Protection carter R&G T700 Emptypar SuperTiti Hier à 21:40
Protection carter R&G T700 Emptypar Joe644 Hier à 18:56
Protection carter R&G T700 Emptypar yop1025 Hier à 13:10
Protection carter R&G T700 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Protection carter R&G T700 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Protection carter R&G T700 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Protection carter R&G T700 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Protection carter R&G T700 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Protection carter R&G T700 Emptypar Arni Dim 17 Nov 2024 - 14:06
Protection carter R&G T700 Emptypar Arni Dim 17 Nov 2024 - 13:13
Protection carter R&G T700 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Protection carter R&G T700 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Protection carter R&G T700 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Protection carter R&G T700 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Protection carter R&G T700 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Protection carter R&G T700 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Protection carter R&G T700 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Protection carter R&G T700 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Protection carter R&G T700 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Protection carter R&G T700 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Protection carter R&G T700 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Protection carter R&G T700 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Protection carter R&G T700 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Protection carter R&G T700 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Protection carter R&G T700 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
tuto réservoir synchro arrière garde embrayage selle phare suis galére pneus reglage huile feux tenere boue rabaissement fourche essence crash amortisseur chaine filtre vidange manuel longues
-25%
599 € 799 €
Champibleu
Champibleu
Moto : 700 Ténéré
Kms de ma moto : 11000
Pneu AV/AR : Pirelli MT21 / Heidenau K60 scout
Ville ou région : Chambéry
MessageSujet: Protection carter R&G T700   Protection carter R&G T700 EmptyMar 7 Avr 2020 - 14:13
Salut à tous, mon protège carter d'embrayage étant arrivé...voilà un petit tuto du montage.
Rien de bien compliqué, vous allez voir !
Tout d'abord, une bonne surprise au déballage, cette protection est plus solide que ce que j'imaginais !
Le plastique est épais mais pas cassant, la finition extérieure est soignée et les nervures intérieures rigidifient bien l'ensemble.
Protection carter R&G T700 110
une petite vue de l'intérieur...
Protection carter R&G T700 210
En plus du carter plastique, un jeu de vis de rechange, plus longues pour remplacer celles d'origine et des entretoises. Celles-ci emprisonnent le carter aux quatre trous de fixation.
Protection carter R&G T700 310
Champibleu
Champibleu
Moto : 700 Ténéré
MessageSujet: Re: Protection carter R&G T700   Protection carter R&G T700 EmptyMar 7 Avr 2020 - 14:22
Petit exercice pour remplacer les différentes vis selon leur longueur....
Dépose de la protection plastique d'origine et inversion des vis pour en mettre des plus courtes...
Erratum : erreur sur la photo et comme je ne veux pas la refaire... " les deux vis à flèches rouges sont à récupérer pour remplacer les jaunes ! "
Protection carter R&G T700 410
Mise en place des entretoises sur la protection R&G
Protection carter R&G T700 511
Mise en place de la protection et.... Y'a plus qu'à ! moto duo
Ca ne vaut pas un crashbar en cas de gros pet mais c'est plutôt bien foutu et assez costaud.
Protection carter R&G T700 611
ursustenerix
ursustenerix
Kms de ma moto : 60 + 15
Pneu AV/AR : K 60 scout
MessageSujet: Re: Protection carter R&G T700   Protection carter R&G T700 EmptyMar 7 Avr 2020 - 15:48
Merci, c'est très clair et ça ne doit pas peser lourd !
Aucune gêne contre la jambe ? Je crois que certains se plaignaient de la protection plastique d'origine (ça ne me dérange pas).
TranTurqUkraURSSUSA
sebti
sebti
Moto : ténéré 700
MessageSujet: Re: Protection carter R&G T700   Protection carter R&G T700 EmptyMar 7 Avr 2020 - 17:48
Il y a 2 fabricants " principaux " c'est R&G et GB racing. Avec une qualité un cran au dessus pour GB racing.
Ce que je crains c'est que l'humidité et la boue reste derrière et que ça fasse pourrir le carter... J'avais monté une protection sur mon enduro et le carter a finalement morflé, du coup j'hésite vraiment...
insta: mobylette rollers
Smile
Champibleu
Champibleu
Moto : 700 Ténéré
MessageSujet: Re: Protection carter R&G T700   Protection carter R&G T700 EmptyMar 7 Avr 2020 - 18:16
Le tout tient avec les quatre vis du kit....A peu près 1 mn pour le déposer et nettoyer derrière... bien
Cette protection dépasse un peu moins que le petit carter d'origine (de peu ! )
La GBracing protège beaucoup moins et surtout pas la pompe à eau...
Je crois que je vais commander le carter gauche...
JeanEd
JeanEd
Moto : BMW R1200 GSA + BMW R80 G/S + BMW R80 G/S Paris Dakar + BMW R 1200C + Yamaha T7
MessageSujet: Re: Protection carter R&G T700   Protection carter R&G T700 EmptyMar 7 Avr 2020 - 19:22
Pire que ça et déjà vu sur une machine équipée de la sorte. Un gravillon de la bonne largeur s'était logé entre le carter et le protège carter, et il est resté là un bon moment. Seulement, avec les vibrations, il est allé est venu entre les deux, pendant des mois et a complètement usé le carter et même commencé à entamer la matière qui était à nu et définitivement marquée. Il faut toujours avoir en tête que quand on met quelque chose devant quelque chose avec un espace entre les deux et de quoi y passer, tôt ou tard quelque chose y passera et... fera son travail.
Perso, j'ai préféré retirer le cache d'origine et j'ai laissé comme ça.
» diametre joint bouchon vidange carter t700
» sabot alu et protection carter
» [ACH] Carter d'alternateur XTZ 750
» pare carter
» Carter embrayage
