Codes Diagnostic 1200 xtz Emptypar SuperTiti Hier à 21:40
Codes Diagnostic 1200 xtz Emptypar Joe644 Hier à 18:56
Codes Diagnostic 1200 xtz Emptypar yop1025 Hier à 13:10
Codes Diagnostic 1200 xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Codes Diagnostic 1200 xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Codes Diagnostic 1200 xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Codes Diagnostic 1200 xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Codes Diagnostic 1200 xtz Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Codes Diagnostic 1200 xtz Emptypar Arni Dim 17 Nov 2024 - 14:06
Codes Diagnostic 1200 xtz Emptypar Arni Dim 17 Nov 2024 - 13:13
Codes Diagnostic 1200 xtz Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Codes Diagnostic 1200 xtz Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Codes Diagnostic 1200 xtz Emptypar Fredard Sam 16 Nov 2024 - 9:43
Codes Diagnostic 1200 xtz Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Codes Diagnostic 1200 xtz Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Codes Diagnostic 1200 xtz Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Codes Diagnostic 1200 xtz Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Codes Diagnostic 1200 xtz Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Codes Diagnostic 1200 xtz Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Codes Diagnostic 1200 xtz Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Codes Diagnostic 1200 xtz Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Codes Diagnostic 1200 xtz Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Codes Diagnostic 1200 xtz Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Codes Diagnostic 1200 xtz Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Codes Diagnostic 1200 xtz Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
vidange suis garde phare crash boue galére huile arrière selle filtre tuto tenere rabaissement amortisseur feux embrayage essence manuel longues fourche reglage chaine synchro pneus réservoir
29.99 €
babu80
babu80
Pneu AV/AR : Metzeler
Ville ou région : Périgord
MessageSujet: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyMer 6 Aoû 2014 - 15:23
Tu peut connaitre aussi l’état de batterie avec le mode diagnostic sur  l'XTZ
le code de diag est le N° 9 et tu doit avoir 12 (pour le voltage )
potofeu
potofeu
Ville ou région : lorient
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyJeu 7 Aoû 2014 - 22:23
Moi, ce que j'aimerai savoir c'est comment qu'on rentre en mode diag et koikidit ... kissè ?
Kms de ma moto : laquelle ?
Ville ou région : Besançon
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyLun 8 Sep 2014 - 1:23
si c'est comme la FJR tu maintient les deux bouton du tdb et du met le contact. Ensuit tu selctionne DIAG ou CO et tu valide
potofeu
potofeu
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyLun 8 Sep 2014 - 10:48
D'ac et merci, mais kika le mode d'emploi des codes diag ?
babu80
babu80
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyLun 8 Sep 2014 - 22:10
En voici un certain nombres à compléter doigtsenV
Trouvés en partie sur le forum XTZ espagnol et vérifiés de ma part;
Voici les codes là-bas, mais il y en a d'autres ..
d01.  Position du papillon de gaz Cette valeur doit être 15 à  17 Position fermé
        97 à 100 Position ouverte , si nous activons l'accélérateur, vous verrez que le nombre augmente à 100.
d3: Pression d' air d'admission
d5: Température de l'air d'admission.
d6:. température d'eau
d7: la vitesse du véhicule.  000 pour véhicule à l’arrêt,  si nous nous tournons, la valeur affichée sera augmenté.
d8: Détecteur de  chute. doit être de 0,5 et 1,4.  ( Si la moto est tombe tu retrouve le code panne  dans d 61 )
D9: tension.  de la batterie  12 pour 12 volt
D 14 Capteur de position de l’accélérateur  N°1  (de 12 à 22 position complétement fermé 97 à 113 position ouverte )
D15  capteur de position de l'accélérateur  N°2   ( de 9 à 25     "          "                 "     97 à 113    "          "        )
D16  Capteur de vitesse roue avant
d20: état ​​position de la béquille latérale  ON-OFF
d21: contacteur de point mort. ON-OFF D50  Déclencheur relais principal permettant d'allumer les témoins d'alertes de pannes moteur
D51  Relais ventilateur  moteur
D 52 relais des phares
D60: Vous devriez voir 00  signifie pas de défaut .   01  et ou 02 Défaut sur cylindre 1 ou 2
D61:liste des erreurs en mémoire   Les codes erreurs sont comprise entre 11 et 50 (00 pas de code d'erreur ) Par exemple, si 30 semble dire que le véhicule a renversé.
D62: Affiche le ,nombre d'erreurs  ( exemple 4 signifie que tu a eut 4 codes de défauts)
Pour effacer le nombre de d’erreurs  il suffit de repositionner ton coupe circuit sur ON
D63: le code d'erreur restauré.
Les codes de 01 à 21 sont des codes de capteurs semble t il, de 30 à 52 codes des actionneurs  et enfin de 60 à 70 codes de contrôles mémoires de l'Ecu
La suite demain hello
omz
omz
Moto : XTZ 1200 - T 700
Kms de ma moto : 80 000
Pneu AV/AR : TKC 70
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyMer 10 Sep 2014 - 7:56
Super merci pour la manip que j'ai essayé hier soir
Par contre quand je fais défiler les differents codes  , il y a un moment ou la pompe a essence se declenche  .....!!!! ( enfin il me semble ca fait le meme bruit  .. )
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyMer 10 Sep 2014 - 11:22
oui, il faut laisser le coupe circuit sur OFF .
babu80
babu80
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyMer 10 Sep 2014 - 19:17
D 30 bobine d'allumage GAUCHE du cylindre n°1
D 31    "         "              "             "        n° 2
d 32 Bobine d'allumage DROITE du cylindre n° 1
d 33    "           "            "                "     n° 2
D 36 Injecteur  cylindre n° 1
D 37       "            "     n° 2
omz
omz
Pneu AV/AR : TKC 70
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyJeu 11 Sep 2014 - 8:14
ok merci Piero.    ;)
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyJeu 11 Sep 2014 - 12:01
En fait, le coupe circuit sert à activer/desactiver une fonction.
Par exemple, en mode DIAG sur le code D36 (injecteur 1), en plaçant le coupe circuit sur ON tu lance une séquence de fonctionnement de l'injecteur ;)
babu80
babu80
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyJeu 11 Sep 2014 - 13:18
salut C'est ce que je pense aussi
Rackham
Rackham
Ville ou région : WANNEHAIN
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 12:54
Je relance de 10...
XT1200ZE d'avril 2015...
Appui long sur les deux boutons de l'ODB + contact = ECU ou SCU
Contact et appui long sur les deux boutons de l'ODB = DIAG
Mais impossible de faire défiler/afficher quoi que soit d'autre...
Je cherche le D09 (batterie), mais comment l'atteindre ? Quelqu'un à la manip' ou j'ai commis une erreur qq part ??
R.
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 13:12
Mais quand tu as DIAG qui apparaît il faut revalider en appuyant sur les deux boutons logiquement
Rackham
Rackham
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 13:44
OK...je file au garage essayer...
R.
Rackham
Rackham
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 13:51
Niet !!
Appui long sur les 2 : rien...
Appui court sur les 2 : rien...
Appui long sur TCS : rien...
Appui court sur RESET : rien...
Appui long RESET : rien...
Appui court sur TCS : rien...
L'ODB reste sur DIAG...
R.
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 13:54
La ZE je maitrise pas forcément mais c est bizard, logiquement coupe circuit sur OFF appui long sur les deux boutons, puis tu sélectionne le mode DIAG et tu revalide par un appui long sur les deux boutons, la, je vois pas trop, normalement ça devrait le faire
Rackham
Rackham
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 13:59
Bah...j'y retourne....
coupe circuit sur off...
Allumage de l'ODB...
Appui long sur les 2...
Apparition de DIAG...
A tout de suite...
Rackham
Rackham
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 14:08
Bah...non...
...si un appui long c'est plus de 13 secondes....ça fonctionne pas...
En tous les cas, merci piéro !!
R.
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 14:11
Bizard, j vais voir si je peu trouver une info quelque part
Rackham
Rackham
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptySam 28 Jan 2017 - 14:18
J'ai qq sites amerloques, mais rien de probant...
Bon...je vais changer ma batterie et basta pour le DIAG D09...
R.
yannick 63
yannick 63
Moto : 1200 xtz
Ville ou région : puy de dome
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyLun 30 Jan 2017 - 19:16
le 42 =capteur ABS roue arrière il me semble. Aussi je croit que ZE n'as pas le diag au tdb mais valise concessionnaire .
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyJeu 23 Mar 2017 - 2:51
Je confirme qu'il y a le diag au tdb sur la ZE.
Ce n'est pas vraiment un diag (comme sur les valises) mais plutôt une lecture des capteurs ou des séquences de commande envoyées aux différents organes pour vérifier leur fonctionnement. Cela permet en effet de dresser un premier diagnostic de panne pour identifier l'élément qui pose problème (comme un capteur présent sur la chaîne de coupure du régulateur de vitesse par exemple...).
Il faut faire un appuis long (10s) sur les deux boutons avant de mettre le contact.
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyJeu 23 Mar 2017 - 2:52
T'es sur ? De mémoire, on avait fait quelques essai, sans succès
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyJeu 23 Mar 2017 - 3:48
Pour l'avoir fait sur la mienne un paquet de fois... oui j'en suis sûr.  bien
1- Coupe circuit sur off
2- Boutons TCS+Reset appuyés
3- Contact on
4- Attendre une dizaine de secondes
5- ECU (calculo de la bécane) et SCU (calculo des suspensions) apparaissent
6- Appuyer sur TCS pour changer entre ECU/SCU. Aller sur ECU
7- Appuyer simultanément sur TCS+Reset pour rentrer dans ECU (environ 2 secondes)
8- Un code diagnostic apparaît. 01 de mémoire. Faire défiler les codes avec TCS pour incrémenter et Reset pour décrémenter. Chaque code correspond à un organe de la moto.
9 - Pour lancer une séquence de test, mettre coupe circuit sur ON.
MessageSujet: Re: Codes Diagnostic 1200 xtz   Codes Diagnostic 1200 xtz EmptyJeu 23 Mar 2017 - 12:00
bon impeccable !! J'arrive pas à me rappeler pourquoi on avait besoin du DIAG sur la ZE, mais en tout cas, maintenant on sait que c'est faisable.
Merci à toi Smile
» Boitier diagnostic possible sur une 1200 XTZ de 2010
» codes couleurs cadre 1200 xtz
» diagnostic des défauts sur la T7
» vends FI Diagnostic Tool
» CODES/PHARES XTZ 660 Ténéré 2012
