Bulle Givi airflow - Page 2 Emptypar SuperTiti Hier à 21:40
Bulle Givi airflow - Page 2 Emptypar Joe644 Hier à 18:56
Bulle Givi airflow - Page 2 Emptypar yop1025 Hier à 13:10
Bulle Givi airflow - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Bulle Givi airflow - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Bulle Givi airflow - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Bulle Givi airflow - Page 2 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Bulle Givi airflow - Page 2 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Bulle Givi airflow - Page 2 Emptypar Arni Dim 17 Nov 2024 - 14:06
Bulle Givi airflow - Page 2 Emptypar Arni Dim 17 Nov 2024 - 13:13
Bulle Givi airflow - Page 2 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Bulle Givi airflow - Page 2 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Bulle Givi airflow - Page 2 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Bulle Givi airflow - Page 2 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Bulle Givi airflow - Page 2 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Bulle Givi airflow - Page 2 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Bulle Givi airflow - Page 2 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Bulle Givi airflow - Page 2 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Bulle Givi airflow - Page 2 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Bulle Givi airflow - Page 2 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Bulle Givi airflow - Page 2 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Bulle Givi airflow - Page 2 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Bulle Givi airflow - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Bulle Givi airflow - Page 2 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Bulle Givi airflow - Page 2 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
réservoir suis embrayage galére crash pneus garde boue rabaissement arrière tuto reglage phare tenere huile selle fourche amortisseur synchro essence vidange chaine longues feux manuel filtre
-30%
139.99 € 198.99 €
 Bulle Givi airflow
Lejeune85
Lejeune85
Moto : XTZ 1200 First Edition
Kms de ma moto : 36000
Pneu AV/AR : Michelin Pilot Road 4 Trail
Ville ou région : PAYS DE LA LOIRE
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyDim 5 Avr 2015 - 22:51
J’ai reçu récemment une bulle Givi Airflow commandée chez Motoblouz pour équiper ma XTZ 1200, et tout à l’heure, en l’installant, j’ai rencontré le problème suivant :  scratch
Après avoir fixé la bulle airflow sur le support d’origine de ma XTZ, je n’ai pas réussi à mettre en place le déflecteur réglable à l’intérieur des 2 verrous de guidage. Les glissières sur le déflecteur ne tombent pas en face des verrous de guidage (il y a au moins 3 mm de décalage). Même en desserrant légèrement les écrous des verrous sur la bulle et en forçant, le déflecteur ne s’emboîte pas.
Bulle Givi airflow - Page 2 980298
J’ai donc finalement démonté la bulle, l’ai ensuite posée à plat sur une surface horizontale, la face bombée orientée vers le haut. Puis j’ai appuyé dessus afin d’atténuer la courbure et rattraper ainsi le décalage de 3 mm afin que les glissières se retrouvent cette fois-ci bien en face des 2 verrous de guidage. J’ai réussi à faire avancer le déflecteur d’environ 3 à 4 cm toujours en forçant, mais vu la pression qu’il fallait exercer pour le faire, j’ai préféré renoncer que de casser quelque chose. Si je dois renvoyer l’article chez Motoblouz, autant ne rien abîmer. Et j’ai d’ailleurs eu encore plus de mal à retirer le déflecteur qu’à le mettre…
Je pense qu’il doit y avoir un problème. se tape tete
Pourtant, la bulle porte bien la référence AF447 ce qui correspond bien aux modèles XTZ 1200 de 2010 à 2013. Par contre il n’y a pas de référence sur le déflecteur. Peut-être que Givi commercialise plusieurs modèles de déflecteurs avec des écartements de glissières différents (dans ce cas le déflecteur que j'ai reçu n'est pas le bon), ou bien alors il produit un modèle unique qui est compatible avec toutes ses bulles (et dans ce cas les cotes de perçage pour le positionnement des 2 verrous de guidage n'ont pas été respectées).
- Avez-vous rencontré le même souci lors de la mise en place du déflecteur sur la bulle airflow ?
- Faut-il réellement forcer pour mettre le déflecteur en place sur la bulle ?
- Le coulissement glissières / verrous de guidage se fait-il facilement une fois que les 2 leviers de blocage sont en position horizontale, ou présente-t-il une résistance importante ?
Merci pour vos retours.
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyDim 5 Avr 2015 - 23:07
il ne faut pas forcer pour inserer la partie mobile.
sur ma bulle, l'entraxe est d'environ 17 cm
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyDim 5 Avr 2015 - 23:17
précisément hors tout 17,5 (cote interieur 16.2)
Bulle Givi airflow - Page 2 P1280810
Bulle Givi airflow - Page 2 P1280811
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyDim 5 Avr 2015 - 23:24
mon modèle ne va pas sur ma nouvelle XTZE motard3
Lejeune85
Lejeune85
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyLun 6 Avr 2015 - 0:56
Merci jlucg pour ta réponse.
Après vérification de l'écartement des glissières sur mon déflecteur, il se trouve qu'il est bien identique au tien : 162 mm intérieur et 175 mm extérieur. Donc à priori cette partie mobile ne semble pas être la cause du problème.
Lejeune85
Lejeune85
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyLun 6 Avr 2015 - 1:55
Maintenant en positionnant le déflecteur sur la bulle, voilà ce que ça donne (verrous de guidage vus d'en dessous) :
verrou de guidage côté droit : on est aligné
Bulle Givi airflow - Page 2 P1010411
verrou de guidage côté gauche : on est décalé
Bulle Givi airflow - Page 2 P1010412
On constate un décalage d'un peu plus de 3 mm. Donc le problème viendrait de la bulle (partie fixe sur la moto) et non du déflecteur :
- soit les entraxes horizontaux n'ont pas été respectés lors des perçages destinés à recevoir les vis de fixation des verrous de guidage (et j'ai vérifié, il n'y a pas de réglage latéral possible),
- soit les perçages sont corrects mais c'est le rayon de courbure de la bulle qui n'est pas conforme et qui entraîne ce décalage (cela voudrait dire dans ce cas que le formage a été réalisé après les perçages).
Il est à noter que les perçages de la partie inférieure de la bulle destinés à sa fixation sur les supports de la moto n'ont posé aucun problème.
Lejeune85
Lejeune85
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyLun 6 Avr 2015 - 2:03
Je vais dès demain demander un échange en espérant qu'il s'agisse d'un cas isolé et que la nouvelle bulle airflow qui me sera renvoyée ne présentera pas les mêmes défauts... doute
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyLun 6 Avr 2015 - 10:54
il y a bien un problème
les mêmes photos que toi
Bulle Givi airflow - Page 2 P1280812
Bulle Givi airflow - Page 2 P1280813
Lejeune85
Lejeune85
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyLun 6 Avr 2015 - 22:33
J'ai déposé ce matin mon colis de retour dans un point Mondial Relay, puis j'ai envoyé un mail à Givi en leur expliquant le problème. On va bien voir s'ils vont me répondre... interrogation
Michio
Michio
Moto : XTZ1200 First Edition #627
Kms de ma moto : 32000
Ville ou région : La Roche-sur-Yon (85)
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyMar 7 Avr 2015 - 0:31
Damned, pas vu ton post plus tôt : si 85 c'est ton département, on aurait pu voir sur la ST directement, puisque j'ai la Airflow de montée...
Inducteur de métacognition pour apprenants en situation de réussite différée...
http://michio.kurata.free.fr
Giorgio 37
Giorgio 37
Moto : xtz 1200 de 2011
Kms de ma moto : 60 000
Pneu AV/AR : Bridgestone Battle Wing
Ville ou région : Touraine
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyMer 8 Avr 2015 - 15:05
Ma bulle actuelle, une MRA avec déflecteur, est probablement trop basse pour moi.
Je ne suis pas un géant puisque je ne mesure que 1.84m, mais je suis probablement court sur pattes car j'ai proportionnellement le haut du corps plus grand par rapport aux hommes de ma taille.
Bref, même avec la selle en position basse et le déflecteur réglé au maximum, j'ai beaucoup de turbulences dans le casque.
Dès que je rentre un peu la tête dans les épaules je ne ressens plus rien, j'en déduis que c'est très certainement un problème de hauteur de bulle.
J'ai pensé à deux solutions et j'aimerais prendre conseil auprès de ceux qui les ont expérimentées.
1 - Monter un support de bulle réglable Touratech qui me permettrait de gagner quelques centimètres en hauteur (et accessoirement de fixer le GPS)
2 - Remplacer ma bulle MRA par une Givi Airflow
Quelle est d'après-vous la meilleure solution ?
jean-luc
jean-luc
Moto : FJR 1300 (2006), Honda Transalp (1992)
Kms de ma moto : 100.000 FJR, 44.... Transalp
Ville ou région : Belgique
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyMer 8 Avr 2015 - 16:05
Personne n'a la VStream? J'ai eu cette merveille sur ma FJR, comme beaucoup de collègues du forum FJR. C'est un produit américain, de National Cycle: pour pas plus cher que les Givi et autre Secdem ou Yam, vous avez là ce qui se fait de mieux. Déviation du vent parfaite, zéro turbulences, pas de poussée dans le dos, pas d'effet "planche à voile" par fort vent. Dans le cas de la XTZ, ils ont le modèle Touring ou Sport, deux hauteurs différentes.
 Vstream windshield
Bulle Givi airflow - Page 2 Images
Bulle Givi airflow - Page 2 VStream_Windshield_001_L
Ma maman, elle dit que je peux
Giorgio 37
Giorgio 37
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyMer 8 Avr 2015 - 17:47
Effectivement elle a l'air géniale cette bulle.
Plus haute, plus large, bien profilée et ........ quand même pas moche par rapport à la Givi Aiflow.
En cherchant sur la toile j'ai vu qu'il y a un revendeur à Grasse, ma Sté ZTechnik, qui propose la bulle haute à 179.95 € livraison gratuite.
Aux USA elle est à 161.95 $
Avec les frais de livraison et les éventuels droits de douane si l'expédition est faite par UPS ou autre transporteur et non par la poste, elle reviendrait plus cher.
Je me laisserais bien tenter.
y-aurait-il par hasard un membre du forum qui aurait monté cette bulle sur son XTZ et pourrait nous apporter son témoignage ?
sub_zero30
sub_zero30
Kms de ma moto : 63000
Ville ou région : ALES
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyJeu 9 Avr 2015 - 9:03
salut giorgio 37, j'ai commandé ce week end la fumé sport de chez V stream sur epona moto, frais de port inclus 159.95€
si ca peut t'aider il ont les 3 modèles il me semble
a+
Giorgio 37
Giorgio 37
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyJeu 9 Avr 2015 - 10:11
Effectivement, les V Stream sont aussi disponibles chez epona moto.
Le bulle Tall Touring est au même prix livraison comprise que chez ZTechnik : 179.95 €
Giorgio 37
Giorgio 37
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyJeu 9 Avr 2015 - 17:23
J'hésite entre la Givi Airflow et la V Stream Tall Touring.
Comme Fast Phil, je pense à l'effet "vitre de scooter"
Les dimensions sont pratiquement les mêmes, hauteur de 61.5cm pour la V Stream et de 61cm pour l'Airflow, les largeurs étant de 43.2 et 43cm.
La Givi Aiflow présente l'avantage d'être réglable, c'est important, et puis, toujours d'après Fast Phil, elle est moins moche en vrai qu'en photo.
La V Stream étant d'une seule pièce elle doit paraître plus imposante, mais bon, d'après ce qu'a écrit Jean Luc, elle est très bien étudiée et très efficace.
Laquelle choisir ?
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyVen 10 Avr 2015 - 7:46
je vais sans doute me séparer de la mienne, vu qu'elle n'est pas compatible avec la XTZE
jean-luc
jean-luc
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyVen 10 Avr 2015 - 11:47
Giorgio,
Je ne peux parler que pour mon expérience de la bulle haute Vstream pour la FJR: comme tous mes potes du forum qui en étaient équipés, rien que du super positif, aucun des désagréments souvent notés pour d'autres marques  ( comme, entre autres, la vision déformée, effet "planche à voile" par fort vent, poussée dans le dos en position maxi, sifflements ou trubulences).
Maintenant, je ne l'ai pas (encore) sur ma XTZ, mais si je devais faire l'achat d'une bulle plus efficace, je n'irais pas chercher ailleurs.
Pour rappel: la version "tall" touring, c'est la grande. La Sport est plus basse, peut-être déjà suffisante ?
Giorgio 37
Giorgio 37
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyVen 10 Avr 2015 - 11:58
Jean-Luc :
Je suis allé jeter un coup d'œil sur un forum FJR, effectivement il semble que tout le monde soit d'accord pour dire que la bulle VStream n'a que des qualités.
Jlucg :
J'ai essayé de retrouver ici un sujet traitant de la nouvelle bulle que tu as réalisée après avoir cassé la tienne, qui est donc inspirée de celle de la GS 2013, mais je n'ai rien trouvé.
Je suppose que la photo de ton avatar est celle de l'ancienne bulle, qui ressemble d'ailleurs pas mal à la VStream, dirait-on, et qui me conviendrait sans doute parfaitement.
Je recherche avant tout le confort et l'absence de bruit, même si cela m'oblige à faire des concessions à l'esthétique, à mon âge on préfère être bien que beau !!!
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyVen 10 Avr 2015 - 12:07
j'ai fait le choix l'année dernière pour la bulle airflow de givi..
j'avais un peu peur quand a l’esthétique mais finalement ça ne dénature pas du tout.
et d'un point de vu confort... c'est vraiment le top, plus de bruit ni turbulences, une vrais protection autant en position haute que basse...
Pour moi le choix est fait et je ne regrette vraiment mais alors vraiment pas mon choix ;)
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyVen 10 Avr 2015 - 12:48
Giorgio 37 a écrit:
Jean-Luc :
Jlucg :
c'est ici : https://www.super-tenere.org/t1196-xtz-1200-bulle-haute-maison?highlight=bulle
La deuxième bulle était super. essai a 200 180 visière ouverte. Le problème c'est que trop protégé tu ne te rends pas compte de la vitesse
Fast Phil
Fast Phil
Moto : XTZ 1200 2010
Kms de ma moto : 12000
Pneu AV/AR : Tourance Next
Ville ou région : Bretagne
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyDim 12 Avr 2015 - 20:06
Laquelle choisir ?
Je confirme après 3 mois, l'esthétique "en vrai" est finalement pas mal.
Coté protection, c'est vraiment nickel.
donc je ne regrette pas la revente du tobinator et de la bulle haute Givi standard, pour les remplacer par l'Airflow.
Et quand j'aurai le temps je teinterai la partie basse en noir (toujours pas trouvé le moyen de faire ça).
Giorgio 37
Giorgio 37
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyLun 13 Avr 2015 - 17:54
La bulle Givi Airflow est, sauf erreur, en polycarbonate.
Attention avant de peindre !
Le polycarbonate est très sensible à de nombreux solvants, donc à beaucoup de chlorures, d'essences, d'hydroxydes et autres.
Vérifier d'abord que la peinture utilisée n'en contienne pas sinon ...... et une airflow à la poubelle Bulle Givi airflow - Page 2 49290
Sinon, la seule peinture pour polycarbonate que je connaisse est la Tamiya PS
Il y en a peut-être d'autres.
Développée pour les maquettes, la Tamiya PS existe en de très nombreuses teintes, elle se vend en petites bombes de 100ml, disponible par exemple sur le site miniplanes.fr
Fast Phil : Je viens de commander une Airflow et je pense aussi peindre la partie basse, le premier des deux qui le fait prévient l'autre !!!
Giorgio 37
Giorgio 37
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyMer 15 Avr 2015 - 14:03
Après quelques recherches, il se trouve que la peinture PC 04 de Tamiya est tout à fait adaptée au polycarbonate.
L'avantage par rapport à la Tamiya PS, qui à priori n'existe qu'en bombe, est qu'elle existe en petits pots.
On peut donc l'utiliser avec un aérographe, ce qui donnera un bien meilleur résultat qu'une bombe, toujours bien difficile à maîtriser.
Giorgio 37
Giorgio 37
MessageSujet: Re: Bulle Givi airflow   Bulle Givi airflow - Page 2 EmptyMer 15 Avr 2015 - 14:24
Rectification :
La Tamiya polycarbonate noire c'était la PC-5, pas la PC-4 qui était bleue.
Je dis "était" parce qu'à priori Tamiya ne fabrique plus cette peinture PC, seule la PS reste disponible et uniquement en bombes.
Je poursuis mes recherches pour essayer de trouver un "substitut" à la Tamiya PC en pot.
Bulle Givi airflow
» Bulle airflow givi
» Bulle givi airflow
» recherche bulle GIVI AIRFLOW
» recherche bulle d'origine 1200 xtz ou échange avec bulle givi [résolu]
» Deflecteurs Yam + XTZ1200 2010 + Givi Airflow, compatibles?
