Montage clignotants led Yamaha Emptypar SuperTiti Hier à 21:40
Montage clignotants led Yamaha Emptypar Joe644 Hier à 18:56
Montage clignotants led Yamaha Emptypar yop1025 Hier à 13:10
Montage clignotants led Yamaha Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Montage clignotants led Yamaha Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Montage clignotants led Yamaha Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Montage clignotants led Yamaha Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Montage clignotants led Yamaha Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Montage clignotants led Yamaha Emptypar Arni Dim 17 Nov 2024 - 14:06
Montage clignotants led Yamaha Emptypar Arni Dim 17 Nov 2024 - 13:13
Montage clignotants led Yamaha Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Montage clignotants led Yamaha Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Montage clignotants led Yamaha Emptypar Fredard Sam 16 Nov 2024 - 9:43
Montage clignotants led Yamaha Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Montage clignotants led Yamaha Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Montage clignotants led Yamaha Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Montage clignotants led Yamaha Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Montage clignotants led Yamaha Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Montage clignotants led Yamaha Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Montage clignotants led Yamaha Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Montage clignotants led Yamaha Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Montage clignotants led Yamaha Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Montage clignotants led Yamaha Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Montage clignotants led Yamaha Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Montage clignotants led Yamaha Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
amortisseur crash garde tenere arrière suis chaine rabaissement galére manuel réservoir boue feux vidange longues filtre tuto selle huile fourche pneus phare embrayage synchro essence reglage
fred21
fred21
Moto : Africatwin
Kms de ma moto : 7500
Pneu AV/AR : Dunlop trailsmart
Ville ou région : Dijon
MessageSujet: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMar 18 Mar 2014 - 14:30
Suite à l’envie de changer mes clignos d’origine (j’avais déja changer les cabochons oranges pas des blancs) j’ai donc acheté le kit cligno led de Yamaha.
Montage clignotants led Yamaha 198966IMG00172
Et c’est parti pour le démontage de la bête.
Dans l’ordre, on démonte :
- la selle pilote
- la pièce plastique pour le réglage de la selle pilote
- la selle passager (2 écrous)
- le porte bagage (4 BTR)
- les poignées passager (4 BTR)
- la pièce qui est sous la selle passager (4 vis torx)
- la pièce on l’on vient visser la selle passager (pas obligé mais c’est mieux pour faire passer les résistances)
jusque là rien de compliqué.
On attaque  la partie pour l’accès  à la connectique électrique
Montage clignotants led Yamaha 356184IMG0597copie
- on dévisse le cache noir en métal pour déconnecter le cable d’ouverture de la selle pilote et on le revisse (flèche bleue)
- on enleve la grande vis du pivot du réservoir (flèche rouge)
- on démonte le pivot du réversoir (flèche jaune)
- on peut maintenant enlever le cache plastisque (flèche vert) qui cache la connectique
- On peut maintenant repérer les connexions pour les clignotans (sur la mienne marron pour le gauche et vert pour le droit)
- J’ai tout déconnecté pour plus de facilité afin de pouvoir sortir le bloc arrière que l’on enlève avec 4 vis BTR (la BTR au dessus du feu stop n’est pas pas à enlever)
Montage clignotants led Yamaha 559804IMG0016copie
Après c’est un jeu d’enfant pour enlever les clignos d’origine. On ecarte les côtés en caoutchouc (flèche bleue) pour pouvoir sortir la pièce centrale (flèche rouge) et après un tire le cligno pour le sortir.
Montage clignotants led Yamaha 409937P1020399copie3
La mise en place des nouveaux ne pose pas de problème, il y a juste a mettre les caches en plastique fournis de chaque côté du support pour combler le trou. Sauf que pour moi, pas de chance. La longueur de cable pour le cligno de droite était trop juste, j’ai du faire une rallonge. (ça aurrait pu le faire mais je trouvais que les cables étaient trop tendus)
Et Hop un de posé  bien
Montage clignotants led Yamaha 646884IMG00182
Pour la mise en place des résistances fournis dans la boite, il faut les mettre uniquement sur les clignos arrière. Pas besoin sur ceux de devant.
Fin du montage arrière
Montage clignotants led Yamaha 301752P1020405
Maintenant on attaque l’avant.
Démontage (Facile) en règle :
- bulle
- déflecteur droit (pour ceux qui ont)
- carénage droit
- déconnexion de l’alimentation du phare c'est le plus gros connecteur (flèche bleue)
Montage clignotants led Yamaha 828411P1020400copie
- carénage de phare (4 BTR)
- phare (4 écrous)
- on enlève le phare et hop, un cligno monté
Montage clignotants led Yamaha 436307P1020401
Alors là je vous conseille se faire les clignos un par un, pour pas vous gourer sur le branchement vue que chez moi les 2 clignos ont la même couleur de cable.
Et une fois fini
Montage clignotants led Yamaha 786606P10204092
Voila j'espère que ça aidera ceux qui hésite.
Ca reste assez facile, j'ai mis environ 2H30 (hors rallonge de cable) en faisant des photos et en prenant mon temps, car c'est la première fois que je démontais mon Super T.
Bonne journée
Fred
ursustenerix
ursustenerix
Kms de ma moto : 60 + 15
Pneu AV/AR : K 60 scout
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMar 18 Mar 2014 - 14:47
fred a écrit:
Ca reste assez facile, j'ai mis environ 2H30 .....
On comprend pourquoi le garage te prend 150 € pour le faire.  Tout compte fait, sont pas si mal les originaux clin d\'oeil .
TranTurqUkraURSSUSA
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMar 18 Mar 2014 - 15:39
Grand merci à toi pour le tuto. bravo
Spiderspeed
Spiderspeed
Moto : Super teneré xtz 1200 2010
Ville ou région : Fontainebleau
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMar 18 Mar 2014 - 15:50
Joli tuto merci!
jackal74
jackal74
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMar 18 Mar 2014 - 17:49
super tuto... bien
mais...je vais garder mes cabochons blancs à l'avant - noirs à l'arrière
Montage clignotants led Yamaha Sans_t10Montage clignotants led Yamaha P1010010 Montage clignotants led Yamaha Logo_c10Montage clignotants led Yamaha P1010012
http://www.lescimes.org
rat68
rat68
Moto : xtz 1200 ze
Kms de ma moto : 20000
Ville ou région : Seine-Maritime
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMar 18 Mar 2014 - 18:07
Bonsoir,
Je voulais savoir ou tu avais eu tes cabochons noirs ? J'en avais commandé mais ils sont mal taillés et ne collaient pas bien au support !
Merci pour l'info.
Rat68
jackal74
jackal74
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMar 18 Mar 2014 - 20:04
désolé de ne pouvoir t'aider sur ce point, c'est l'ancien proprio qui les avait changé
mais je n'ai pas constaté de mauvais plaquement...d'autant que l'ancien proprio était plutôt maniaque...
cela dit, un pote qui me suivait un jour de grand soleil me disait qu'ils n'étaient pas très visibles...
rat68
rat68
Moto : xtz 1200 ze
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMer 19 Mar 2014 - 9:10
Merci tout de même. Je vais continuer à chercher !
aigle74
aigle74
Moto : :st 1200 bleu
Kms de ma moto : 31100
Ville ou région : rhone alpes,bas chablais
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyJeu 20 Mar 2014 - 16:32
Salut Fred21 beau boulot! que fait tu de tes cabochons blancs, si bon état je te les rachètes enfin si tu les vents?? à plus
fred21
fred21
Moto : Africatwin
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyJeu 20 Mar 2014 - 18:52
Il fo que je regarde si j'ai les oranges dans mon bordel et je te le redis.
Fred
Varaderomania
Varaderomania
Moto : XTZ Edition Limited (2012)
Kms de ma moto : 10300 km
Pneu AV/AR : Bridgestone Battle Wing
Ville ou région : Maisons Alfort 94 ou Les Ulis 91
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyJeu 27 Mar 2014 - 18:22
Une adresse ou un lien pour changer juste les cabochons d'origine par des blancs ?  chef
Montage clignotants led Yamaha 20131102100214-f77e54bf
Honda 125 CBS - 125 SL  - 750 Four - Yamaha  500 XS - 500 XT -
Honda 750 Africa Twin - 100 Varadero Carbu - 100 Varadero Injection - Yamaha XTZ 1200 -
http://www.varadero1000france.fr/
ursustenerix
ursustenerix
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyJeu 27 Mar 2014 - 19:50
N'oublie pas de changer les ampoules en orange sinon tout est blanc ...
TranTurqUkraURSSUSA
valdostrom
valdostrom
Moto : KTM 790 ADV 2019 et 500 FANTIC CABALLERO
Kms de ma moto : 1000 et 26000 et 1000
Pneu AV/AR : CONTITRAILATTACK3
Ville ou région : NORD
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyJeu 27 Mar 2014 - 21:12
Je les avais commandé chez mon conss yam...c'est les mêmes que la R1....et je pense moins de 10 euros le capuchon blanc
fred21
fred21
Moto : Africatwin
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyVen 28 Mar 2014 - 8:24
Il me semble que ça doit revenir a plus ou moins 10€ par cligno pour le tout (cabochon +ampoule)
Fred
prom
prom
Moto : XTZ
Kms de ma moto : 5000
Ville ou région : LYON
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyLun 2 Mar 2015 - 16:55
je me suis servi de ce super Tuto pour monter mes Led Yam Smile Merci.
Temps ~2h30 car c'était la 1ere fois que je démontais la bête et que je voulais faire un montage propre.
Juste pour précision, j'ai du rallonger les 2 cligno arrières pour suivre le cheminement original : ~15 cm pour l'un et 5 cm pour l'autre.
fred21
fred21
Moto : Africatwin
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyLun 2 Mar 2015 - 16:57
Oui c'est le problème que j'avais rencontré moi aussi.
Fred
Janfi
Janfi
Moto : 1200XTZ
Kms de ma moto : Evolutif.....
Pneu AV/AR : Road5T
Ville ou région : IDF91 / FWI
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyVen 25 Sep 2015 - 5:42
Bah il a deja 18 mois , mais Merci pour ce Super Tuto... trosuper agenouille trosuper
doigtsenV
fred21
fred21
Moto : Africatwin
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyVen 25 Sep 2015 - 12:29
Ça fait toujours plaisir Double V
Fred
jean-pierre 74
jean-pierre 74
Kms de ma moto : 82 000
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptySam 10 Oct 2015 - 12:18
Suite à un croisement d'un peu trop prés avec une voiture, je dois changer mon clignotant AV gauche.
Pas de rallonge de fils à prévoir pour celui-ci ?
Est-on obligé d'enlever la bulle et le phare ?
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyDim 29 Nov 2015 - 23:05
super tuto bien
jean-pierre 74
jean-pierre 74
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyLun 11 Avr 2016 - 13:33
salut Fred,
Bon je me réveille, après avoir longuement hésité pour me lancer dans ce bricolage, j'ai décidé de changer mon cligno AV gauche aujourd'hui.
Effectivement avec méthode et minutie ça le fait bien. Encore merci pour ce tuto qui m'a grandement aidé.
trosuper Montage clignotants led Yamaha 231456
philou69
philou69
Moto : XT1200Z
Kms de ma moto : 50000
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyMer 3 Mai 2017 - 17:59
Salut!
Super le tuto! je récupère la mienne ce we, donc changement direct!
Aurais tu la référence de tes cligno? Parce qu'ils rendent vraiment bien je trouve
pog974
pog974
Moto : XTZ 1200 super Ténéré
Kms de ma moto : 46000
Ville ou région : Ile de la Réunion
MessageSujet: Re: Montage clignotants led Yamaha   Montage clignotants led Yamaha EmptyDim 29 Sep 2019 - 21:02
Merci pour ce tuto précis.... ça permet daller plus vite👍
» Montage crash-bar YAMAHA
» montage porte paquet yamaha
» Topic pour le montage de crochets d'arrimage sur valises Yamaha
» Partenariat yamaha Motor France Stage TT Yamaha T7
» SOS clignotants
