Changement centrale clignotants, Help Emptypar SuperTiti Hier à 21:40
Changement centrale clignotants, Help Emptypar Joe644 Hier à 18:56
Changement centrale clignotants, Help Emptypar yop1025 Hier à 13:10
Changement centrale clignotants, Help Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Changement centrale clignotants, Help Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Changement centrale clignotants, Help Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Changement centrale clignotants, Help Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Changement centrale clignotants, Help Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Changement centrale clignotants, Help Emptypar Arni Dim 17 Nov 2024 - 14:06
Changement centrale clignotants, Help Emptypar Arni Dim 17 Nov 2024 - 13:13
Changement centrale clignotants, Help Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Changement centrale clignotants, Help Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Changement centrale clignotants, Help Emptypar Fredard Sam 16 Nov 2024 - 9:43
Changement centrale clignotants, Help Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Changement centrale clignotants, Help Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Changement centrale clignotants, Help Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Changement centrale clignotants, Help Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Changement centrale clignotants, Help Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Changement centrale clignotants, Help Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Changement centrale clignotants, Help Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Changement centrale clignotants, Help Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Changement centrale clignotants, Help Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Changement centrale clignotants, Help Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Changement centrale clignotants, Help Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Changement centrale clignotants, Help Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
manuel boue arrière crash garde pneus phare selle huile réservoir longues tuto vidange fourche chaine essence tenere galére rabaissement amortisseur feux embrayage synchro filtre suis reglage
Le Deal du moment : -29%
269.99 €
Vincent974
Vincent974
Moto : SuperTénéré XTZ 750 1995
Ville ou région : Réunion
MessageSujet: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptyVen 18 Sep 2020 - 17:00
Salut tous,
J'ai besoin de vos lumières de champion de l'électricité, sujet où je suis plus mauvais que mauvais ... désolé mon truc c'est le bois.
J'ai monté des clignotants "petits", plus design selon moi sur ma 750, seulement ils sont en 12v, et donc ça clignote pas, ça reste allumé. Normal, c'est donné pour tourné en 18v et ma centrale j'imagine est calibrée pour.
Alors question à 100 balles, est ce qu'en changeant tout simplement ma centrale d'origine par une 12v ça va fonctionner ou alors elle aussi va se retrouver en défaut car elle reçoit également du 18v en amont? AUquel, j'imagine il faudrait une résistance en plus?
Merci d'avance pour l'éclairage ... et si vous avez au passage un lien pour m'orienter dans les achats, merci beaucoup
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptyVen 18 Sep 2020 - 21:15
Je ne comprends pas pourquoi il y aurait du 18 volts sur ta moto...  Et comment tu as pu trouver une centrale en 18 volts...   Es tu sur qu'il s'agit de volts ?
Il te faut trouver une centrale en 12 volts qui corresponde à la puissance (en watts) de tes deux ampoules + le voyant .  Parfois la puissance indiquée correspond à la puissance d'une ampoule (ex 21watts) ; renseigne toi !
volpone
volpone
Moto : bmw1100GS / yamaha 700 tenere
Kms de ma moto : 95000
Ville ou région : vercors sud
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptyVen 18 Sep 2020 - 22:41
Vincent974 a écrit:
Salut tous,
tu as des clignots a empoule d'origine
si tu as mis des clignotants LED sa ne marchera pas avec tas central origine
il te faut une central pour clignot led
et trouver du 18v sur tas moto tu me dira ou parce que moi
je ne vois pas !!
"Heureux soient les fêlés, car ils laisseront passer la lumière."
Vincent974
Vincent974
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptySam 19 Sep 2020 - 12:47
Mes ampoules d'origine sont en 18v ... Changement centrale clignotants, Help 49290
volpone
volpone
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptySam 19 Sep 2020 - 13:02
tu es sur que ce n'est pas 12v et 18w !!! 12v c'est la tension 18whatt puissance
Vincent974
Vincent974
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptyDim 20 Sep 2020 - 17:50
Bein je vois pas trop pourquoi mes nouveaux clignotants en 12v alors sont allumés en continu ... je v revérifié
Vincent974
Vincent974
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptyLun 21 Sep 2020 - 14:21
Ok c'est bon suis une m***e ... 1an que je roule sans clignotants juste parce que j'ai besoin de lunettes ... m'en vais acheter des ampoules wedge 12v 21watts dès demain
volpone
volpone
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptyLun 21 Sep 2020 - 15:39
trosuper
Vincent974
Vincent974
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptyVen 2 Oct 2020 - 16:06
Bon j'ai mis des 12V 21W comme d'origine mais ça clignote tjs pas ... incompréhensible! ça reste allumé en continu alors qu'avec les origines ça fonctionne ... je comprends pas du tout pourquoi, ça n'a pas de sens
volpone
volpone
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptyVen 2 Oct 2020 - 16:52
les ampoules que tu a mis simple ou double filament ?
Vincent974
Vincent974
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptySam 3 Oct 2020 - 10:48
Simple à priori ...
Changement centrale clignotants, Help 20201010
Changement centrale clignotants, Help 20201011
volpone
volpone
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptySam 3 Oct 2020 - 17:22
sa c'est pas pour les clignotant c'est pour la veilleuse
fait une photos intérieur de tes clignotants
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptySam 3 Oct 2020 - 19:25
En effet, ça ressemble à des 5 watts... Mais ça ne fait peut être que ressembler...Etonnant que ce soit posé dans des clignotants qui sont appelés à vibrer; ces ampoules ne sont pas bloquées par une baîonnette ;
Trouver des doubles fils dans cette gamme d'ampoules, je ne pense pas que ça puisse exister de toutes façons .
volpone
volpone
MessageSujet: Re: Changement centrale clignotants, Help   Changement centrale clignotants, Help EmptySam 3 Oct 2020 - 20:59
tu as raison de plus les ampoules de clignot
sont a culot quart de tour monofilament
généralement en 12v21w
» Relocalisation de la plaque d'immat'
» clignotants
» clignotants LED
» SOS clignotants
» Problème clignotants
