Double restauration XTZ 750 - Page 7 Emptypar REYNALD Lun 6 Mai 2024 - 17:08
Double restauration XTZ 750 - Page 7 Emptypar REYNALD Lun 6 Mai 2024 - 17:06
Double restauration XTZ 750 - Page 7 Emptypar Mich77 Dim 5 Mai 2024 - 11:08
Double restauration XTZ 750 - Page 7 Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
Double restauration XTZ 750 - Page 7 Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
Double restauration XTZ 750 - Page 7 Emptypar oustad Lun 29 Avr 2024 - 19:03
Double restauration XTZ 750 - Page 7 Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
Double restauration XTZ 750 - Page 7 Emptypar ST44 Sam 27 Avr 2024 - 18:07
Double restauration XTZ 750 - Page 7 Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
Double restauration XTZ 750 - Page 7 Emptypar meux Ven 26 Avr 2024 - 18:44
Double restauration XTZ 750 - Page 7 Emptypar REYNALD Ven 26 Avr 2024 - 11:53
Double restauration XTZ 750 - Page 7 Emptypar MB Mer 24 Avr 2024 - 21:40
Double restauration XTZ 750 - Page 7 Emptypar Mer14 Mer 24 Avr 2024 - 10:42
Double restauration XTZ 750 - Page 7 Emptypar aulo Mar 23 Avr 2024 - 13:54
Double restauration XTZ 750 - Page 7 Emptypar yd64 Mar 23 Avr 2024 - 8:34
Double restauration XTZ 750 - Page 7 Emptypar yop1025 Lun 22 Avr 2024 - 20:30
Double restauration XTZ 750 - Page 7 Emptypar Buszost Ven 19 Avr 2024 - 22:56
Double restauration XTZ 750 - Page 7 Emptypar Buszost Ven 19 Avr 2024 - 22:45
Double restauration XTZ 750 - Page 7 Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
Double restauration XTZ 750 - Page 7 Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
Double restauration XTZ 750 - Page 7 Emptypar jean-pierre 74 Mer 17 Avr 2024 - 10:43
Double restauration XTZ 750 - Page 7 Emptypar Palex Mar 16 Avr 2024 - 22:33
Double restauration XTZ 750 - Page 7 Emptypar thierry Mar 16 Avr 2024 - 7:14
Double restauration XTZ 750 - Page 7 Emptypar aulo Mar 9 Avr 2024 - 13:09
Double restauration XTZ 750 - Page 7 Emptypar Mer14 Mar 9 Avr 2024 - 9:09
fourche boue manuel synchro réservoir feux suis reglage huile carburateur phare galére amortisseur arrière embrayage filtre vidange rabaissement longues crash pneus garde tenere essence tuto chaine
Pokémon EV06 : où acheter le Bundle Lot 6 Boosters Mascarade ...
Aller à la page : Précédent  1, 2, 3, 4, 5, 6, 7
coolstef
coolstef
Kms de ma moto : 14800
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptySam 6 Fév 2021 - 19:48
Quelques nouvelles...
J'ai terminé la restauration de la deuxième et j'ai fait une trentaine de bornes hier sans problème.
Il me reste quand même un problème qui intervient de manière aléatoire.
C'est à dire soit la bécane marche très bien, comme hier en balade, soit tout est dégradé : ralenti instable, montée/descente pas franche, pétarades...
Comme dit précédemment, je pensais à une prise d'air mais celle-ci serait permanente. Or il suffit que je déplace la bécane ou que je bricole dessus pour passer du mode normal au mode dégradé et inversement.
Des idées ?
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptySam 6 Fév 2021 - 19:49
Double restauration XTZ 750 - Page 7 Img_6712
jean fioretti
jean fioretti
Moto : XTZ 700 Rallye
Kms de ma moto : 80
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptySam 6 Fév 2021 - 20:59
Des idées ?
Un mauvais conatct electrique; Cosses mal serrée ou autre ?
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyLun 8 Fév 2021 - 15:01
Bien vu ! J'ai démonté et mis du nettoyant contact sur tous les connecteurs, y compris sur le CDI.
A priori, c'était une des cosses sur la bobine qui était mal serrée, mais j'ai du mal à comprendre les symptômes : ralenti instable, montée/descente pas franche, pétarades...
jean fioretti
jean fioretti
Kms de ma moto : 80
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyLun 8 Fév 2021 - 15:10
L'explication est relativement simple et classique en electronique : Lorsqu'une cosse est mal serrée ou oxydée le contact se fait mais il se fait mal et il se créer ce que l'on appelle "une résistance de contact" cette résistance de contact permet certes le passage du courant mais elle influe sur sa valeur et provoque des perturbations dans les valeurs electriques requises pour le bon fonctionnement.
Parfois selon le régime moteur le contact se fait mieux ou moins bien en fonction des vibrations, de la température voir même de la position du guidon si le mauvais contact se situe dans les commodos ou dans le faisceau qui passe sur la colone de direction.
Je suis content d'avoir pu te rendre service , j'ai eu une 750 ST de 1990 a 1994 j'en ai gardé un trés bon souvenir.
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyLun 8 Fév 2021 - 21:03
En effet, ton explication est convaincante.
Je n'avais vraiment pas pensé à un problème électrique avant de constater que le déplacement de la bécane intervenait...
Du coup, vu les symptômes, j'ai passé beaucoup de temps sur le carbu sur lequel il y avait surement des éléments à changer aussi.
Complexe quand un problème est causé par des facteurs multiples...
Mais ça vaut le coup, plus j'avance, plus je trouve que la 750 ST est une très bonne bécane !
jean fioretti
jean fioretti
Kms de ma moto : 80
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyLun 8 Fév 2021 - 21:12
J'ai fais toute ma carriére dans l 'electronique des faux contacts, des prises mal branchées et des cosses déssérées j'en ai vu des tas, je n'ai pas vraiment de mérite c'est devenu un automatisme chez moi clin d\'oeil
Rassure toi, même neuve la ST avait des soucis de carburateur et de starter  Double restauration XTZ 750 - Page 7 198135
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyLun 29 Mar 2021 - 21:01
Finalement, comme j'avais besoin de disque pour une autre super T, j'ai fait une permutation et j'ai acheté des disques de 320mm avec les platines de déport.
Et ben... effectivement, ça freine nettement mieux. On obtient un freinage comparable à celui des bécanes récentes.
Par contre, et je crois avoir vu ça sur d'autres posts, ça siffle. On entend surtout ce sifflement aigu à bas régime.
Bon, c'est juste gênant pour l'oreille mais on peut peut être y remédier ?
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyLun 29 Mar 2021 - 21:02
Double restauration XTZ 750 - Page 7 Img_7010
Thebestroll
Thebestroll
Ville ou région : Sarrebourg
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyLun 29 Mar 2021 - 21:53
Eh oui on y vient au freinage en 320 mm Double restauration XTZ 750 - Page 7 1f60e ! C’est un budget mais ça vous change la Tenere! Et la vie, allez savoir.
Pour le bruit, essaie la pâte au cuivre au dos des plaquettes, sur les ressorts d’appuis au fond de l’étrier. .... partout où tu peux en mettre sauf là où doit pas y en avoir. Mais c’est sans garantie.
Ça dépend aussi des plaquettes, pas besoin de super racing machin pour du 320 mm
Thibs
Thibs
Kms de ma moto : 80.000
Ville ou région : jurbise
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptySam 3 Avr 2021 - 10:56
Top ça 👍👌 alors déjà bien roulé avec ta bécane ? Perso j'ai fait un peu plus de 2000 et ravi de la bête, tu as trouvé une solution pour le sifflement ?
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptySam 3 Avr 2021 - 19:19
Pas eu le temps de trop rouler, j’ai du faire même pas 300 bornes...
Par contre, comme toi très satisfait de la bécane. Avec le freinage amélioré et la fourche plus dure (j’avais mis du 15W), j’ai pas grand chose à lui reprocher, elle tourne comme une horloge et on a presque le confort d’une GT 😉😄
Pour le sifflement, je pense que comme les disques sont neufs et donc un peu plus épais, les plaquettes frottent un peu (je l’entends en déplaçant la moto). Donc, je vais attendre un peu l’usure avant de démonter pour essayer de reculer les pistons ou tenter la pâte de cuivre.
Thibs
Thibs
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyMer 28 Avr 2021 - 23:27
Salut Coolstef,
Je suis en train de faire la réfection des carbus et kit suisse mais je n'ai pas reçu le joint qui tue, pourrais tu me donner les références du joint que tu as commende sur 123roulement ?
Merci a toi !!!
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 - Page 7 EmptyJeu 29 Avr 2021 - 9:01
Salut Thibs,
Ci-dssous les références du joint chez 123roulement.
J'en profite pour donner des nouvelles.
Mon problème de disques neufs qui sifflent s'est résolu tout seul. La cause était le léger frottement du aux disques neufs un peu plus épais.
Pour le reste, après 500 bornes, ma bécane tourne super bien et je suis très satisfait du confort pour une bécane de 30 ans. J'ai aussi une Zéphyr 750 du même âge et pour faire des bornes, y'a pas photo !
Mon frangin a récupéré l'autre ST 750 que 'ai restauré et il est aussi super content !
La, je suis sur une autre restauration de ST 750 et j'en causerai sur une autre post.
J'ai l'impression que la côte de nos bécane a bien grimpé ces dernier mois et rejoint celle des Africa Twin. Peut-être l'effet 700 Ténéré...
Double restauration XTZ 750 - Page 7 Captur12[url=https://servimg.com/view/18688654/53]Double restauration XTZ 750 - Page 7 Captur12[/url]
» Modification Double H4 sur ST 750
» Faire un double
» DOUBLE DE CLE PERDU
» Prix des XTZ à vendre Simple au double
Page 7 sur 7Aller à la page : Précédent  1, 2, 3, 4, 5, 6, 7
