ZUMO 550 - QUEL CABLE Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
ZUMO 550 - QUEL CABLE Emptypar Joe644 Mer 20 Nov 2024 - 18:56
ZUMO 550 - QUEL CABLE Emptypar yop1025 Mer 20 Nov 2024 - 13:10
ZUMO 550 - QUEL CABLE Emptypar REYNALD Mar 19 Nov 2024 - 10:58
ZUMO 550 - QUEL CABLE Emptypar REYNALD Mar 19 Nov 2024 - 10:49
ZUMO 550 - QUEL CABLE Emptypar REYNALD Mar 19 Nov 2024 - 10:46
ZUMO 550 - QUEL CABLE Emptypar REYNALD Mar 19 Nov 2024 - 10:44
ZUMO 550 - QUEL CABLE Emptypar jackal74 Lun 18 Nov 2024 - 11:58
ZUMO 550 - QUEL CABLE Emptypar Arni Dim 17 Nov 2024 - 14:06
ZUMO 550 - QUEL CABLE Emptypar Arni Dim 17 Nov 2024 - 13:13
ZUMO 550 - QUEL CABLE Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
ZUMO 550 - QUEL CABLE Emptypar yop1025 Sam 16 Nov 2024 - 23:12
ZUMO 550 - QUEL CABLE Emptypar Fredard Sam 16 Nov 2024 - 9:43
ZUMO 550 - QUEL CABLE Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
ZUMO 550 - QUEL CABLE Emptypar J-Marc Mar 12 Nov 2024 - 12:44
ZUMO 550 - QUEL CABLE Emptypar J-Marc Lun 11 Nov 2024 - 21:58
ZUMO 550 - QUEL CABLE Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
ZUMO 550 - QUEL CABLE Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
ZUMO 550 - QUEL CABLE Emptypar thierry83 Dim 10 Nov 2024 - 9:29
ZUMO 550 - QUEL CABLE Emptypar REYNALD Ven 8 Nov 2024 - 16:55
ZUMO 550 - QUEL CABLE Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
ZUMO 550 - QUEL CABLE Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
ZUMO 550 - QUEL CABLE Emptypar REYNALD Mar 29 Oct 2024 - 20:18
ZUMO 550 - QUEL CABLE Emptypar REYNALD Mar 29 Oct 2024 - 20:00
ZUMO 550 - QUEL CABLE Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
crash embrayage selle huile boue essence suis tuto galére fourche réservoir manuel amortisseur filtre synchro reglage tenere phare vidange rabaissement longues feux arrière pneus garde chaine
Le Deal du moment : -25%
749.99 €
zbar
zbar
Moto : 1200 ST gris - 990 SUPERDUKE - MONSTER S4
Ville ou région : ILE DE FRANCE
MessageSujet: ZUMO 550 - QUEL CABLE   ZUMO 550 - QUEL CABLE EmptyVen 22 Juil 2011 - 13:38
Quel cable pour brancher mon ZUMO 550, celui-ci :
- http://www.touratech.com/shops/007/product_info.php?cPath=13_116_688&products_id=7915&osCsid=9663442774cfdb5ee7614b37e22d217a
Ou celui la :
- http://www.touratech.com/shops/007/product_info.php?cPath=13_116_688&products_id=7789&osCsid=9663442774cfdb5ee7614b37e22d217a
Je pense que les 2 doivent faire l'affaire par contre ce que je ne comprends pas, c'est la différence qu'il y a entre les 2.
Merci d'avance.
V V V V V V V V V V V V V V
peyo
peyo
Moto : ZE Race blue 2015
Kms de ma moto : 21585 kms
Ville ou région : Aquitaine
MessageSujet: Re: ZUMO 550 - QUEL CABLE   ZUMO 550 - QUEL CABLE EmptyVen 22 Juil 2011 - 14:01
Ou celui la :
Merci d'avance.
Tu as l'explication: pour le premier, le câble peut aisément être débranché au niveau du raccordement
Superseal. La partie reliée à la batterie reste ainsi montée sur la moto, ce qui te permet, le soir à l'etape, de débrancher au niveau du raccordement superseal et d'emmener avec toi le support GPS et le GPS.
Dans le deuxième cas, tu ne peux retirer que le GPS et tu laisses le support sur la moto. C'est mon cas, mais comme je n'ai pas mis les deux petites vis qui servent à fixer la fiche sur le support du GPS, il me suffit de retirer cette fiche pour emmener avec moi le support et le gps.
zbar
zbar
MessageSujet: Re: ZUMO 550 - QUEL CABLE   ZUMO 550 - QUEL CABLE EmptyVen 22 Juil 2011 - 15:33
Perso, je ne vois pas l'intérêt de démonter le support mais bon.....
Par contre l'un a des oeillets pour, j'imagine, brancher directement sur les bornes de la batterie et l'autre non.
Comment se raccorde t'il ?
Pour le cable avec branchement, ce qui serait bien c'est de pouvoir se servir de la même prise pour le GPS et pour un chargeur de batterie genre OPTIMATE.
Crois tu que c'est possible ?
peyo
peyo
MessageSujet: Re: ZUMO 550 - QUEL CABLE   ZUMO 550 - QUEL CABLE EmptyVen 22 Juil 2011 - 19:12
J'ai monté mon GPS comme çà ; ZUMO 550 - QUEL CABLE Dsc02515
ensuite le support est fixé sur la boule ZUMO 550 - QUEL CABLE Dsc02516
et comme je ne met pas les vis pour fixer la fiche de raccordement je peux l'enlever.
Un support GPS si tu le laissses la nuit ou la journée sur ta moto sans suveillance, ça peut interreser certaines personnes.
Pour le branchement,soit tu te branches directement sur la batterie,soit tu a un plus après contact ( je retrouve la photo et je te l'envoie)
peyo
peyo
MessageSujet: Re: ZUMO 550 - QUEL CABLE   ZUMO 550 - QUEL CABLE EmptyVen 22 Juil 2011 - 21:23
Pour zebar,
Photos du branchement du + pour le GPS et phares additionnels.
ZUMO 550 - QUEL CABLE Moz-screenshot-10ZUMO 550 - QUEL CABLE Moz-screenshot-11ZUMO 550 - QUEL CABLE Dsc05411
Le + c'est le câble bleu gainée de rouge qui est soudé sur la fiche qui se trouve dans le boitier blanc. Pour ça il faut d éclipser le boitier blanc, extraire avec un petit tournevis la cosse, et souder le fil sur la cosse (attention la soudure ne doit pas être trop épaisse pour qu'une fois le fil soudé à la fiche le tout rentre de nouveau dans l'emplacement)
le fil - est branché sur le - de la batterie.
ZUMO 550 - QUEL CABLE Moz-screenshot-8ZUMO 550 - QUEL CABLE Moz-screenshot-9
zbar
zbar
MessageSujet: Re: ZUMO 550 - QUEL CABLE   ZUMO 550 - QUEL CABLE EmptyVen 22 Juil 2011 - 23:10
Merci peyo, c'est cool mais je crois que je vais prendre l'autre cable.Plus simple avec anneaux pour une quiche comme moi.
» Quel magazine moto lisez vous, ou, quel est votre préféré ???
» GPS ZUMO XT
» câble d'accélérateur
» cable antiparasite
» Câble embrayage
