COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar SuperTiti Hier à 21:40
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar Joe644 Hier à 18:56
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar yop1025 Hier à 13:10
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar Arni Dim 17 Nov 2024 - 14:06
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar Arni Dim 17 Nov 2024 - 13:13
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar Fredard Sam 16 Nov 2024 - 9:43
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
COURBE COUPLE/PUISSANCE ST 1200 2011 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
tuto manuel galére longues tenere chaine phare vidange essence synchro crash amortisseur embrayage reglage garde rabaissement pneus feux réservoir boue huile arrière selle fourche filtre suis
Le Deal du moment : -25%
749.99 €
MessageSujet: COURBE COUPLE/PUISSANCE ST 1200 2011   COURBE COUPLE/PUISSANCE ST 1200 2011 EmptyDim 5 Fév 2012 - 18:48
Voici les courbes puissance/couple d'une ST 2011 lors du comparatif avec la versys 1000 sur motostation.
http://www.moto-station.com/article13090-p3-kawasaki-versys-1000-vs-yamaha-xt-1200-z-super-tenere-tank-il-y-aura-des-trails.html
COURBE COUPLE/PUISSANCE ST 1200 2011 Kawasa10
Yamaha XT 1200 Z (courbes vertes) : 107 ch à 6 981 tr/min, 12,1 mkg à 5 736 tr/min
Lorsque l'on regarde la couple de couple en particulier on voit qu'entre 3000tr/mn et 6000tr/mn celle ci est plate à une très bonne valeur de près de 12mkg au vilo ! bien
J'ai une 2011 et je ne sens plus ce trou entre 3000 et 6000 que j'avais ressenti auparavant sur une 2010 d'essai ... (avis perso ... COURBE COUPLE/PUISSANCE ST 1200 2011 49290 )
Yamaha aurait-il réctifié le tir sur la carto 2011 suite aux remarques des clients qui se plaignaient de cette molesse ? merci
A vos plumes chers Routards ... clapping
COURBE COUPLE/PUISSANCE ST 1200 2011 Adminv10
MessageSujet: Re: COURBE COUPLE/PUISSANCE ST 1200 2011   COURBE COUPLE/PUISSANCE ST 1200 2011 EmptyDim 5 Fév 2012 - 19:01
je voudrais bien voir ma courbe pour comparer :(
je repose la question, que peut apporter un flash avec les modèles 2011,2012 ?
MessageSujet: Re: COURBE COUPLE/PUISSANCE ST 1200 2011   COURBE COUPLE/PUISSANCE ST 1200 2011 EmptyDim 5 Fév 2012 - 19:24
Courbes d'après flash tuning
COURBE COUPLE/PUISSANCE ST 1200 2011 XTZ1200%20tune%203eme
modèle 2010 d'origine : 11.6mkg à 5992 trs et 107.5cv à 7297 trs
flashé : 12.1 à 5196 trs et 109.3 à 7466 trs
modèle 2011 : 107 ch à 6 981 tr/min, 12,1 mkg à 5 736 tr/min
dixit Flash Tuning :
La XTZ 1200 a la particularité d'être bridée sur les 4 premiers rapports entre 3000 trs et 6000.
Ce bridage électronique pénalise beaucoup la moto, c'est pour cela qu'elle a été mal accueilli par la presse, au niveau comportement moteur, par rapport à ses concurrentes. En supprimant cette restriction électronique, la super ténéré redevient la "bête" qu'elle devrait être. L'agrément de conduite devient génial ... Les relances musclées...En bref, c'est une nouvelle moto !
A 4200 trs, le gain culmine à 2.3 mkg / 14cv !!
La suppression de cette bride peut se combiner avec la version Europe qui délivre 110cv au lieu de 106cv (réservé à la compétition). Cette modification du software n'altère en rien, le fonctionnement des différents mode de TCS, tout fonctionne comme avant mais ...en mieux !
Il n'y 'aurait pas un pro qui pourrait décrypter ces deux tableaux de courbes de façon simple pour le commun des mortels ?
salegamin
salegamin
Moto : ZTX 1200 black
Kms de ma moto : 22000
Pneu AV/AR : TR91 / TR91
Ville ou région : La Ciotat
MessageSujet: Re: COURBE COUPLE/PUISSANCE ST 1200 2011   COURBE COUPLE/PUISSANCE ST 1200 2011 EmptyLun 6 Fév 2012 - 9:07
Le GIPRO sur ma Vstrom enlevé d'ailleurs cette bride électronique, sur les 4 premiers rapports, en faisant croire au CDI, que la boite était sur le 6éme rapport.
La moto était plus souple, le moteur plus puissant au même régime moteur et moins de consommation d'essence.
MessageSujet: Re: COURBE COUPLE/PUISSANCE ST 1200 2011   COURBE COUPLE/PUISSANCE ST 1200 2011 EmptyLun 6 Fév 2012 - 9:25
Pour moi ce que j'en comprend c'est que le moteur sera plus remplis a mis régime (meilleur traction, monté en régime plus rapide) et que le rupteur interviendra un peux plus tard donc la moto gagne quelque tours minutes. c'est surtout le gain de couple qui a l'aire intéressant . Y a pas un bitonio comme ça pour faire gagner 500 tr/min et 0.5 m/kg pour la 660???
COURBE COUPLE/PUISSANCE ST 1200 2011 230111
MessageSujet: Re: COURBE COUPLE/PUISSANCE ST 1200 2011   COURBE COUPLE/PUISSANCE ST 1200 2011 EmptyLun 6 Fév 2012 - 9:48
filtre a air kn et couper le "periscope" de la boite a air... tu gagne pas de tours/mn mais le gain de souplesse est flagrant... et peu etre en + une bougie iridium mais j'ai pas encore essayé....
y'a des post' là dessus....
MessageSujet: Re: COURBE COUPLE/PUISSANCE ST 1200 2011   COURBE COUPLE/PUISSANCE ST 1200 2011 EmptyLun 6 Fév 2012 - 10:11
» xtz 1200 2011
» xtz 1200 2011
» XTZ 1200 2011 NOIR
» Une Xtz 1200 en 2011 au Canada? de plus en plus sur
» Centrale ABS XTZ 1200 de 2011
