Eclairage Top case Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
Eclairage Top case Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Eclairage Top case Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Eclairage Top case Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Eclairage Top case Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Eclairage Top case Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Eclairage Top case Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Eclairage Top case Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Eclairage Top case Emptypar Arni Dim 17 Nov 2024 - 14:06
Eclairage Top case Emptypar Arni Dim 17 Nov 2024 - 13:13
Eclairage Top case Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Eclairage Top case Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Eclairage Top case Emptypar Fredard Sam 16 Nov 2024 - 9:43
Eclairage Top case Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Eclairage Top case Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Eclairage Top case Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Eclairage Top case Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Eclairage Top case Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Eclairage Top case Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Eclairage Top case Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Eclairage Top case Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Eclairage Top case Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Eclairage Top case Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Eclairage Top case Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Eclairage Top case Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
reglage filtre arrière huile tenere phare galére chaine embrayage réservoir crash boue vidange longues tuto suis essence synchro manuel garde fourche pneus amortisseur rabaissement feux selle
-17%
249 € 299 €
 Eclairage Top case
t-teuf
t-teuf
Moto : yamaha XTZ 1200 Worldcrosser
Ville ou région : Alsace
MessageSujet: Eclairage Top case   Eclairage Top case EmptySam 24 Juin 2017 - 18:24
J'ai acheté un top case T-ray de chez Motech qui intègre un éclairage.
Sur la platine il faut brancher un + et un -
Ou, sur la xtz 1200 je peux trouver des cosses de libre pour brancher ces 2 fils ? Et ou je peux passer sans percer pour allez de la moto à la platine ?
Merci pour votre aide.
Appel 2 phares
Patrick
http://passion-moto-fr.bbactif.com/
http://voyagesmoto.bbactif.com/
Ferdi
Ferdi
Kms de ma moto : 20000
Pneu AV/AR : Mitas E07
Ville ou région : Suisse
MessageSujet: Re: Eclairage Top case   Eclairage Top case EmptySam 24 Juin 2017 - 22:05
Pour le moins, tu te branches directement sur la batterie, pour le +12V après contact, tu peux te reprendre sur un fusible. Tu dénudes le fil du plus et tu le coinces sur la borne avec le fusible.
J'ai l'alimentation du GPS et les poignées chauffantes Technoglobe de branchées comme ça, et ça marche Nickel !
Pour ce qui est du passage du câblage, il suffit de longer le cadre sous le réservoir, puis de passer sous les selles conducteur et passager (la selle passager se démonte avec deux BTR), et hop, tu arrives à ta platine !
MessageSujet: Re: Eclairage Top case   Eclairage Top case EmptySam 24 Juin 2017 - 22:38
Attention au bricolage! On ne branche pas n'importe quoi sur n'importe quel fusible; un éclairage de top case ne se branche pas sur un fusible de sécurité du genre "allumage"; si, pour une cause indéterminée , un court circuit se produit lors d'un dépassement, tu peux te retrouver avec une coupure moteur, et ça peut être plus que dangereux; ça n'est pas pour rien que Yamaha a scindé les protections des divers organes des motos, afin d'améliorer notre sécurité; dans ce domaine, il ne serait pas très judicieux d'aller à contre courant .
Ferdi
Ferdi
MessageSujet: Re: Eclairage Top case   Eclairage Top case EmptyDim 25 Juin 2017 - 14:12
Entièrement d'accord avec toi !
Ca me paraissait tellement évident que je n'ai pas pensé à préciser. Mea culpa.
Je pense qu'un fusible dédié à l'éclairage est tout indiqué. Au choix on a :
 - le fusible de phare (20 A)
 - le fusible du système de signalisation (10 A)
 - le fusible de feu arrière (7.5 A)
A sélectionner en fonction de la puissance du feu de la platine du top case (voir notice d'installation de ladite platine).
t-teuf
t-teuf
MessageSujet: Re: Eclairage Top case   Eclairage Top case EmptyDim 25 Juin 2017 - 19:09
Merci pour vos explications. bien
Et les fusibles sont à l'avant à droite je crois Eclairage Top case 49290
Ferdi
Ferdi
MessageSujet: Re: Eclairage Top case   Eclairage Top case EmptyDim 25 Juin 2017 - 19:22
Oui c'est ça. Regarde avec le manuel utilisateur pour repérer les fusibles.
t-teuf
t-teuf
MessageSujet: Re: Eclairage Top case   Eclairage Top case EmptyDim 25 Juin 2017 - 19:35
Merci pour vos aides
MessageSujet: Re: Eclairage Top case   Eclairage Top case EmptyMar 27 Juin 2017 - 13:13
Pour le "moins", inutile d'aller chercher le "moins" de la batterie. Une bonne masse non loin de la platine, sous la selle par exemple, suffit. Ça fera un fil de moins à tirer (sauf si c'est un fil double) et surtout du bordel en moins derrière le carénage où se trouve la batterie. C'est déjà bien encombré.
Eclairage Top case
» case sur top case yamaha
» Eclairage.
» Eclairage XTZ
» éclairage compteur
» Soucis d'éclairage
