branchement durite Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
branchement durite Emptypar Joe644 Mer 20 Nov 2024 - 18:56
branchement durite Emptypar yop1025 Mer 20 Nov 2024 - 13:10
branchement durite Emptypar REYNALD Mar 19 Nov 2024 - 10:58
branchement durite Emptypar REYNALD Mar 19 Nov 2024 - 10:49
branchement durite Emptypar REYNALD Mar 19 Nov 2024 - 10:46
branchement durite Emptypar REYNALD Mar 19 Nov 2024 - 10:44
branchement durite Emptypar jackal74 Lun 18 Nov 2024 - 11:58
branchement durite Emptypar Arni Dim 17 Nov 2024 - 14:06
branchement durite Emptypar Arni Dim 17 Nov 2024 - 13:13
branchement durite Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
branchement durite Emptypar yop1025 Sam 16 Nov 2024 - 23:12
branchement durite Emptypar Fredard Sam 16 Nov 2024 - 9:43
branchement durite Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
branchement durite Emptypar J-Marc Mar 12 Nov 2024 - 12:44
branchement durite Emptypar J-Marc Lun 11 Nov 2024 - 21:58
branchement durite Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
branchement durite Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
branchement durite Emptypar thierry83 Dim 10 Nov 2024 - 9:29
branchement durite Emptypar REYNALD Ven 8 Nov 2024 - 16:55
branchement durite Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
branchement durite Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
branchement durite Emptypar REYNALD Mar 29 Oct 2024 - 20:18
branchement durite Emptypar REYNALD Mar 29 Oct 2024 - 20:00
branchement durite Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
réservoir galére rabaissement reglage embrayage essence manuel fourche filtre phare boue amortisseur longues vidange feux chaine suis pneus arrière tenere crash selle synchro tuto garde huile
Le Deal du moment : -30%
139.99 €
 branchement durite
Super Ten
Super Ten
Moto : xtz 750 95
Kms de ma moto : 45000
Ville ou région : Var
MessageSujet: branchement durite   branchement durite EmptyVen 29 Jan 2021 - 11:25
j'ai fait un gros entretien à ma machine en ne laissant que le bloc sur lae cadre, en revanche au remontage j'ai une durite qui sent l'essence et je ne sais pas où la rebrancher, c'est vraiment tout bête mais quelques fois on se retrouve bloqué pour pas grand chose.
Il s'agit de la durite entouré en rouge sur l'image (côté droit de la machine quand on est assis dessus).
Celle qui est entouré en bleu va bien au robinet d'essence.
Merci pour votre aide.
branchement durite Echn
Borgil
Borgil
Kms de ma moto : 89000
Ville ou région : Grenoble
MessageSujet: Re: branchement durite   branchement durite EmptyVen 29 Jan 2021 - 13:05
Elle va sur la pompe à essence côté gauche de la moto. C'est ça qui alimente tes carbus
Gaffe par contre à ne pas mélanger avec celle qui sert à la dépression et se branche sur UNE SEULE pipe d'admission (à l'avant)
Super Ten
Super Ten
Moto : xtz 750 95
MessageSujet: Re: branchement durite   branchement durite EmptyVen 29 Jan 2021 - 13:29
Merci Borgil c'est sympa d'avoir répondu bien
...J'ai du me mélanger les pinceaux parce que de l'autre côté (à gauche) j'avais déjà prévu les 3 trois sorties de la pompe...
Je vais reprendre une photo pour être certain des branchements je suis un peu perdu là.
coolstef
coolstef
Kms de ma moto : 14800
MessageSujet: Re: branchement durite   branchement durite EmptyVen 29 Jan 2021 - 16:18
Il y a trois durites à partir de la pompe :
- une double durite, qui fait un T, qui part de la pompe à essence (entrée de la pompe) est qui va aux deux robinets d'essences du réservoir. D'après ta photo, ce sont les deux durites avec le chiffon rose, dont une est entourée en bleu.
- une durite qui part de la pompe et va au carbu (sortie de la pompe). On le la voit pas sur ta photo.
- une durite, plus petite qui va de la pompe à la pipe d'admission,  sous le carbu droit (entrée dépression de la pompe). On le la voit pas sur ta photo.
Borgil
Borgil
MessageSujet: Re: branchement durite   branchement durite EmptyLun 1 Fév 2021 - 10:08
- une durite qui part de la pompe et va au carbu (sortie de la pompe). On ne la voit pas sur ta photo.
Bah si justement, c'est celle dont il parle (cerclé de rouge) Smile
Borgil
Borgil
MessageSujet: Re: branchement durite   branchement durite EmptyLun 1 Fév 2021 - 10:12
branchement durite Durite10
Pour faire simple :
vert : arrivée d'essence qui vient du réservoir (la double durite en T)
- rouge : sortie d'essence qui va entre les 2 carbus, en "haut" (et donc c'est celle là que tu cherches à brancher !)
- jaune : durite de dépression qui va sur la pipe d'admission du carbu droit (et surtout pas gauche)
coolstef
coolstef
MessageSujet: Re: branchement durite   branchement durite EmptyLun 1 Fév 2021 - 10:50
T’as raison Borgil, j’avais mal regardé pourtant je les ai branchés et débranchés un paquet de fois 😉
Super Ten
Super Ten
Moto : xtz 750 95
MessageSujet: Re: branchement durite   branchement durite EmptyLun 1 Fév 2021 - 13:31
Cool,
merci à vous deux mais surtout merci à Borgil bien , je vais faire le branchement cet après midi, je posterais une autre photo pour être certain que mes branchements soient corrects.
Super Ten
Super Ten
Moto : xtz 750 95
MessageSujet: Re: branchement durite   branchement durite EmptyLun 1 Fév 2021 - 17:44
Voilà mon branchement, mais il reste encore un tuyau...
branchement durite Xipk
branchement durite Tiiv
Borgil
Borgil
MessageSujet: Re: branchement durite   branchement durite EmptyLun 1 Fév 2021 - 17:53
Celui là c'est bien celui "sous" le rouge que tu viens de brancher ? Qui est lui aussi branché entre les 2 carbus ?
Si oui, c'est normal, il ne va nul part (en tous cas moi je l'ai jamais vu brancher, ça ressemble à une prise d'air ou trop plein) Smile
Super Ten
Super Ten
Moto : xtz 750 95
MessageSujet: Re: branchement durite   branchement durite EmptyLun 1 Fév 2021 - 18:15
Merci Borgil c'est cool ;)
C'est celui qui est branché en haut entre les carbus
Mais effectivement en y regardant de plus près on voit bien que l'embout est net ;-)
Tu m'as vraiment aidé, c'est super sympa !
branchement durite
» Durite d'evacuation
» durite d essence
» Durite refroidissement
» Elle va où cette durite ?
» Durite fantôme Carbu
