court circuit 750 xtz 91 Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
court circuit 750 xtz 91 Emptypar Joe644 Mer 20 Nov 2024 - 18:56
court circuit 750 xtz 91 Emptypar yop1025 Mer 20 Nov 2024 - 13:10
court circuit 750 xtz 91 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
court circuit 750 xtz 91 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
court circuit 750 xtz 91 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
court circuit 750 xtz 91 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
court circuit 750 xtz 91 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
court circuit 750 xtz 91 Emptypar Arni Dim 17 Nov 2024 - 14:06
court circuit 750 xtz 91 Emptypar Arni Dim 17 Nov 2024 - 13:13
court circuit 750 xtz 91 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
court circuit 750 xtz 91 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
court circuit 750 xtz 91 Emptypar Fredard Sam 16 Nov 2024 - 9:43
court circuit 750 xtz 91 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
court circuit 750 xtz 91 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
court circuit 750 xtz 91 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
court circuit 750 xtz 91 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
court circuit 750 xtz 91 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
court circuit 750 xtz 91 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
court circuit 750 xtz 91 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
court circuit 750 xtz 91 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
court circuit 750 xtz 91 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
court circuit 750 xtz 91 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
court circuit 750 xtz 91 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
court circuit 750 xtz 91 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
suis manuel huile vidange garde réservoir fourche rabaissement chaine synchro boue pneus reglage feux arrière amortisseur selle tenere tuto filtre longues galére crash embrayage essence phare
35 €
gautier thomas
gautier thomas
Moto : yamaha 750 xtz super T
Kms de ma moto : 59759
Ville ou région : FIGEAC (LOT) SUD-OUEST
MessageSujet: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyDim 8 Déc 2013 - 18:22
Ma moto (750 XTZ 1991) étant tombée en panne de batterie, j'ai eu l'idée géniale de tenter de la redémarrer en collant un booster de voiture sur les cosses de la batterie (!) et.....après 15-20 bonnes secondes en continu sur le bouton de démarreur (qui tournait parfaitement).....le fusible principal (30A) a claqué.
Je l'ai changé et il a reclaqué instantanément sans même que j'aie le temps de redémarrer, puis un autre fusible, puis un autre......Plus rien. Dès que je remets un fusible, il claque, même sans mettre le contact.
J'en ai conclu que l'ampérage était trop fort et que quelque chose avait cramé. J'ai donc commencé par démonter le régulateur, au cas où ce serait lui qui se soit mis en court-jus....et, pareil, ça claque, même non remis en place.
J'ai pensé au relais de démarreur que j'ai testé et démonté....pareil, ça claque sans même le remonter.
Quand on teste le circuit électrique à l'ohm-mètre, ça indique un court-circuit.
Avez vous une idée de ce qui pourrait être arrivé, faisceau fondu (à quel endroit ça pourrait être car il n'y a aucune brûlure apparente) ou autre chose.....?
Merci pour votre aide.
Tom.
MG
MG
Moto : XTZ1200 / XTZ1200E
Pneu AV/AR : Tourance
Ville ou région : Essonne
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyDim 8 Déc 2013 - 20:20
dans tes opérations :le contact est on ou off? si off donc le pb est entre la batterie et le contacteur (je suppose que ton fusible est en sortie de batterie vers le contacteur principal) as tu le schéma électrique de la bête?
MG
gautier thomas
gautier thomas
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyDim 8 Déc 2013 - 20:38
En effet, dans toutes ces opérations, le contact est fermé, le régulateur et le relais de démarreur débranchés.
La panne se trouve effectivement quelque part sur le faisceau puisque quand tu testes un + et un - à l'ohm-mètre, à n'importe quel endroit du circuit, ça indique un court-circuit…..mais où?
Entre la batterie et le démarreur en passant par le contact, c'est à dire n'importe où et sans aucune trace de brûlure!
MG
MG
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyDim 8 Déc 2013 - 22:04
si tu as un micro ohmmètre à 4 fils pour faire une mesure précise tu peux effectuer différentes mesures en tout les points accessibles entre les 2 endroits de la mesure la plus faible se trouve tout court circuit, autre méthode barbare par contre !! tu mets un trombone à la place du fusible tu branches la batterie et là tu vas soit avoir un échauffement et ou des étincelles au niveau du CC... mais bon là tu peux aussi brulé ton faisceau l'astuce serait de mettre en série avec la batterie 2 ampoules de phare (ensemble à la place du fusible) ainsi tu auras dans ton circuit électrique que 10 ampères ce qui peut suffire peut être à voir une étincelle ou un échauffement localiser...
gautier thomas
gautier thomas
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyDim 8 Déc 2013 - 22:56
Je m'y collerai demain et je te tiens au courant….le grand démontage commence!
Bonne soirée.
Smitty
Smitty
Moto : XTZ1200 Noire Matt
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyMer 11 Déc 2013 - 18:26
bonjour  court circuit 750 xtz 91 297713  Welcome
Benjamin Franklin. court circuit 750 xtz 91 3199447018
Paulo Coelho. clin d\'oeil
court circuit 750 xtz 91 Untitl12
http://www.ambk.be
tabar
tabar
Moto : revére ntv 650
Kms de ma moto : 100 000km
Pneu AV/AR : Mitas
Ville ou région : 30220
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyMer 11 Déc 2013 - 19:14
smitty a écrit:
court circuit 750 xtz 91 292714  court circuit 750 xtz 91 297713  court circuit 750 xtz 91 431897
 mais que dit il ?
 tape du poing rire  tape du poing rire .....et smitty le gonze et dans la m***e avec son 750 xtz!!!  ricane
 muhuaha toi tu lui souhaite la bienvenue.... hyenes ...........humour.      (l'erreur et humaine)court circuit 750 xtz 91 2107
bon plus sérieusement !!tu en est ou avec ton cour circuit.??????Very Happy
court circuit 750 xtz 91 Bonett10 court circuit 750 xtz 91 OAatjW
________________
court circuit 750 xtz 91 Mr84-110
XT 600 3TD
gautier thomas
gautier thomas
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyMer 11 Déc 2013 - 19:21
Hi,
J'ai acheté un nouveau faisceau qui va remplacer le mien (cramé) dès que j'ai une  heure ou deux!
Merci pour tes voeux de bienvenue.
tabar
tabar
Pneu AV/AR : Mitas
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyMer 11 Déc 2013 - 19:30
ok... tu nous tiens au courant...de la suite... en photos..stp. c'est mieux pour nous... a plus... clin d\'oeil
________________
XT 600 3TD
gautier thomas
gautier thomas
MessageSujet: Re: court circuit 750 xtz 91   court circuit 750 xtz 91 EmptyMer 11 Déc 2013 - 19:53
D'ac Doc, je vous tiens au parfum.
» Probleme electrique. Court circuit probablement
» CH cable USB micro USB court
» Court essai de la R1150GSAdventure
» Câble gaz trop court
» leviers court deux doigts
