Branchements faisceau electrique led Emptypar SuperTiti Hier à 21:40
Branchements faisceau electrique led Emptypar Joe644 Hier à 18:56
Branchements faisceau electrique led Emptypar yop1025 Hier à 13:10
Branchements faisceau electrique led Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Branchements faisceau electrique led Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Branchements faisceau electrique led Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Branchements faisceau electrique led Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Branchements faisceau electrique led Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Branchements faisceau electrique led Emptypar Arni Dim 17 Nov 2024 - 14:06
Branchements faisceau electrique led Emptypar Arni Dim 17 Nov 2024 - 13:13
Branchements faisceau electrique led Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Branchements faisceau electrique led Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Branchements faisceau electrique led Emptypar Fredard Sam 16 Nov 2024 - 9:43
Branchements faisceau electrique led Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Branchements faisceau electrique led Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Branchements faisceau electrique led Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Branchements faisceau electrique led Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Branchements faisceau electrique led Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Branchements faisceau electrique led Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Branchements faisceau electrique led Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Branchements faisceau electrique led Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Branchements faisceau electrique led Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Branchements faisceau electrique led Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Branchements faisceau electrique led Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Branchements faisceau electrique led Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
amortisseur feux tenere tuto chaine fourche huile réservoir manuel garde phare galére essence synchro vidange filtre reglage pneus suis arrière selle longues boue crash rabaissement embrayage
Le Deal du moment : -17%
SSD interne Crucial SSD P3 1To NVME à ...
49.99 €
peyo
peyo
Moto : ZE Race blue 2015
Kms de ma moto : 21585 kms
Ville ou région : Aquitaine
MessageSujet: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyMer 1 Fév 2017 - 23:04
Pour les spécialistes en électricité : je dois alimenter mes leds sur ma XTZE avec le faisceau ci-dessous mais j'hésite à faire les branchements j'ai pas envie de faire une con..ries.
Pour les cosses à brancher sur les fils des lampes leds,( les 4 recouvertes d'une protection transparente) j'ai bien compris que le fil blanc c'est le + qui va sur le fil rouge + venant des lampes leds et le noir sur le fil noir. J'ai juste ?
Le fil rouge après le fusible doit aller sur le plus de la batterie, et le fil noir qui vient du relais, comme il est très court, sur une masse ? Si c ça, je ne sais pas ou prendre une masse.
Merci pour vos conseils
Branchements faisceau electrique led Img_0710
peyo
peyo
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyMer 1 Fév 2017 - 23:11
 Branchements faisceau electrique led Img_0711Branchements faisceau electrique led Img_0712
peyo
peyo
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyMer 1 Fév 2017 - 23:38
Kms de ma moto : 140000
Pneu AV/AR : SCORPION
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyJeu 2 Fév 2017 - 7:47
Oui, le rouge sur la batterie, et le noir sur une masse, mais où prends tu l'information qui alimente le relais via l'inter au guidon ? Tes leds doivent elles s'allumer avec les feux de croisement ou les feux de route ? A en croire les photos, on a l'impression que rien n'est prévu pour la commande, et qu'il est possible d'allumer les leds contact coupé !
Sinon, quand tu veux modifier ton message, il faut faire "éditer", et non pas "citer" !
peyo
peyo
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyJeu 2 Fév 2017 - 9:43
Merci Cfrancois pour ta réponse. C bien ce que je pensais, qu'avec ce type de branchement les leds pourront s'allumer contact coupé....alors ça se complique si je veux les allumer indépendamment des feux de croisement ou des feux de route.
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyJeu 2 Fév 2017 - 11:45
Qu'as tu comme fils sur le relais ? il y en a t'il un couplé avec le fils route + batt  et qui va à l'inter ?
As tu un schéma avec des numéros sur le relais ?
peyo
peyo
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyJeu 2 Fév 2017 - 20:49
     Oui il y a un fil jaune qui va à l'inter couplé avec le fil rouge du + batterie
   Les branchement du relais ;
  -    1 fil rouge + batterie, avec un fil jaune qui va à l'interrupteur
  -   3 fils noirs groupés ( fil de masse, fil - des lampes led et fil noir qui va à l'inter)
  -   1 fil blanc + qui va au led
  -   1 fil rouge qui va à l'inter
 Au total = 7 fils
Branchements faisceau electrique led Img_0714Branchements faisceau electrique led Img_0713
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyJeu 2 Fév 2017 - 21:06
Si tu supprimes le pont qui va du rouge au jaune, et si tu raccordes ce jaune au signal que tu souhaites pour allumer tes phares additionnels, ça devrait fonctionner !
Tu n'as pas précisé si tu souhaitais un allumage des leds avec les feux de croisement ou avec les pleins phares.
peyo
peyo
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyJeu 2 Fév 2017 - 21:34
 J'aimerais les allumer indépendamment des feux de croisement et des pleins phares et qu'ils ne s'allument pas contact coupé. Encore merci pour tes réponses.
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyJeu 2 Fév 2017 - 21:40
Ok, si tes leds peuvent rester alumer quand tu croises d'autre véhicule, tu peux prendre l'info sur un + après contact (comme les feux de positions par exemple) si par contre tu dois les couper en croisant les autres véhicules, il faut prendre l'info sur plein phare.
peyo
peyo
MessageSujet: Re: Branchements faisceau electrique led   Branchements faisceau electrique led EmptyJeu 2 Fév 2017 - 22:42
bien merci Branchements faisceau electrique led 231456   A+
» faisceau electrique
» Prise faisceau électrique
» Changement faisceau électrique
» faisceau electrique alernateur 660 XTZ 3YF 1991
» Rappel FAISCEAU 1200XTZ par Yamaha Belgique et France
