Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar SuperTiti Hier à 21:40
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar Joe644 Hier à 18:56
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar yop1025 Hier à 13:10
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar Arni Dim 17 Nov 2024 - 14:06
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar Arni Dim 17 Nov 2024 - 13:13
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar Fredard Sam 16 Nov 2024 - 9:43
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Cable de bougie "HAUTE PUISSANCE NOLOGY" Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
chaine synchro reglage vidange tuto tenere suis pneus galére selle boue embrayage phare huile feux filtre fourche amortisseur garde réservoir arrière crash essence longues manuel rabaissement
Le Deal du moment : -36%
254.99 €
Ned
Ned
Moto : XTZ750
MessageSujet: Cable de bougie "HAUTE PUISSANCE NOLOGY"   Cable de bougie "HAUTE PUISSANCE NOLOGY" EmptyJeu 7 Avr 2011 - 8:10
j' adore le net! Voilà les "câble d' alimentation haute puissance":
ICI
et on peut les trouver: Là
combinés à la bobine de la même marque et à des bougie "Irridium", il semblerait que la combustion du mélange soit optimum, et de fait avec une bonne étanchéité du moteur on prendrait sévère en puissance au final... hello
-ULYSS FACTOR-
MessageSujet: Re: Cable de bougie "HAUTE PUISSANCE NOLOGY"   Cable de bougie "HAUTE PUISSANCE NOLOGY" EmptyJeu 7 Avr 2011 - 8:58
il y a très longtemps (j'étais tout jeune) j'avais des amis qui faisaient la "Coupe RDLC 350" avec obligation de garder la moto d'origine...
et bien ils m'ont expliqués que la meilleure préparation consistait a démonter complètement le moteur et a le remonter avec une grande précision: équilibrage des pièces en mouvement, couples de serrages respectés et égaux polissage des conduits ect...ect...
un autre jour; j'ai surpris une conversation dans un magasin Suz' : pour la 400 DR, il mettait un joint de culasse beaucoup plus fin ce qui augmente la compression et ainsi la puissance avec conservation de la garantie
on est loin des prepa' couteuses avec des pièces exotiques...
MessageSujet: Re: Cable de bougie "HAUTE PUISSANCE NOLOGY"   Cable de bougie "HAUTE PUISSANCE NOLOGY" EmptyJeu 7 Avr 2011 - 21:00
sur un moteur de 750 c'est des connerie tous ça,soit on passe au gros carbu,pot vidé,super bougie,agrandissement des des soupapes,piston wiseco,.............................................avec une facture de plusieur millier d'euro et un entretien couteux
ou on achete une 1200cc
ou une moto pieces d'origine et tres tres bien regle,deja pour l'exploiter au maxi il en faut des c...lles
ne pas oublier que les rd (j'ai eut une 80,125,350en rdlc,125 rg,250rg gama,125 ktm,350 ktm) sont des deux temps c'est plus facile et moins couteux a modifie qu'un quatre temps!!!!
a plus!!!
MessageSujet: Re: Cable de bougie "HAUTE PUISSANCE NOLOGY"   Cable de bougie "HAUTE PUISSANCE NOLOGY" EmptySam 9 Avr 2011 - 23:26
Hello à tous ...
Sans la maîtrise, la puissance n'est rien les amis ...
Si les 60 bourrins de la 750 ne sont pas suffisants, faut aller voir plus haut ... Pourquoi ne pas poser un 900cc de TDM au lieu de trafiquer ce bon vieux 3LD ;-) ...
Pour ce qui est des câbles, l'étincelle sera juste de meilleure qualité puisque la partie diélectrique sera meilleure et la résistivité du conducteur moindre ;-) ...
Tchüss à tous ;-) ...
Cable de bougie "HAUTE PUISSANCE NOLOGY" Rassos10
Ned
Ned
Moto : XTZ750
MessageSujet: Re: Cable de bougie "HAUTE PUISSANCE NOLOGY"   Cable de bougie "HAUTE PUISSANCE NOLOGY" EmptyMer 13 Avr 2011 - 12:38
je me vois pas bien sur de la piste avé un tdm...
-ULYSS FACTOR-
MessageSujet: Re: Cable de bougie "HAUTE PUISSANCE NOLOGY"   Cable de bougie "HAUTE PUISSANCE NOLOGY" EmptyMer 13 Avr 2011 - 14:14
Derfu a écrit:
..... Pourquoi ne pas poser un 900cc de TDM au lieu de trafiquer ce bon vieux 3LD ;-) ......
le pense qu'il voulait dire de mettre le moteur de la TDM dans la super teneré...
legrandyan
legrandyan
MessageSujet: Re: Cable de bougie "HAUTE PUISSANCE NOLOGY"   Cable de bougie "HAUTE PUISSANCE NOLOGY" EmptyMer 13 Avr 2011 - 14:27
Derfu a écrit:
Hello à tous ...
heuu 70 bourrins mon ami, n'en enléve pas non plus.... Cable de bougie "HAUTE PUISSANCE NOLOGY" 46975
avis d'air zen
» CLE A BOUGIE
» Bougie irridium
» carenage et bougie
» compatibilité bougie xtz et xt
» Bougie NGK Iridium
