Surbottes or not surbottes Emptypar SuperTiti Hier à 21:40
Surbottes or not surbottes Emptypar Joe644 Hier à 18:56
Surbottes or not surbottes Emptypar yop1025 Hier à 13:10
Surbottes or not surbottes Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Surbottes or not surbottes Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Surbottes or not surbottes Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Surbottes or not surbottes Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Surbottes or not surbottes Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Surbottes or not surbottes Emptypar Arni Dim 17 Nov 2024 - 14:06
Surbottes or not surbottes Emptypar Arni Dim 17 Nov 2024 - 13:13
Surbottes or not surbottes Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Surbottes or not surbottes Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Surbottes or not surbottes Emptypar Fredard Sam 16 Nov 2024 - 9:43
Surbottes or not surbottes Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Surbottes or not surbottes Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Surbottes or not surbottes Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Surbottes or not surbottes Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Surbottes or not surbottes Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Surbottes or not surbottes Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Surbottes or not surbottes Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Surbottes or not surbottes Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Surbottes or not surbottes Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Surbottes or not surbottes Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Surbottes or not surbottes Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Surbottes or not surbottes Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
tuto boue filtre selle réservoir crash amortisseur galére reglage phare chaine fourche embrayage tenere essence rabaissement synchro manuel arrière feux longues suis garde huile pneus vidange
Le Deal du moment : -16%
Friteuse sans huile NINJA Foodi Dual Zone 7,6 L 2400W ...
135.01 €
Super-Ice-T
Super-Ice-T
Kms de ma moto : 62500
Pneu AV/AR : Trailmax
Ville ou région : Rouen
MessageSujet: Surbottes or not surbottes   Surbottes or not surbottes EmptyJeu 14 Oct 2010 - 23:40
J'ai vu chez Maxxess des surbottes étanches (Bering je crois) . Comme ce sont les chaussures qui sont le plus exposées sur la 1200 ST quand il pleut elles me tentent.
MAIS...
elles sont ainsi faites qu'il y a un film plastique sous l'avant de la semelle, et je crains qu'il glisse sur sol mouillé (et sur le sec on s'en fout, vous en conviendrez).
Est-ce que quelqu'un les a acheté?
Super-Ice-T, 1500 km de 1200 ST
kick
kick
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyJeu 14 Oct 2010 - 23:52
non pas acheté...sinon tu colles du papier de verre gros grains....je déconne mais anecdote, j'ai des bottes sidi avec bouts ferrés et je me suis fais avoir au début...ça glisse, donc je les ai abrasés...pour revenir au sujet, vu la photo, normalement ...!
Surbottes or not surbottes Bering12semelleberingno
Surbottes or not surbottes Pause_10
Pneu AV/AR : AnakeeIII & T63
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyVen 15 Oct 2010 - 0:26
Parait que c'est galère les sure bottes.
Le mieux reste à mon avis de bonnes bottes gore tex.
Avec mon ancienne paire, y'a 2 ans, je suis resté 3h sous des trombes d'eau (pluie + panne moteur de la 125 après avoir roulé dans 80cm d'eau), j'avais les pieds parfaitement secs.
J'avais même fait quelques pas avec de l'eau aux genoux.
Surbottes or not surbottes Barre_10
Surbottes or not surbottes Sign-vm-net
http://www.voyages-moto.net
Surbottes or not surbottes Adminv10
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyVen 15 Oct 2010 - 0:30
j'ai le même modèle avec un élastique en plus en dessous. ca se coince facilement dans les cale-pied et dur de marcher avec. vaut mieux prendre le modèle complètement fermé en dessous. pour mettre par dessus des chaussures , pas des bottes ...
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyVen 15 Oct 2010 - 18:38
faudrait que " aigle " développe une paire de botte en caoutchouc spéciale motard ............
ils le font bien pour les randonneurs , des super bottes de marche .
perso , je les sens pas les surbottes , je préfèrerais investir dans une paire de bottes au top avec la fermeture et le rabat sur l'extérieur de la jambe pour éviter les entrées d'eau par les projections de la roue .
Super-Ice-T
Super-Ice-T
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyVen 15 Oct 2010 - 22:42
Merci de vos conseils. Je n'avais pas pensé au problème de la surbotte qui se coince dans le sélecteur, mais ça refroidit.
Je vais m'orienter vers une paire de chaussures étanches.
XTAZ
XTAZ
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyVen 15 Oct 2010 - 23:02
Il y a quelques années la marque "LE CHAMEAU" faisait des bottes en
cuir a l'interieur et caoutchouté a l'exterieur, résutat c'était chaud et confortable en plus d'etre pafaitement étanche, inconvénient pas beau du tout
mais on s'en fout sous une grosse averse.Pour ma part j'ai abandonné
les surbottes car c'est a emporter en PLUS du reste, au profit d'une paire
de bottes classique type pompier, je les lave a grande eau et les graisse
a l'huile de pied de boeuf!!! (poche de synovie de l'articulation )
ça colle pas et mes bottes sont toujours étanches,
vous avez aussi le graisse pour chaussures de rando a mettre en 2 ou 3
couches en laissant sécher entre chaque,
ma dernière paire a 3ans et je suis aller reconnaitre des gués puis
traversé au sec de nombreuses fois.
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptySam 16 Oct 2010 - 4:52
A mon humble avis, c'est inutile, peu pratique, limite dangereux......quand tu as une bonne paire de bottes GORE-TEX. Je n'ai jamais eu de problèmes d'étanchéité, même sur des longs trajets et fortes pluies avec des bottes de ce type.
Par exemple :
confortables et 1 fermeture de chaque côté, ce qui permet de les mettre plus facilement, pour ceux qui, comme moi, ont un fort coup de pied.
http://www.hein-gericke.co.uk/shop/product_info.php/products_id/5307
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 12:28
Hello à tous ...
Je réveil ce post histoire de relancer le débat et pour quelques compléments d'informations ;-) ...
J'ai des sur-bottes de chez Dafy depuis déjà presque deux ans ...
Surbottes or not surbottes 050110200105
Je les ai choisies en XXL me semble-t-il ... Elles chaussent parfaitement mes bottes Magnum ...
ou de grosses bottines sas problème ... et elle m'ont déjà sortie de la panade une paire de fois sous gros orages ...
No problémo d'accroche sur sélecteur ou cale pied ;-) ...
Pour ce qui est des bottes, je serai assez d'accord avec vous tous sur l'étanchéité ... mais quel compromis moto-marche-pas chaudes l'été et étanche ...
Je sais ... je veux le beurre, l'argent du beurre et le c_l de la crémière ;-) ...
xamar59 a écrit:
Par exemple : confortables et 1 fermeture de chaque côté, ce qui permet de les mettre plus facilement, pour ceux qui, comme moi, ont un fort coup de pied.
C'est dommage qui ne fonctionne plus ton link Xamar :-\ ...
Surbottes or not surbottes Rassos10
Super-Ice-T
Super-Ice-T
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 13:28
Après la discussion du mois d'octobre j'ai opté pour des bottes étanches (des Alpinestar Web si mes souvenirs sont bons), c'est parfait.
Sur la T1200 il devrait être possible d'installer des protège-pieds sur les protections du moteur, je ne sais pas si un équipementier y a pensé
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 13:35
Merki SIT (plus facile à écrire ;-) ...
Surbottes or not surbottes 233507_large
Essaie de mettre un ch'tit link la prochaine fois ... c'est plus sympa et ça égaye le topic ;-)
Alpinestar Web
Tchüss à tous ;-) ...
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 14:31
je crois avoir vu ça ici mais de fabrication maison ........ peut être que je confond .
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 14:36
c'est là mais je n'ai pas réussi à ouvrir les liens , peut être que le concepteur nous repostera des tofs .
https://www.super-tenere.org/t1272-deflecteurs-pour-les-pieds?highlight=protection+pieds
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 15:47
Hello à tous ...
Pas mieux ... on dirait que le blog a été supprimé :-\ ... p'tet mp à Cfrançois ;-)
Super-Ice-T
Super-Ice-T
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 22:54
Hé non ça ne s'ouvre pas, je verrai ça à la rentrée,
bonnes vacances
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 23:19
Bonnes Vacs SIT ;-) ...
Super-Ice-T
Super-Ice-T
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMar 5 Juil 2011 - 23:35
Merci DRF
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMer 6 Juil 2011 - 8:23
j'ai acheté en avril ces BOTTES étanches en Gore-Tex chez HG.
Après 3000 km, j'en suis vraiment satisfait et elles sont bien étanches (testé sous 3 heures de pluie battante dans le Doubs), confortables même après 600km sur la journée, la marche à pied est facile en ville et en forêt.
Soldées actuellement à 100€ ... ça peut être un bon plan.
(voir discussion https://www.super-tenere.org/t65p60-route-ou-tt)
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMer 6 Juil 2011 - 16:24
c'est même un super bon plan .........
t'as commandé sur leur site ou tu es parti dans une boutique ?
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMer 6 Juil 2011 - 16:43
C'est sympa de penser à nous ;-) ... Merki Drom'
MessageSujet: Re: Surbottes or not surbottes   Surbottes or not surbottes EmptyMer 6 Juil 2011 - 19:03
la boutique HG de Kehl est à 5Km de chez moi ... toujours mieux d'essayer Surbottes or not surbottes 2120
pour info j'ai pris du 45, comme mes 1/2 bottes Dainese, alors qu'en tiag ou ville je chausse plutôt du 44.
@derfu : de rien Surbottes or not surbottes 379565
