Probleme allumage ( probleme resolu )  Emptypar SuperTiti Hier à 21:40
Probleme allumage ( probleme resolu )  Emptypar Joe644 Hier à 18:56
Probleme allumage ( probleme resolu )  Emptypar yop1025 Hier à 13:10
Probleme allumage ( probleme resolu )  Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Probleme allumage ( probleme resolu )  Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Probleme allumage ( probleme resolu )  Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Probleme allumage ( probleme resolu )  Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Probleme allumage ( probleme resolu )  Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Probleme allumage ( probleme resolu )  Emptypar Arni Dim 17 Nov 2024 - 14:06
Probleme allumage ( probleme resolu )  Emptypar Arni Dim 17 Nov 2024 - 13:13
Probleme allumage ( probleme resolu )  Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Probleme allumage ( probleme resolu )  Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Probleme allumage ( probleme resolu )  Emptypar Fredard Sam 16 Nov 2024 - 9:43
Probleme allumage ( probleme resolu )  Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Probleme allumage ( probleme resolu )  Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Probleme allumage ( probleme resolu )  Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Probleme allumage ( probleme resolu )  Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Probleme allumage ( probleme resolu )  Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Probleme allumage ( probleme resolu )  Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Probleme allumage ( probleme resolu )  Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Probleme allumage ( probleme resolu )  Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Probleme allumage ( probleme resolu )  Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Probleme allumage ( probleme resolu )  Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Probleme allumage ( probleme resolu )  Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Probleme allumage ( probleme resolu )  Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
vidange rabaissement tenere crash galére garde huile pneus boue amortisseur synchro embrayage selle tuto essence réservoir filtre phare longues fourche reglage arrière feux chaine manuel suis
-23%
(Black Friday) Apple watch Apple SE GPS 44mm (plusieurs coloris) à ...
199 € 259 €
oufrider2728
oufrider2728
Moto : xtz 750
Kms de ma moto : 540000
Ville ou région : Normandie
MessageSujet: Probleme allumage ( probleme resolu )    Probleme allumage ( probleme resolu )  EmptyMer 14 Mar 2018 - 18:10
Voila le problème, suite a un changement de moteur, ma moto avait beaucoup de mal a démarrer ( j'ai juste démarrer deux fois 30 secondes et coupé le contact )
En faisant un contrôle de l'étincelle aux bougies je me suis rendu compte qu'elle était très faible puis a la suite de mes essai je n'ai plus du tout d'étincelle aux bougies...
Le problème c'est que j'ai quasiment tout contrôlé et la je sèche totalement
Voici ce que j'ai controlé/changé
Bougies neuves
Enroulement de bobine primaire et secondaire OK
Enroulement du stator OK
Diode OK
Batterie charger ( j'ai meme testé de brancher une batterie de voiture au cas ou la mienne manque d'amperage )
Transistor du CDI changer ( 2SD2141 par un 2SD1071 )
Capteur allumage OK
Si quelqu'un a une idée ou une solution ca pourrais grandement m'aidé  doigtsenV
oufrider2728
oufrider2728
Moto : xtz 750
MessageSujet: Re: Probleme allumage ( probleme resolu )    Probleme allumage ( probleme resolu )  EmptyMer 14 Mar 2018 - 21:43
Bon j'ai enfin trouvé mon probleme et c'est bien bete. On en apprend tout les jours cool
Le transistor que j'ai remplacé etait bel et bien HS mais j'ai fait une boulette avec le nouveau.
Comme on peux le voir mon ancien transistor n'avait pas une partie en metal au dos, je pensais que c'etait pour aidé la dissipation thermique mais non ca me le mets en court circuit a priori. J'ai essayé en l'isolant du radiateur et la miracle une belle etincelle !  Double V
Si ca peux servir a quelqu'un un jour je post les photos, il me reste plus qu'a trouver un transistor sans la plaque en metal au dos
Probleme allumage ( probleme resolu )  1521059830-img-0793
Probleme allumage ( probleme resolu )  1521059829-img-0794
J'ai ce CDI la au cas ou:
Probleme allumage ( probleme resolu )  Img_5210
MessageSujet: Re: Probleme allumage ( probleme resolu )    Probleme allumage ( probleme resolu )  EmptyMer 14 Mar 2018 - 22:12
bien
» Probléme puissance (RESOLU)
» problème allumage
» Problème régulateur / alternateur ? Résolu P3 !
» Problème d'allumage
» Problème d'allumage xtz 750
