Support top case givi Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
Support top case givi Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Support top case givi Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Support top case givi Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Support top case givi Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Support top case givi Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Support top case givi Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Support top case givi Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Support top case givi Emptypar Arni Dim 17 Nov 2024 - 14:06
Support top case givi Emptypar Arni Dim 17 Nov 2024 - 13:13
Support top case givi Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Support top case givi Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Support top case givi Emptypar Fredard Sam 16 Nov 2024 - 9:43
Support top case givi Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Support top case givi Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Support top case givi Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Support top case givi Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Support top case givi Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Support top case givi Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Support top case givi Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Support top case givi Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Support top case givi Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Support top case givi Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Support top case givi Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Support top case givi Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
manuel vidange rabaissement suis réservoir selle boue amortisseur arrière longues huile chaine essence galére crash filtre garde fourche embrayage tuto reglage feux phare tenere pneus synchro
-20%
Drone Dji DJI Mini 4K (EU)
239 € 299 €
mct
Moto : ST1200
Kms de ma moto : 20000
Ville ou région : paris
MessageSujet: Support top case givi   Support top case givi EmptyDim 27 Nov 2011 - 17:46
Hello,
Je viens de monter le support top case givi. Très simple, pas trop haut, suis ravi.
Le support est en métal, il met le top case en déport mais c'est du gros acier. On doit pouvoir pas mal charger.
Si y'en a des intéressés, je peux faire des photos.
M. chenu
fred77
fred77
Moto : dl 650 /xtz1200 n°667 / explorer 1200
Ville ou région : GUIGNES 77
MessageSujet: Re: Support top case givi   Support top case givi EmptyDim 27 Nov 2011 - 18:29
chenu a écrit:
Hello,
M. chenu
Quelque soit le support le top a une charge de 10 kg maxi
http://fred77.blog4ever.com
vabreflorent
vabreflorent
Moto : xtz1200superT
Ville ou région : harfleur
MessageSujet: Re: Support top case givi   Support top case givi EmptyDim 27 Nov 2011 - 18:31
Je l'ai monté aussi. Du bon matos.
mct
Moto : ST1200
MessageSujet: Re: Support top case givi   Support top case givi EmptyDim 27 Nov 2011 - 19:37
Le porte paquet d'origine c'est 5kg
les 10kg max c'est pas pour le porte top case,il a l'air de pouvoir encaisser plus
parcontre avec 209kg sur la boucle arriere plus 10 kg en portafaux je ne dis pas
VDN
VDN
Ville ou région : POITIERS
MessageSujet: Re: Support top case givi   Support top case givi EmptyDim 27 Nov 2011 - 22:00
chenu a écrit:
Hello,
M. chenu
Intéressé,
VDN / YVES
Support top case givi S2t1cy10
Support top case givi Cavt4510
Mase_51
Mase_51
Moto : CBR 1000 RR
Ville ou région : Marne
MessageSujet: Re: Support top case givi   Support top case givi EmptyLun 28 Nov 2011 - 14:49
Justement une question, je vais commander un givi e55 tech, + le support.
Faut-il rajouter une platine en plus ? Car sur le descriptif du TC, il est indiqué que la platine n'est pas fournie.
fred77
fred77
MessageSujet: Re: Support top case givi   Support top case givi EmptyLun 28 Nov 2011 - 18:09
Ne pas confondre platine spécifique pour top case et support les deux sont indépendant
la platine sert a fixer le top et le tout sur un porte bagage "costaud"
sur la XT le porte bagage est tres "souple" donc le supprimer et mettre de ce fait le support +platine + top
Red-Caponord
Red-Caponord
Moto : Super Ténéré 1200 bleue First Edition n°388
Kms de ma moto : 38.000
Pneu AV/AR : TR91/TR91
Ville ou région : Marche-en-Famenne (B)
MessageSujet: Re: Support top case givi   Support top case givi EmptyLun 28 Nov 2011 - 19:26
Réponse pour Mase_51.
Si tu commandes ceci:
Support top case givi Rad10
Tu auras ceci:Support top case givi P8140913
Mase_51
Mase_51
Moto : CBR 1000 RR
MessageSujet: Re: Support top case givi   Support top case givi EmptyMar 29 Nov 2011 - 6:32
Merci pour ces infos.
Cela commence à faire cher leur affaire : 215€ de TC + 89 de support et 69 de platine. Ils se rince bien sur notre dos quand même.
J'ai actuellement un TC yam, le support ou platine n'est bien sur pas récuperable pour y mettre le Givi ?
Red-Caponord
Red-Caponord
MessageSujet: Re: Support top case givi   Support top case givi EmptyMar 29 Nov 2011 - 7:36
Le rack Givi a été conçu pour remplacer le support défectueux des premières 1200. Il est fourni avec la platine spécifique des TC Givi. Donc, pas besoin de ce que tu appelles "support" à 89 eur. De plus, il se fixe directement sur le cadre de la moto en remplaçant le plastoche (même si renforcé maintenant) d'origine. Plus aucun risque de perdre ta passagère ou ton TC.
Quant à adapter le matériel yam pour du Givi ...
Mase_51
Mase_51
Moto : CBR 1000 RR
MessageSujet: Re: Support top case givi   Support top case givi EmptyMar 29 Nov 2011 - 8:23
Merci, en voila une bonne nouvelle donc le rack à 69 + TC et ça roule.
"Plus aucun risque de perdre ta passagère ou ton TC" Voilà un bon argument d'achat auprès de ma blonde Smile
Je passe la commande.
Xavier78
Moto : XT1200ZE n°3
Ville ou région : 78
MessageSujet: Re: Support top case givi   Support top case givi EmptyVen 16 Déc 2011 - 18:11
C'est celui que j'ai monté aussi avec TC GIVI TREKKER, les 2 pattes sont balaises, effectivement vissées directement sur le cadre, tu peux charger sans crainte, ca bouge pas.
Support top case givi 2120
XTZE 1200 GRISE  N3 Support top case givi 2120
https://declic-dietetique.fr
Xavier78
Moto : XT1200ZE n°3
MessageSujet: Re: Support top case givi   Support top case givi EmptyVen 16 Déc 2011 - 18:17
[img][/img]Support top case givi Imgp0122
La tu vois les 2 pattes vissées sur le cadre
Xavier78
Moto : XT1200ZE n°3
MessageSujet: Re: Support top case givi   Support top case givi EmptyVen 16 Déc 2011 - 18:21
C'est vrai que tu as un porte a faux un peu plus important mais pas de risque de semer ton TC
Support top case givi Imgp0123
pascal81
pascal81
Moto : XTZ 1200 WORLDCROSSER
MessageSujet: Re: Support top case givi   Support top case givi EmptyMer 5 Sep 2012 - 18:50
Hop déterrage de post
J'ai le support top case que l'on voie sur la photo , sans les support en métal
Question , peut on monter le support Top case sans les support métal directement
sur la 12
Merki
J'ai envoyé un mail a givi , pour les supports métal au cas ou
Pascal
» support top case givi " trouvé"
» [Donne] support top case Givi
» Top case Givi 55L ?
» Montage Support pour top case Givi SRA2101
» Toolbox GIVI avec fixation sur support valise GIVI
