Double restauration XTZ 750 Emptypar REYNALD Lun 6 Mai 2024 - 17:08
Double restauration XTZ 750 Emptypar REYNALD Lun 6 Mai 2024 - 17:06
Double restauration XTZ 750 Emptypar Mich77 Dim 5 Mai 2024 - 11:08
Double restauration XTZ 750 Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
Double restauration XTZ 750 Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
Double restauration XTZ 750 Emptypar oustad Lun 29 Avr 2024 - 19:03
Double restauration XTZ 750 Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
Double restauration XTZ 750 Emptypar ST44 Sam 27 Avr 2024 - 18:07
Double restauration XTZ 750 Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
Double restauration XTZ 750 Emptypar meux Ven 26 Avr 2024 - 18:44
Double restauration XTZ 750 Emptypar REYNALD Ven 26 Avr 2024 - 11:53
Double restauration XTZ 750 Emptypar MB Mer 24 Avr 2024 - 21:40
Double restauration XTZ 750 Emptypar Mer14 Mer 24 Avr 2024 - 10:42
Double restauration XTZ 750 Emptypar aulo Mar 23 Avr 2024 - 13:54
Double restauration XTZ 750 Emptypar yd64 Mar 23 Avr 2024 - 8:34
Double restauration XTZ 750 Emptypar yop1025 Lun 22 Avr 2024 - 20:30
Double restauration XTZ 750 Emptypar Buszost Ven 19 Avr 2024 - 22:56
Double restauration XTZ 750 Emptypar Buszost Ven 19 Avr 2024 - 22:45
Double restauration XTZ 750 Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
Double restauration XTZ 750 Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
Double restauration XTZ 750 Emptypar jean-pierre 74 Mer 17 Avr 2024 - 10:43
Double restauration XTZ 750 Emptypar Palex Mar 16 Avr 2024 - 22:33
Double restauration XTZ 750 Emptypar thierry Mar 16 Avr 2024 - 7:14
Double restauration XTZ 750 Emptypar aulo Mar 9 Avr 2024 - 13:09
Double restauration XTZ 750 Emptypar Mer14 Mar 9 Avr 2024 - 9:09
arrière crash galére garde tenere filtre tuto synchro rabaissement réservoir phare longues vidange pneus embrayage amortisseur carburateur essence chaine reglage fourche suis huile boue manuel feux
Aller à la page : 1, 2, 3, 4, 5, 6, 7  Suivant
coolstef
coolstef
Kms de ma moto : 14800
MessageSujet: Double restauration XTZ 750   Double restauration XTZ 750 EmptyDim 25 Oct 2020 - 22:23
Salut à tous,
Vous pouvez voir ma présentation là :
https://www.super-tenere.org/t16406-nouveau-venu-en-xtz-750
Bon, fait pas beau alors j’avance les restaurations.
Pour rappel, j’ai récupéré deux XTZ 750, une pour moi (1990, 14800km) et une pour mon frangin (1993, 48000km).
La mienne n’a pas roulé depuis au moins 10ans, donc beaucoup de boulot mais vu le faible kilométrage, une très bonne base, pas de rouille à part le réservoir. Les carénages sont en bon état.
Celle de mon frangin roulait mais était très mal entretenue donc beaucoup de boulot aussi, notamment le collecteur très rouillé et des carénages cassés.
Après avoir démonté roues, fourche, collecteur et optique, j’attaque la réfection des carbus pour pouvoir faire tourner les moteurs et voir ce que ça donne.
J’ai été obligé d’acheter sur eBay un nouveau carbu car le mien était en pièces détachés caramélisées et il manquait une cuve.
Donc démontage complet, nettoyage dans un bain chaud au vinaigre blanc, changement des gicleurs (j’ai commandé des gicleurs plus petits chez gn-moto, l’équivalent moins cher du fameux kit suisse), changement des différents joints et des vis de richesse.
Je fais les deux bécanes en parallèle, je règle et je remonte les carbus et je vous dit quoi
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyDim 25 Oct 2020 - 22:28
Double restauration XTZ 750 Img_6511
Double restauration XTZ 750 Img_6412
Borgil
Borgil
Kms de ma moto : 89000
Ville ou région : Grenoble
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyLun 26 Oct 2020 - 10:20
Et beh, déjà que faire la restauration d'une, c'est bien long (et ça peut devenir chiant, comme dans mon cas...), mais alors le faire pour 2...sacré courage.
Vous êtes plusieurs ces dernières semaines en plus à rénover des 750, ça donne envie de remettre les mains dans la mienne (HS depuis 1an, et c'est pas faute d'avoir essayé de la réparer).
Faudrait voir l'état de tes plastiques, mais en tous cas les cadres ont l'air dans un état impeccable...t'as déjà une bonne base pour travailler, ça devrait bien se faire ;)
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyLun 26 Oct 2020 - 11:27
Les plastiques sont biens sur l’une et cassés sur l’autre mais réparables.
Elle a quoi ta bécane ? Ça vaut le coup de t’y mettre, il y a de l’aide sur ce forum ! 😊
Borgil
Borgil
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyLun 26 Oct 2020 - 15:29
T'en fais pas, plusieurs topics entiers me sont dédiés x)
Mais là, j'ai coulé une bielle sur un moteur acheté d'occas sur le forum (400€ perdus pour seulement 20km avant que le moteur lâche...), et j'ai un souci de bruit bizarre sur l'autre (un membre du forum a même passé un aprem chez moi pour chercher, en vain).
La seule chose qui me reste à faire c'est démonter ENTIEREMENT le moteur pour trouver d'où vient le bruit. Car on a déjà éliminé la chaine de distrib, les soupapes, et l'embrayage...
Mais après avoir installé / retiré le moteur 3 fois, avoir démonté plusieurs trucs dedans, fais plein de vérifs....j'ai fini par en avoir marre et ai laissé la moto dans un coin. Avec le confinement, j'ai plus besoin de bouger de chez moi donc c'est moins pressé, et comme j'ai déjà plein d'autres tâches en attente dans la maison... Smile
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyLun 26 Oct 2020 - 22:00
OK, en effet si t’as déjà démonté le moteur 3 fois, c’est pas gagné.
Mais bon, y’a toujours une solution 😉
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyMar 27 Oct 2020 - 23:00
Bon, carbus remontés, synchro faire avec la méthode des forets.
Réglage des niveaux de cuve en suivant la RMT.
Ça démarre, ça tourne, ça revient au ralenti mais je n’insiste pas car vu l’ancienneté de l’huile, je préfère faire une vidange avant de monter un peu dans les tours et peaufiner les réglages.
J’ai attaqué le freinage. Démontage complet des six étriers, des pistons et des durites. Je compte mettre partout des durites avia et changer les maîtres cylindre avant.
Quelques difficultés pour sortir certain pistons coincés avec du vieux liquide de frein collant... Je n’ai pas d’air comprimé alors je les sort simplement en actionnant les freins et et mettant un serre-joint pour éviter que l’un des pistons sorte complètement avant l’autre.
Les joints et cache poussière sont corrects. Nettoyage complet et remontage des pistons et des nouvelles plaquettes en métal fritté.
On testera plus tard en remettant les durites et les maitres cylindre.
Double restauration XTZ 750 84094f10
Borgil
Borgil
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyMer 28 Oct 2020 - 10:18
Ca vaut presque le coup quand t'en est là de changer les joints. C'est pas "si cher", et au moins c'est toujours du temps de gagné.
Pour les plaquettes, j'avais mis un pack complet à 30€ trouvé sur je ne sais plus quel site (de scooter... :p ), et en vrai j'ai pas vu de différence avec les plaquettes d'origine. Une XTZ750, c'est pas une fusée, donc bon...ça me suffit bien
skritch
skritch
Moto : xtz 750 super ténéré
Kms de ma moto : 58000
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyMer 28 Oct 2020 - 22:35
Super projet :o
Super Ténéré?! la Legende!
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyVen 30 Oct 2020 - 23:10
Pas eu trop le temps ces jours ci mais j’ai reçu les maîtres cylindre de FZ6.
Problème : il faut percer et tarauder pour le rétro et... c’est un pas de vis à gauche donc faut un taraud à gauche. On va tacher de trouver ça !
En attendant, j’attaque le collecteur. Dérouillage au vinaigre blanc en mettant du d’opaline imbibé. Ça marche pas mal. Ensuite tampon Jex avec savon et huile coude. Résultat final moyen en tout cas pas prêt à peindre, j’essaierai d’améliorer avec du papier de verre à l’eau. À suivre...Double restauration XTZ 750 D1dfa210
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyVen 30 Oct 2020 - 23:11
Double restauration XTZ 750 18ea1310
MiniSapin
MiniSapin
Moto : XTZ 750 Super Tenere
Kms de ma moto : 62300
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyVen 30 Oct 2020 - 23:18
Ça va, je me sent moins seul avec ma ligne d'echappement ... Dans un état similaire 😅
Un conseil, si tu traite au Frameto, laisse sécher assez longtemps avant de mettre en chauffe, j'ai enfumé mon garage ce matin 😂
Thebestroll
Thebestroll
Ville ou région : Sarrebourg
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyVen 30 Oct 2020 - 23:24
Au fait comment tu as réussi à séparer les brides d’échappement de la culasse?
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptySam 31 Oct 2020 - 8:54
Avec du WD40, les brides se sont décollées facilement, j’ai eu de la chance.
Par contre j’essaie même pas de séparer le silencieux du collecteur car d’expérience, c’est toujours galère au démontage et au remontage. On tord un peu les métaux, ça fuit...
Ton frameto, ça a vraiment bien dérouillé ou c’est plus un cache
misère ?
Thibs
Thibs
Kms de ma moto : 80.000
Ville ou région : jurbise
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptySam 31 Oct 2020 - 9:31
Ca avance bien tout ça !
Je suis curieux d'avoir ton retour sur le MC de FZ6 !!! Je compte faire la même chose sur la mienne  trosuper trosuper trosuper
MiniSapin
MiniSapin
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptySam 31 Oct 2020 - 9:59
misère ?
Le Frameto c'est un stoppeur de rouille. Il faut passer la brosse laiton (attaque moin la ferraille qu'une brosse acier) pour enlever le plus gros de la rouille. Avec une brosse sur perceuse ça se fait bien. Il faut plusieurs formes de brosses différentes pour passer partout Smile
N'avait traité un cadre acier avec Frameto et oublié dans le jardin 😅 des semaines au vent et pluie... Pas un grain de rouille n'y est revenu Smile
Et, une fois sec, tu peu repeindre dessus Smile
Luckas16
Luckas16
Moto : XTZ 750 super ténéré
Kms de ma moto : 71 000
Pneu AV/AR : Contiescape
Ville ou région : Provence
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptySam 31 Oct 2020 - 15:21
Je suis assez jaloux de toi ! Ton collecteur lui est bien venu, je vais retenter l’an prochain pour la mienne j’en profiterais peut être pour changer le pot pour un arrow classique!
Pourquoi peindre le collecteur d’échappement et ne pas le faire revenir au belgum alu ?
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyJeu 5 Nov 2020 - 8:55
Pour tester le MC de FZ6, j’ai encore pas mal de boulot !
Je fais la vidange des fourches puis remontage fourches, kit chaîne, roues, étrier...
Ça avance mais doucement 😉Double restauration XTZ 750 Ed06ce10
Thibs
Thibs
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyJeu 5 Nov 2020 - 8:58
Top, par contre il y a une vis de vidange pour la fourche avant , tu as préféré totalement les déposer je vois ? Tu change les joints ou autre ?
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyJeu 5 Nov 2020 - 9:03
C’est moins efficace avec la vis de vidange et puis ça me permet de tout vérifier et de nettoyer les soufflets qui sont plus noirs que bleus.
Les joints spi ne fuient pas, en règle générale, je ne change que ce qui est hs.
coolstef
coolstef
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyVen 6 Nov 2020 - 23:18
Fourches, roues avant, étriers, maître cylindre et durites avia remontées. J’ai hâte de pouvoir faire un essai sur route pour tester le freinage mais je me suis aperçu que les patins de bras oscillant sont cassés sur les deux bécanes donc commandé chez Kedo, pas donné pour un bout de plastique !Double restauration XTZ 750 3906d910
Double restauration XTZ 750 0032d510
Thibs
Thibs
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptyVen 6 Nov 2020 - 23:21
J'ai eu pareil sur la mienne ... (Pour le patin) je suis curieux de voir ton ressenti pour le maître cylindre de FZ6 !!!
Luckas16
Luckas16
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptySam 7 Nov 2020 - 7:54
Pour les patins de chaîne j’ai commandé sur le bon coin à un type qui en vends, il fait lui même le patin est à 22 euros, il fait aussi une grille avant pour les phares, un couvercle porte paquet et un logement sous la selle super utile ! Le patin est beaucoup plus costaud que celui d’origine !
Thibs
Thibs
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptySam 7 Nov 2020 - 7:59
Sérieux ??!!! Ça m interesse, tu sais m'envoyer le lien en mp?
Luckas16
Luckas16
MessageSujet: Re: Double restauration XTZ 750   Double restauration XTZ 750 EmptySam 7 Nov 2020 - 8:14
fait!
Pour l’amélioration du freinage c’est top, petit conseil : il faut aussi penser à améliorer La Fourche qui je trouve, est très molle. un ressort progressif ou une cale de précontrainte Pour la rigidifier un peu car un super freinage avec une fourche en chamalow c’est pas top Smile
» Modification Double H4 sur ST 750
» Faire un double
» DOUBLE DE CLE PERDU
» Prix des XTZ à vendre Simple au double
Page 1 sur 7Aller à la page : 1, 2, 3, 4, 5, 6, 7  Suivant
