Super Tenere - Page 2 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Freinage 750 Super Tenere - Page 2 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Freinage 750 Super Tenere - Page 2 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Freinage 750 Super Tenere - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Freinage 750 Super Tenere - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Freinage 750 Super Tenere - Page 2 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
huile arrière chaine manuel crash galére réservoir reglage tuto pneus rabaissement vidange phare essence garde filtre boue amortisseur embrayage synchro feux fourche tenere suis longues selle
Le Deal du moment : -23%
199 €
jpdesm
jpdesm
Moto : Yam 750 XTZ + 350 XT
Ville ou région : Grenoble
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyLun 8 Nov 2010 - 11:14
Réponses à Cedric / Vince.
Pour sortir les pistons, une fois les plaquettes enlevées, mettre des cales plus fines que les plaquettes à la place, et pomper sur la poignée. Une petite plaquette de bois fait bien l'affaire. Le faire avec le couvercle du bocal enlevé et, si le niveau descend trop, rajouter un peu de liquide. Une fois les étriers sortis au delà de la course qu'ils effectuent normalement lors de l'usure des plaquettes, on est sur une zone de frottement "propre" entre l'étrier et le joint, lubrifiée par le liquide, et normalement ça peut sortir beaucoup plus facilement : on enlève la cale, on pompe, et l'un des deux pistons sort tout seul. L'autre vient en le pinçant à travers un chiffon et en le faisant tourner en même temps qu'on le tire vers la sortie. Mettre un récipent dessous, car tout le liquide va passer par terre. Je me répète : bien nettoyer les pistons à la laine d'acier avant remontage et, si nécessaire, changer les joints.
Pour purger, la manip en quatre temps :
1 - Ouvrir d'un quart de tour la vis de purge
2 - Serrer le levier de frein
3 - Fermer la vis de purge : pas besoin de forcer comme un bourrin
4 - Relacher le levier
Ca marche très bien, mais attention, on surveille le niveau dans le bocal, et lorsqu'on en manque, on en rajoute. Ca le fait mieux à deux que seul : embauchez votre doudou pour manoeuvrer la poignée / verser du liquide.
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyLun 8 Nov 2010 - 15:12
pour faciliter la tache, une fois le circuit entièrement vidé, il faut amorcer le maitre cylindre. Pour cela, le remplir, desséré le banjo qui raccorde la durite de frein au maitre cylindre, et utiliser cette dernière comme vis de purge. Comme celà on peut amorcer le maitre cylindre et le reste devient un jeu d'enfant, corrosif mais un jeu d'enfant. content
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyLun 8 Nov 2010 - 17:06
jpdesm a écrit:
... Ca le fait mieux à deux que seul : embauchez votre doudou pour manoeuvrer la poignée / verser du liquide ...
Houlaaa ... pour manoeuvrer oui ... pour verser attention à la peinture ... même si c'est bien protégé par un carton !!!
J'ai déjà entendu :
- "Ouais mais c'est pas grave ... tu vas pas me ch.. une pendule pour une petite goutte, vous en faites bien sur la lunette des chiottes vous les mecs !!!"
- "Ouais mais là c'est d'acide !!! Andouille !!!"
- "Ouais bin ce qui sort de ton corps aussi !!!"
Qu'est-ce que vous voulez répondre après ça !!!
Bon pour en revenir à notre post ... si nettoyage de piston il y a, mieux vaut changer les joints ... au prix que ça coute ...
Tchüss à tous ... Et n'oubliez pas ... la mécanique c'est et ça doit rester un truc de mec ! (à de très rares exceptions près) ...
Freinage 750 Super Tenere - Page 2 Rassos10
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyLun 8 Nov 2010 - 17:21
Flo44 a écrit:
pour faciliter la tache, une fois le circuit entièrement vidé, il faut amorcer le maitre cylindre. Pour cela, le remplir, desserré le banjo qui raccorde la durite de frein au maitre cylindre, et utiliser cette dernière comme vis de purge. Comme celà on peut amorcer le maitre cylindre et le reste devient un jeu d'enfant, corrosif mais un jeu d'enfant. content
Pas mal ta méthode mais comme tu dis Flo, corrosif le produit !!!
Je préfère quand même ma méthode avec les deux tubes sur les deux vis de purge d'étrier légèrement desserrées et le bocal rempli de DOT4 au bout ...
C'est moins dangereux (il y a de la dioxine dans cette m..de !!!)
==> Pour le changement complet de liquide, j'avais oublié de dire que j'utilisais des cales en bois de presque la largeur de l'étrier pour que les pistons soient maintenus les plus possible dans leurs logements ... ça évite d'évacuer beaucoup d'air avant que le DOT4 ne coule ... ;-) ...
Portez vous toujours avec des gants et des lunettes anti-projection, comme pour l'acide de batterie ... Les yeux, on en a que deux ;-)
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyLun 8 Nov 2010 - 20:21
dire que j'en ai deja eu sur la bouche de se produit...... pale Freinage 750 Super Tenere - Page 2 513686
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyLun 8 Nov 2010 - 21:04
Beuark !!! ... Mais quand on aime la mécanique faut gouter à tout !!!
Essences, gasoil, lhm, huiles diverses et variées, liquide de refroidissement ...
le WD40 à quand même un sale gout ;-))
Tchüss à tous ...
jpdesm
jpdesm
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyMar 9 Nov 2010 - 11:06
Et moi j'en ai pris dans l'oeil. Je m'en souviens encore...
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyMar 9 Nov 2010 - 11:34
Hello à tous ...
Et ouais ... C'est pour ça ... Lunettes & gants ...
Sinon ça pique hein ? ... et ça n'arrive qu'aux autres ...
Tchüss à tous ...
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyMar 9 Nov 2010 - 14:24
un p'tit verre d'huile de boite 20ans d'age, rien de mieux Freinage 750 Super Tenere - Page 2 198135
vince74
Moto : 750 xtz / N°000253
Ville ou région : Annecy
MessageSujet: Toujours pas de pression , je craque    Freinage 750 Super Tenere - Page 2 EmptySam 13 Nov 2010 - 19:32
Derfu a écrit:
Hello Vince ...
Tu as tout d'origine ou tu as changé de maître cylindre ?
J'ai vidé complètement mes circuits de freins sur mon xtz ... Le remplissage complet du circuit avant à été bien plus long que l'arrière ... toujours des petites bulles qui remontaient dans le vase ...
En définitive j'en ai eu un peu marre ... alors achat de deux longs tubes pour chacun des étriers ... dévissage gentil de chaque vis de purge ... plonger les tubes dans du DOT4 ... commencer par une purge classique jusqu'à ce qu'il n'y ait plu de bulles en sortie ... puis laisser les vis de purges déserrées ... pomper et remplir le vase dès que le niveau baisse ...
Toutes les petites bulles remontent et le DOT 4 fait va et vient dans les tubes ... de purge ... le tour est joué ...
Là où les bulles stagnent le plus c'est dans le "T" de séparation des durites d'origine ...
A l'avenir ... essaye de citer l'essentiel du post auquel tu fais référence... C'est gavant de tout relire ;-)
Tchüss Man !
Hello ,
j'ai essayé ta technique avec les tubes dans le DOT 4 , j'ai aussi essayé la méthode de FLO 44 , et bien par un sortilège inexplicable après 3 heures passées sur le sujet je fais le constat suivant : plus une seule bulle dans le circuit , en tout cas plus d'air ne sort par les tubes et toujours 0 pression ( malheureusement c'est inversement proportionnel du coté du "mécano" ) .
J'ai un maitre cylindre d'origine , la seule chose qui diffère par rapport à la description de ton post c'est que je n'ai pas de "T" de séparation , le précédent propriétaire avais mis des durits avia qui vont directement du maitre cylindre aux étriers .
Il y a forcément quelque chose qui m'échappe mais pour l'instant je suis "sec" / Les avis seront les bienvenus , d'avance merci .
sonylegitan
sonylegitan
Ville ou région : LILLE NORD
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptySam 13 Nov 2010 - 20:19
A mon avis ton maître cylindre est mort et pis c'est tout!.
vince74
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptySam 13 Nov 2010 - 21:23
Salut ,
c'est une hypothèse , mais le maître cylindre fonctionnait normalement avant que je ne démonte mes étriers , donc je suis quand même sceptique .
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptySam 13 Nov 2010 - 22:40
Hello Vince ...
vince74 a écrit:
Hello ,
J'ai essayé ta technique avec les tubes dans le DOT 4 , j'ai aussi essayé la méthode de FLO 44 , et bien par un sortilège inexplicable après 3 heures passées sur le sujet je fais le constat suivant : plus une seule bulle dans le circuit , en tout cas plus d'air ne sort par les tubes et toujours 0 pression ( malheureusement c'est inversement proportionnel du coté du "mécano" ) .
Il y a forcément quelque chose qui m'échappe mais pour l'instant je suis "sec" / Les avis seront les bienvenus , d'avance merci.
Sony a peut-être raison ...
Ca n'est pas normal que tu n'aies pas de pression après tout ce que tu as fait ...
la seule chose qui pourrait contrarier la pression sur les piston c'est qu'il ne soient freinés ou bloqués dans leur course par de la corrosion d'aluminium entre le joint et le bloc l'étrier, mais même dans ce cas là, la pression devrait les faire sortir, la gêne n'apparait qu'au retrait et induit un frottement continu des plaquettes sur le disque et l'impossibilité de faire tourner la roue à la main !!!
Pour les durits, j'ai la même configuration que toi mais j'ai quand même parlé de ce "T" de dérivation car c'est la configuration d'origine de l'XTZ ;-)
Une question me vient ... ton DOT4 est neuf ? S'il est un peu ancien, bidon ouvert depuis pas mal de temps, le DOT4 peut se charger d'humidité et perds de ses propriétés ...
Il te reste peut être une solution si tu incrimines ton maître cylindre ... le démonter et voir si un des joints n'est pas mort ... Si le levier mets juste le DOT4 en mouvement sans le comprimer, ton problème est peut-être là ...
Tchüss Man !
vince74
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyDim 14 Nov 2010 - 8:26
Derfu a écrit:
Hello Vince ...
vince74 a écrit:
Hello ,
Tchüss Man !
Hello ,
Derfu,Sony merci pour vos réponses .
Le DOT 4 que j'utilise est neuf , je vais donc me pencher ce jour sur la santé du maitre cylindre .
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyDim 14 Nov 2010 - 12:08
maitre cylindre utilisé pour faire une purge en bout de course, si il était un peu fatigué, il a pas aimé..du tout
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyDim 14 Nov 2010 - 15:16
Hello Flo ...
Là je dis détails ... Serge ! ... ;-)
Tchüss à tous ...
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyDim 14 Nov 2010 - 15:19
un maitre cylindre ne travail pas sur toute sa course en mode travail. La "chemise" s'use et le joint aussi. Or lorsque l'on passe en bout de course, lors de purge on arrive sur la partie de la chemise non utilisé en mode de marche. souvent le joint morfle, et c'est pour ça qu'on déconseil de purger sur toute la course (en auto en tout cas, car course longue)
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyDim 14 Nov 2010 - 15:43
Merki Flo ...
T'as pas des photos ou des schémas ... Fleime de chercher sur le web aujourd'hui ...
Tchüss Man !
alain30à10
alain30à10
Moto : 750 XTZ 1989 (n° 2279)
Pneu AV/AR : ANAKEE
Ville ou région : 10
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptySam 26 Mai 2012 - 6:28
Un grand merci à tous les fondus de mécanique, grâce à vous j'ai acheté un kit disque 320 mm en Allemagne, monté sans problème, j'avais déjà monté des durits avia. Quel joie de pouvoir s'arrêter quand on veut !
A plus.
Freinage 750 Super Tenere - Page 2 Hpim3810
Freinage 750 Super Tenere - Page 2 Monta13
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptySam 26 Mai 2012 - 11:46
De rien Man, ... maintenant, tu vas pouvoir la piloter comme une SM dans les rues de Nîmes ;-) ...
Tiens, les déports d'étriers ne sont pas les même que les miens on dirait qu'ils sont cintrés ;-) ...
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptySam 26 Mai 2012 - 13:04
nous on est d'origine en aviation,ça nous empeche pas taquiner la zone rouge!!!
obi.01
obi.01
Moto : yamaha xtz 750
Kms de ma moto : 40 000
Ville ou région : st julien aux bois 19220
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyVen 5 Fév 2016 - 14:55
salut a tous bon maintenant que ma bete roule et que le moteur tourne je vais passer au frein qui son vraiment merdeux il bloque donc meme quand je dois la pousser pour la sortir du garage ben j en chie vous me direr une super t qui freine il devrait etre heureux ben non pas quand on veux pas
donc j ai purger et changer le lookid de frein
mais idem avez vous de bonne idée et de bonne adresse pour pas que ca me coute un bras et les 2 reins merci a vous
tabar
tabar
Moto : revére ntv 650
Kms de ma moto : 100 000km
Pneu AV/AR : Mitas
Ville ou région : 30220
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptySam 6 Fév 2016 - 7:36
il te faut démonter tes étriers bien dégraisser car ils sont apparemment gripper et remonter en pensant a bien graisser les petits axes coulissant,vérifier les pistons et les faire fonctionner avec du look id
si piston très sale possible légèrement avec une toile émeri très fine
a bientôt
Freinage 750 Super Tenere - Page 2 Bonett10 Freinage 750 Super Tenere - Page 2 OAatjW
________________
Freinage 750 Super Tenere - Page 2 Mr84-110
XT 600 3TD
obi.01
obi.01
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptySam 6 Fév 2016 - 21:54
ok merci de la graisse cuivrer est bonne pour ca ?? de toute facon je pense monter des durite avio des que mes finance le premettront et je dois aussi faire ma vidange pour les jours de soleila oui j ai un nettoyeur a ultra son tu pense que je peux les nettoyer avec ou pas conseiller ??
merci et si quelqu un a des photos ou autre merci
tabar
tabar
Pneu AV/AR : Mitas
MessageSujet: Re: Freinage 750 Super Tenere   Freinage 750 Super Tenere - Page 2 EmptyDim 7 Fév 2016 - 7:01
oui c'est bon aussi quand tu démonte fait nous quelques photos .a plus
________________
XT 600 3TD
» xs 308 tanklock et bague BF05 tenere et super tenere
» Compatibilité optiques ténéré 660/super ténéré 750/TDR 125?
» super ténéré concept 1200 ténéré
» Ma super Ténéré de 92
Page 2 sur 4Aller à la page : Précédent  1, 2, 3, 4  Suivant
