support bagagerie souple Emptypar SuperTiti Hier à 21:40
support bagagerie souple Emptypar Joe644 Hier à 18:56
support bagagerie souple Emptypar yop1025 Hier à 13:10
support bagagerie souple Emptypar REYNALD Mar 19 Nov 2024 - 10:58
support bagagerie souple Emptypar REYNALD Mar 19 Nov 2024 - 10:49
support bagagerie souple Emptypar REYNALD Mar 19 Nov 2024 - 10:46
support bagagerie souple Emptypar REYNALD Mar 19 Nov 2024 - 10:44
support bagagerie souple Emptypar jackal74 Lun 18 Nov 2024 - 11:58
support bagagerie souple Emptypar Arni Dim 17 Nov 2024 - 14:06
support bagagerie souple Emptypar Arni Dim 17 Nov 2024 - 13:13
support bagagerie souple Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
support bagagerie souple Emptypar yop1025 Sam 16 Nov 2024 - 23:12
support bagagerie souple Emptypar Fredard Sam 16 Nov 2024 - 9:43
support bagagerie souple Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
support bagagerie souple Emptypar J-Marc Mar 12 Nov 2024 - 12:44
support bagagerie souple Emptypar J-Marc Lun 11 Nov 2024 - 21:58
support bagagerie souple Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
support bagagerie souple Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
support bagagerie souple Emptypar thierry83 Dim 10 Nov 2024 - 9:29
support bagagerie souple Emptypar REYNALD Ven 8 Nov 2024 - 16:55
support bagagerie souple Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
support bagagerie souple Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
support bagagerie souple Emptypar REYNALD Mar 29 Oct 2024 - 20:18
support bagagerie souple Emptypar REYNALD Mar 29 Oct 2024 - 20:00
support bagagerie souple Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
vidange arrière réservoir longues galére manuel garde phare synchro feux fourche chaine rabaissement boue suis selle embrayage amortisseur huile pneus filtre tenere tuto essence reglage crash
gohandunord
gohandunord
Moto : xtz 660 noire + suzuki vanvan
Ville ou région : l'est de la belgique
MessageSujet: support bagagerie souple   support bagagerie souple EmptyLun 25 Juin 2012 - 20:49
Comment puis-je faire pour "fixer" ce genre de valises sur ma Z? Si c'est possible...
http://www.cameron.fr/index.php?act=fiche-produit&idp=23904
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyLun 25 Juin 2012 - 21:06
J'ai exactement les même, et avec les pots d'origine je les fixent directement sur le cache pot avec les sandows fournis avec (accrochés au cales pieds passagers, aux poignés passagers) et avec une petite sangle qui passe autour de la bavette.
Je les trouves bien foutu (bon mon teste n'a duré que 60 km avec 2 oreillers dans chaque sacoche).
Mais 2 petits inconvegnant:
-ne peux pas ce monter sans support si ce n'est pas le pot d'origine
-et pas de duo si pas de support (pas la place pour les pieds.
support bagagerie souple 230111
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyLun 25 Juin 2012 - 21:10
pas besoin de support ... sangle au dessus de la selle et du porte-paquets et poser directement sur l'échappement.
techniquement pas de soucis ... esthétiquement c'est vrai que chargées les sacoches ont tendance à glisser vers l'intérieur.
gohandunord
gohandunord
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyLun 25 Juin 2012 - 21:29
ok, merci les gars.
Vous auriez des photos?
Décidément, je trouve ce forum et ces utilisateurs au top support bagagerie souple 2120
support bagagerie souple 609592
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyLun 25 Juin 2012 - 21:32
Bah j'avais trouver une astuce pour ne pas qu'elle rentre ver l’intérieur. malheureusement je n'ai pas fait de photos je t'en ferais demain soir (car la j'ai vraiment la flème de descendre au garage). Le montage était un peux fastidieux j'ai du faire plusieurs essais.
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyLun 25 Juin 2012 - 23:19
c'est pas des photos d'art ...
support bagagerie souple Dapart16
support bagagerie souple Dapart17
Les sacoches sont en configuration 20L (elles peuvent être plus larges pour 27L)
En solo je les pose à la place du passager et elle s'appuient sur le support du cale-pied ... elle ne rentrent pas trop vers l'intérieur.
En duo elle sont plus vers l'arrière pour laisser le cale-pied libre.
voilà ... mais si je trouve un support de valises d'occasion clin d\'oeil
gohandunord
gohandunord
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyMar 26 Juin 2012 - 23:00
héhé, les noires sont les plus belles support bagagerie souple 704842
merci pour les photos.
Clément, si tu veux en publier aussi, çà m'intéresse.
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyMer 27 Juin 2012 - 18:31
Je vient de les faire a l'instant
support bagagerie souple 2012-033
support bagagerie souple 2012-034
support bagagerie souple 2012-035
Donc voilou c'est fixé avec 4 sandows et 2 ptites sangles (les 2 sangles c'est pour que ça ne bouge vraiment pas) et en prime ça ne gène pas le montage de mon top case yam'
gohandunord
gohandunord
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyMer 27 Juin 2012 - 19:15
Sur les photos, on ne voit pas bien ton ingénieux montage. Tu peux m'expliquer?
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyMer 27 Juin 2012 - 19:26
C'est les deux sangles! Elles sont prisent sur les crochet des valises entoure la valise et se rejoigne, donc plus tu sert, plus ça remonte les valises et moins ça ballotte. On voit sur la deuxième photo.
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyJeu 26 Juil 2012 - 21:09
support bagagerie souple Siege_15
un truc!!!pour toutes motos prendre un siége a roulettes !!
support bagagerie souple Siege_16
support bagagerie souple Siege_18
a suivre!!!
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyJeu 26 Juil 2012 - 21:14
support bagagerie souple Siege_19
si !!!ta pas compris ,c'est ça!!!!!!
XTAZ
XTAZ
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptyJeu 26 Juil 2012 - 22:30
Tabar a raison, le siège est en vente chez kikea peu cher support bagagerie souple 64297
IAC
IAC
Moto : Africa Twin DCT 2017
Kms de ma moto : 19M
Ville ou région : 78
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptySam 6 Sep 2014 - 19:21
Pour tous ceux qui ont posé des valises souples sur les pots, il n'y a pas eu de souci de fonte des sacoches cavalières ?
rodmac02
rodmac02
Kms de ma moto : 51000
MessageSujet: Re: support bagagerie souple   support bagagerie souple EmptySam 6 Sep 2014 - 19:30
trosuper tout simplement excellent comme idée!  je la pique!!! comme quoi le vieux proverbe français a toujours raison:  en france on n'a pas d'argent, mais on a des idées!!! applaudit applaudit applaudit
» Bagagerie souple
» Bagagerie souple
» supports de bagagerie souple pour ST 750
» Camping avec bagagerie souple
» support bagage souple
SUPER TENERE XTZ :: PRÉSENTATION MÉCANIQUE ACCESSOIRES DES XTZ :: 660 XTZ TENERE (Depuis 2008) :: BAGAGERIE, SELLE-
