bobby06008
Moto : Honda Transalp 600 1995 - Kawasaki GTR 1400 2017 - Yamaha XTZ 1200 2014 : pas de jaloux Kms de ma moto : XTZ 1200 : 40000 km Pneu AV/AR : Tourance Next Messages : 57 Date d'inscription : 17/03/2015 Age : 66 Ville ou région : Alpes Maritimes
| Sujet: Purge circuit ABS Ven 4 Mar 2022 - 13:51 | |
| Bonjour Pour une purge du circuit ABS, c'est bine cet adaptateur qu'il faut ?
https://www.cmsnl.com/products/abs-test-coupler-adopter_9089003149
Merci d'avance Cordialement Robert |
| Sujet: Re: Purge circuit ABS Ven 4 Mar 2022 - 18:33 | |
doujm
Moto : XT1200Z 03/2013 Kms de ma moto : 240000 Pneu AV/AR : Bridgestone A41 Messages : 29 Date d'inscription : 11/09/2018 Age : 65 Ville ou région : Sacy-le-Grand (Oise)
| Sujet: Re: Purge circuit ABS Jeu 30 Nov 2023 - 9:00 | |
| Bonjour, en partage, ci-dessous le résultat d'une recherche matinale sur le web :-) si vous changez le liquide frein ...
https://www.youtube.com/watch?v=W_DdB0dIEN8
https://www.yamahasupertenere.com/index.php?threads/how-to-cycle-the-abs-pump.22743/
Here's how to use the S10 built in ABS pump cycling feature.
Tools Needed: 1. Jumper wire with both ends stripped. 2. Mini Screw Driver to remove the waterproof rubber bungs. 3. Fully Charged Battery.
3'. Locate the 4-way connector under the main seat. 4. Remove the 2 rubber bungs on Blue and Black wire. Then attach the jumper wire as shown. The wire diameter of the stripped ends needs to be of a certain size so that they are 'catch' inside the connectors. 5. Set the Kill Switch to OFF 6. Turn the KEY to ON. Observer that the ABS warning light on the dash is flickering ON and OFF. If this is not so, the jumper wire is not connected correctly. 7. PRESS and HOLD the START BUTTON for about 4 seconds. 8. Simultaneously Step down on the Rear Brake Pedal and Grab the Front Brake lever. 9. The ABS Pump will first actuate the Front for a few seconds, then the Rear, and then back to the Front. All done in about 15 seconds. 10. Key Off. Congrats. ABS Pump cycled. 11. Remove jumper wire. Replace the 2 bungs to the connector. 12. Enjoy the ride! Then have a beer. |
Mulder
Moto : ST1200 Kms de ma moto : 35000 Messages : 14 Date d'inscription : 30/06/2024 Age : 50 Ville ou région : Nantes
| Sujet: Re: Purge circuit ABS Mar 23 Juil 2024 - 16:08 | |
| Bonjour, j'ai l'adaptateur en question que j'utilisais pour tester ma centrale ABS de ma TDM 900 . Quelle est la procédure en français ? Merci par avance. |
LeJean
Moto : - Kms de ma moto : - Messages : 24 Date d'inscription : 24/02/2023 Age : 69 Ville ou région : -
| Sujet: Re: Purge circuit ABS Mar 23 Juil 2024 - 20:06 | |
| Sur ce site https://www.gn-moto.com/506-manuels-atelier-proprietaire-xtz tu peux télécharger gratuitement les manuels atelier XTZ toutes années Le vendeur est très sérieux et compétent, et vend de la pièce à des prix corrects _________________ « Il est plus facile de désintégrer un atome qu’un préjugé. » Albert Einstein
Mulder
| Sujet: Re: Purge circuit ABS Mar 23 Juil 2024 - 21:41 | |
| Merci du conseil. Je connais ce site mais j ignorais qu il était possible de télécharger le manuel d'atelier. Aussi, je pourrais peut-être régler mon soucis de poignées chauffants qui n'apparaissent plus dans le menus. Bonne soirée. |
onemonthoneride
Moto : Yamaha XT1200Z 2012 Kms de ma moto : 134 000 Messages : 17 Date d'inscription : 05/09/2020 Age : 34 Ville ou région : Europe
| Sujet: Re: Purge circuit ABS Mer 31 Juil 2024 - 8:40 | |
| Salut Mulder, si jamais tu recherches toujours la procédure en Français :
il faut un fil électrique de quelques centimètres (câble de pontage)
sous la selle il y a un fil libre avec 4 entrées et un couvercle
apres avoir retirer le couvercle il faut ponter le fil noir au bleu
pontage en place, on place le coupe circuit sur OFF et on tourne la clé
le voyant ABS doit clignoter ; si non il faut vérifier le pontage
on enfonce le bouton de démarrage pendant environ 4s en maintenant le levier et la pédale de frein arrière « enfoncés » puis on relache le bouton de démarrage
La pompe ABS s’active et provoque un mouvement au levier et à la pédale
On peut répéter l'opération une seconde fois avant de tout refermer
Voila ! Tu peux checker notre article si besoin de photos :
https://www.onemonthoneride.com/purge-liquide-de-frein-moto/
Cheers, |
LeJean
| Sujet: Re: Purge circuit ABS Mer 31 Juil 2024 - 14:03 | |
| bonjour,
Et l'adaptateur tout fait (pas de risque de se tromper...), ref 90890-03149 vaut actuellement 4,20€ TTC sur Pièces Yam https://www.pieces-yam.com/yamaha-moto/tarif Et il sert à plusieurs modèles Yamaha, XTZ, FJR et sûrement d'autres _________________ « Il est plus facile de désintégrer un atome qu’un préjugé. » Albert Einstein
Mulder
| Sujet: Re: Purge circuit ABS Jeu 1 Aoû 2024 - 12:04 | |
| Bonjour à tous merci pour vos réponses J'ai un adaptateur que j'utilisais sur ma TDM 900 pour tester la centrale ABS, visiblement ça doit-être le même (?). Aussi, peut-être avez-vous une réponse à m'apporter concernant la disparition de mes poignées chauffantes dans le menu du tableau de bord. J'ai lu sur le forum certaines mauvaises expériences. J'ai fait le tour des connexions et vérifier l'état des câbles et je ne vois rien. Par contre, je ne trouve pas le fusible en question pour le vérifier. ST de 2018, j'aimerai trouver une solution avant d'avoir la grosse artillerie de chez le concessionnaire.... Je prends toutes vos bonnes idées! |
| Sujet: Re: Purge circuit ABS | |
