Entretien fourche (huile, joints et ressort) Emptypar SuperTiti Hier à 21:40
Entretien fourche (huile, joints et ressort) Emptypar Joe644 Hier à 18:56
Entretien fourche (huile, joints et ressort) Emptypar yop1025 Hier à 13:10
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Entretien fourche (huile, joints et ressort) Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Entretien fourche (huile, joints et ressort) Emptypar Arni Dim 17 Nov 2024 - 14:06
Entretien fourche (huile, joints et ressort) Emptypar Arni Dim 17 Nov 2024 - 13:13
Entretien fourche (huile, joints et ressort) Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Entretien fourche (huile, joints et ressort) Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Entretien fourche (huile, joints et ressort) Emptypar Fredard Sam 16 Nov 2024 - 9:43
Entretien fourche (huile, joints et ressort) Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Entretien fourche (huile, joints et ressort) Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Entretien fourche (huile, joints et ressort) Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Entretien fourche (huile, joints et ressort) Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Entretien fourche (huile, joints et ressort) Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Entretien fourche (huile, joints et ressort) Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Entretien fourche (huile, joints et ressort) Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Entretien fourche (huile, joints et ressort) Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Entretien fourche (huile, joints et ressort) Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Entretien fourche (huile, joints et ressort) Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
filtre tuto galére suis pneus manuel crash synchro feux longues reglage boue phare réservoir selle essence arrière embrayage huile fourche amortisseur rabaissement garde chaine vidange tenere
le marin
le marin
Kms de ma moto : 13000
Ville ou région : Gironde
MessageSujet: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptySam 9 Oct 2010 - 9:44
Salut a tous xtz-man (voir girl)
Je souhaite entretenir mes tubes fourche donc
-Changer l'huile ainsi que les joints éventuel
-changer les ressorts
Le problème c'est que je n'ai jamais fait cela et je sais pas comment m'y prendre
est-ce possible d'avoir un tutoriel la dessus ?
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptySam 9 Oct 2010 - 14:01
regarde dans ma signature tu as la base.
deja il faudra que tu te fasse un outils, pour pouvoir démonter la vis creuse en fond de fourche.
Les ressorts, a moins qu'ils aient beaucoup de bornes, il ne semblerait pas obliger de les changer sauf si tu fais un upgrade
le marin
le marin
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 10 Oct 2010 - 9:25
L'outils il te permet de sortir quoi ?
Pas besoin de l'outil pour sortir les ressorts ?
Les ressorts je les changes pour quel plonge moins
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 10 Oct 2010 - 12:32
le tarage est trop mou d'origine, met des cales de précontraintes (30mm c'est bien)
tu veux changer tes spy, tu es obliger de démonter le fameux écrou :lol:
le marin
le marin
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyVen 15 Oct 2010 - 9:27
erf ok merci
Je vais pas pouvoir du coup faire ca moi même
il y a un petit garage a coté de chez moi
Il me change les ressorts main d'œuvre compris pour 240 euros
Le marin
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyVen 15 Oct 2010 - 20:07
euhh et il te met quoi comme ressorts???
didiercoca
didiercoca
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 8 Jan 2012 - 21:45
c est quoi comme outil???
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 8 Jan 2012 - 21:53
un écrou de 30 (cléf) souder sur une tige en fer .....en ...T...
bien sur l'écrou en bas du T longueur 1000?..
didiercoca
didiercoca
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 8 Jan 2012 - 21:56
longueur 1metre? oulalala c est du serieux comme outil!
bon quand j y serai je verrai bien!
merci du renseignement
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyDim 8 Jan 2012 - 21:58
te fait une photo demain.du T..... simple ..zérororos...tu dois trouvez...
sergeb
sergeb
Moto : yamaha 750xtz super tenere 3LD-000267
Ville ou région : Proximité de TOULOUSE haute-garonne
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 18 Jan 2012 - 11:39
Salut Tabar,
Où est la tof???
sergeb
sergeb
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 18 Jan 2012 - 11:43
Salut Flo44?
'Scuse, comment ont fait pour voir la base? pas su trouver
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 18 Jan 2012 - 18:09
heuuuu!!!s'cuse je me suis tromper....
Entretien fourche (huile, joints et ressort) T_00210mon SDS...Smile
Entretien fourche (huile, joints et ressort) T_00310un écrous de 30..
Entretien fourche (huile, joints et ressort) Humou210
Entretien fourche (huile, joints et ressort) T_00410
c'est pas un truc pour nain,,,heuu!!!scratch ..j'ai dis une connerie??????.pale .........Entretien fourche (huile, joints et ressort) 64068
sergeb
sergeb
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyJeu 19 Jan 2012 - 10:34
Salut Tabar et les autres
Joli le bestiau, tu l'engraisses pour un futur paté ou une daube provencale ? Entretien fourche (huile, joints et ressort) 165632
Concernant l'outil, je suppose que c'est la périphérie (et non pas le pas de vis ) de l'ecrou de 30 qui sert au démontage.
http://www2.yamaha-motor.fr/2010/ypec/?prodCategory=10
Sur le site Yam , c'est la piece 9 qu'on dévisse?
csandjo
csandjo
Moto : 660 tenere 2008
Ville ou région : porto-vecchio
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMar 26 Juin 2012 - 22:15
apres diagnostique je m'aperçoit que ma fourche n'a plus d'huile, les spy tres certainement a changer, seul probleme les bagues sont arrivées a leur terme et j'ai des rayures sur mes tubes ! j'hesite a changer spy, bagues...sans changer les tubes pour ne pas a recommencer le tout et detruire les spy neuf ect... quel'qun 'un a deja eu ce genre de rayures ? secondo le prix des tubes 290 euros pieces 580 les deux, j'en ai trouvé n adaptable a 160 euros pieces, quelqu'un en a deja essayer ? merci
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMar 26 Juin 2012 - 22:37
nous on vends deux tube complet bonne etat!!!!!Entretien fourche (huile, joints et ressort) 49290
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 27 Juin 2012 - 5:41
a 80 euros tu peux avoir une fourche complette d'occaseEntretien fourche (huile, joints et ressort) 704842 .......
a remonter......Very Happy le coin coin!!!!
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 27 Juin 2012 - 8:14
ou chez nous!!!!Entretien fourche (huile, joints et ressort) 49290
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMer 27 Juin 2012 - 12:27
ben vouiEntretien fourche (huile, joints et ressort) 49290
csandjo
csandjo
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyVen 29 Juin 2012 - 18:12
combien peu couter une fourche d'occas nikel pour mon 660 de 2008 ?
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptySam 30 Juin 2012 - 14:02
jojo a de la pièces de 750Entretien fourche (huile, joints et ressort) 49290
Entretien fourche (huile, joints et ressort) Barre_10
csandjo
csandjo
MessageSujet: Re: Entretien fourche (huile, joints et ressort)   Entretien fourche (huile, joints et ressort) EmptyMar 17 Juil 2012 - 22:56
pour demonter fourche du 660 tenere de 2008 la longue cle c'est bien un boulon de 30 ?
» Changer les joints SPY de fourche.
» Ressort de fourche
» Niveau huile de fourche
» ressort de fourche
