ABSENCE FREIN MOTEUR - Page 2 Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
ABSENCE FREIN MOTEUR - Page 2 Emptypar Joe644 Mer 20 Nov 2024 - 18:56
ABSENCE FREIN MOTEUR - Page 2 Emptypar yop1025 Mer 20 Nov 2024 - 13:10
ABSENCE FREIN MOTEUR - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
ABSENCE FREIN MOTEUR - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
ABSENCE FREIN MOTEUR - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
ABSENCE FREIN MOTEUR - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
ABSENCE FREIN MOTEUR - Page 2 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
ABSENCE FREIN MOTEUR - Page 2 Emptypar Arni Dim 17 Nov 2024 - 14:06
ABSENCE FREIN MOTEUR - Page 2 Emptypar Arni Dim 17 Nov 2024 - 13:13
ABSENCE FREIN MOTEUR - Page 2 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
ABSENCE FREIN MOTEUR - Page 2 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
ABSENCE FREIN MOTEUR - Page 2 Emptypar Fredard Sam 16 Nov 2024 - 9:43
ABSENCE FREIN MOTEUR - Page 2 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
ABSENCE FREIN MOTEUR - Page 2 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
ABSENCE FREIN MOTEUR - Page 2 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
ABSENCE FREIN MOTEUR - Page 2 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
ABSENCE FREIN MOTEUR - Page 2 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
ABSENCE FREIN MOTEUR - Page 2 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
ABSENCE FREIN MOTEUR - Page 2 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
ABSENCE FREIN MOTEUR - Page 2 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
ABSENCE FREIN MOTEUR - Page 2 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
ABSENCE FREIN MOTEUR - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
ABSENCE FREIN MOTEUR - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
ABSENCE FREIN MOTEUR - Page 2 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
filtre suis fourche rabaissement pneus synchro huile tenere chaine longues selle garde phare boue amortisseur galére arrière reglage réservoir essence manuel tuto feux crash embrayage vidange
Le Deal du moment : -30%
139.99 €
MessageSujet: Re: ABSENCE FREIN MOTEUR   ABSENCE FREIN MOTEUR - Page 2 EmptyLun 20 Nov 2017 - 13:27
etinag a écrit:
Sujet évoqué ici sur le fofo ricain
http://www.yamahasupertenere.com/index.php?topic=2895.0
Un paquet de pages, ça commence en 2011 et jusqu'à il y a 15 jours
On apprend pleins pleins de choses (même que j'ai cru voir que les  XTZ12 ricaines n'étaient pas transpondées  interrogation )
(google translate ou autre et lecture en diagonale pour moi; ça passe mieux clin d\'oeil)
Ca parle même de saisir la justice .... Pour dire que le sujet est brûlant par là ...
C'est clair que les ricains ils sont super actif pour la Ténéré. Entre le forum supertenere et advrider, il y a une mine d'infos!
MessageSujet: Re: ABSENCE FREIN MOTEUR   ABSENCE FREIN MOTEUR - Page 2 EmptyJeu 23 Nov 2017 - 9:37
Petite question qui me vient...
Avez-vous jeté un œil à la température de l'eau lorsque le problème se fait sentir?
Autre point, qui normalement devrait se faire sentir aussi au ralenti en roue libre, mais bon on ne sait jamais...
Il faudrait que vous jetiez un œil à la valeur d'adaptation de la commande de ralenti (ISC). C'est le code diagnostic 67. Si "00", les données d'adaptation ont été effacées, "01", il n'est pas nécessaire de les effacer, "02", il faut les effacer.
Juste pour info, le contrôle du ralenti se faire normalement après un contrôle de jeu au soupapes, une synchronisation des boîtiers d'injection et remplacement ou nettoyage du filtre à air.
jackal74
jackal74
MessageSujet: Re: ABSENCE FREIN MOTEUR   ABSENCE FREIN MOTEUR - Page 2 EmptyMer 4 Avr 2018 - 10:43
j'ai eu le même problème de perte de frein moteur sur la ZE
sujet abordé ICI et LA
en bref, perte du frein moteur et régime haut (1400 à 1600 à chaud / 4-5 barrettes), descente lente des tr/mn en débrayant
pot Akra mais même problème avec le pot d'origine...et de toute façon jamais eu le problème avec la Z + Akra
Mars 2017, la bête est passée entre les mains de Mr Yamaha France...qui n'a rien trouvé
1 semaine à faire des essais, tout dérégler / re-régler (sans changer la moindre pièce au final mais en faisant des tests avec les organes d'une autre ZE en magasin pour voir)
toujours est-il, quand je l'ai récupérée, j'ai senti un "mieux". problème beaucoup plus rare et moins intense mais surtout je peux utiliser une solution facile à appliquer pour remédier au problème :
au démarrage (moteur froid ou chaud) je sais détecter si le problème de ralenti est présent
j'attend que le moteur soit chaud, je veille une descente ou un arrêt au stop ou au feu et je coupe le moteur au bouton et le rallume...et là, MIRACLE : régime à 1200 tr/mn (3 barrettes) et frein moteur de camion
mais le mystère reste entier sur la raison du problème
ABSENCE FREIN MOTEUR - Page 2 Sans_t10ABSENCE FREIN MOTEUR - Page 2 P1010010 ABSENCE FREIN MOTEUR - Page 2 Logo_c10ABSENCE FREIN MOTEUR - Page 2 P1010012
http://www.lescimes.org
jean-pierre 74
jean-pierre 74
Kms de ma moto : 82 000
MessageSujet: Re: ABSENCE FREIN MOTEUR   ABSENCE FREIN MOTEUR - Page 2 EmptyMer 4 Avr 2018 - 18:50
J'ai eu un problème presque similaire sur ma dernière FJR. Lorsque je montais en altitude la moto devenait inconduisible avec un régime moteur qui baissait jusqu'à caler dans les épingles. Hyper dangereux. La moto est passée je ne sais combien de fois à la concession au point que le chef d'atelier ne savait plus quoi faire. Pour régler momentanément le problème je coupais le moteur au bouton pour faire une sorte de "reset" et ça repartait normal jusqu'à la prochaine défaillance parfois moins de 2 km plus loin. Le technicien de Yamaha France est venu voir la moto et n'a rien trouvé d'anormal et pour cause il a toujours essayé la moto en plaine. Ce n'est que 8 mois plus tard que Yamaha France à envoyer à ces concessionnaires une directive pour remédier au problème sur toutes les motos concernées. En fait d'un millésime à l'autre pour faire des économies ils avaient supprimé un capteur d'altitude. Résultat ils ont du changer le CDI de toutes les motos concernées dans le monde. A 800 euros la bête on peut juger de la boulette faite par les ingénieurs.
J'ai rencontré cet été dans les Dolomittes deux gars en ZE qui m'ont décrit le même problème, à savoir un ralenti instable et perte du frein moteur.
Ils avaient des motos achetées début 2016 mais peut-être de millésime 2015. A voir, peut-être une piste à suivre....
jackal74
jackal74
MessageSujet: Re: ABSENCE FREIN MOTEUR   ABSENCE FREIN MOTEUR - Page 2 EmptyJeu 5 Avr 2018 - 8:22
salut Jean-Pierre
la mienne est également de début 2016  ABSENCE FREIN MOTEUR - Page 2 242583
mais chez Yamaha France, ils ne sont pas très loquasses pour ébruiter les problèmes rencontrés sur d'autres motos de la série
ils collectent les infos mais ne les redistribuent pas (ou partiellement) aux concessionnaires qui se retrouvent comme une poule devant un couteau
mon problème était le même que celui de Patou33 en Gironde, YF le savait et pourtant dit à mon concess que c'est un cas isolé  saispas
jean-pierre 74
jean-pierre 74
MessageSujet: Re: ABSENCE FREIN MOTEUR   ABSENCE FREIN MOTEUR - Page 2 EmptyJeu 5 Avr 2018 - 8:42
Tout pareil pour mon FJR. Yamaha Japon savait mais n'avait pas informé ces concessionnaires. Moto achetée neuve en Mars et problème réglé en Novembre. Cela fait quand même 9 mois de galère pour une moto de près de 18.000 euros à l'époque (2007). Comme d'hab c'est le marché américain qui a fait progresser l'affaire en menaçant de dépôt de plainte.
En France, vu le prix de la pièce à changer Yamaha n'a pris en charge que les motos des propriétaire des départements montagneux ce qui est à mon sens complétement ridicule.
» le frein moteur fait le yoyo
» frein 600 xt 3aj
» frein arrière
» étriers de frein
» purge frein
